[PostGIS] #5925: TopoGeo_AddPoint crash on infinite point
PostGIS trac at osgeo.org
Fri Jun 6 18:26:22 PDT 2025
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.0.12
 Component:  topology  |    Version:  3.5.x
Resolution:            |   Keywords:
Comment (by robe):
 As expected TopoGeo_LoadGeometry has the same issue:
 SELECT TopoGeo_LoadGeometry('test', foo1.the_geom, 20.1)  As result
                                                         FROM ((SELECT
 '0101000020E6100000000000000000F07F000000000000F07F'::geometry AS the_geom
 ) ) As foo1
  and goes thru the same function.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5925#comment:2>
