[PostGIS] #5926: raster garden tests are broken
PostGIS trac at osgeo.org
Fri Jun 6 18:03:23 PDT 2025
 Reporter:  robe          |      Owner:  robe
     Type:  defect        |     Status:  assigned
 Priority:  medium        |  Milestone:  PostGIS 3.5.4
Component:  QA/testsuite  |    Version:  3.5.x
 Keywords:                |
 I think this might have happened with the docbook xml, change, perhaps
 some parts I didn't account for.
 During garden tests, the raster garden is failing with:
 See Also
 ERROR:  syntax error at or near "Raster"
 LINE 1: Raster Support Data types
 I traced this back to the sql generated file, and it starts spitting out
 the whole section of Raster Support Data Types as plain text right after
 ST_DFullyWithin.
 Maybe I just have to excluse that section cause it doesn't fit method
 pattern
 SELECT 'ST_DFullyWithin NULLRaster(rastA, rastB, distance_of_srid): End
 Testing null against other types';
                 This section lists the PostgreSQL data types specifically
 created to support raster functionality.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5926>
