[PostGIS] #5935: GHA latest failing on GDAL 3.12dev with deprecated notice
PostGIS trac at osgeo.org
Mon Jun 30 20:57:18 PDT 2025
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.6.0
Component:  raster   |    Version:  3.5.x
 Keywords:           |
 -------------- Dependencies --------------
   GEOS config:          /usr/bin/pkg-config geos
   GEOS version:         3.14.0dev (31400)
   GDAL config:          /usr/local/bin/gdal-config
   GDAL version:         3.12.0dev (31200)
   SFCGAL config:        /usr/local/bin/sfcgal-config
   SFCGAL version:       2.2.0
   PostgreSQL config:    /usr/local/pgsql/bin/pg_config
   PostgreSQL version:   PostgreSQL 18beta1
   PROJ version:         9.7.0 (90700)
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.9.14
   JSON-C support:       yes
   protobuf support:     yes
   protobuf-c version:   1004001
   PCRE support:         Version 1
   Perl:                 /usr/bin/perl
 rm -f rtpostgis_upgrade_cleanup.sql.tmp
 echo 'BEGIN;' > rtpostgis_upgrade.sql
 cat ../../postgis/common_before_upgrade.sql rtpostgis_upgrade_cleanup.sql
 rtpostgis_upgrade.sql.in rtpostgis_drop.sql
 ../../postgis/common_after_upgrade.sql | sed -e 's/^BEGIN;$//' -e
 's/^COMMIT;$//' >> rtpostgis_upgrade.sql
 echo 'COMMIT;' >> rtpostgis_upgrade.sql
 rtpg_gdal.c: In function 'RASTER_InterpolateRaster':
 rtpg_gdal.c:736:9: error: 'GDALGetDataTypeSize' is deprecated [-Werror
 =deprecated-declarations]
   736 |         in_band_gdaltype_size =
 GDALGetDataTypeSize(in_band_gdaltype) / 8;
 In file included from ./../rt_core/librtcore.h:125,
                  from rtpostgis.h:39,
                  from rtpg_gdal.c:44:
 /usr/local/include/gdal.h:70:25: note: declared here
    70 | int CPL_DLL CPL_STDCALL GDALGetDataTypeSize(GDALDataType)
 cc1: all warnings being treated as errors
 make[3]: *** [<builtin>: rtpg_gdal.o] Error 1
 make[3]: *** Waiting for unfinished jobs....
 make[3]: Leaving directory '/src/postgis/raster/rt_pg'
 make[2]: Leaving directory '/src/postgis/raster'
 make[2]: *** [Makefile:41: pglib] Error 2
 make[1]: *** [Makefile:29: all] Error 2
 make[1]: Leaving directory '/src/postgis/raster'
 make: *** [GNUmakefile:36: all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5935>
