[PostGIS] #5858: dist doc build failing on debbie building docks
    trac at osgeo.org
    Mon Mar  3 09:25:11 PST 2025
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 3.5.3
 Component:  documentation  |    Version:  3.4.x
Resolution:                 |   Keywords:
Comment (by robe):
 okay even without epub, it's broken at least on master
 11:35:01 grep -v '\&postgis_special;' postgis.xml > postgis-
 nospecial.xml.in
 11:35:01 /usr/bin/xmllint --path
 .:/var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/fb7e416b6a4cbf41155af21b23aab281ee6d2d44/doc
 --noent -o postgis-nospecial.xml postgis-nospecial.xml.in
 11:35:01 reference.xml:13: parser error : Entity 'reference_transaction'
 not defined
 11:35:01  &reference_bbox; &reference_lrs; &reference_trajectory;
 &reference_transaction;
 11:35:01
 11:35:01 reference.xml:14: parser error : chunk is not well balanced
 11:35:01
 11:35:01 ^
 11:35:01 postgis-nospecial.xml.in:180: parser error : Entity 'reference'
 failed to parse
 11:35:01   &reference;
 11:35:01              ^
 11:35:01 make[2]: *** [../../Makefile:389: postgis-nospecial.xml] Error 1
 11:35:01 make[2]: Leaving directory
 '/var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/fb7e416b6a4cbf41155af21b23aab281ee6d2d44/doc/po/fr'
 11:35:01 make[1]: *** [../Makefile.local:18: local-html] Error 2
 11:35:01 make[1]: Leaving directory
 11:35:01 make: *** [Makefile:408: html-localized] Error 1
 11:35:01 Build step 'Execute shell' marked build as failure
 11:35:01 [Gitea] do not publish assets due to build being non-Successfully
 11:35:01 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5858#comment:2>
