[SCM] PostGIS branch master updated. 3.5.0-381-g8060d5ef4
Fri Jun 6 19:27:54 PDT 2025
the project "PostGIS".
       via  8060d5ef40161ac8240073846f602fdf3d9db233 (commit)
      from  496a9b33481691e76671a210083308386aee5b02 (commit)
revisions in full, below.
commit 8060d5ef40161ac8240073846f602fdf3d9db233
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jun 6 21:08:08 2025 -0400
    GARDEN FIXINS
     - Fix raster garden tests - Closes #5926 for PostGIS 3.6.0
     - More input handlings for postgis_garden core
     - Lower case all topogeometry type references to match with other type casing
       Needed cause garden test is looking for lower case
     - other topology garden type replace Closes #2297 for PostGIS 3.6.0
diff --git a/.gitignore b/.gitignore
index b2f46cfcd..56da459ad 100644
--- a/.gitignore
+++ b/.gitignore
@@ -178,6 +178,7 @@ regress/sfcgal/Makefile
 regress/postgis.sql
 regress/postgis_garden_result.txt
 regress/raster_garden_result.txt
+regress/topology_garden_result.txt
 sfcgal/Makefile
 sfcgal/regress/Makefile
 sfcgal/regress/tests.mk
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 9d4b2d01f..6dd944a30 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -1095,7 +1095,7 @@ SELECT topology.MakeTopologyPrecise(
 				<funcsynopsis>
 					<funcprototype>
                         <funcdef>topology <function>FindTopology</function></funcdef>
-                        <paramdef><type>TopoGeometry</type> <parameter>topogeom</parameter></paramdef>
+                        <paramdef><type>topogeometry</type> <parameter>topogeom</parameter></paramdef>
 					</funcprototype>
 					<funcprototype>
@@ -1159,7 +1159,7 @@ SELECT name(findTopology('features.land_parcels', 'feature'));
 				<funcsynopsis>
 					<funcprototype>
                         <funcdef>topology.layer <function>FindLayer</function></funcdef>
-                        <paramdef><type>TopoGeometry</type> <parameter>tg</parameter></paramdef>
+                        <paramdef><type>topogeometry</type> <parameter>tg</parameter></paramdef>
 					</funcprototype>
 					<funcprototype>
@@ -3490,7 +3490,7 @@ faceid
 		<funcsynopsis>
 		  <funcprototype>
 			<funcdef>geometry <function>ST_Simplify</function></funcdef>
 			<paramdef><type>float8</type> <parameter>tolerance</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index f7a09e657..cb367a6b7 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -11,7 +11,7 @@
 			using a garden variety of geometries.  Its intent is to flag major crashes.
 	<xsl:output method="text" />
-	<xsl:variable name='testversion'>3.5.0</xsl:variable>
+	<xsl:variable name='testversion'>3.6.0</xsl:variable>
 	<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
 	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable CG_Visibility CG_YMonotonePartition ST_AlphaShape ST_OptimalAlphaShape</xsl:variable>
 	<!--This is just a place holder to state functions not supported or tested separately -->
@@ -36,7 +36,7 @@
 	<xsl:variable name='var_matrix'>'FF1FF0102'</xsl:variable>
 	<xsl:variable name='var_boolean'>false</xsl:variable>
 	<xsl:variable name='var_geom_name'>the_geom</xsl:variable>
-	<xsl:variable name='var_logtable'>postgis_garden_log35</xsl:variable>
+	<xsl:variable name='var_logtable'>postgis_garden_log36</xsl:variable>
 	<xsl:variable name='var_logupdatesql'>UPDATE <xsl:value-of select="$var_logtable" /> SET log_end = clock_timestamp()
 		FROM (SELECT logid FROM <xsl:value-of select="$var_logtable" /> ORDER BY logid DESC limit 1) As foo
 		WHERE <xsl:value-of select="$var_logtable" />.logid = foo.logid  AND <xsl:value-of select="$var_logtable" />.log_end IS NULL;</xsl:variable>
@@ -717,6 +717,9 @@ SELECT '<xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of sel
 					<xsl:when test="contains(db:parameter, 'NDR')">
 						'<xsl:value-of select="$var_NDRXDR" />'
 					</xsl:when>
+					<xsl:when test="(contains(db:parameter, 'target_version'))">
+						'<xsl:value-of select="$testversion" />'
+					</xsl:when>
 					<xsl:when test="contains(db:parameter, 'gj_version')">
 						<xsl:value-of select="$var_gj_version" />
 					</xsl:when>
@@ -739,6 +742,9 @@ SELECT '<xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of sel
 						'<xsl:value-of select="$var_geom_name" />'
 					</xsl:when>
+					<xsl:when test="contains(db:parameter, 'relation_oid')">
+						'<xsl:value-of select="$var_logtable" />'::regclass
+					</xsl:when>
 					<xsl:when test="contains(db:parameter, 'bounds')">
 						ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096))
 					</xsl:when>
@@ -762,11 +768,11 @@ SELECT '<xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of sel
 					<xsl:when test="contains(db:type, 'bigint[]')">
 						<xsl:text>ARRAY[ST_XMin(foo1.the_geom)::bigint]</xsl:text>
 					</xsl:when>
-					<xsl:when test="contains(db:type, 'geometry[]') and count($func/paramdef/db:type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1'">
-						ARRAY[foo1.the_geom]
+					<xsl:when test="contains(db:type, 'geometry[]') and count($func/paramdef/db:type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '2'">
+						ARRAY[foo2.the_geom]
 					</xsl:when>
 					<xsl:when test="contains(db:type, 'geometry[]')">
-						ARRAY[foo2.the_geom]
+						ARRAY[foo1.the_geom]
 					</xsl:when>
 					<xsl:when test="contains(db:parameter, 'EWKT')">
 						<xsl:text>ST_AsEWKT(foo1.the_geom)</xsl:text>
diff --git a/doc/xsl/raster_gardentest.sql.xsl b/doc/xsl/raster_gardentest.sql.xsl
index 61d6a9fa8..01ed0e637 100644
--- a/doc/xsl/raster_gardentest.sql.xsl
+++ b/doc/xsl/raster_gardentest.sql.xsl
@@ -133,8 +133,8 @@ DROP TABLE IF EXISTS <xsl:value-of select="$var_logtable" />;
 CREATE TABLE <xsl:value-of select="$var_logtable" />(logid serial PRIMARY KEY, log_label text, spatial_class text DEFAULT 'raster', func text, g1 text, g2 text, log_start timestamp, log_end timestamp, log_sql text);
 DROP TABLE IF EXISTS <xsl:value-of select="$var_logtable" />_output;
 CREATE TABLE <xsl:value-of select="$var_logtable" />_output(logid integer PRIMARY KEY, log_output xml);
-						<xsl:apply-templates select="/db:book/db:chapter[@xml:id='RT_reference']" />
-            <xsl:apply-templates select="/db:book/db:chapter[@xml:id='RT_reference']/db:section[contains(@xml:id, 'Type')]" />
+			<xsl:apply-templates select="/db:book/db:chapter[@xml:id='RT_reference']" />
         </xsl:template>
 	<xsl:template match='db:chapter'>
 <!-- define a table we call pgis_rgarden_mega that will contain a raster column with a band for all types of pixels we support -->
diff --git a/doc/xsl/topology_gardentest.sql.xsl b/doc/xsl/topology_gardentest.sql.xsl
index 95f5d77f3..75c0f7ee3 100644
--- a/doc/xsl/topology_gardentest.sql.xsl
+++ b/doc/xsl/topology_gardentest.sql.xsl
@@ -600,6 +600,19 @@ SELECT '<xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of sel
 					</xsl:when>
+					<xsl:when test="contains(db:parameter, 'feature_column') and db:type = 'name'">
+						'topo'
+					</xsl:when>
+					<xsl:when test="contains(db:parameter, 'layer_table') and db:type = 'regclass'">
+						'public.pgis_tgarden_point'::regclass
+					</xsl:when>
+					<xsl:when test="contains(db:parameter, 'new_name') and db:type = 'name'">
+						'topo'
+					</xsl:when>
 					</xsl:when>
@@ -632,6 +645,7 @@ SELECT '<xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of sel
 					</xsl:when>
 					</xsl:when>
@@ -683,10 +697,10 @@ SELECT '<xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of sel
 					<xsl:when test="contains(db:type, 'spheroid')">
 						<xsl:value-of select="$var_spheroid" />
 					</xsl:when>
-					<xsl:when test="contains(db:type, 'integer') and position() = 2">
+					<xsl:when test="contains(db:type, 'int') and position() = 2">
 						<xsl:value-of select="$var_integer1" />
 					</xsl:when>
-					<xsl:when test="contains(db:type, 'integer') or contains(db:type, 'int4')">
+					<xsl:when test="contains(db:type, 'int') or contains(db:type, 'int4')">
 						<xsl:value-of select="$var_integer2" />
 					</xsl:when>
 					<xsl:when test="contains(db:type, 'text')">
Summary of changes:
 .gitignore                          |  1 +
 doc/extras_topology.xml             |  6 +++---
 doc/xsl/postgis_gardentest.sql.xsl  | 16 +++++++++++-----
 doc/xsl/raster_gardentest.sql.xsl   |  4 ++--
 doc/xsl/topology_gardentest.sql.xsl | 18 ++++++++++++++++--
 5 files changed, 33 insertions(+), 12 deletions(-)
hooks/post-receive
