[SCM] PostGIS branch master updated. 3.5.0-217-g3a8e408ed
    git at osgeo.org
    git at osgeo.org
    Tue Mar  4 02:30:32 PST 2025
the project "PostGIS".
       via  3a8e408edba1ac7a62d29379d70e59267cb24b5f (commit)
       via  4d5979036e1c8bf712f0b278230e8bd4871bf0ea (commit)
      from  fb7e416b6a4cbf41155af21b23aab281ee6d2d44 (commit)
revisions in full, below.
commit 3a8e408edba1ac7a62d29379d70e59267cb24b5f
Author: DeepL <noreply-mt-deepl at weblate.org>
Date:   Tue Mar 4 10:25:42 2025 +0000
    Translated PostGIS Manual using Weblate (French)
    Currently translated at 97.6% (5620 of 5756 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index f08b2ebeb..cf853dd77 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -12,7 +12,7 @@ msgstr ""
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-11-19 11:58+0000\n"
 "PO-Revision-Date: 2025-03-04 10:30+0000\n"
-"Last-Translator: Vincent Bre <vincent.bre at oslandia.com>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/fr/>\n"
 "Language: fr\n"
@@ -8522,7 +8522,7 @@ msgstr ""
 "<link xlink:href=\"http://www.gtk.org/\"> http://www.gtk.org/ </link> ."
 #. Tag: para
-#, fuzzy, no-c-format
+#, no-c-format
 msgid ""
 "SFCGAL, 1.4.1 or higher is required and 1.5.0+ is needed to be able to use "
 "all functionality. SFCGAL can be used to provide additional 2D and 3D "
@@ -10702,7 +10702,7 @@ msgid "David Techer"
 msgstr "David Techer"
 #. Tag: member
+#, no-c-format
 msgid "Dian M Fay"
 msgstr "Dian M Fay"
@@ -16524,6 +16524,9 @@ msgid ""
 "linkend=\"ST_SetSRID\"/> to set the SRID if the given origin has an unknown "
 "SRID (as is the case by default)."
 msgstr ""
+"Les carrés sont générés avec le SRID de l'origine donnée. Utilisez <xref "
+"linkend=\"ST_SetSRID\"/> pour définir le SRID si l'origine donnée a un SRID "
+"inconnu (comme c'est le cas par défaut)."
 #. Tag: title
 #, no-c-format
commit 4d5979036e1c8bf712f0b278230e8bd4871bf0ea
Author: Vincent Bre <vincent.bre at oslandia.com>
Date:   Tue Mar 4 10:26:34 2025 +0000
index ab9e6d0f4..f08b2ebeb 100644
@@ -5,13 +5,14 @@
 # DeepL <noreply-mt-deepl at weblate.org>, 2024, 2025.
 # Edouard Choinière <echoix at users.noreply.weblate.osgeo.org>, 2024.
 # Pierre Cardinal <pierre.cardinal at sympatico.ca>, 2025.
+# Vincent Bre <vincent.bre at oslandia.com>, 2025.
 msgid ""
 msgstr ""
 "Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2025-02-12 02:47+0000\n"
-"Last-Translator: Pierre Cardinal <pierre.cardinal at sympatico.ca>\n"
+"PO-Revision-Date: 2025-03-04 10:30+0000\n"
+"Last-Translator: Vincent Bre <vincent.bre at oslandia.com>\n"
 "Language: fr\n"
@@ -12297,8 +12298,7 @@ msgstr ""
 "&reference_relationship; &reference_measure; &reference_overlay; "
 "&reference_processing; &reference_coverage; &reference_transformation; "
 "&reference_cluster; &reference_bbox; &reference_lrs; &reference_trajectory; "
-"&reference_transaction; &reference_version; &reference_guc; "
-"&reference_troubleshooting;"
+"&reference_version; &reference_guc; &reference_troubleshooting;"
 #. Tag: title
 #, no-c-format
@@ -15685,7 +15685,7 @@ msgstr ""
 "créé."
 #. Tag: para
+#, no-c-format
 msgid ""
 "While not OGC-compliant, <varname>ST_MakePoint</varname> is faster than "
 "<xref linkend=\"ST_GeomFromText\"/> and <xref linkend=\"ST_PointFromText\"/"
Summary of changes:
 doc/po/fr/postgis-manual.po | 17 ++++++++++-------
 1 file changed, 10 insertions(+), 7 deletions(-)
hooks/post-receive
