[SCM] PostGIS branch master updated. 3.5.0-404-g4e4b425e2
Mon Jun 16 14:10:52 PDT 2025
the project "PostGIS".
       via  4e4b425e2b156632355903967e46595eb059955f (commit)
       via  f0682757859dc94d28811a9cdbd11f2db8c04961 (commit)
       via  f531fb328fb4cf4d03940d5749220a46afd16ed1 (commit)
      from  13549324f0bb8fd62960eb4c57385d4d8688ffc2 (commit)
revisions in full, below.
commit 4e4b425e2b156632355903967e46595eb059955f
Merge: 13549324f f06827578
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Jun 16 17:09:18 2025 -0400
    Closes https://git.osgeo.org/gitea/postgis/postgis/pulls/254
    for PostGIS 3.6.0
commit f0682757859dc94d28811a9cdbd11f2db8c04961
Date:   Mon Jun 16 15:47:40 2025 -0400
    Remove CG_Extrude_Straight_Skeleton from garden exclusion list
diff --git a/doc/xsl/sfcgal_gardentest.sql.xsl b/doc/xsl/sfcgal_gardentest.sql.xsl
index 819fd6733..5cd41b796 100644
--- a/doc/xsl/sfcgal_gardentest.sql.xsl
+++ b/doc/xsl/sfcgal_gardentest.sql.xsl
@@ -13,7 +13,7 @@
 	<xsl:output method="text" />
 	<xsl:variable name='testversion'>3.6.0</xsl:variable>
 	<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
-	<xsl:variable name='fnexclude'>CG_ExtrudeStraightSkeleton CG_Simplify CG_Visibility CG_YMonotonePartition ST_AlphaShape ST_OptimalAlphaShape</xsl:variable>
+	<xsl:variable name='fnexclude'>CG_Simplify CG_Visibility CG_YMonotonePartition ST_AlphaShape ST_OptimalAlphaShape</xsl:variable>
 	<!--This is just a place holder to state functions not supported or tested separately -->
 	<xsl:variable name='var_srid'>3395</xsl:variable>
commit f531fb328fb4cf4d03940d5749220a46afd16ed1
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Fri Jun 6 09:23:41 2025 +0200
    fix(StraightSkeleton): CG_ExtrudeStraightSkeleton returns PolyhedralSurface Empty and doesno'tchrash anymore
diff --git a/sfcgal/lwgeom_sfcgal.c b/sfcgal/lwgeom_sfcgal.c
index e55c36b62..b50a10c43 100644
--- a/sfcgal/lwgeom_sfcgal.c
+++ b/sfcgal/lwgeom_sfcgal.c
@@ -1129,6 +1129,8 @@ sfcgal_extrudestraightskeleton(PG_FUNCTION_ARGS)
 	    POSTGIS_SFCGAL_VERSION);
 	PG_RETURN_NULL();
 #else /* POSTGIS_SFCGAL_VERSION >= 10500 */
 	GSERIALIZED *input, *output;
 	sfcgal_geometry_t *geom;
 	sfcgal_geometry_t *result;
@@ -1139,6 +1141,18 @@ sfcgal_extrudestraightskeleton(PG_FUNCTION_ARGS)
 	input = PG_GETARG_GSERIALIZED_P(0);
 	srid = gserialized_get_srid(input);
+#if POSTGIS_SFCGAL_VERSION < 20200
+	if (gserialized_is_empty(input))
+		result = sfcgal_polyhedral_surface_create();
+		output = SFCGALGeometry2POSTGIS(result, 0, srid);
+		sfcgal_geometry_delete(result);
+		PG_FREE_IF_COPY(input, 0);
+		PG_RETURN_POINTER(output);
+#endif
 	geom = POSTGIS2SFCGALGeometry(input);
diff --git a/sfcgal/regress/extrudestraigthskeleton.sql b/sfcgal/regress/extrudestraigthskeleton.sql
index 434654a04..11d12dbf4 100644
--- a/sfcgal/regress/extrudestraigthskeleton.sql
+++ b/sfcgal/regress/extrudestraigthskeleton.sql
@@ -39,3 +39,5 @@ SELECT
   test_result
 FROM
   check_patches;
+SELECT 'Empty building and roof', ST_AsText(CG_ExtrudeStraightSkeleton(ST_GeomFromText('POLYGON EMPTY',4326), 20.1, 20.1));
+SELECT 'Empty roof', ST_AsText(CG_ExtrudeStraightSkeleton(ST_GeomFromText('POLYGON EMPTY',4326), 20.1));
diff --git a/sfcgal/regress/extrudestraigthskeleton_expected b/sfcgal/regress/extrudestraigthskeleton_expected
index 840482c1d..8a8ac4ddc 100644
--- a/sfcgal/regress/extrudestraigthskeleton_expected
+++ b/sfcgal/regress/extrudestraigthskeleton_expected
@@ -1,2 +1,4 @@
 Extrude roof|POLYHEDRALSURFACE Z (((4 5 0,5 5 0,4 4 0,4 5 0)),((2 1 0,5 0 0,0 0 0,2 1 0)),((5 5 0,5 0 0,4 4 0,5 5 0)),((2 1 0,0 0 0,1 1 0,2 1 0)),((1 2 0,1 1 0,0 0 0,1 2 0)),((0 4 0,2 2 0,1 2 0,0 4 0)),((0 4 0,1 2 0,0 0 0,0 4 0)),((4 4 0,5 0 0,2 2 0,4 4 0)),((4 4 0,2 2 0,0 4 0,4 4 0)),((2 2 0,5 0 0,2 1 0,2 2 0)),((0.5 2.5 0.5,0 0 0,0.5 0.5 0.5,0.5 2.5 0.5)),((1 3 1,0 4 0,0.5 2.5 0.5,1 3 1)),((0.5 2.5 0.5,0 4 0,0 0 0,0.5 2.5 0.5)),((2.5 0.5 0.5,5 0 0,3.5 1.5 1.5,2.5 0.5 0.5)),((0 0 0,5 0 0,2.5 0.5 0.5,0 0 0)),((0.5 0.5 0.5,0 0 0,2.5 0.5 0.5,0.5 0.5 0.5)),((4.5 3.5 0.5,5 5 0,4.5 4.5 0.5,4.5 3.5 0.5)),((3.5 2.5 1.5,3.5 1.5 1.5,4.5 3.5 0.5,3.5 2.5 1.5)),((4.5 3.5 0.5,5 0 0,5 5 0,4.5 3.5 0.5)),((3.5 1.5 1.5,5 0 0,4.5 3.5 0.5,3.5 1.5 1.5)),((5 5 0,4 5 0,4.5 4.5 0.5,5 5 0)),((4.5 4.5 0.5,4 4 0,4.5 3.5 0.5,4.5 4.5 0.5)),((4.5 4.5 0.5,4 5 0,4 4 0,4.5 4.5 0.5)),((3 3 1,0 4 0,1 3 1,3 3 1)),((3.5 2.5 1.5,4.5 3.5 0.5,3 3 1,3.5 2.5 1.5)),((3 3 1,4 4 0,0 4 0,3 3 1)),((4.5 3.5 0.5,4 4 0,3 3 1,4.5 3
 .5 0.5)),((2 1 0,1 1 0,0.5 0.5 0.5,2 1 0)),((2.5 0.5 0.5,2 1 0,0.5 0.5 0.5,2.5 0.5 0.5)),((1 1 0,1 2 0,0.5 2.5 0.5,1 1 0)),((0.5 0.5 0.5,1 1 0,0.5 2.5 0.5,0.5 0.5 0.5)),((1 3 1,2 2 0,3 3 1,1 3 1)),((0.5 2.5 0.5,1 2 0,1 3 1,0.5 2.5 0.5)),((1 3 1,1 2 0,2 2 0,1 3 1)),((2 2 0,2 1 0,2.5 0.5 0.5,2 2 0)),((3.5 2.5 1.5,3 3 1,3.5 1.5 1.5,3.5 2.5 1.5)),((3.5 1.5 1.5,2 2 0,2.5 0.5 0.5,3.5 1.5 1.5)),((3 3 1,2 2 0,3.5 1.5 1.5,3 3 1)))
 Extrude building and roof|t
+Empty building and roof|POLYHEDRALSURFACE EMPTY
+Empty roof|POLYHEDRALSURFACE EMPTY
Summary of changes:
 doc/xsl/sfcgal_gardentest.sql.xsl               |  2 +-
 sfcgal/lwgeom_sfcgal.c                          | 14 ++++++++++++++
 sfcgal/regress/extrudestraigthskeleton.sql      |  2 ++
 sfcgal/regress/extrudestraigthskeleton_expected |  2 ++
 4 files changed, 19 insertions(+), 1 deletion(-)
hooks/post-receive
