[SCM] PostGIS branch stable-3.5 updated. 3.5.3-16-gee62ab039
git at osgeo.org
git at osgeo.org
Fri Jun 6 19:30:42 PDT 2025
the project "PostGIS".
The branch, stable-3.5 has been updated
via ee62ab039211f99d8498019e026a14a229e13d26 (commit)
from 93eab661c2071fe2333e62e6f3d9c77c3904108b (commit)
revisions in full, below.
commit ee62ab039211f99d8498019e026a14a229e13d26
Author: Regina Obe <lr at pcorp.us>
Date: Fri Jun 6 22:30:34 2025 -0400
Fix raster garden, closes #5926 for PostGIS 3.5.4
diff --git a/doc/xsl/raster_gardentest.sql.xsl b/doc/xsl/raster_gardentest.sql.xsl
index aa0f61998..0d0439216 100644
--- a/doc/xsl/raster_gardentest.sql.xsl
+++ b/doc/xsl/raster_gardentest.sql.xsl
@@ -133,8 +133,8 @@ DROP TABLE IF EXISTS <xsl:value-of select="$var_logtable" />;
CREATE TABLE <xsl:value-of select="$var_logtable" />(logid serial PRIMARY KEY, log_label text, spatial_class text DEFAULT 'raster', func text, g1 text, g2 text, log_start timestamp, log_end timestamp, log_sql text);
DROP TABLE IF EXISTS <xsl:value-of select="$var_logtable" />_output;
CREATE TABLE <xsl:value-of select="$var_logtable" />_output(logid integer PRIMARY KEY, log_output xml);
- <xsl:apply-templates select="/db:book/db:chapter[@xml:id='RT_reference']" />
- <xsl:apply-templates select="/db:book/db:chapter[@xml:id='RT_reference']/db:section[contains(@xml:id, 'Type')]" />
+ <xsl:apply-templates select="/db:book/db:chapter[@xml:id='RT_reference']" />
</xsl:template>
<xsl:template match='db:chapter'>
<!-- define a table we call pgis_rgarden_mega that will contain a raster column with a band for all types of pixels we support -->
Summary of changes:
doc/xsl/raster_gardentest.sql.xsl | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
