[SCM] PostGIS branch stable-3.5 updated. 3.5.3-20-g4ca710549
git at osgeo.org
git at osgeo.org
Tue Jun 17 08:38:26 PDT 2025
the project "PostGIS".
The branch, stable-3.5 has been updated
via 4ca710549d93933ff07d5fc5833abb7842f80cd2 (commit)
via d15a2bdaf8c24bb0c7ce40957df559eec7536164 (commit)
via c3e4a53d906a723f9ce89b06611341ea52321746 (commit)
from 0967ea906a7632b8a763216e159b015df0e6cccb (commit)
revisions in full, below.
commit 4ca710549d93933ff07d5fc5833abb7842f80cd2
Author: Regina Obe <lr at pcorp.us>
Date: Mon Jun 16 17:47:15 2025 -0400
Make extrude straight skeleton test version agnostic
diff --git a/sfcgal/regress/extrudestraigthskeleton.sql b/sfcgal/regress/extrudestraigthskeleton.sql
index bc16f0e61..11d12dbf4 100644
--- a/sfcgal/regress/extrudestraigthskeleton.sql
+++ b/sfcgal/regress/extrudestraigthskeleton.sql
@@ -1,4 +1,43 @@
SELECT 'Extrude roof', ST_AsText(CG_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 2.0));
-SELECT 'Extrude building and roof', ST_AsText(CG_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 3.0, 2.0));
+WITH
+ version_info AS (
+ -- The result depends on the SFCGAL Version.
+ -- Prior to version 2.2, it contained extra patches.
+ SELECT
+ string_to_array(postgis_sfcgal_version (), '.')::INT[] AS sfcgal_version_array
+ skeleton AS (
+ SELECT
+ ST_NumPatches (
+ CG_ExtrudeStraightSkeleton (
+ 'POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))',
+ 3.0,
+ 2.0
+ ) AS num_patches
+ check_patches AS (
+ SELECT
+ sfcgal_version_array,
+ num_patches,
+ sfcgal_version_array <= ARRAY[2, 1, 0]
+ AND num_patches = 49
+ OR (
+ sfcgal_version_array > ARRAY[2, 1, 0]
+ AND num_patches = 39
+ ) AS test_result
+ FROM
+ skeleton,
+ version_info
+SELECT
+ 'Extrude building and roof',
+ test_result
+FROM
+ check_patches;
SELECT 'Empty building and roof', ST_AsText(CG_ExtrudeStraightSkeleton(ST_GeomFromText('POLYGON EMPTY',4326), 20.1, 20.1));
SELECT 'Empty roof', ST_AsText(CG_ExtrudeStraightSkeleton(ST_GeomFromText('POLYGON EMPTY',4326), 20.1));
diff --git a/sfcgal/regress/extrudestraigthskeleton_expected b/sfcgal/regress/extrudestraigthskeleton_expected
index 9234a7cb8..8a8ac4ddc 100644
--- a/sfcgal/regress/extrudestraigthskeleton_expected
+++ b/sfcgal/regress/extrudestraigthskeleton_expected
@@ -1,4 +1,4 @@
Extrude roof|POLYHEDRALSURFACE Z (((4 5 0,5 5 0,4 4 0,4 5 0)),((2 1 0,5 0 0,0 0 0,2 1 0)),((5 5 0,5 0 0,4 4 0,5 5 0)),((2 1 0,0 0 0,1 1 0,2 1 0)),((1 2 0,1 1 0,0 0 0,1 2 0)),((0 4 0,2 2 0,1 2 0,0 4 0)),((0 4 0,1 2 0,0 0 0,0 4 0)),((4 4 0,5 0 0,2 2 0,4 4 0)),((4 4 0,2 2 0,0 4 0,4 4 0)),((2 2 0,5 0 0,2 1 0,2 2 0)),((0.5 2.5 0.5,0 0 0,0.5 0.5 0.5,0.5 2.5 0.5)),((1 3 1,0 4 0,0.5 2.5 0.5,1 3 1)),((0.5 2.5 0.5,0 4 0,0 0 0,0.5 2.5 0.5)),((2.5 0.5 0.5,5 0 0,3.5 1.5 1.5,2.5 0.5 0.5)),((0 0 0,5 0 0,2.5 0.5 0.5,0 0 0)),((0.5 0.5 0.5,0 0 0,2.5 0.5 0.5,0.5 0.5 0.5)),((4.5 3.5 0.5,5 5 0,4.5 4.5 0.5,4.5 3.5 0.5)),((3.5 2.5 1.5,3.5 1.5 1.5,4.5 3.5 0.5,3.5 2.5 1.5)),((4.5 3.5 0.5,5 0 0,5 5 0,4.5 3.5 0.5)),((3.5 1.5 1.5,5 0 0,4.5 3.5 0.5,3.5 1.5 1.5)),((5 5 0,4 5 0,4.5 4.5 0.5,5 5 0)),((4.5 4.5 0.5,4 4 0,4.5 3.5 0.5,4.5 4.5 0.5)),((4.5 4.5 0.5,4 5 0,4 4 0,4.5 4.5 0.5)),((3 3 1,0 4 0,1 3 1,3 3 1)),((3.5 2.5 1.5,4.5 3.5 0.5,3 3 1,3.5 2.5 1.5)),((3 3 1,4 4 0,0 4 0,3 3 1)),((4.5 3.5 0.5,4 4 0,3 3 1,4.5 3
.5 0.5)),((2 1 0,1 1 0,0.5 0.5 0.5,2 1 0)),((2.5 0.5 0.5,2 1 0,0.5 0.5 0.5,2.5 0.5 0.5)),((1 1 0,1 2 0,0.5 2.5 0.5,1 1 0)),((0.5 0.5 0.5,1 1 0,0.5 2.5 0.5,0.5 0.5 0.5)),((1 3 1,2 2 0,3 3 1,1 3 1)),((0.5 2.5 0.5,1 2 0,1 3 1,0.5 2.5 0.5)),((1 3 1,1 2 0,2 2 0,1 3 1)),((2 2 0,2 1 0,2.5 0.5 0.5,2 2 0)),((3.5 2.5 1.5,3 3 1,3.5 1.5 1.5,3.5 2.5 1.5)),((3.5 1.5 1.5,2 2 0,2.5 0.5 0.5,3.5 1.5 1.5)),((3 3 1,2 2 0,3.5 1.5 1.5,3 3 1)))
-Extrude building and roof|POLYHEDRALSURFACE Z (((0 0 0,0 4 0,4 4 0,4 5 0,5 5 0,5 0 0,0 0 0),(1 1 0,2 1 0,2 2 0,1 2 0,1 1 0)),((0 0 0,0 0 2,0 4 2,0 4 0,0 0 0)),((0 4 0,0 4 2,4 4 2,4 4 0,0 4 0)),((4 4 0,4 4 2,4 5 2,4 5 0,4 4 0)),((4 5 0,4 5 2,5 5 2,5 5 0,4 5 0)),((5 5 0,5 5 2,5 0 2,5 0 0,5 5 0)),((5 0 0,5 0 2,0 0 2,0 0 0,5 0 0)),((1 1 0,1 1 2,2 1 2,2 1 0,1 1 0)),((2 1 0,2 1 2,2 2 2,2 2 0,2 1 0)),((2 2 0,2 2 2,1 2 2,1 2 0,2 2 0)),((1 2 0,1 2 2,1 1 2,1 1 0,1 2 0)),((4 5 2,5 5 2,4 4 2,4 5 2)),((2 1 2,5 0 2,0 0 2,2 1 2)),((5 5 2,5 0 2,4 4 2,5 5 2)),((2 1 2,0 0 2,1 1 2,2 1 2)),((1 2 2,1 1 2,0 0 2,1 2 2)),((0 4 2,2 2 2,1 2 2,0 4 2)),((0 4 2,1 2 2,0 0 2,0 4 2)),((4 4 2,5 0 2,2 2 2,4 4 2)),((4 4 2,2 2 2,0 4 2,4 4 2)),((2 2 2,5 0 2,2 1 2,2 2 2)),((0.5 2.5 2.5,0 0 2,0.5 0.5 2.5,0.5 2.5 2.5)),((1 3 3,0 4 2,0.5 2.5 2.5,1 3 3)),((0.5 2.5 2.5,0 4 2,0 0 2,0.5 2.5 2.5)),((2.5 0.5 2.5,5 0 2,3.5 1.5 3.5,2.5 0.5 2.5)),((0 0 2,5 0 2,2.5 0.5 2.5,0 0 2)),((0.5 0.5 2.5,0 0 2,2.5 0.5 2.5,0.5 0.5 2.5)),((4.5
3.5 2.5,5 5 2,4.5 4.5 2.5,4.5 3.5 2.5)),((3.5 2.5 3.5,3.5 1.5 3.5,4.5 3.5 2.5,3.5 2.5 3.5)),((4.5 3.5 2.5,5 0 2,5 5 2,4.5 3.5 2.5)),((3.5 1.5 3.5,5 0 2,4.5 3.5 2.5,3.5 1.5 3.5)),((5 5 2,4 5 2,4.5 4.5 2.5,5 5 2)),((4.5 4.5 2.5,4 4 2,4.5 3.5 2.5,4.5 4.5 2.5)),((4.5 4.5 2.5,4 5 2,4 4 2,4.5 4.5 2.5)),((3 3 3,0 4 2,1 3 3,3 3 3)),((3.5 2.5 3.5,4.5 3.5 2.5,3 3 3,3.5 2.5 3.5)),((3 3 3,4 4 2,0 4 2,3 3 3)),((4.5 3.5 2.5,4 4 2,3 3 3,4.5 3.5 2.5)),((2 1 2,1 1 2,0.5 0.5 2.5,2 1 2)),((2.5 0.5 2.5,2 1 2,0.5 0.5 2.5,2.5 0.5 2.5)),((1 1 2,1 2 2,0.5 2.5 2.5,1 1 2)),((0.5 0.5 2.5,1 1 2,0.5 2.5 2.5,0.5 0.5 2.5)),((1 3 3,2 2 2,3 3 3,1 3 3)),((0.5 2.5 2.5,1 2 2,1 3 3,0.5 2.5 2.5)),((1 3 3,1 2 2,2 2 2,1 3 3)),((2 2 2,2 1 2,2.5 0.5 2.5,2 2 2)),((3.5 2.5 3.5,3 3 3,3.5 1.5 3.5,3.5 2.5 3.5)),((3.5 1.5 3.5,2 2 2,2.5 0.5 2.5,3.5 1.5 3.5)),((3 3 3,2 2 2,3.5 1.5 3.5,3 3 3)))
+Extrude building and roof|t
Empty building and roof|POLYHEDRALSURFACE EMPTY
Empty roof|POLYHEDRALSURFACE EMPTY
commit d15a2bdaf8c24bb0c7ce40957df559eec7536164
Date: Mon Jun 16 17:25:04 2025 -0400
Add garden test, and use stable branch for pg17
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 2c22795eb..7c042da6d 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -17,7 +17,7 @@ jobs:
matrix:
ci:
# Use the last stable releases to run more tests
- - { tag: pg17-geosmain-gdal39-proj94, mode: coverage }
+ - { tag: pg17-geos313-gdal39-proj94, mode: coverage }
- { tag: pg16-geos312-gdal37-proj921, mode: coverage }
- { tag: pg15-geos311-gdal35-proj90, mode: coverage }
- { tag: pg15-clang-geos311-gdal35-proj90, mode: usan_clang }
@@ -30,6 +30,7 @@ jobs:
- { tag: pg13-clang-geos39-gdal31-proj71, mode: usan_clang }
# Run tests with different dependency combinations
- { tag: latest, mode: tests }
+ - { tag: pg17-geos313-gdal39-proj94, mode: garden }
- { tag: pg13-geos38-gdal31-proj71, mode: tests }
- { tag: pg12-geos38-gdal30-proj611, mode: tests }
index dab998cef..9234a7cb8 100644
@@ -1,4 +1,4 @@
-Empty roof|POLYHEDRALSURFACE EMPTY
\ No newline at end of file
+Empty roof|POLYHEDRALSURFACE EMPTY
commit c3e4a53d906a723f9ce89b06611341ea52321746
Date: Mon Jun 16 17:19:34 2025 -0400
Fix for CG_ExtrudeStraightSkeleton closes #5923 for PostGIS 3.5.4
diff --git a/NEWS b/NEWS
index 468fcf76c..5e40ae47d 100644
--- a/NEWS
+++ b/NEWS
@@ -13,6 +13,7 @@ PostgreSQL 12-18 required. GEOS 3.8+ required. Proj 6.1+ required.
- #5905, Crash on deeply nested geometries (Paul Ramsey)
- #5909, ST_ValueCount crashes on empty table (Paul Ramsey)
- #5917, ST_Relate becomes unresponsive (Paul Ramsey)
+- #5923, CG_ExtrudeStraightSkeleton crashes on empty polygon (Loïc Bartoletti)
PostGIS 3.5.3
diff --git a/sfcgal/lwgeom_sfcgal.c b/sfcgal/lwgeom_sfcgal.c
index c091acadb..b59ec5b10 100644
--- a/sfcgal/lwgeom_sfcgal.c
+++ b/sfcgal/lwgeom_sfcgal.c
@@ -1136,6 +1136,17 @@ sfcgal_extrudestraightskeleton(PG_FUNCTION_ARGS)
input = PG_GETARG_GSERIALIZED_P(0);
srid = gserialized_get_srid(input);
+#if POSTGIS_SFCGAL_VERSION < 20200
+ if (gserialized_is_empty(input))
+ result = sfcgal_polyhedral_surface_create();
+ output = SFCGALGeometry2POSTGIS(result, 0, srid);
+ sfcgal_geometry_delete(result);
+ PG_FREE_IF_COPY(input, 0);
+ PG_RETURN_POINTER(output);
+#endif
geom = POSTGIS2SFCGALGeometry(input);
index c0b8df3c1..bc16f0e61 100644
@@ -1,2 +1,4 @@
+SELECT 'Empty building and roof', ST_AsText(CG_ExtrudeStraightSkeleton(ST_GeomFromText('POLYGON EMPTY',4326), 20.1, 20.1));
+SELECT 'Empty roof', ST_AsText(CG_ExtrudeStraightSkeleton(ST_GeomFromText('POLYGON EMPTY',4326), 20.1));
index 0b3805b35..dab998cef 100644
@@ -1,2 +1,4 @@
+Empty building and roof|POLYHEDRALSURFACE EMPTY
Summary of changes:
.github/workflows/ci.yml | 3 +-
NEWS | 1 +
sfcgal/lwgeom_sfcgal.c | 11 +++++++
sfcgal/regress/extrudestraigthskeleton.sql | 43 ++++++++++++++++++++++++-
sfcgal/regress/extrudestraigthskeleton_expected | 4 ++-
5 files changed, 59 insertions(+), 3 deletions(-)
hooks/post-receive
