[PostGIS] #5630: CG_Visibility crash
PostGIS trac at osgeo.org
Fri Jun 6 06:42:09 PDT 2025
  Reporter:  robe     |      Owner:  Loïc Bartoletti
      Type:  defect   |     Status:  reopened
  Priority:  blocker  |  Milestone:  PostGIS SFCGAL
 Component:  sfcgal   |    Version:  master
Resolution:           |   Keywords:
Changes (by robe):
 * resolution:  fixed =>
 * status:  closed => reopened
Comment:
 Also crashes on empty polygon.
 SELECT CG_Visibility(ST_GeomFromText('POLYGON EMPTY',4326),
 ST_Point(1,2,4326) , ST_Point(1,2,4326))
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5630#comment:5>
