[PostGIS] #5927: ST_IsCollection throwing exception with large, complex MultiPolygon
trac at osgeo.org
Fri Jun 20 11:42:21 PDT 2025
Reporter: dsavitsky | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.4
Component: postgis | Version: 3.5.x
Keywords: Multipolygon ST_IsCollection |
Steps to reproduce:
1) Insert the attached MultiPolygon into a geometry field of a table.
2) SELECT ST_IsCollection() on that field
ERROR: Invalid subtype (Unknown) for collection type (MultiPolygon)
Exception does not occur in PostGIS 3.4 or 3.1
SELECT ST_IsCollection(ST_MakeValid()) produces a valid result
ST_IsValid() returns true
ST_IsCollection(ST_GeomFromText(<attached>, 4326) produces a valid result,
as does ST_IsCollection('<attached>'::geometry). Exception only occurs
when querying from a table.
GeometryType and ST_GeometryType both return valid results
PostgreSQL 16.8 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 11.5.0
20240719 (Red Hat 11.5.0-5), 64-bit
POSTGIS="3.5.2 dea6d0a" [EXTENSION] PGSQL="160" GEOS="3.13.1-CAPI-1.19.2"
PROJ="9.5.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/home/postgres/.local/share/proj
DATABASE_PATH=/usr/proj95/share/proj/proj.db" (compiled against PROJ
9.5.1) LIBXML="2.9.13" LIBJSON="0.14" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
(Internal)"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5927>
