[PostGIS] #5926: raster garden tests are broken
PostGIS trac at osgeo.org
Fri Jun 6 19:27:56 PDT 2025
  Reporter:  robe          |      Owner:  robe
      Type:  defect        |     Status:  closed
  Priority:  medium        |  Milestone:  PostGIS 3.5.4
 Component:  QA/testsuite  |    Version:  3.5.x
Resolution:  fixed         |   Keywords:
Changes (by Regina Obe <lr@…>):
 * resolution:   => fixed
 * status:  assigned => closed
Comment:
 In [changeset:"8060d5ef40161ac8240073846f602fdf3d9db233/git" 8060d5e/git]:
 {{{#!CommitTicketReference repository="git"
 revision="8060d5ef40161ac8240073846f602fdf3d9db233"
 GARDEN FIXINS
  - Fix raster garden tests - Closes #5926 for PostGIS 3.6.0
  - More input handlings for postgis_garden core
  - Lower case all topogeometry type references to match with other type
 casing
    Needed cause garden test is looking for lower case
  - other topology garden type replace Closes #2297 for PostGIS 3.6.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5926#comment:1>
