[SCM] PostGIS branch master updated. 3.5.0-219-gbf715caf8
git at osgeo.org
git at osgeo.org
Tue Mar 4 03:48:01 PST 2025
the project "PostGIS".
via bf715caf808bd2c480a31a5fbebceea8660ff633 (commit)
via 1f437a694faad1e977be297a4e7563e3a1376f6f (commit)
from 3a8e408edba1ac7a62d29379d70e59267cb24b5f (commit)
revisions in full, below.
commit bf715caf808bd2c480a31a5fbebceea8660ff633
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Tue Mar 4 10:49:57 2025 +0000
Translated PostGIS Manual using Weblate (French)
Currently translated at 99.1% (5705 of 5756 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index 7aaaaca09..321a5801d 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -12,7 +12,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-11-19 11:58+0000\n"
"PO-Revision-Date: 2025-03-04 11:47+0000\n"
-"Last-Translator: Vincent Bre <vincent.bre at oslandia.com>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/fr/>\n"
"Language: fr\n"
@@ -18003,6 +18003,8 @@ msgid ""
"Removes points that are irrelevant for rendering a specific rectangular view "
"of a geometry."
msgstr ""
+"Supprime les points qui ne sont pas pertinents pour le rendu d'une vue "
+"rectangulaire spécifique d'une géométrie."
#. Tag: para
#, no-c-format
@@ -18019,6 +18021,8 @@ msgid ""
"This function can be used to quickly preprocess geometries that should be "
"rendered only within certain bounds."
msgstr ""
+"Cette fonction peut être utilisée pour prétraiter rapidement les géométries "
+"qui ne doivent être rendues qu'à l'intérieur de certaines limites."
#. Tag: para
#, no-c-format
@@ -18026,6 +18030,8 @@ msgid ""
"Only geometries of type (MULTI)POLYGON and (MULTI)LINESTRING are evaluated. "
"Other geometries keep unchanged."
msgstr ""
+"Seules les géométries de type (MULTI)POLYGONE et (MULTI)LINESTRING sont "
+"évaluées. Les autres géométries restent inchangées."
#. Tag: para
#, no-c-format
@@ -18038,16 +18044,18 @@ msgid ""
"sorts out points without computing new intersection points which avoids "
"rounding errors and usually increases performance,"
msgstr ""
+"trie les points sans calculer de nouveaux points d'intersection, ce qui "
+"évite les erreurs d'arrondi et augmente généralement les performances,"
#. Tag: para
#, no-c-format
msgid "returns a geometry with equal or similar point number,"
-msgstr ""
+msgstr "renvoie une géométrie dont le nombre de points est égal ou similaire,"
#. Tag: para
#, no-c-format
msgid "leads to the same rendering result within the specified view, and"
-msgstr ""
+msgstr "conduit au même résultat de rendu dans la vue spécifiée, et"
#. Tag: para
#, no-c-format
@@ -18055,6 +18063,8 @@ msgid ""
"may introduce self-intersections which would make the resulting geometry "
"invalid (see example below)."
msgstr ""
+"peut introduire des auto-intersections qui rendraient la géométrie "
+"résultante invalide (voir l'exemple ci-dessous)."
#. Tag: para
#, no-c-format
@@ -18065,6 +18075,12 @@ msgid ""
"introduce rendering artifacts if the resulting coordinates are projected "
"into another (non-cartesian) coordinate system before rendering."
msgstr ""
+"Si <code>cartesian_hint</code> est défini à <code>true</code>, l'algorithme "
+"applique des optimisations supplémentaires impliquant des mathématiques "
+"cartésiennes pour réduire davantage le nombre de points résultant. Veuillez "
+"noter que l'utilisation de cette option peut introduire des artefacts de "
+"rendu si les coordonnées résultantes sont projetées dans un autre système de "
+"coordonnées (non cartésien) avant le rendu."
#. Tag: para
#, no-c-format
@@ -18073,6 +18089,9 @@ msgid ""
"valid. This situation can be checked with <xref linkend=\"ST_IsValid\"/> and "
"repaired with <xref linkend=\"ST_MakeValid\"/>."
msgstr ""
+"Pour les polygones, cette fonction ne garantit pas actuellement que le "
+"résultat est valide. Cette situation peut être vérifiée avec <xref linkend="
+"\"ST_IsValid\"/> et réparée avec <xref linkend=\"ST_MakeValid\"/>."
#. Tag: para
#, no-c-format
@@ -18081,6 +18100,9 @@ msgid ""
"points remain, the rendering result (light-blue area) within the grey view "
"box remains as well."
msgstr ""
+"Exemple : ST_RemoveIrrelevantPointsForView() appliqué à un polygone. Les "
+"points bleus restent, le résultat du rendu (zone bleu clair) à l'intérieur "
+"de la boîte de visualisation grise reste également."
#. Tag: para
#, no-c-format
@@ -18089,6 +18111,9 @@ msgid ""
"are computed, the result of ST_RemoveIrrelevantPointsForView() may contain "
"self-intersections."
msgstr ""
+"Exemple : Étant donné que les points sont simplement triés et qu'aucun "
+"nouveau point n'est calculé, le résultat de "
+"ST_RemoveIrrelevantPointsForView() peut contenir des auto-intersections."
#. Tag: para
#, no-c-format
@@ -18099,6 +18124,7 @@ msgstr ", <xref linkend=\"ST_Intersection\"/>"
#, no-c-format
msgid "Removes small parts (polygon rings or linestrings) of a geometry."
msgstr ""
+"Supprime les petites parties (anneaux de polygone ou lignes) d'une géométrie."
#. Tag: para
#, no-c-format
@@ -18106,6 +18132,8 @@ msgid ""
"Returns a <xref linkend=\"geometry\"/> without small parts (exterior or "
"interior polygon rings, or linestrings)."
msgstr ""
+"Retourne un <xref linkend=\"geometry\"/> sans les petites parties (anneaux "
+"de polygones extérieurs ou intérieurs, ou lignes)."
#. Tag: para
#, no-c-format
@@ -18113,6 +18141,9 @@ msgid ""
"This function can be used as preprocessing step for creating simplified "
"maps, e. g. to remove small islands or holes."
msgstr ""
+"Cette fonction peut être utilisée comme étape de prétraitement pour créer "
+"des cartes simplifiées, par exemple pour supprimer les petites îles ou les "
+"trous."
#. Tag: para
#, no-c-format
@@ -18120,6 +18151,8 @@ msgid ""
"It evaluates only geometries of type (MULTI)POLYGON and (MULTI)LINESTRING. "
"Other geometries remain unchanged."
msgstr ""
+"Il n'évalue que les géométries de type (MULTI)POLYGONE et (MULTI)LINESTRING. "
+"Les autres géométries restent inchangées."
#. Tag: para
#, no-c-format
@@ -18166,7 +18199,7 @@ msgstr "la géométrie d'origine,"
#. Tag: para
#, no-c-format
msgid "a POLYGON with all rings with less vertices,"
-msgstr ""
+msgstr "un POLYGONE avec tous les anneaux ayant moins de sommets,"
#. Tag: para
#, no-c-format
@@ -18180,7 +18213,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "a POLYGON EMPTY, or"
-msgstr ""
+msgstr "un POLYGONE VIDE, ou"
#. Tag: para
#, no-c-format
@@ -18188,6 +18221,8 @@ msgid ""
"a MULTIPOLYGON with a reduced number of polygons (having possibly less "
"interior rings or vertices), or"
msgstr ""
+"un MULTIPOLYGONE avec un nombre réduit de polygones (ayant éventuellement "
+"moins d'anneaux intérieurs ou de sommets), ou"
#. Tag: para
#, no-c-format
@@ -18864,6 +18899,10 @@ msgid ""
"href=\"https://www.postgresql.org/docs/current/sql-altersystem.html\">SQL "
"ALTER SYSTEM</link>"
msgstr ""
+"Pour plus d'exemples d'utilisation, voir <link xlink:href=\"https://www."
+"postgresql.org/docs/current/sql-set.html\">SQL SET</link> et <link "
+"xlink:href=\"https://www.postgresql.org/docs/current/sql-altersystem.html\""
+">SQL ALTER SYSTEM</link>."
#. Tag: refpurpose
#, no-c-format
@@ -19091,11 +19130,15 @@ msgid ""
"To set and reset <varname>postgis.gdal_enabled_drivers</varname> for current "
"session"
msgstr ""
+"Pour définir et réinitialiser <varname>postgis.gdal_enabled_drivers</"
+"varname> pour la session en cours"
#. Tag: para
#, no-c-format
msgid "Set for all new connections to a specific database to specific drivers"
msgstr ""
+"Définir pour toutes les nouvelles connexions à une base de données "
+"spécifique des pilotes spécifiques"
#. Tag: para
#, no-c-format
@@ -19104,6 +19147,10 @@ msgid ""
"user access. Also note that database, session, and user settings override "
"this."
msgstr ""
+"Paramètre pour l'ensemble du cluster de bases de données afin d'activer tous "
+"les pilotes. Nécessite l'accès d'un super utilisateur. Notez également que "
+"les paramètres de la base de données, de la session et de l'utilisateur sont "
+"prioritaires."
#. Tag: para
#, no-c-format
@@ -19181,6 +19228,7 @@ msgstr ""
#, no-c-format
msgid "Set for all new connections to a specific database"
msgstr ""
+"Défini pour toutes les nouvelles connexions à une base de données spécifique"
#. Tag: para
#, no-c-format
@@ -25266,6 +25314,8 @@ msgstr "Les géométries 3D sont prises en charge :"
#, no-c-format
msgid "Options argument can be used to add BBOX and CRS in GeoJSON output:"
msgstr ""
+"L'argument Options peut être utilisé pour ajouter BBOX et CRS dans la sortie "
+"GeoJSON :"
#. Tag: para
#, no-c-format
@@ -29058,6 +29108,9 @@ msgid ""
"Behavior changed in GEOS 3.11 so offset curves now have the same direction "
"as the input line, for both positive and negative offsets."
msgstr ""
+"Comportement modifié dans GEOS 3.11 de sorte que les courbes de décalage ont "
+"désormais la même direction que la ligne d'entrée, tant pour les décalages "
+"positifs que négatifs."
#. Tag: para
#, no-c-format
@@ -31431,7 +31484,7 @@ msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid "Aggregate. Renders PostGIS geometries into a new raster."
-msgstr ""
+msgstr "Aggregate. Rend les géométries PostGIS dans un nouveau raster."
#. Tag: para
#, no-c-format
@@ -31439,17 +31492,20 @@ msgid ""
"Returns a single-band raster containing the rendered version of all incoming "
"geometries, each with its associated value."
msgstr ""
+"Renvoie un raster à bande unique contenant la version rendue de toutes les "
+"géométries entrantes, chacune avec sa valeur associée."
#. Tag: para
#, no-c-format
msgid "Availability: 3.6.0"
-msgstr ""
+msgstr "Disponibilité : 3.6.0"
#. Tag: para
#, no-c-format
msgid ""
", <xref linkend=\"RT_ST_DumpAsPolygons\"/>, <xref linkend=\"RT_ST_Union\"/>"
msgstr ""
+", <xref linkend=\"RT_ST_DumpAsPolygons\"/>, <xref linkend=\"RT_ST_Union\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -41041,6 +41097,8 @@ msgid ""
"In mathematical terms: <emphasis>ST_Touches(A, B) ⇔ (Int(A) ⋂ Int(B) = ∅) ∧ "
"(A ⋂ B ≠ ∅) </emphasis>"
msgstr ""
+"En termes mathématiques : <emphasis>ST_Touches(A, B) ⇔ (Int(A) ⋂ Int(B) = ∅) "
+"∧ (A ⋂ B ≠ ∅). </emphasis>"
#. Tag: para
#, no-c-format
@@ -41651,7 +41709,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "&sqlmm_compliant; SQL-MM IEC 13249-3: 9.1 (same as CG_3DVolume)"
-msgstr ""
+msgstr "&sqlmm_compliant ; SQL-MM IEC 13249-3 : 9.1 (identique à CG_3DVolume)"
#. Tag: para
#, no-c-format
@@ -41661,6 +41719,10 @@ msgid ""
"linkend=\"CG_MakeSolid\"/>. Areal geometries have no volume. Here is an "
"example to demonstrate."
msgstr ""
+"Lorsque des surfaces fermées sont créées avec WKT, elles sont traitées comme "
+"des surfaces aréolaires et non comme des surfaces solides. Pour les rendre "
+"solides, vous devez utiliser <xref linkend=\"CG_MakeSolid\"/>. Les "
+"géométries aréolaires n'ont pas de volume. Voici un exemple de démonstration."
#. Tag: para
#, no-c-format
@@ -42050,7 +42112,7 @@ msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid "Perform 3D union using postgis_sfcgal."
-msgstr ""
+msgstr "Réaliser l'union 3D en utilisant postgis_sfcgal."
#. Tag: para
#, no-c-format
@@ -42175,7 +42237,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "Availability: 3.5.0 - requires SFCGAL >= 1.4.1."
-msgstr ""
+msgstr "Disponibilité : 3.5.0 - nécessite SFCGAL >= 1.4.1."
#. Tag: para
#, no-c-format
@@ -42348,7 +42410,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "CG_ConstrainedDelaunayTriangles of 2 polygons"
-msgstr ""
+msgstr "CG_ConstrainedDelaunayTriangles de 2 polygones"
#. Tag: para
#, no-c-format
@@ -42625,6 +42687,8 @@ msgid ""
"Optimal alpha-shape of a MultiPoint (same example as <xref "
"linkend=\"CG_AlphaShape\"/>)"
msgstr ""
+"Forme alpha optimale d'un MultiPoint (même exemple que <xref linkend="
+"\"CG_AlphaShape\"/>)"
#. Tag: para
#, no-c-format
@@ -42632,6 +42696,8 @@ msgid ""
"Optimal alpha-shape of a MultiPoint, allowing holes (same example as <xref "
msgstr ""
+"Forme alpha optimale d'un MultiPoint, autorisant les trous (même exemple que "
+"<xref linkend=\"CG_AlphaShape\"/>)"
#. Tag: para
#, no-c-format
commit 1f437a694faad1e977be297a4e7563e3a1376f6f
Author: Vincent Bre <vincent.bre at oslandia.com>
Date: Tue Mar 4 11:18:13 2025 +0000
index cf853dd77..7aaaaca09 100644
@@ -11,8 +11,8 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2025-03-04 10:30+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2025-03-04 11:47+0000\n"
+"Last-Translator: Vincent Bre <vincent.bre at oslandia.com>\n"
"Language: fr\n"
@@ -18010,6 +18010,8 @@ msgid ""
"Returns a <xref linkend=\"geometry\"/> without points being irrelevant for "
"rendering the geometry within a given rectangular view."
msgstr ""
+"Renvoie une <xref linkend=\"geometry\"/> sans les points non pertinents pour "
+"le rendu de la géométrie dans une vue rectangulaire donnée."
#. Tag: para
#, no-c-format
@@ -18125,6 +18127,8 @@ msgid ""
"If <parameter>minSizeX</parameter> is greater than 0, parts are sorted out "
"if their width is smaller than <parameter>minSizeX</parameter>."
msgstr ""
+"Si <parameter>minSizeX</parameter> est supérieur à 0, les parties sont "
+"triées si leur largeur est inférieure à <parameter>minSizeX</parameter>."
#. Tag: para
#, no-c-format
@@ -18132,6 +18136,8 @@ msgid ""
"If <parameter>minSizeY</parameter> is greater than 0, parts are sorted out "
"if their height is smaller than <parameter>minSizeY</parameter>."
msgstr ""
+"Si <parameter>minSizeY</parameter> est supérieur à 0, les parties sont "
+"triées si leur hauteur est inférieure à <parameter>minSizeY</parameter>."
#. Tag: para
#, no-c-format
@@ -18139,6 +18145,9 @@ msgid ""
"Both <parameter>minSizeX</parameter> and <parameter>minSizeY</parameter> are "
"measured in coordinate system units of the geometry."
msgstr ""
+"Les deux paramètres, <parameter>minSizeX</parameter> et <parameter>minSizeY</"
+"parameter> sont mesurés dans les unités du système de coordonnées de la "
+"géométrie."
#. Tag: para
#, no-c-format
@@ -18146,6 +18155,8 @@ msgid ""
"For polygon types, evaluation is done separately for each ring which can "
"lead to one of the following results:"
msgstr ""
+"Pour les objets de type polygone, l'évaluation est effectuée séparément pour "
+"chaque anneau, ce qui peut conduire à l'un des résultats suivants :"
#. Tag: para
#, no-c-format
@@ -18163,6 +18174,8 @@ msgid ""
"a POLYGON with a reduced number of interior rings (having possibly less "
"vertices),"
msgstr ""
+"un POLYGONE avec un nombre réduit d'anneaux intérieurs (ayant éventuellement "
+"moins de sommets),"
#. Tag: para
#, no-c-format
@@ -18179,7 +18192,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "a MULTIPOLYGON EMPTY."
-msgstr ""
+msgstr "un MULTIPOLYGONE VIDE."
#. Tag: para
#, no-c-format
@@ -18187,16 +18200,18 @@ msgid ""
"For linestring types, evaluation is done for each linestring which can lead "
"to one of the following results:"
msgstr ""
+"Pour les types linestring l'évaluation est effectuée pour chaque ligne, ce "
+"qui peut conduire à l'un des résultats suivants :"
#. Tag: para
#, no-c-format
msgid "a LINESTRING with a reduced number of vertices,"
-msgstr ""
+msgstr "une LINESTRING avec un nombre réduit de sommets,"
#. Tag: para
#, no-c-format
msgid "a LINESTRING EMPTY,"
-msgstr ""
+msgstr "une LINESTRING VIDE,"
#. Tag: para
#, no-c-format
@@ -18204,17 +18219,21 @@ msgid ""
"a MULTILINESTRING with a reduced number of linestrings (having possibly less "
"vertices), or"
msgstr ""
+"une MULTILINESTRING avec un nombre réduit de lignes (ayant éventuellement "
+"moins de sommets), ou"
#. Tag: para
#, no-c-format
msgid "a MULTILINESTRING EMPTY."
-msgstr ""
+msgstr "une MULTILINESTRING VIDE."
#. Tag: para
#, no-c-format
msgid ""
"Example: ST_RemoveSmallParts() applied to a multi-polygon. Blue parts remain."
msgstr ""
+"Exemple : ST_RemoveSmallParts() appliqué à un multi-polygone. Les parties "
+"bleues sont conservées."
#. Tag: refpurpose
#, no-c-format
@@ -19169,6 +19188,9 @@ msgid ""
"Setting for whole database cluster. Requires super user access. Also note "
"that database, session, and user settings override this."
msgstr ""
+"Paramètre pour l'ensemble du cluster de bases de données. Nécessite l'accès "
+"d'un super-utilisateur. Notez également que les paramètres de la base de "
+"données, de la session et de l'utilisateur sont prioritaires."
#. Tag: refpurpose
#, no-c-format
@@ -22120,6 +22142,10 @@ msgid ""
"web.archive.org/web/20160827203903/http://boundlessgeo.com/2012/07/making-"
"geography-faster/\">Making Geography faster</link> for details."
msgstr ""
+"Amélioration : la version 2.1.0 a amélioré la vitesse pour le type "
+"geography. Voir <link xlink:href=\"https://web.archive.org/web/"
+"20160827203903/http://boundlessgeo.com/2012/07/making-geography-faster/\""
+">Making Geography faster</link> pour plus de détails."
#. Tag: para
#, no-c-format
@@ -33089,6 +33115,13 @@ msgid ""
"linkend=\"ST_MakeEnvelope\"/>, <xref linkend=\"ST_Intersects\"/>, <xref "
"linkend=\"ST_Intersection\"/>"
msgstr ""
+", <xref linkend=\"RT_ST_SetValue\"/>, <xref linkend=\"RT_ST_DumpAsPolygons\"/"
+">, <xref linkend=\"RT_ST_NumBands\"/>, <xref linkend=\"RT_ST_PixelAsPolygon\""
+"/>, <xref linkend=\"RT_ST_ScaleX\"/>, <xref linkend=\"RT_ST_ScaleY\"/>, "
+"<xref linkend=\"RT_ST_UpperLeftX\"/>, <xref linkend=\"RT_ST_UpperLeftY\"/>, "
+"<xref linkend=\"RT_ST_SRID\"/>, <xref linkend=\"ST_AsText\"/>, <xref linkend="
+"\"ST_Point\"/>, <xref linkend=\"ST_MakeEnvelope\"/>, <xref linkend="
+"\"ST_Intersects\"/>, <xref linkend=\"ST_Intersection\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -35397,6 +35430,12 @@ msgid ""
"varname> is set to TRUE, then touched pixels are included, otherwise only if "
"the center of the pixel is in the geometry it is included."
msgstr ""
+"Renvoie le raster découpé par la géométrie d'entrée. Si le numéro de bande "
+"n'est pas spécifié, toutes les bandes sont traitées. Si <varname>crop</"
+"varname> n'est pas spécifié ou est TRUE, le raster de sortie est rogné. Si "
+"<varname>touched</varname> est défini sur TRUE, les pixels touchés sont "
+"inclus, sinon seulement si le centre du pixel est dans la géométrie, il est "
+"inclus."
#. Tag: para
#, no-c-format
@@ -38364,6 +38403,8 @@ msgid ""
", <xref linkend=\"RT_ST_AsRasterAgg\"/>, <xref linkend=\"RT_ST_Value\"/>, "
"<xref linkend=\"RT_ST_Polygon\"/>, <xref linkend=\"RT_ST_ValueCount\"/>"
msgstr ""
+", <xref linkend=\"RT_ST_AsRasterAgg\"/>, <xref linkend=\"RT_ST_Value\"/>, "
+"<xref linkend=\"RT_ST_Polygon\"/>, <xref linkend=\"RT_ST_ValueCount\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -41595,6 +41636,8 @@ msgid ""
", <xref linkend=\"CG_MakeSolid\"/>, <xref linkend=\"CG_IsSolid\"/>, <xref "
"linkend=\"CG_Area\"/>"
msgstr ""
+", <xref linkend=\"CG_MakeSolid\"/>, <xref linkend=\"CG_IsSolid\"/>, <xref "
+"linkend=\"CG_Area\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -41622,17 +41665,21 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ", <xref linkend=\"CG_MakeSolid\"/>, <xref linkend=\"CG_IsSolid\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"CG_MakeSolid\"/>, <xref linkend=\"CG_IsSolid\"/>"
#. Tag: para
#, no-c-format
msgid "is deprecated as of 3.5.0. Use <xref linkend=\"CG_ForceLHR\"/> instead."
msgstr ""
+"est obsolète depuis la version 3.5.0. Utilisez <xref linkend=\"CG_ForceLHR\"/"
+"> à la place."
#. Tag: para
#, no-c-format
msgid "is deprecated as of 3.5.0. Use <xref linkend=\"CG_IsPlanar\"/> instead."
msgstr ""
+"est obsolète depuis la version 3.5.0. Utilisez <xref linkend=\"CG_IsPlanar\"/"
+"> à la place."
#. Tag: para
#, no-c-format
@@ -41647,23 +41694,31 @@ msgstr ""
#, no-c-format
msgid "is deprecated as of 3.5.0. Use <xref linkend=\"CG_IsSolid\"/> instead."
msgstr ""
+"est obsolète depuis la version 3.5.0. Utilisez <xref linkend=\"CG_IsSolid\"/"
+"> à la place."
#. Tag: para
#, no-c-format
msgid ""
"is deprecated as of 3.5.0. Use <xref linkend=\"CG_MakeSolid\"/> instead."
msgstr ""
+"est obsolète depuis la version 3.5.0. Utilisez <xref linkend=\"CG_MakeSolid\""
+"/> à la place."
#. Tag: para
#, no-c-format
msgid ""
"is deprecated as of 3.5.0. Use <xref linkend=\"CG_Orientation\"/> instead."
msgstr ""
+"est obsolète depuis la version 3.5.0. Utilisez <xref linkend=\"CG_Orientation"
+"\"/> à la place."
#. Tag: para
#, no-c-format
msgid "is deprecated as of 3.5.0. Use <xref linkend=\"CG_3DArea\"/> instead."
msgstr ""
+"est obsolète depuis la version 3.5.0. Utilisez <xref linkend=\"CG_3DArea\"/> "
+"à la place."
#. Tag: para
#, no-c-format
@@ -41678,6 +41733,8 @@ msgstr ""
#, no-c-format
msgid "is deprecated as of 3.5.0. Use <xref linkend=\"CG_Volume\"/> instead."
msgstr ""
+"est obsolète depuis la version 3.5.0. Utilisez <xref linkend=\"CG_Volume\"/> "
+"à la place."
#. Tag: para
#, no-c-format
@@ -41782,6 +41839,8 @@ msgstr "Effectuer une différence 3D"
msgid ""
"is deprecated as of 3.5.0. Use <xref linkend=\"CG_3DDifference\"/> instead."
msgstr ""
+"est obsolète depuis la version 3.5.0. Utilisez <xref linkend="
+"\"CG_3DDifference\"/> à la place."
#. Tag: para
#, no-c-format
@@ -41817,6 +41876,8 @@ msgid ""
", <xref linkend=\"ST_AsX3D\"/>, <xref linkend=\"CG_3DIntersection\"/> <xref "
"linkend=\"CG_3DUnion\"/>"
msgstr ""
+", <xref linkend=\"ST_AsX3D\"/>, <xref linkend=\"CG_3DIntersection\"/> <xref "
+"linkend=\"CG_3DUnion\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -41840,7 +41901,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ", <xref linkend=\"CG_Distance\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"CG_Distance\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -41876,6 +41937,8 @@ msgstr "Calcule l'enveloppe convexe 3D d'une géométrie."
msgid ""
"is deprecated as of 3.5.0. Use <xref linkend=\"CG_3DConvexHull\"/> instead."
msgstr ""
+"\"CG_3DConvexHull\"/> à la place."
#. Tag: para
#, no-c-format
@@ -41897,6 +41960,8 @@ msgstr "Réaliser une intersection 3D"
msgid ""
"is deprecated as of 3.5.0. Use <xref linkend=\"CG_3DIntersection\"/> instead."
msgstr ""
+"\"CG_3DIntersection\"/> à la place."
#. Tag: para
#, no-c-format
@@ -41958,6 +42023,8 @@ msgstr "Effectuer l'union 3D."
#, no-c-format
msgid "is deprecated as of 3.5.0. Use <xref linkend=\"CG_3DUnion\"/> instead."
msgstr ""
+"est obsolète depuis la version 3.5.0. Utilisez <xref linkend=\"CG_3DUnion\"/"
+"> à la place."
#. Tag: para
#, no-c-format
@@ -41994,6 +42061,12 @@ msgid ""
"it operates on rows of data, in the same way the SUM() and AVG() functions "
"do and like most aggregates, it also ignores NULL geometries."
msgstr ""
+"<emphasis role=\"bold\">Variante aggregate :</emphasis> renvoie une "
+"géométrie qui est l'union 3D d'un ensemble de géométries. La fonction "
+"CG_3DUnion() est une fonction \"aggregate\" dans la terminologie de "
+"PostgreSQL. Cela signifie qu'elle opère sur des lignes de données, de la "
+"même manière que les fonctions SUM() et AVG() et, comme la plupart des "
+"agrégats, elle ignore les géométries NULL."
#. Tag: para
#, no-c-format
@@ -42012,6 +42085,8 @@ msgid ""
"linkend=\"CG_3DDifference\"/>"
msgstr ""
+"linkend=\"CG_3DDifference\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -42023,6 +42098,8 @@ msgstr "Calcul d'une forme Alpha entourant une géométrie"
msgid ""
"is deprecated as of 3.5.0. Use <xref linkend=\"CG_AlphaShape\"/> instead."
msgstr ""
+"est obsolète depuis la version 3.5.0. Utilisez <xref linkend=\"CG_AlphaShape"
+"\"/> à la place."
#. Tag: para
#, no-c-format
@@ -42106,6 +42183,8 @@ msgid ""
"Alpha-shape of a MultiPoint (same example As <xref "
"linkend=\"CG_OptimalAlphaShape\"/>)"
msgstr ""
+"Forme alpha d'un MultiPoint (même exemple que <xref linkend="
+"\"CG_OptimalAlphaShape\"/>)"
#. Tag: para
#, no-c-format
@@ -42113,6 +42192,8 @@ msgid ""
"Alpha-shape of a MultiPoint, allowing holes (same example as <xref "
msgstr ""
+"Forme alpha d'un MultiPoint, autorisant les trous (même exemple que <xref "
+"linkend=\"CG_OptimalAlphaShape\"/>)"
#. Tag: para
#, no-c-format
@@ -42126,7 +42207,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ", <xref linkend=\"CG_OptimalAlphaShape\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"CG_OptimalAlphaShape\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -42215,6 +42296,8 @@ msgid ""
"is deprecated as of 3.5.0. Use <xref linkend=\"CG_ApproximateMedialAxis\"/> "
"instead."
msgstr ""
+"\"CG_ApproximateMedialAxis\"/> à la place."
#. Tag: para
#, no-c-format
@@ -42248,6 +42331,8 @@ msgid ""
"is deprecated as of 3.5.0. Use <xref "
"linkend=\"CG_ConstrainedDelaunayTriangles\"/> instead."
msgstr ""
+"\"CG_ConstrainedDelaunayTriangles\"/> à la place."
#. Tag: para
#, no-c-format
@@ -42278,6 +42363,8 @@ msgid ""
", <xref linkend=\"ST_TriangulatePolygon\"/>, <xref linkend=\"CG_Tesselate\"/"
">, <xref linkend=\"ST_ConcaveHull\"/>, <xref linkend=\"ST_Dump\"/>"
msgstr ""
+", <xref linkend=\"ST_TriangulatePolygon\"/>, <xref linkend=\"CG_Tesselate\"/"
+">, <xref linkend=\"ST_ConcaveHull\"/>, <xref linkend=\"ST_Dump\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -42288,6 +42375,8 @@ msgstr "Extruder une surface vers un volume"
#, no-c-format
msgid "is deprecated as of 3.5.0. Use <xref linkend=\"CG_Extrude\"/> instead."
msgstr ""
+"est obsolète depuis la version 3.5.0. Utilisez <xref linkend=\"CG_Extrude\"/"
+"> à la place."
#. Tag: para
#, no-c-format
@@ -42339,6 +42428,16 @@ msgid ""
"with CG_Extrude(polygon, 0, 0, body_height). The result is an union of these "
"polyhedralsurfaces."
msgstr ""
+"Il s'agit peut-être du premier cas d'utilisation (historique) des squelettes "
+"droits : étant donné un toit polygonal, le squelette droit donne directement "
+"la disposition de chaque tente. Si chaque arête du squelette est soulevée du "
+"plan d'une hauteur égale à sa distance de décalage, le toit résultant est "
+"\"correct\" en ce sens que l'eau tombera toujours vers les bords du contour ("
+"la bordure du toit), quel que soit l'endroit où elle tombe sur le toit. La "
+"fonction calcule cette extrusion ou \"toit\" sur un polygone. Si l'argument "
+"body_height > 0, alors le polygone est extrudé comme avec CG_Extrude("
+"polygon, 0, 0, body_height). Le résultat est une union de ces polyedres "
+"surfaciques."
#. Tag: para
#, no-c-format
@@ -42384,6 +42483,8 @@ msgstr "Effectue la somme de Minkowski"
msgid ""
"is deprecated as of 3.5.0. Use <xref linkend=\"CG_MinkowskiSum\"/> instead."
msgstr ""
+"\"CG_MinkowskiSum\"/> à la place."
#. Tag: para
#, no-c-format
@@ -42478,6 +42579,8 @@ msgid ""
"is deprecated as of 3.5.0. Use <xref linkend=\"CG_OptimalAlphaShape\"/> "
"instead."
msgstr ""
+"\"CG_OptimalAlphaShape\"/> à la place."
#. Tag: para
#, no-c-format
@@ -42533,7 +42636,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ", <xref linkend=\"CG_AlphaShape\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"CG_AlphaShape\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -42601,6 +42704,8 @@ msgid ""
"is deprecated as of 3.5.0. Use <xref linkend=\"CG_StraightSkeleton\"/> "
"instead."
msgstr ""
+"\"CG_StraightSkeleton\"/> à la place."
#. Tag: refpurpose
#, no-c-format
Summary of changes:
doc/po/fr/postgis-manual.po | 209 ++++++++++++++++++++++++++++++++++++++++----
1 file changed, 190 insertions(+), 19 deletions(-)
hooks/post-receive
