[SCM] PostGIS branch master updated. 3.5.0-380-g496a9b334
Fri Jun 6 17:18:30 PDT 2025
the project "PostGIS".
       via  496a9b33481691e76671a210083308386aee5b02 (commit)
       via  31ecc3545081bb4347d4f64de291b4fb8d5fb969 (commit)
      from  1454b6f5b907d3197977546f85e29ef2dabb04da (commit)
revisions in full, below.
commit 496a9b33481691e76671a210083308386aee5b02
Merge: 1454b6f5b 31ecc3545
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jun 6 20:07:17 2025 -0400
    Garden fixings
     - Fixup topology garden xsl so some tests work
       , still needs some work
       References #2297
     - Add sfcgal garden to make garden target
       and remove some failing test on it for now
     - Have GHA start doing garden tests on latest
     - Change log table suffix to 36 for all garden tests
diff --cc doc/xsl/raster_gardentest.sql.xsl
index aa0f61998,aa0f61998..61d6a9fa8
--- a/doc/xsl/raster_gardentest.sql.xsl
+++ b/doc/xsl/raster_gardentest.sql.xsl
@@@ -10,7 -10,7 +10,7 @@@
  			using a garden variety of rasters.  Its intent is to flag major crashes.
  	<xsl:output method="text" />
--	<xsl:variable name='testversion'>3.5.0</xsl:variable>
++	<xsl:variable name='testversion'>3.6.0</xsl:variable>
  	<xsl:variable name='fnexclude'>AddRasterColumn AddRasterConstraints DropRasterConstraints DropRasterColumn DropRasterTable</xsl:variable>
  	<!--This is just a place holder to state functions not supported in 1.3 or tested separately -->
@@@ -33,7 -33,7 +33,7 @@@
  	<xsl:variable name='var_rastercolumn'>'rast'</xsl:variable>
  	<xsl:variable name='var_rastertable'>'pgis_rgarden_1bb'</xsl:variable>
  	<xsl:variable name='var_boolean'>false</xsl:variable>
--	<xsl:variable name='var_logtable'>raster_garden_log35</xsl:variable>
++	<xsl:variable name='var_logtable'>raster_garden_log36</xsl:variable>
  	<xsl:variable name='var_pixeltypes'>{8BUI,1BB}</xsl:variable>
  	<xsl:variable name='var_pixelvalues'>{255,0}</xsl:variable>
  	<xsl:variable name='var_algorithm'>'Lanczos'</xsl:variable>
diff --cc doc/xsl/sfcgal_gardentest.sql.xsl
index 747a345f2,c78dd3edb..819fd6733
--- a/doc/xsl/sfcgal_gardentest.sql.xsl
+++ b/doc/xsl/sfcgal_gardentest.sql.xsl
@@@ -11,9 -11,9 +11,9 @@@
  			using a garden variety of geometries.  Its intent is to flag major crashes.
  	<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
- 	<xsl:variable name='fnexclude'>CG_Visibility CG_YMonotonePartition ST_AlphaShape ST_OptimalAlphaShape</xsl:variable>
 -	<xsl:variable name='fnexclude'>CG_ExtrudeStraightSkeleton CG_Visibility CG_YMonotonePartition ST_AlphaShape ST_OptimalAlphaShape</xsl:variable>
++	<xsl:variable name='fnexclude'>CG_ExtrudeStraightSkeleton CG_Simplify CG_Visibility CG_YMonotonePartition ST_AlphaShape ST_OptimalAlphaShape</xsl:variable>
  	<!--This is just a place holder to state functions not supported or tested separately -->
  	<xsl:variable name='var_srid'>3395</xsl:variable>
@@@ -36,7 -36,7 +36,7 @@@
  	<xsl:variable name='var_matrix'>'FF1FF0102'</xsl:variable>
  	<xsl:variable name='var_geom_name'>the_geom</xsl:variable>
--	<xsl:variable name='var_logtable'>postgis_garden_log35</xsl:variable>
++	<xsl:variable name='var_logtable'>postgis_garden_log36</xsl:variable>
  	<xsl:variable name='var_logupdatesql'>UPDATE <xsl:value-of select="$var_logtable" /> SET log_end = clock_timestamp()
  		FROM (SELECT logid FROM <xsl:value-of select="$var_logtable" /> ORDER BY logid DESC limit 1) As foo
  		WHERE <xsl:value-of select="$var_logtable" />.logid = foo.logid  AND <xsl:value-of select="$var_logtable" />.log_end IS NULL;</xsl:variable>
commit 31ecc3545081bb4347d4f64de291b4fb8d5fb969
Date:   Mon Jun 2 23:39:24 2025 -0400
    WIP topology garden
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 3d83c7473..45bba0dc3 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -18,6 +18,7 @@ jobs:
         ci:
         # Use the last stable releases to run more tests
         - { tag: pg17-geos313-gdal39-proj94, mode: coverage }
+        # - { tag: pg17-geos313-gdal39-proj94, mode: garden }
         - { tag: pg16-geos312-gdal37-proj921, mode: coverage }
         - { tag: pg15-geos311-gdal35-proj90, mode: coverage }
         - { tag: pg15-clang-geos311-gdal35-proj90, mode: usan_clang }
@@ -30,6 +31,7 @@ jobs:
         - { tag: pg13-clang-geos39-gdal31-proj71, mode: usan_clang }
         # Run tests with different dependency combinations
         - { tag: latest, mode: tests }
+        - { tag: latest, mode: garden }
         - { tag: pg13-geos38-gdal31-proj71, mode: tests }
         - { tag: pg12-geos38-gdal30-proj611, mode: tests }
diff --git a/.gitignore b/.gitignore
index 7fd707a09..b2f46cfcd 100644
--- a/.gitignore
+++ b/.gitignore
@@ -55,6 +55,7 @@ doc/raster_comments.sql
 doc/postgis_gardentest_*.sql
 doc/raster_gardentest_*.sql
 doc/sfcgal_gardentest_*.sql
+doc/topology_gardentest_*.sql
 doc/tiger_geocoder_comments.sql
 doc/topology_comments.sql
 extensions/Makefile
diff --git a/doc/Makefile.in b/doc/Makefile.in
index c8a394c23..d31a1ebb9 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -512,6 +512,7 @@ clean: images-clean html-clean pdf-clean epub-clean cheatsheet-clean clean-pot
 	rm -f postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
 	rm -f raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
 	rm -f sfcgal_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
+	rm -f topology_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
 	rm -f *.tmp
 	$(MAKE) clean-localized
@@ -599,7 +600,7 @@ uninstall: comments-uninstall man-uninstall
 ifeq ($(XSLTPROC),)
 garden: requirements_not_met_xsltproc
 else
-garden: postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql sfcgal_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
+garden: postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql sfcgal_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql topology_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
 endif
 %_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql: xsl/%_gardentest.sql.xsl postgis-out.xml
diff --git a/doc/xsl/sfcgal_gardentest.sql.xsl b/doc/xsl/sfcgal_gardentest.sql.xsl
index 747a345f2..c78dd3edb 100644
@@ -13,7 +13,7 @@
+	<xsl:variable name='fnexclude'>CG_ExtrudeStraightSkeleton CG_Visibility CG_YMonotonePartition ST_AlphaShape ST_OptimalAlphaShape</xsl:variable>
diff --git a/doc/xsl/topology_gardentest.sql.xsl b/doc/xsl/topology_gardentest.sql.xsl
index 0674a578b..95f5d77f3 100644
--- a/doc/xsl/topology_gardentest.sql.xsl
+++ b/doc/xsl/topology_gardentest.sql.xsl
@@ -1,33 +1,45 @@
-<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform"  xmlns:pgis="http://www.postgis.org/pgis">
+<xsl:stylesheet version="1.0"
+	xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
+	xmlns:db="http://docbook.org/ns/docbook" xmlns:pgis="http://postgis.net/pgis"
 	 Copyright 2008-2010, Regina Obe
-	 License: BSD
+	 License: BSD-3-Clause
 	 Purpose: This is an xsl transform that generates an sql test script from xml docs to test all the functions we have documented
-	<xsl:variable name='testversion'>3.3.0</xsl:variable>
-	<xsl:variable name='fnexclude'>AddTopoGeometryColumn DropTopoGeometryColumn CreateTopology</xsl:variable>
-	<!--This is just a place holder to state functions not supported in 1.3 or tested separately -->
+	<xsl:variable name='fnexclude'>AddTopoGeometryColumn DropTopoGeometryColumn DropTopology</xsl:variable>
+	<!--This is just a place holder to state functions not supported or tested separately -->
+	<xsl:variable name='var_topology_name'>'topo_test'</xsl:variable>
+	<xsl:variable name='var_schema_name'>'public'</xsl:variable>
+	<xsl:variable name='var_topology_srid'>4326</xsl:variable>
 	<xsl:variable name='var_position'>1</xsl:variable>
 	<xsl:variable name='var_integer1'>3</xsl:variable>
 	<xsl:variable name='var_integer2'>5</xsl:variable>
-	<xsl:variable name='var_float1'>0.5</xsl:variable>
+	<xsl:variable name='var_float1'>20.1</xsl:variable>
 	<xsl:variable name='var_float2'>0.75</xsl:variable>
+	<xsl:variable name='var_frac'>0.80</xsl:variable>
 	<xsl:variable name='var_distance'>100</xsl:variable>
 	<xsl:variable name='var_version1'>1</xsl:variable>
 	<xsl:variable name='var_version2'>2</xsl:variable>
+	<xsl:variable name='var_gj_version'>1</xsl:variable> <!-- GeoJSON version -->
 	<xsl:variable name='var_NDRXDR'>XDR</xsl:variable>
 	<xsl:variable name='var_text'>'monkey'</xsl:variable>
+	<xsl:variable name='var_row'>foo1</xsl:variable>
+	<xsl:variable name='var_buffer_style'>'quad_segs=1 endcap=square join=mitre mitre_limit=1.1'</xsl:variable>
 	<xsl:variable name='var_varchar'>'test'</xsl:variable>
 	<xsl:variable name='var_spheroid'>'SPHEROID["GRS_1980",6378137,298.257222101]'</xsl:variable>
-	<xsl:variable name='var_logtable'>postgis_topology_garden_log33</xsl:variable>
+	<xsl:variable name='var_geom_name'>the_geom</xsl:variable>
+	<xsl:variable name='var_toponame'>'topo_test'</xsl:variable>
+	<xsl:variable name='var_logtable'>topology_garden_log36</xsl:variable>
@@ -38,26 +50,26 @@
 				SELECT logid, query_to_xml(log_sql, false,false,'') As log_output
 				    FROM <xsl:value-of select="$var_logtable" /> ORDER BY logid DESC LIMIT 1;</xsl:variable>
 	<pgis:gardens>
-		<pgis:gset ID='POINT' GeometryType='POINT'>(SELECT ST_SetSRID(ST_Point(i,j),4326) As the_geom
-		FROM (SELECT a*1.11111111 FROM generate_series(-10,50,10) As a) As i(i)
-			CROSS JOIN generate_series(40,70, 15) j
+		<pgis:gset ID='POINT' GeometryType='POINT' createtable="true">(SELECT ST_SetSRID(ST_Point(i,j),4326) As the_geom
+		FROM (SELECT a*1.11111111 FROM generate_series(-10,50,2) As a) As i(i)
+			CROSS JOIN generate_series(40,70, 5) j
 			ORDER BY i,j
 			)</pgis:gset>
-		<pgis:gset ID='LINESTRING' GeometryType='LINESTRING'>(SELECT ST_MakeLine(ST_SetSRID(ST_Point(i,j),4326),ST_SetSRID(ST_Point(j,i),4326))  As the_geom
+		<pgis:gset ID='LINESTRING' GeometryType='LINESTRING' createtable="true">(SELECT ST_MakeLine(ST_SetSRID(ST_Point(i,j),4326),ST_SetSRID(ST_Point(j,i),4326))  As the_geom
 			CROSS JOIN generate_series(40,70, 15) As j
 			WHERE NOT(i = j)
 			ORDER BY i, i*j)</pgis:gset>
-		<pgis:gset ID='POLYGON' GeometryType='POLYGON'>(SELECT ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j*0.05)  As the_geom
+		<pgis:gset ID='POLYGON' GeometryType='POLYGON' createtable="true">(SELECT ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j*0.05)  As the_geom
 			CROSS JOIN generate_series(40,70, 20) As j
 			ORDER BY i, i*j, j)</pgis:gset>
-		<pgis:gset ID='POINTM' GeometryType='POINTM'>(SELECT ST_SetSRID(ST_MakePointM(i,j,m),4326) As the_geom
+		<pgis:gset ID='POINTM' GeometryType='POINTM' createtable="true">(SELECT ST_SetSRID(ST_MakePointM(i,j,m),4326) As the_geom
 		FROM generate_series(-10,50,10) As i
 			CROSS JOIN generate_series(50,70, 20) AS j
 			CROSS JOIN generate_series(1,2) As m
 			ORDER BY i, j, i*j*m)</pgis:gset>
-		<pgis:gset ID='LINESTRINGM' GeometryType='LINESTRINGM'>(SELECT ST_MakeLine(ST_SetSRID(ST_MakePointM(i,j,m),4326),ST_SetSRID(ST_MakePointM(j,i,m),4326))  As the_geom
+		<pgis:gset ID='LINESTRINGM' GeometryType='LINESTRINGM' createtable="true">(SELECT ST_MakeLine(ST_SetSRID(ST_MakePointM(i,j,m),4326),ST_SetSRID(ST_MakePointM(j,i,m),4326))  As the_geom
 			CROSS JOIN generate_series(50,70, 20) As j
@@ -69,17 +81,17 @@
 			ORDER BY i, j, m, i*j*m
 			)</pgis:gset>-->
-		<pgis:gset ID='POLYGONM' GeometryType='POLYGONM'>(SELECT geom  As the_geom
+		<pgis:gset ID='POLYGONM' GeometryType='POLYGONM' createtable="true">(SELECT geom  As the_geom
 FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;POLYGONM((-71.1319 42.2503 1,-71.132 42.2502 3,-71.1323 42.2504 -2,-71.1322 42.2505 1,-71.1319 42.2503 0))') ),
 	( ST_GeomFromEWKT('SRID=4326;POLYGONM((-71.1319 42.2512 0,-71.1318 42.2511 20,-71.1317 42.2511 -20,-71.1317 42.251 5,-71.1317 42.2509 4,-71.132 42.2511 6,-71.1319 42.2512 30))') )
 		)	As g(geom))</pgis:gset>
-		<pgis:gset ID='POINTZ' GeometryType='POINTZ'>(SELECT ST_SetSRID(ST_MakePoint(i,j,k),4326) As the_geom
+		<pgis:gset ID='POINTZ' GeometryType='POINTZ' createtable="true">(SELECT ST_SetSRID(ST_MakePoint(i,j,k),4326) As the_geom
 		FROM generate_series(-10,50,20) As i
 			CROSS JOIN generate_series(40,70, 20) j
 			CROSS JOIN generate_series(1,2) k
 			ORDER BY i,i*j, j*k, i + j + k)</pgis:gset>
-		<pgis:gset ID='LINESTRINGZ' GeometryType='LINESTRINGZ'>(SELECT ST_SetSRID(ST_MakeLine(ST_MakePoint(i,j,k), ST_MakePoint(i+k,j+k,k)),4326) As the_geom
+		<pgis:gset ID='LINESTRINGZ' GeometryType='LINESTRINGZ' createtable="true">(SELECT ST_SetSRID(ST_MakeLine(ST_MakePoint(i,j,k), ST_MakePoint(i+k,j+k,k)),4326) As the_geom
@@ -89,41 +101,94 @@ FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;POLYGONM((-71.1319 42.2503 1,-71.132 4
 			ORDER BY i, j, i+j+m, m, i*j*m)</pgis:gset>-->
-		<pgis:gset ID='POLYGONZ' GeometryType='POLYGONZ'>(SELECT geom  As the_geom
+		<pgis:gset ID='POLYGONZ' GeometryType='POLYGONZ' createtable="true">(SELECT geom  As the_geom
 FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.0771 42.3866 1,-71.0767 42.3872 1,-71.0767 42.3863 1,-71.0771 42.3866 1))') ),
 	( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.0775 42.386 2,-71.0773 42.3863 1.75,-71.0773 42.3859 1.75,-71.0775 42.386 2))') )
-		<pgis:gset ID='POLYGONZM' GeometryType='POLYGONZM'>(SELECT geom  As the_geom
+		<pgis:gset ID='POLYGONZM' GeometryType='POLYGONZM' createtable="true">(SELECT geom  As the_geom
 FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.0771 42.3866 1 2,-71.0767 42.3872 1 2.3,-71.0767 42.3863 1 2.3,-71.0771 42.3866 1 2))') ),
 	( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.0775 42.386 2 1.5,-71.0773 42.3863 1.75 1.5,-71.0773 42.3859 1.75 1.5,-71.0775 42.386 2 1.5))') )
+		<pgis:gset ID='POLYHEDRALSURFACE' GeometryType='POLYHEDRALSURFACE' createtable="true">(SELECT ST_Translate(the_geom,-72.2, 41.755) As the_geom
+		FROM (VALUES ( ST_GeomFromEWKT(
+'SRID=4326;PolyhedralSurface(
+((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
+((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)), ((0 0 0, 1 0 0, 1 0 1, 0 0 1, 0 0 0)),  ((1 1 0, 1 1 1, 1 0 1, 1 0 0, 1 1 0)),
+((0 1 0, 0 1 1, 1 1 1, 1 1 0, 0 1 0)),  ((0 0 1, 1 0 1, 1 1 1, 0 1 1, 0 0 1))
+( ST_GeomFromEWKT(
+((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)) )') ) )
+As foo(the_geom)  ) </pgis:gset>
+		<pgis:gset ID='TRIANGLE' GeometryType='TRIANGLE' createtable="true">(SELECT ST_GeomFromEWKT(
+'SRID=4326;TRIANGLE ((
+                -71.0821 42.3036,
+                -71.0821 42.3936,
+                -71.0901 42.3036,
+                -71.0821 42.3036
+            ))') As the_geom) </pgis:gset>
+		<pgis:gset ID='TIN' GeometryType='TIN' createtable="true">(SELECT ST_GeomFromEWKT(
+'SRID=4326;TIN (((
+                -71.0821 42.3036 0,
+               -71.0821 42.3036 1,
+                -71.0821 42.3436 0,
+                -71.0831 42.3436 0,
+            )') As the_geom) </pgis:gset>
+<!--		<pgis:gset ID='GCSet3D' GeometryType='GEOMETRYCOLLECTIONZ' SkipUnary='1'>(SELECT ST_Collect(ST_Collect(ST_SetSRID(ST_MakePoint(i,j,m),4326),ST_SetSRID(ST_MakePolygon(ST_AddPoint(ST_AddPoint(ST_MakeLine(ST_MakePoint(i+m,j,m),ST_MakePoint(j+m,i-m,m)),ST_MakePoint(i,j,m)),ST_MakePointM(i+m,j,m))),4326)))  As the_geom
+		FROM generate_series(-10,50,20) As i
+			CROSS JOIN generate_series(50,70, 20) As j
+			CROSS JOIN generate_series(1,2) As m
+			)</pgis:gset>-->
+		<pgis:gset ID='GEOMETRYCOLLECTIONZ' GeometryType='GEOMETRYCOLLECTIONZ' SkipUnary='1'>(SELECT ST_Collect(geom)  As the_geom
+		FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.0822 42.3036 2,-71.082 42.3038 2,-71.0819 42.3037 2,-71.0821 42.3036 2)))') ),
+	( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.1261 42.2703 1,-71.1257 42.2703 1,-71.1257 42.2701 1,-71.126 42.2701 1,-71.1261 42.2702 1,-71.1261 42.2703 1))') )
+		)	As g(geom) CROSS JOIN generate_series(1,3) As i
+		GROUP BY i
+			)</pgis:gset>
+		<pgis:gset ID='GEOMETRYCOLLECTIONM' GeometryType='GEOMETRYCOLLECTIONM' SkipUnary='1'>(SELECT ST_Collect(geom)  As the_geom
+		FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGONM(((-71.0821 42.3036 2,-71.0822 42.3036 3,-71.082 42.3038 2,-71.0819 42.3037 2,-71.0821 42.3036 2)))') ),
+	( ST_GeomFromEWKT('SRID=4326;POLYGONM((-71.1261 42.2703 1,-71.1257 42.2703 1,-71.1257 42.2701 2,-71.126 42.2701 1,-71.1261 42.2702 1,-71.1261 42.2703 1))') )
+		GROUP BY i
+			)</pgis:gset>
 <!-- MULTIs start here -->
-		<pgis:gset ID='MULTIPOINT' GeometryType='MULTIPOINT'>(SELECT ST_Collect(s.the_geom) As the_geom
+		<pgis:gset ID='MULTIPOINT' GeometryType='MULTIPOINT' createtable="true">(SELECT ST_Collect(s.the_geom) As the_geom
 		FROM (SELECT ST_SetSRID(ST_Point(i,j),4326) As the_geom
 		FROM generate_series(-10,50,15) As i
 			) As s)</pgis:gset>
-		<pgis:gset ID='MULTILINESTRING' GeometryType='MULTILINESTRING'>(SELECT ST_Collect(s.the_geom) As the_geom
+		<pgis:gset ID='MULTILINESTRING' GeometryType='MULTILINESTRING' createtable="true">(SELECT ST_Collect(s.the_geom) As the_geom
 		FROM (SELECT ST_MakeLine(ST_SetSRID(ST_Point(i,j),4326),ST_SetSRID(ST_Point(j,i),4326))  As the_geom
 			WHERE NOT(i = j)) As s)</pgis:gset>
-		<pgis:gset ID='MULTIPOLYGON' GeometryType='MULTIPOLYGON'>(SELECT ST_Multi(ST_Union(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j*0.05)))  As the_geom
+		<pgis:gset ID='MULTIPOLYGON' GeometryType='MULTIPOLYGON' createtable="true">(SELECT ST_Multi(ST_Union(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j*0.05)))  As the_geom
 			CROSS JOIN generate_series(40,70, 25) As j)</pgis:gset>
-		<pgis:gset ID='MULTIPOINTZ' GeometryType='MULTIPOINTZ'>(SELECT ST_Collect(ST_SetSRID(ST_MakePoint(i,j,k),4326)) As the_geom
+		<pgis:gset ID='MULTIPOINTZ' GeometryType='MULTIPOINTZ' createtable="true">(SELECT ST_Collect(ST_SetSRID(ST_MakePoint(i,j,k),4326)) As the_geom
 			CROSS JOIN generate_series(40,70, 25) j
 			CROSS JOIN generate_series(1,3) k
 			)</pgis:gset>
-		<pgis:gset ID='MULTILINESTRINGZ' GeometryType='MULTILINESTRINGZ'>(SELECT ST_Multi(ST_Union(ST_SetSRID(ST_MakeLine(ST_MakePoint(i,j,k), ST_MakePoint(i+k,j+k,k)),4326))) As the_geom
+		<pgis:gset ID='MULTILINESTRINGZ' GeometryType='MULTILINESTRINGZ' createtable="true">(SELECT ST_Multi(ST_Union(ST_SetSRID(ST_MakeLine(ST_MakePoint(i,j,k), ST_MakePoint(i+k,j+k,k)),4326))) As the_geom
@@ -135,37 +200,165 @@ FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.0771 42.3866 1 2,-71.0767
 			CROSS JOIN generate_series(50,70, 25) As j
 			) As s)</pgis:gset>-->
-		<pgis:gset ID='MULTIPOLYGONZ' GeometryType='MULTIPOLYGONZ'>(SELECT geom  As the_geom
+		<pgis:gset ID='MULTIPOLYGONZ' GeometryType='MULTIPOLYGONZ' createtable="true">(SELECT geom  As the_geom
 	( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.1261 42.2703 1,-71.1257 42.2703 1,-71.1257 42.2701 1,-71.126 42.2701 1,-71.1261 42.2702 1,-71.1261 42.2703 1)))') )
-		<pgis:gset ID='MULTIPOINTM' GeometryType='MULTIPOINTM'>(SELECT ST_Collect(s.the_geom) As the_geom
+		<pgis:gset ID='MULTIPOINTM' GeometryType='MULTIPOINTM' createtable="true">(SELECT ST_Collect(s.the_geom) As the_geom
 		FROM (SELECT ST_SetSRID(ST_MakePointM(i - 0.0821,j + 0.3036,m),4326) As the_geom
 		FROM generate_series(-71,50,15) As i
 			CROSS JOIN generate_series(42,70, 25) AS j
 			) As s)</pgis:gset>
-		<pgis:gset ID='MULTILINESTRINGM' GeometryType='MULTILINESTRINGM'>(SELECT ST_Collect(s.the_geom) As the_geom
+		<pgis:gset ID='MULTILINESTRINGM' GeometryType='MULTILINESTRINGM' createtable="true">(SELECT ST_Collect(s.the_geom) As the_geom
 		FROM (SELECT ST_MakeLine(ST_SetSRID(ST_MakePointM(i - 0.0821,j + 0.3036,m),4326),ST_SetSRID(ST_MakePointM(j,i,m),4326))  As the_geom
-		<pgis:gset ID='MULTIPOLYGONM' GeometryType='MULTIPOLYGONM'>(
+		<pgis:gset ID='MULTIPOLYGONM' GeometryType='MULTIPOLYGONM' createtable="true">(
 			SELECT ST_GeomFromEWKT('SRID=4326;MULTIPOLYGONM(((0 0 2,10 0 1,10 10 -2,0 10 -5,0 0 -5),(5 5 6,7 5 6,7 7 6,5 7 10,5 5 -2)))')  As the_geom
 			)</pgis:gset>
+		<!-- replacing crasher with a more harmless curve polygon and circular string -->
+		<pgis:gset ID='CURVEPOLYGON' GeometryType='CURVEPOLYGON' createtable="true">(SELECT ST_GeomFromEWKT('SRID=4326;CURVEPOLYGON(CIRCULARSTRING(-71.0821 42.3036, -71.4821 42.3036, -71.7821 42.7036, -71.0821 42.7036, -71.0821 42.3036),(-71.1821 42.4036, -71.3821 42.6036, -71.3821 42.4036, -71.1821 42.4036) ) ') As the_geom)</pgis:gset>
+		<pgis:gset ID='CURVEPOLYGON2' GeometryType='CURVEPOLYGON' createtable="true">(SELECT ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j))  As the_geom
+		        FROM generate_series(-10,50,10) As i
+					CROSS JOIN generate_series(40,70, 20) As j
+					ORDER BY i, j, i*j)
+		</pgis:gset>
+		<pgis:gset ID='CIRCULARSTRING' GeometryType='CIRCULARSTRING'>(SELECT ST_GeomFromEWKT('SRID=4326;CIRCULARSTRING(-71.0821 42.3036,-71.4821 42.3036,-71.7821 42.7036,-71.0821 42.7036,-71.0821 42.3036)') As the_geom)</pgis:gset>
+		<pgis:gset ID='MULTISURFACE' GeometryType='MULTISURFACE'>(SELECT ST_GeomFromEWKT('SRID=4326;MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(-71.0821 42.3036, -71.4821 42.3036, -71.7821 42.7036, -71.0821 42.7036, -71.0821 42.3036),(-71.1821 42.4036, -71.3821 42.6036, -71.3821 42.4036, -71.1821 42.4036) ))') As the_geom)</pgis:gset>
+		<!--These are special case geometries -->
+		<pgis:gset ID="Typed Empty Geometries" GeometryType="GEOMETRY" createtable="false">(SELECT ST_GeomFromText('POINT EMPTY',4326) As the_geom
+			UNION ALL SELECT ST_GeomFromText('MULTIPOINT EMPTY',4326) As the_geom
+			UNION ALL SELECT ST_GeomFromText('MULTIPOLYGON EMPTY',4326) As the_geom
+			UNION ALL SELECT ST_GeomFromText('LINESTRING EMPTY',4326) As the_geom
+			UNION ALL SELECT ST_GeomFromText('MULTILINESTRING EMPTY',4326) As the_geom
+		</pgis:gset>
+		<pgis:gset ID="Empty Linestring" GeometryType="LINESTRING" createtable="false">
+		(SELECT ST_GeomFromText('LINESTRING EMPTY',4326) As the_geom)
+		</pgis:gset>
+		<pgis:gset ID="Empty Point" GeometryType="POINT" createtable="false">
+		(SELECT ST_GeomFromText('POINT EMPTY',4326) As the_geom)
+		</pgis:gset>
+		<pgis:gset ID='MULTIPOLYGON with Empty' GeometryType='MULTIPOLYGON'>
+		(SELECT ST_GeomFromText('MULTIPOLYGON (((9 9, 9 1, 1 1, 2 4, 7 7, 9 9)), EMPTY)', 4326) As the_geom )
+		</pgis:gset>
+		<pgis:gset ID="Empty Polygon" GeometryType="POLYGON" createtable="false">
+		(SELECT ST_GeomFromText('POLYGON EMPTY',4326) As the_geom)
+		</pgis:gset>
+		<pgis:gset ID="Empty Geometry Collection" GeometryType="GEOMETRY" createtable="false">
+		 (SELECT ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326) As the_geom )
+		</pgis:gset>
+		<pgis:gset ID="Geometry Collection with Empty Point" GeometryType="GEOMETRY" createtable="false">
+		 (SELECT ST_GeomFromText('GEOMETRYCOLLECTION (POINT EMPTY, LINESTRING (0 0, 1 1))',4326) As the_geom )
+		</pgis:gset>
+		<pgis:gset ID="Single NULL" GeometryType="GEOMETRY" createtable="false">(SELECT CAST(Null As geometry) As the_geom)</pgis:gset>
+		<pgis:gset ID="Multiple NULLs" GeometryType="GEOMETRY" createtable="false">(SELECT CAST(Null As geometry) As the_geom FROM generate_series(1,4) As foo)</pgis:gset>
+		<pgis:gset ID="Malformed Linestrings" GeometryType="LINESTRING" createtable="false">(SELECT ST_GeomFromText('LINESTRING(1 2, 1 2)',4326) As the_geom
+			UNION ALL SELECT ST_MakeLine('SRID=4326;POINT(1 2)'::geometry, 'SRID=4326;POINT EMPTY'::geometry) As the_geom
+		</pgis:gset>
+		<pgis:gset ID="Malformed Polygons" GeometryType="POLYGON" createtable="false">(SELECT ST_MakePolygon(ST_GeomFromText('LINESTRING(1 2, 1 2,1 2, 1 2)',4326)) As the_geom
+			UNION ALL SELECT ST_MakePolygon(ST_GeomFromText('LINESTRING(1 2, 1 2,1 2, 1 2, 3 2, 1 2)',4326)) As the_geom
+		</pgis:gset>
+		<pgis:gset ID="Infinite Polygons" GeometryType="POLYGON" createtable="false">(SELECT '0106000020E61000000100000001030000000100000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geometry  AS the_geom
+		</pgis:gset>
+		<pgis:gset ID="Infinite 3D Polygons" GeometryType="POLYGON" createtable="false">(SELECT '01060000A0E61000000100000001030000800100000005000000000000000000F07F000000000000F07F000000000000F03F000000000000F07F000000000000F07F000000000000F03F000000000000F07F000000000000F07F000000000000F03F000000000000F07F000000000000F07F000000000000F03F000000000000F07F000000000000F07F000000000000F03F'::geometry  AS the_geom
+		</pgis:gset>
+		<pgis:gset ID="Infinite Linestrings" GeometryType="LINESTRING" createtable="false">(SELECT '0102000020E610000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geometry  AS the_geom
+		</pgis:gset>
+		<pgis:gset ID="Infinite Point" GeometryType="POINT" createtable="false">(SELECT '0101000020E6100000000000000000F07F000000000000F07F'::geometry AS the_geom )
+		</pgis:gset>
+		<pgis:gset ID="Infinite MultiPoint" GeometryType="MULTIPOINT" createtable="false">(SELECT
+		'0104000020E6100000050000000101000000000000000000F07F000000000000F07F0101000000000000000000F07F000000000000F07F0101000000000000000000F07F000000000000F07F0101000000000000000000F07F000000000000F07F0101000000000000000000F07F000000000000F07F'::geometry AS the_geom )
+		</pgis:gset>
+		<pgis:gset ID="Multipoint with Empty coordinates" GeometryType="MULTIPOINT" createtable="false">
+		(SELECT ST_GeomFromText('MULTIPOINT(EMPTY,2 1,2 4, 4 5)',4326) As the_geom)
+		</pgis:gset>
+		<pgis:gset ID="Linestring Z with Nan coordinates" GeometryType="LINESTRINGZ" createtable="false">
+		(SELECT ST_GeomFromText('LINESTRING Z (1 2 NaN,3 4 10,5 6 NaN)',4326) As the_geom)
+		</pgis:gset>
+		<pgis:gset ID="Linestring M with Nan coordinates" GeometryType="LINESTRINGM" createtable="false">
+		(SELECT ST_GeomFromText('LINESTRING M (1 2 NaN,3 4 10,5 6 NaN)',4326) As the_geom)
+		</pgis:gset>
+		<pgis:gset ID="Linestring ZM with Nan coordinates" GeometryType="LINESTRINGZM" createtable="false">
+		(SELECT ST_GeomFromText('LINESTRING ZM (1 2 3 NaN,3 4 10 5,5 6 NaN NaN)',4326) As the_geom)
+		</pgis:gset>
+		</pgis:gset>
 	<!-- TODO: Finish off MULTI list -->
 	</pgis:gardens>
+	<!--This is just a placeholder to hold geometries that will crash server when hitting against some functions
+		We'll fix these crashers in 1.4 -->
+		<pgis:gset ID='CurvePolySet' GeometryType='CURVEPOLYGON'>(SELECT ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j))  As the_geom
+					ORDER BY i, j, i*j)</pgis:gset>
+		<pgis:gset ID='CircularStringSet' GeometryType='CIRCULARSTRING'>(SELECT ST_LineToCurve(ST_Boundary(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j)))  As the_geom
+		<pgis:gset ID="Collection of Empties" GeometryType="GEOMETRY" createtable="false">(SELECT ST_Collect(ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326), ST_GeomFromText('POLYGON EMPTY',4326)) As the_geom
+			UNION ALL SELECT ST_Collect(ST_GeomFromText('POINT EMPTY',4326), ST_GeomFromText('MULTIPOINT EMPTY',4326)) As the_geom
+		)</pgis:gset>
+		<pgis:gset ID="POLYGON EMPTY" GeometryType="POLYGON" createtable="false">(SELECT ST_GeomFromText('POLYGON EMPTY',4326) As the_geom)</pgis:gset>
+		<pgis:gset ID="Collection of Empties Basic" GeometryType="GEOMETRY" createtable="false">(SELECT ST_Collect(ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326), ST_GeomFromText('POLYGON EMPTY',4326)) As the_geom
+			UNION ALL SELECT ST_Collect(ST_GeomFromText('LINESTRING EMPTY',4326), ST_GeomFromText('MULTILINESTRING EMPTY',4326)) As the_geom
+		)</pgis:gset>
+		<pgis:gset ID="TIN / TRIANGLE EMPTY" GeometryType="GEOMETRY" createtable="false">(SELECT ST_GeomFromText('TRIANGLE EMPTY',4326) As the_geom
+			UNION ALL SELECT ST_GeomFromText('TIN EMPTY',4326) As the_geom
+		)</pgis:gset>
+		<pgis:gset ID="TINZ / TRIANGLEZ EMPTY" GeometryType="GEOMETRY" createtable="false">(SELECT ST_GeomFromText('TINZ EMPTY',4326) As the_geom
+			UNION ALL SELECT ST_GeomFromText('TRIANGLEZ EMPTY',4326) As the_geom
+		)</pgis:gset>
+		<pgis:gset ID="LINESTRING EMPTY with NON-EMPTY" GeometryType="POLYGON" createtable="false">(SELECT ST_Collect(ARRAY[ST_GeomFromText('LINESTRING(0 0, 1 1)'), ST_GeomFromText('LINESTRING EMPTY')]) As the_geom)</pgis:gset>
+	<pgis:gardencrashers>
-        <!-- We deal only with the reference chapter -->
+	</pgis:gardencrashers>
+        <!-- We deal only with the topology chapter -->
         <xsl:template match="/">
 <!-- Create logging tables -->
 DROP TABLE IF EXISTS <xsl:value-of select="$var_logtable" />;
@@ -173,181 +366,71 @@ CREATE TABLE <xsl:value-of select="$var_logtable" />(logid serial PRIMARY KEY, l
 DROP TABLE IF EXISTS <xsl:value-of select="$var_logtable" />_output;
 CREATE TABLE <xsl:value-of select="$var_logtable" />_output(logid integer PRIMARY KEY, log_output xml);
-                <xsl:apply-templates select="/db:book/db:chapter[@xml:id='Topology']" />
+            <xsl:apply-templates select="/db:book/db:chapter[@xml:id='Topology']" />
         </xsl:template>
-	<xsl:template match='chapter'>
+	<xsl:template match='db:chapter'>
+<!--Start Topology creation -->
+SELECT CreateTopology(<xsl:value-of select="$var_topology_name" />, 4326);
+<!-- End Topology creation -->
 <!--Start Test table creation, insert, analyze crash test, drop -->
-		<xsl:for-each select="document('')//pgis:gardens/pgis:gset[not(contains(@createtable,'false'))]">
-			<xsl:variable name='log_label'>table Test <xsl:value-of select="@GeometryType" /></xsl:variable>
+		<xsl:for-each select="document('')//pgis:gardens/pgis:gset[contains(@createtable,'true')]">
+			<xsl:variable name='log_label'>table Create Test <xsl:value-of select="@GeometryType" /></xsl:variable>
 SELECT '<xsl:value-of select="$log_label" />: Start Testing';
-<xsl:variable name='var_sql'>CREATE TABLE pgis_garden (gid serial);
-	SELECT AddGeometryColumn('pgis_garden','the_geom',ST_SRID(the_geom),GeometryType(the_geom),ST_CoordDim(the_geom))
-			FROM (<xsl:value-of select="." />) As foo limit 1;
-	SELECT AddGeometryColumn('pgis_garden','the_geom_multi',ST_SRID(the_geom),GeometryType(ST_Multi(the_geom)),ST_CoordDim(the_geom))
+<xsl:variable name='var_sql'>CREATE TABLE pgis_tgarden_<xsl:value-of select="@ID" />(gid serial);
+	SELECT AddTopoGeometryColumn(<xsl:value-of select="$var_topology_name" />,<xsl:value-of select="$var_schema_name" />, lower('pgis_tgarden_<xsl:value-of select="@ID" />'),'topo', GeometryType(the_geom))
 			FROM (<xsl:value-of select="." />) As foo limit 1;</xsl:variable>
 INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, log_start, log_sql)
-VALUES('<xsl:value-of select="$log_label" /> AddGeometryColumn','AddGeometryColumn', '<xsl:value-of select="@GeometryType" />', clock_timestamp(),
+VALUES('<xsl:value-of select="$log_label" /> AddTopoGeometryColumn','AddTopoGeometryColumn', '<xsl:value-of select="@GeometryType" />', clock_timestamp(),
     '<xsl:call-template name="escapesinglequotes"><xsl:with-param name="arg1"><xsl:value-of select="$var_sql" /></xsl:with-param></xsl:call-template>');
 BEGIN;
 	<xsl:value-of select="$var_logupdatesql" />
 COMMIT;
+</xsl:for-each>
-SELECT '<xsl:value-of select="$log_label" /> Geometry index: Start Testing <xsl:value-of select="@ID" />';
-INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, log_start) VALUES('<xsl:value-of select="$log_label" /> gist index Geometry','CREATE gist index geometry', '<xsl:value-of select="@ID" />', clock_timestamp());
-BEGIN;
-	CREATE INDEX idx_pgis_geom_gist ON pgis_garden USING gist(the_geom);
-	<xsl:value-of select="$var_logupdatesql" />
-COMMIT;
-SELECT '<xsl:value-of select="$log_label" /> geometry index: End Testing <xsl:value-of select="@ID" />';
+<!-- adding data -->
+<xsl:for-each select="document('')//pgis:gardens/pgis:gset[contains(@createtable,'true')]">
+	<xsl:variable name='var_sql'>SELECT topology.toTopoGeom(the_geom, <xsl:value-of select="$var_topology_name" />, ( topology.FindLayer(lower('pgis_tgarden_<xsl:value-of select="@ID" />')::regclass, 'topo') ).layer_id  )
+		FROM (<xsl:value-of select="." />) As foo;</xsl:variable>
+	INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, log_start, log_sql)
+	VALUES('insert data Topogeometry <xsl:value-of select="@GeometryType" />','insert data', '<xsl:value-of select="@ID" />',
+		clock_timestamp(), '<xsl:call-template name="escapesinglequotes"><xsl:with-param name="arg1"><xsl:value-of select="$var_sql" /></xsl:with-param></xsl:call-template>');
+	BEGIN;
+		<xsl:value-of select="$var_sql" />
+		<xsl:value-of select="$var_logupdatesql" />
+	COMMIT;
+</xsl:for-each>
-VALUES('<xsl:value-of select="$log_label" /> insert data Geometry','insert data', '<xsl:value-of select="@ID" />', clock_timestamp());
-BEGIN;
-	INSERT INTO pgis_garden(the_geom, the_geom_multi)
-	SELECT the_geom, ST_Multi(the_geom)
-	FROM (<xsl:value-of select="." />) As foo;
-COMMIT;
-VALUES('<xsl:value-of select="$log_label" /> UpdateGeometrySRID','UpdateGeometrySRID', '<xsl:value-of select="@GeometryType" />', clock_timestamp());
-BEGIN;
-	SELECT UpdateGeometrySRID('pgis_garden', 'the_geom', 4269);
-COMMIT;
-VALUES('<xsl:value-of select="$log_label" /> vacuum analyze Geometry','vacuum analyze Geometry', '<xsl:value-of select="@ID" />', clock_timestamp());
-VACUUM ANALYZE pgis_garden;
+VALUES('vacuum analyze topogeometries','vacuum analyze TopoGeometry <xsl:value-of select="@GeometryType" />', '<xsl:value-of select="@ID" />', clock_timestamp());
+VACUUM ANALYZE pgis_tgarden_<xsl:value-of select="@ID" />;
-VALUES('<xsl:value-of select="$log_label" /> DropGeometryColumn','DropGeometryColumn', '<xsl:value-of select="@GeometryType" />', clock_timestamp());
-BEGIN;
-	SELECT DropGeometryColumn ('pgis_garden','the_geom');
-COMMIT;
-VALUES('<xsl:value-of select="$log_label" /> DropGeometryTable','DropGeometryTable', '<xsl:value-of select="@ID" />', clock_timestamp());
-BEGIN;
-	SELECT DropGeometryTable ('pgis_garden');
-COMMIT;
-SELECT '<xsl:value-of select="$log_label" />: End Testing  <xsl:value-of select="@ID" />';
 	<xsl:text>
 	</xsl:text>
-SELECT '<xsl:value-of select="$log_label" /> Geography: Start Testing <xsl:value-of select="@ID" />';
-INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, log_start) VALUES('<xsl:value-of select="$log_label" /> Create Table / Add data - Geography','CREATE TABLE geography', '<xsl:value-of select="@ID" />', clock_timestamp());
-BEGIN;
-	CREATE TABLE pgis_geoggarden (gid serial PRIMARY KEY, the_geog geography(<xsl:value-of select="@GeometryType" />, 4326));
-	INSERT INTO pgis_geoggarden(the_geog)
-	SELECT the_geom
-COMMIT;
-SELECT '<xsl:value-of select="$log_label" /> Geography: End Testing <xsl:value-of select="@ID" />';
-SELECT '<xsl:value-of select="$log_label" /> Geography index: Start Testing <xsl:value-of select="@ID" />';
-INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, log_start) VALUES('<xsl:value-of select="$log_label" /> gist index Geography','CREATE gist index geography', '<xsl:value-of select="@ID" />', clock_timestamp());
-BEGIN;
-	CREATE INDEX idx_pgis_geoggarden_geog_gist ON pgis_geoggarden USING gist(the_geog);
-COMMIT;
-SELECT '<xsl:value-of select="$log_label" /> Geography index: End Testing <xsl:value-of select="@ID" />';
-<!-- vacuum analyze can't be put in a commit so we can't completely tell if it completes if it doesn't crash -->
-INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, log_start, log_sql) VALUES('<xsl:value-of select="$log_label" /> vacuum analyze Geography','analyze geography table', '<xsl:value-of select="@ID" />', clock_timestamp(),
-    'VACUUM ANALYZE pgis_geoggarden;');
-VACUUM ANALYZE pgis_geoggarden;
-INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, log_start) VALUES('<xsl:value-of select="$log_label" /> drop Geography table','drop geography table', '<xsl:value-of select="@ID" />', clock_timestamp());
-BEGIN;
-    SELECT 'BEFORE DROP' As look_at, * FROM geography_columns;
-	DROP TABLE pgis_geoggarden;
-	SELECT 'AFTER DROP' As look_at, * FROM geography_columns;
-COMMIT;
-SELECT '<xsl:value-of select="$log_label" /> Geography: End Testing';
-	<xsl:text>
-	</xsl:text>
-		</xsl:for-each>
+</xsl:for-each>
 <!--End Test table creation, insert, drop  -->
-<!--Start test on operators  -->
-	<xsl:for-each select="db:sect1[contains(@xml:id,'Operator') and not(contains($fnexclude,db:funcdef/db:function))]/db:refentry">
-		<xsl:sort select="@id"/>
-		<xsl:for-each select="db:refsynopsisdiv/db:funcsynopsis/db:funcprototype">
-			<xsl:variable name='fnname'><xsl:value-of select="db:funcdef/db:function"/></xsl:variable>
-			<xsl:variable name='fndef'><xsl:value-of select="." /></xsl:variable>
-			<xsl:for-each select="document('')//pgis:gardens/pgis:gset">
-			<!--Store first garden sql geometry from -->
-					<xsl:variable name="from1"><xsl:value-of select="." /></xsl:variable>
-					<xsl:variable name='geom1type'><xsl:value-of select="@GeometryType"/></xsl:variable>
-					<xsl:variable name='geom1id'><xsl:value-of select="@ID"/></xsl:variable>
-					<xsl:variable name='log_label'><xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="$geom1id" /> against other types</xsl:variable>
-		SELECT '<xsl:value-of select="$log_label" />: Start Testing ';
-		<xsl:choose>
-			  <xsl:when test="contains($fndef, 'geography')">
-			  INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, g2, log_start, log_sql)
-			  	VALUES('<xsl:value-of select="$log_label" /> Geography <xsl:value-of select="$geom1id" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />','<xsl:value-of select="$fnname" />', '<xsl:value-of select="$geom1id" />','<xsl:value-of select="@ID" />', clock_timestamp(),
-			  	'<xsl:call-template name="escapesinglequotes">
- <xsl:with-param name="arg1">SELECT ST_AsEWKT(foo1.the_geom) as ewktgeog1, ST_AsEWKT(foo2.the_geom) as ewktgeog2, geography(foo1.the_geom) <xsl:value-of select="$fnname" /> geography(foo2.the_geom) As geog1_op_geog2
-					FROM (<xsl:value-of select="$from1" />) As foo1 CROSS JOIN (<xsl:value-of select="." />) As foo2
-					WHERE (geography(foo1.the_geom) <xsl:value-of select="$fnname" /> geography(foo2.the_geom)) = true OR
-						(geography(foo1.the_geom) <xsl:value-of select="$fnname" /> geography(foo2.the_geom)) = false;</xsl:with-param>
-</xsl:call-template>');
-			SELECT 'Geography <xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />: Start Testing <xsl:value-of select="$geom1id" />, <xsl:value-of select="@ID" />';
-			BEGIN;
-			    <xsl:value-of select="$var_logresultsasxml" />
-			COMMIT;
-			</xsl:when>
-			<xsl:otherwise>
-			SELECT 'Geometry <xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />: Start Testing <xsl:value-of select="$geom1id" />, <xsl:value-of select="@ID" />';
-			  	VALUES('<xsl:value-of select="$log_label" /> Geometry <xsl:value-of select="$geom1id" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />','<xsl:value-of select="$fnname" />', '<xsl:value-of select="$geom1id" />','<xsl:value-of select="@ID" />', clock_timestamp(),
- <xsl:with-param name="arg1">SELECT ST_AsEWKT(foo1.the_geom) as ewktgeom1, ST_AsEWKT(foo2.the_geom) as ewktgeom2, foo1.the_geom <xsl:value-of select="$fnname" /> foo2.the_geom As geom1_op_geom2
-						WHERE (foo1.the_geom <xsl:value-of select="$fnname" /> foo2.the_geom) = true OR
-						(foo1.the_geom <xsl:value-of select="$fnname" /> foo2.the_geom) = false;</xsl:with-param></xsl:call-template>');
-			BEGIN;
-			COMMIT;
-			</xsl:otherwise>
-		</xsl:choose>
-					</xsl:for-each>
-		SELECT '<xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />: End Testing <xsl:value-of select="@GeometryType" /> against other types';
-				</xsl:for-each>
-			</xsl:for-each>
-	</xsl:for-each>
-<!--End test on operators -->
 <!-- Start regular function checks excluding operators -->
-		<xsl:for-each select="db:sect1[not(contains(@xml:id,'Operator'))]/db:refentry">
+		<xsl:for-each select="db:section[not(contains(@xml:id,'Operator'))]//db:refentry">
-<!--Create dummy parameters to be used later -->
+<!--Create dummy db:parameters to be used later -->
 				<xsl:variable name='fnfakeparams'><xsl:call-template name="replaceparams"><xsl:with-param name="func" select="." /></xsl:call-template></xsl:variable>
 				<xsl:variable name='fnargs'><xsl:call-template name="listparams"><xsl:with-param name="func" select="." /></xsl:call-template></xsl:variable>
 				<xsl:variable name='fndef'><xsl:value-of select="db:funcdef"/></xsl:variable>
-				<xsl:variable name='numparams'><xsl:value-of select="count(db:paramdef/parameter)" /></xsl:variable>
-				<xsl:variable name='numparamgeoms'><xsl:value-of select="count(db:paramdef/db:type[contains(text(),'geometry') or contains(text(),'geography') or contains(text(),'box') or contains(text(), 'bytea')]) + count(db:paramdef/parameter[contains(text(),'WKT')]) + count(db:paramdef/parameter[contains(text(),'geomgml')])" /></xsl:variable>
-				<xsl:variable name='numparamgeogs'><xsl:value-of select="count(db:paramdef/db:type[contains(text(),'geography')] )" /></xsl:variable>
+				<xsl:variable name='numparams'><xsl:value-of select="count(db:paramdef/db:parameter)" /></xsl:variable>
+				<xsl:variable name='numparamgeoms'><xsl:value-of select="count(db:paramdef/db:type[contains(text(),'geometry') or contains(text(),'geography') or contains(text(),'box') or contains(text(), 'topogeometry') or contains(text(), 'bytea') or contains(text(),'anyelement')] ) + count(db:paramdef/db:parameter[contains(text(),'WKT')]) + count(db:paramdef/db:parameter[contains(text(),'geomgml')]) + count(db:paramdef/db:parameter[contains(text(),'geomjson')]) + count(db:paramdef/db:parameter[contains(text(),'geomkml')])" /></xsl:variable>
+				<xsl:variable name='numparamtopogeoms'><xsl:value-of select="count(db:paramdef/db:type[contains(text(),'topogeometry')] )" /></xsl:variable>
 				<xsl:variable name='log_label'><xsl:value-of select="db:funcdef/db:function" />(<xsl:value-of select="$fnargs" />)</xsl:variable>
 				<xsl:variable name="geoftype">
@@ -356,18 +439,30 @@ SELECT '<xsl:value-of select="$log_label" /> Geography: End Testing';
 					<xsl:when test="$numparamgeoms > '0'">
 					  <xsl:value-of select="'Geometry'"/>
 					</xsl:when>
-					<xsl:when test="$numparamgeogs > '0'">
-					  <xsl:value-of select="'Geography'"/>
+					<xsl:when test="$numparamtopogeoms > '0'">
+					  <xsl:value-of select="'Topogeometry'"/>
 					</xsl:when>
 					<xsl:otherwise>
 					  <xsl:value-of select="'Other'"/>
 					</xsl:otherwise>
 				  </xsl:choose>
 				</xsl:variable>
+				<!-- is a window or aggregate function -->
+				<xsl:variable name='over_clause'>
+					 <xsl:choose>
+					 	<xsl:when test="db:paramdef/db:type[contains(text(),'set')]">
+					 		<xsl:value-of select="'OVER(ORDER BY random())'"/>
+					 	</xsl:when>
+					<xsl:otherwise>
+					  <xsl:value-of select="''"/>
+					</xsl:otherwise>
+				  </xsl:choose>
+				</xsl:variable>
 				<!-- For each function prototype generate a test sql statement -->
 				<xsl:choose>
 <!--Test functions that take no arguments and take no geometries/geographies -->
-	<xsl:when test="($numparamgeoms = '0' and $numparamgeogs = '0') and not(contains($fnexclude,db:funcdef/db:function))">SELECT  'Starting <xsl:value-of select="db:funcdef/db:function" />(<xsl:value-of select="$fnargs" />)';
+	<xsl:when test="($numparamgeoms = '0' and $numparamtopogeoms = '0') and not(contains($fnexclude,db:funcdef/db:function))">SELECT  'Starting <xsl:value-of select="db:funcdef/db:function" />(<xsl:value-of select="$fnargs" />)';
 INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, log_start, log_sql)
 			  	VALUES('<xsl:value-of select="$log_label" /> <xsl:value-of select="$geoftype" />','<xsl:value-of select="$fnname" />', clock_timestamp(),
@@ -379,18 +474,19 @@ BEGIN;
 COMMIT;
 SELECT  'Ending <xsl:value-of select="db:funcdef/db:function" />(<xsl:value-of select="$fnargs" />)';
 	</xsl:when>
-<!--Start Test aggregate and unary functions for both geometry and geography -->
-<!-- put functions that take only one geometry/geography no need to cross with another geom collection, these are unary geom, aggregates, and so forth -->
-	<xsl:when test="($numparamgeoms = '1' or $numparamgeogs = '1')  and not(contains($fnexclude,db:funcdef/db:function))" >
+<!--Start Test aggregate and unary functions for both geometry and topogeometry -->
+<!-- put functions that take only one geometry/topogeometry no need to cross with another geom collection, these are unary geom, aggregates, window and so forth -->
+<!-- for window functions we need to put in OVER() -->
+	<xsl:when test="($numparamgeoms = '1' or $numparamtopogeoms = '1')  and not(contains($fnexclude,db:funcdef/db:function))">
 		SELECT '<xsl:value-of select="$geoftype" /> <xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />: Start Testing';
 			  	VALUES('<xsl:value-of select="$log_label" /> <xsl:value-of select="$geoftype" />  <xsl:text> </xsl:text><xsl:value-of select="@ID" /><xsl:text> </xsl:text>','<xsl:value-of select="$fnname" />', '<xsl:value-of select="@ID" />', clock_timestamp(),
- <xsl:with-param name="arg1">SELECT <xsl:value-of select="$fnname" />(<xsl:value-of select="$fnfakeparams" />) As result
+ <xsl:with-param name="arg1">SELECT <xsl:value-of select="$fnname" />(<xsl:value-of select="$fnfakeparams" />)<xsl:value-of select="$over_clause" />  As result
 							FROM (<xsl:value-of select="." />) As foo1
-				LIMIT 3;</xsl:with-param></xsl:call-template>');
+				LIMIT 10;</xsl:with-param></xsl:call-template>');
 BEGIN;
@@ -409,13 +505,13 @@ COMMIT;
 SELECT '<xsl:value-of select="$fnname" /> <xsl:text> </xsl:text><xsl:value-of select="@ID" />(<xsl:value-of select="$fnargs" />): Start Testing <xsl:value-of select="$geom1id" /> against other types';
 			<xsl:choose>
-			  <xsl:when test="($numparamgeogs > '0' or $numparamgeoms > '0')">
+			  <xsl:when test="($numparamtopogeoms > '0' or $numparamgeoms > '0')">
 			  	VALUES('<xsl:value-of select="$log_label" /> <xsl:value-of select="$geoftype" /> <xsl:text> </xsl:text> <xsl:value-of select="@ID" />','<xsl:value-of select="$fnname" />','<xsl:value-of select="$geom1id" />', '<xsl:value-of select="@ID" />', clock_timestamp(),
  <xsl:with-param name="arg1">SELECT <xsl:value-of select="$fnname" />(<xsl:value-of select="$fnfakeparams" />) As result, ST_AsText(foo1.the_geom) As ref1_geom, ST_AsText(foo2.the_geom) As ref2_geom
-			LIMIT 2;</xsl:with-param></xsl:call-template>');
 			BEGIN;
@@ -448,7 +544,7 @@ SELECT '<xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of sel
 			</xsl:for-each>
 		</xsl:for-each>
 		<!-- flag primary grouping the functions belong in -->
-		UPDATE <xsl:value-of select="$var_logtable" /> SET spatial_class = 'geography' WHERE (log_label ILIKE '%geography%' or log_sql ILIKE '%geography%') AND spatial_class IS NULL;
+		UPDATE <xsl:value-of select="$var_logtable" /> SET spatial_class = 'topogeometry' WHERE (log_label ILIKE '%topogeometry%' or log_sql ILIKE '%topogeometry%') AND spatial_class IS NULL;
 		UPDATE <xsl:value-of select="$var_logtable" /> SET spatial_class = 'geometry' WHERE log_label ILIKE '%geometry%' or log_label ILIKE '%other%' AND spatial_class IS NULL;
 	</xsl:template>
@@ -459,105 +555,168 @@ SELECT '<xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of sel
 		<xsl:for-each select="$func">
 			<xsl:for-each select="db:paramdef">
 				<xsl:choose>
-					<xsl:when test="contains(parameter, 'matrix') or contains(parameter, 'Matrix')">
+				    <!-- ignore output parameters -->
+				    <xsl:when test="contains(db:parameter,'OUT')"></xsl:when>
+				    	<xsl:when test="contains(db:parameter, 'buffer_style_parameters') or contains(db:parameter, 'buffer_style_parameters')">
+						<xsl:value-of select="$var_buffer_style" />
+					</xsl:when>
+					<xsl:when test="contains(db:parameter, 'matrix') or contains(db:parameter, 'Matrix')">
 						<xsl:value-of select="$var_matrix" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'distance')">
+					<xsl:when test="contains(db:parameter, 'distance')">
 						<xsl:value-of select="$var_distance" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'srid')">
+					<xsl:when test="contains(db:parameter, 'row')">
+						<xsl:value-of select="$var_row" />
+					</xsl:when>
+					<xsl:when test="contains(db:parameter, 'srid')">
 						<xsl:value-of select="$var_srid" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'position')">
+					<xsl:when test="contains(db:parameter, 'position')">
 						<xsl:value-of select="$var_position" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'NDR')">
+					<xsl:when test="contains(db:parameter, 'NDR')">
 						'<xsl:value-of select="$var_NDRXDR" />'
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'gj_version')">
+					<xsl:when test="contains(db:parameter, 'gj_version')">
 						<xsl:value-of select="$var_gj_version" />
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'version') and position() = 2">
+					<xsl:when test="contains(db:parameter, 'version') and position() = 2">
 						<xsl:value-of select="$var_version1" />
 					</xsl:when>
-					<xsl:when test="(contains(parameter, 'version'))">
+					<xsl:when test="(contains(db:parameter, 'version'))">
 						<xsl:value-of select="$var_version2" />
 					</xsl:when>
-					<xsl:when test="(contains(parameter,'geomgml'))">
+					<xsl:when test="(contains(db:parameter,'geomgml'))">
 						<xsl:text>ST_AsGML(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="(contains(parameter,'geomkml'))">
+					<xsl:when test="(contains(db:parameter,'geomkml'))">
 						<xsl:text>ST_AsKML(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="(contains(type,'box') or type = 'geometry' or type = 'geometry ' or contains(type,'geometry set')) and (position() = 1 or count($func/paramdef/db:type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1')">
+					<xsl:when test="(contains(db:parameter,'geomjson'))">
+						<xsl:text>ST_AsGeoJSON(foo1.the_geom)</xsl:text>
+					</xsl:when>
+					<xsl:when test="contains(db:parameter, 'geom_name')">
+						'<xsl:value-of select="$var_geom_name" />'
+					</xsl:when>
+					<xsl:when test="contains(db:parameter, 'bounds')">
+						ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096))
+					</xsl:when>
+					<xsl:when test="(contains(db:type,'box') or db:type = 'geometry' or db:type = 'geometry ' or contains(db:type,'geometry set') or contains(db:type,'geometry winset') ) and (position() = 1 or count($func/db:paramdef/db:type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1')">
 						<xsl:text>foo1.the_geom</xsl:text>
 					</xsl:when>
-					<xsl:when test="(type = 'geography' or type = 'geography ' or contains(type,'geography set')) and (position() = 1 or count($func/paramdef/db:type[contains(text(),'geography')]) = '1' )">
+					<xsl:when test="(db:type = 'geography' or db:type = 'geography ' or contains(db:type,'geography set')) and (position() = 1 or count($func/paramdef/db:type[contains(text(),'geography')]) = '1' )">
 						<xsl:text>geography(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(type,'box') or type = 'geometry' or type = 'geometry '">
+					<xsl:when test="(db:type = 'topogeometry' or db:type = 'topogeometry ' or db:type = 'topoelement' or contains(db:type,'topogeometry set')) and (position() = 1 or count($func/paramdef/db:type[contains(text(),'geography')]) = '1' )">
+						<xsl:text>topology.toTopoGeom(foo1.the_geom, 'topo_test', 1, 0.001)</xsl:text>
+					</xsl:when>
+					<xsl:when test="contains(db:type,'box') or db:type = 'geometry' or db:type = 'geometry '">
 						<xsl:text>foo2.the_geom</xsl:text>
 					</xsl:when>
-					<xsl:when test="type = 'geography' or type = 'geography '">
+					<xsl:when test="contains(db:type,'topogeometry') or db:type = 'topogeometry '">
+						<xsl:text>topology.toTopoGeom(foo2.the_geom, 'topo_test', 1, 0.001)</xsl:text>
+					</xsl:when>
+					<xsl:when test="db:type = 'geography' or db:type = 'geography '">
 						<xsl:text>geography(foo2.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(type, 'geometry[]') and count($func/paramdef/db:type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1'">
+					<xsl:when test="contains(db:type, 'bigint[]')">
+						<xsl:text>ARRAY[ST_XMin(foo1.the_geom)::bigint]</xsl:text>
+					</xsl:when>
+					<xsl:when test="contains(db:type, 'geometry[]') and count($func/paramdef/db:type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1'">
 						ARRAY[foo1.the_geom]
 					</xsl:when>
-					<xsl:when test="contains(type, 'geometry[]')">
+					<xsl:when test="contains(db:type, 'geometry[]')">
 						ARRAY[foo2.the_geom]
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'EWKT')">
+					<xsl:when test="contains(db:parameter, 'EWKT')">
 						<xsl:text>ST_AsEWKT(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'WKT')">
+					<xsl:when test="contains(db:parameter, 'toponame')">
+						<xsl:value-of select="$var_toponame" />
+					</xsl:when>
+					<xsl:when test="contains(db:parameter, 'topology_schema_name')">
+						<xsl:value-of select="$var_topology_name" />
+					</xsl:when>
+					<xsl:when test="contains(db:parameter, 'topology_name')">
+					</xsl:when>
+					<xsl:when test="contains(db:parameter, 'table_name')">
+						<xsl:text>'public'</xsl:text>
+					</xsl:when>
+					<xsl:when test="contains(db:parameter, 'WKT')">
 						<xsl:text>ST_AsText(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(parameter, 'EWKB')">
+					<xsl:when test="contains(db:parameter, 'EWKB')">
 						<xsl:text>ST_AsEWKB(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(type, 'bytea')">
+					<xsl:when test="contains(db:parameter, 'twkb')">
+						<xsl:text>ST_AsTWKB(foo1.the_geom)</xsl:text>
+					</xsl:when>
+					<xsl:when test="contains(db:type, 'bytea')">
 						<xsl:text>ST_AsBinary(foo1.the_geom)</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(type, 'float') or contains(type, 'double')">
+					<xsl:when test="contains(db:parameter, 'Frac') or contains(db:parameter, 'frac') or contains(db:parameter, 'percent')">
+						<xsl:value-of select="$var_frac" />
+					</xsl:when>
+					<xsl:when test="contains(db:type, 'float') or contains(db:type, 'double')">
 						<xsl:value-of select="$var_float1" />
 					</xsl:when>
-					<xsl:when test="contains(type, 'spheroid')">
+					<xsl:when test="contains(db:type, 'spheroid')">
 						<xsl:value-of select="$var_spheroid" />
 					</xsl:when>
-					<xsl:when test="contains(type, 'integer') and position() = 2">
+					<xsl:when test="contains(db:type, 'integer') and position() = 2">
 						<xsl:value-of select="$var_integer1" />
 					</xsl:when>
-					<xsl:when test="contains(type, 'integer')">
+					<xsl:when test="contains(db:type, 'integer') or contains(db:type, 'int4')">
 						<xsl:value-of select="$var_integer2" />
 					</xsl:when>
-					<xsl:when test="contains(type, 'text')">
+					<xsl:when test="contains(db:type, 'text')">
 						<xsl:value-of select="$var_text" />
 					</xsl:when>
-					<xsl:when test="contains(type, 'varchar')">
+					<xsl:when test="contains(db:type, 'varchar')">
 						<xsl:value-of select="$var_varchar" />
 					</xsl:when>
-					<xsl:when test="contains(type,'timestamp') or type = 'date'">
+					<xsl:when test="contains(db:type,'timestamp') or db:type = 'date'">
 						<xsl:text>'2009-01-01'</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(type,'boolean')">
+					<xsl:when test="contains(db:type,'boolean')">
 						<xsl:value-of select="$var_boolean" />
 					</xsl:when>
 				</xsl:choose>
-				<xsl:if test="position()<last()"><xsl:text>, </xsl:text></xsl:if>
+				<!-- put a comma before an arg if it is not the first argument in a function and it is not an OUT parameter nor does it precede an OUT parameter -->
+				<xsl:if test="position()<last() and not(contains(db:parameter,'OUT')) and not(contains(following-sibling::paramdef[1],'OUT'))"><xsl:text>, </xsl:text></xsl:if>
 			</xsl:for-each>
 		</xsl:for-each>
 	</xsl:template>
-	<!--macro to pull out function parameter names so we can provide a pretty arg list prefix for each function -->
+	<!--macro to pull out function db:parameter names so we can provide a pretty arg list prefix for each function -->
 	<xsl:template name="listparams">
 		<xsl:param name="func" />
-			<xsl:if test="count(db:paramdef/parameter) > 0"> </xsl:if>
+			<xsl:if test="count(db:paramdef/db:parameter) > 0"> </xsl:if>
 				<xsl:choose>
-					<xsl:when test="count(parameter) > 0">
-						<xsl:value-of select="parameter" />
+					<xsl:when test="count(db:parameter) > 0">
+						<xsl:value-of select="db:parameter" />
 					</xsl:when>
 				</xsl:choose>
diff --git a/regress/Makefile.in b/regress/Makefile.in
index a9a1ba17b..cc4b8dfff 100644
--- a/regress/Makefile.in
+++ b/regress/Makefile.in
@@ -105,6 +105,8 @@ garden: staged-install
 	psql -qX -v ON_ERROR_STOP=true -d $(GARDENDB) < $(REGRESS_INSTALLDIR)/share/contrib/postgis/postgis.sql
 	psql -qX -v ON_ERROR_STOP=true -d $(GARDENDB) < $(REGRESS_INSTALLDIR)/share/contrib/postgis/spatial_ref_sys.sql
 	psql -qX -v ON_ERROR_STOP=true -d $(GARDENDB) < $(REGRESS_INSTALLDIR)/share/contrib/postgis/rtpostgis.sql
+	psql -qX -v ON_ERROR_STOP=true -d $(GARDENDB) < $(REGRESS_INSTALLDIR)/share/contrib/postgis/topology.sql
+	psql -qX -v ON_ERROR_STOP=true -d $(GARDENDB) < $(REGRESS_INSTALLDIR)/share/contrib/postgis/sfcgal.sql
 	@echo '-------------------------------------------------'
 	@echo 'PostGIS garden tests in progress (it will take time)'
@@ -121,3 +123,19 @@ garden: staged-install
 		> raster_garden_result.txt 2>&1 || { \
 		tail -n 20 raster_garden_result.txt; false; }
+	@echo '-------------------------------------------------'
+	@echo 'PostGIS Topology garden tests in progress (it will take time)'
+	psql -X -ad $(GARDENDB) < \
+		../doc/topology_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql \
+		> topology_garden_result.txt 2>&1 || { \
+		tail -n 20 topology_garden_result.txt; false; }
+	@echo 'PostGIS SFCGAL garden tests in progress (it will take time)'
+		../doc/sfcgal_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql \
+		> sfcgal_garden_result.txt 2>&1 || { \
+		tail -n 20 sfcgal_garden_result.txt; false; }
Summary of changes:
 .github/workflows/ci.yml            |   2 +
 .gitignore                          |   1 +
 doc/Makefile.in                     |   3 +-
 doc/xsl/raster_gardentest.sql.xsl   |   4 +-
 doc/xsl/sfcgal_gardentest.sql.xsl   |   6 +-
 doc/xsl/topology_gardentest.sql.xsl | 597 +++++++++++++++++++++++-------------
 regress/Makefile.in                 |  18 ++
 7 files changed, 406 insertions(+), 225 deletions(-)
hooks/post-receive
