[SCM] PostGIS branch master updated. 3.5.0-385-gdf6ce6e2f
git at osgeo.org
git at osgeo.org
Sun Jun 8 10:47:45 PDT 2025
the project "PostGIS".
via df6ce6e2fccbc8e1253186d4b06b7f9b1a6302d9 (commit)
from 84b5e2b5408a910cead53fdf14e51bf21c9ec89c (commit)
revisions in full, below.
commit df6ce6e2fccbc8e1253186d4b06b7f9b1a6302d9
Author: Daniel Nylander <daniel at danielnylander.se>
Date: Sun Jun 8 16:55:05 2025 +0000
Translated PostGIS Manual using Weblate (Swedish)
Currently translated at 100.0% (5807 of 5807 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/sv/
diff --git a/doc/po/sv/postgis-manual.po b/doc/po/sv/postgis-manual.po
index 986e84f45..d09178e86 100644
--- a/doc/po/sv/postgis-manual.po
+++ b/doc/po/sv/postgis-manual.po
@@ -5,7 +5,7 @@ msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-05-18 00:48+0000\n"
-"PO-Revision-Date: 2025-06-08 13:47+0000\n"
+"PO-Revision-Date: 2025-06-08 17:47+0000\n"
"Last-Translator: Daniel Nylander <daniel at danielnylander.se>\n"
"Language-Team: Swedish <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/sv/>\n"
@@ -1037,7 +1037,7 @@ msgstr ""
"Koden är inbyggd i ett enda PostgreSQL-tilläggsbibliotek som heter "
"<code>address_standardizer</code> som kan installeras med <code>CREATE "
"EXTENSION address_standardizer;.</code> Förutom address_standardizer-"
-"tillägget byggs en exempeldataförlängning som heter "
+"tillägget byggs en exempeldatautökning som heter "
"<code>address_standardizer_data_us</code> extensions, som innehåller gaz-, "
"lex- och regeltabeller för amerikanska data. Detta tillägg kan installeras "
"via: <code>CREATE EXTENSION address_standardizer_data_us;</code>"
@@ -7720,7 +7720,7 @@ msgstr "Förbättrad: 2.2.1 har lagt till stöd för puntal-ingångar"
#. Tag: title
#, no-c-format
msgid "Topology Spatial Relationships"
-msgstr "Topologi Spatiala relationer"
+msgstr "Spatiala relationer mellan topologier"
#. Tag: para
#, no-c-format
@@ -8110,7 +8110,7 @@ msgid ""
"against PostgreSQL versions &min_postgres_version; - &max_postgres_version;. "
"Earlier versions of PostgreSQL are <emphasis>not</emphasis> supported."
msgstr ""
-"PostGIS-modulen är en förlängning av PostgreSQL-backend-servern. Som sådan "
+"PostGIS-modulen är en utökning av PostgreSQL-backendservern. Som sådan "
"<emphasis>kräver</emphasis> PostGIS & last_release_version; full "
"tillgång till PostgreSQL-serverhuvud för att kunna kompilera. Det kan byggas "
"mot PostgreSQL-versioner &min_postgres_version; - "
@@ -9039,16 +9039,16 @@ msgstr ""
"Tilläggstabellerna <varname>spatial_ref_sys</varname>, <varname>layer</"
"varname>, <varname>topology</varname> kan inte uttryckligen "
"säkerhetskopieras. De kan bara säkerhetskopieras när respektive "
-"<varname>postgis-</varname> eller <varname>postgis_topology-tillägg</"
-"varname> säkerhetskopieras, vilket bara verkar hända när du "
+"<varname>postgis-</varname> eller <varname>postgis_topology</varname>-"
+"utökningen säkerhetskopieras, vilket bara verkar hända när du "
"säkerhetskopierar hela databasen. Från och med PostGIS 2.0.1 "
"säkerhetskopieras endast srid-poster som inte är paketerade med PostGIS när "
"databasen säkerhetskopieras, så gå inte runt och ändra srids som vi "
-"paketerar och förvänta dig att dina ändringar ska finnas där. Lägg in en "
-"biljett om du hittar ett problem. Strukturerna i tilläggstabellerna "
+"paketerar och förvänta dig att dina ändringar ska finnas där. Lägg in ett "
+"ärende om du hittar ett problem. Strukturerna i tilläggstabellerna "
"säkerhetskopieras aldrig eftersom de skapas med <code>CREATE EXTENSION</"
"code> och antas vara desamma för en given version av ett tillägg. Dessa "
-"beteenden är inbyggda i den nuvarande PostgreSQL-förlängningsmodellen, så "
+"beteenden är inbyggda i den nuvarande PostgreSQL-utökningsmodellen, så "
"ingenting vi kan göra åt det."
#. Tag: para
@@ -9061,10 +9061,10 @@ msgid ""
"advised to switch to an extension build before upgrading to PostgreSQL 13."
msgstr ""
"Om du installerade &last_release_version;, utan att använda vårt underbara "
-"förlängningssystem, kan du ändra det till att vara förlängningsbaserat genom "
-"att köra kommandona nedan för att paketera funktionerna i deras respektive "
-"förlängning. Installation med `unpackaged` togs bort i PostgreSQL 13, så du "
-"rekommenderas att byta till en tilläggsbyggnad innan du uppgraderar till "
+"utökningssystem, kan du ändra det till att vara utökningsbaserat genom att "
+"köra kommandona nedan för att paketera funktionerna i deras respektive "
+"utökning. Installation med `unpackaged` togs bort i PostgreSQL 13, så du "
+"rekommenderas att byta till en utökningsbyggnad innan du uppgraderar till "
"PostgreSQL 13."
#. Tag: title
@@ -9347,7 +9347,7 @@ msgstr ""
"<filename>share/extension/postgis_tiger_geocoder.*</filename> från paketen i "
"avsnittet <link xlink:href=\"http://postgis.net/windows_downloads/\">Windows "
"Unreleased Versions</link> för din version av PostgreSQL. Även om dessa "
-"paket är för Windows, kommer postgis_tiger_geocoder-förlängningsfilerna att "
+"paket är för Windows, kommer postgis_tiger_geocoder-utökningsfilerna att "
"fungera på alla operativsystem eftersom tillägget endast är ett SQL / "
"plpgsql-tillägg."
@@ -9957,8 +9957,8 @@ msgid ""
"Victoria, British Columbia, Canada, specializing in data integration and "
"custom software development."
msgstr ""
-"PostGIS är en spatial förlängning för PostgreSQL relationsdatabas som "
-"skapades av Refractions Research Inc, som ett forskningsprojekt för spatial "
+"PostGIS är en spatial utökning för PostgreSQL relationsdatabas som skapades "
+"av Refractions Research Inc, som ett forskningsprojekt för spatial "
"databasteknik. Refractions är ett GIS- och databaskonsultföretag i Victoria, "
"British Columbia, Kanada, som specialiserat sig på dataintegration och "
"anpassad mjukvaruutveckling."
@@ -11339,11 +11339,11 @@ msgid ""
msgstr ""
"Nuvarande PostgreSQL-versioner (inklusive 9.6) lider av en svaghet i "
"frågeoptimeraren angående TOAST-tabeller. TOAST-tabeller är ett slags "
-"\"förlängningsrum\" som används för att lagra stora (i betydelsen "
-"datastorlek) värden som inte passar in på normala datasidor (som långa "
-"texter, bilder eller komplexa geometrier med många hörn), se <link "
-"xlink:href=\"http://www.postgresql.org/docs/current/static/storage-toast."
-"html\">PostgreSQL-dokumentationen för TOAST</link> för mer information)."
+"\"utökningsrum\" som används för att lagra stora (i betydelsen datastorlek) "
+"värden som inte passar in på normala datasidor (som långa texter, bilder "
+"eller komplexa geometrier med många hörn), se <link xlink:href=\"http://www."
+"postgresql.org/docs/current/static/storage-toast.html\">PostgreSQL-"
+"dokumentationen för TOAST</link> för mer information)."
#. Tag: para
#, no-c-format
@@ -11624,9 +11624,9 @@ msgid ""
"PostGIS includes support for GiST-based R-Tree spatial indexes, and "
"functions for analysis and processing of GIS objects."
msgstr ""
-"PostGIS är en förlängning av <link xlink:href=\"https://www.postgresql.org/\""
+"PostGIS är en utökning till <link xlink:href=\"https://www.postgresql.org/\""
">PostgreSQL-objektrelationsdatabassystemet</link> som gör att GIS-objekt ("
-"Geographic Information Systems) kan lagras i databasen. PostGIS inkluderar "
+"geografiska informationssystem) kan lagras i databasen. PostGIS inkluderar "
"stöd för GiST-baserade R-Tree spatiala index och funktioner för analys och "
"bearbetning av GIS-objekt."
@@ -43890,7 +43890,7 @@ msgid ""
"ST_IsValid. The flag is a PostGIS extension."
msgstr ""
"Varken OGC-SFS eller SQL-MM-specifikationerna innehåller ett flaggargument "
-"för ST_IsValid. Flaggan är en PostGIS-förlängning."
+"för ST_IsValid. Flaggan är en PostGIS-utökning."
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/sv/postgis-manual.po | 48 ++++++++++++++++++++++-----------------------
1 file changed, 24 insertions(+), 24 deletions(-)
hooks/post-receive
