[SCM] PostGIS branch master updated. 3.5.0-221-g450d3b770
    git at osgeo.org
    git at osgeo.org
    Tue Mar  4 06:47:42 PST 2025
the project "PostGIS".
       via  450d3b770035c2281dd8e63b25be694b0b9baec8 (commit)
       via  eb0a1042dcadcd7ceb14838be291c0ee753255fb (commit)
      from  bf715caf808bd2c480a31a5fbebceea8660ff633 (commit)
revisions in full, below.
commit 450d3b770035c2281dd8e63b25be694b0b9baec8
Author: Vincent Bre <vincent.bre at oslandia.com>
Date:   Tue Mar 4 13:17:46 2025 +0000
    Translated PostGIS Manual using Weblate (French)
    Currently translated at 100.0% (5756 of 5756 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index bc3d6ad16..0060fb9d3 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -12,7 +12,7 @@ msgstr ""
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-11-19 11:58+0000\n"
 "PO-Revision-Date: 2025-03-04 14:47+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"Last-Translator: Vincent Bre <vincent.bre at oslandia.com>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/fr/>\n"
 "Language: fr\n"
@@ -12282,7 +12282,7 @@ msgstr ""
 "supprimées des prochaines version de PostGIS. IL NE FAUT PLUS LES UTILISER."
 #. Tag: chapter
-#, fuzzy, no-c-format
+#, no-c-format
 msgid ""
 "&reference_type; &reference_management; &reference_constructor; "
 "&reference_accessor; &reference_editor; &reference_validation; "
@@ -14456,7 +14456,7 @@ msgstr ""
 "renvoie NULL. Avant la version 1.5.4, une exception était levée."
 #. Tag: para
+#, no-c-format
 msgid ""
 "Escaping names for tables and/or namespaces that include special characters "
 "and quotes may require special handling. A user notes: \"For schemas and "
@@ -18902,7 +18902,7 @@ msgstr ""
 "Pour plus d'exemples d'utilisation, voir <link xlink:href=\"https://www."
 "postgresql.org/docs/current/sql-set.html\">SQL SET</link> et <link "
 "xlink:href=\"https://www.postgresql.org/docs/current/sql-altersystem.html\""
-">SQL ALTER SYSTEM</link>."
+">SQL ALTER SYSTEM</link>"
 #. Tag: refpurpose
 #, no-c-format
@@ -31549,11 +31549,11 @@ msgstr ""
 "Pour les variantes avec le paramètre <code>nbands</code> en texte, le "
 "délimiteur par défaut est <code>,</code>, il faut donc passer par exemple "
 "<code>'1,2,3'</code>. Pour utiliser un autre délimiteur, utilisez le "
-"paramètre delimiter : <code>ST_Band(rast, '1 at 2@3', '@')</code>. Néanmoins, "
+"paramètre delimiter : <code>ST_Band(rast, '1 at 2@3', '@')</code>. Néanmoins, "
 "pour utiliser plusieurs bandes, nous encourageons fortement d'utiliser la "
-"variante avec le paramètre de type tableau (e.g. <code>ST_Band(rast, "
-"'{1,2,3}'::int[]);</code>); la variante avec la liste de bandes en "
-"<code>text</code> peut être supprimée des prochaines versions de PostGIS."
+"variante avec le paramètre de type tableau (e.g. <code>ST_Band(rast, '{1,2,3}"
+"' ::int[]) ;</code>) ; la variante avec la liste de bandes en <code>text</"
+"code> peut être supprimée des prochaines versions de PostGIS."
 #. Tag: para
 #, no-c-format
@@ -42787,6 +42787,8 @@ msgstr ""
 msgid ""
 "is deprecated as of 3.5.0. Use <xref linkend=\"CG_Tesselate\"/> instead."
 msgstr ""
+"est obsolète depuis la version 3.5.0. Utilisez <xref linkend=\"CG_Tesselate\""
+"/> à la place."
 #. Tag: para
 #, no-c-format
@@ -42958,6 +42960,14 @@ msgid ""
 "The <parameter>buffer_type</parameter> specifies the type of buffer to "
 "create: 0: Rounded buffer (default) 1: Flat buffer 2: Square buffer"
 msgstr ""
+"Génère un tampon 3D autour de la géométrie d'entrée <parameter>geom</"
+"parameter> avec un <parameter>radius</parameter> spécifié . Le tampon est "
+"construit dans l'espace 3D, créant une représentation volumétrique de "
+"l'environnement de la géométrie. Le paramètre <parameter>segments</"
+"parameter> définit le nombre de segments utilisés pour approximer les "
+"sections courbes du tampon. Le paramètre <parameter>buffer_type</parameter> "
+"spécifie le type de tampon à créer : 0 : tampon arrondi (par défaut) 1 : "
+"tampon plat 2 : tampon carré"
 #. Tag: para
 #, no-c-format
@@ -42998,7 +43008,7 @@ msgstr "32 segments, carrés"
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"ST_3DConvexHull\"/>, <xref linkend=\"ST_AsX3D\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_3DConvexHull\"/>, <xref linkend=\"ST_AsX3D\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -43022,7 +43032,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"ST_Rotate\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_Rotate\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -43049,7 +43059,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"CG_3DRotate\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"CG_3DRotate\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -43072,7 +43082,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"CG_RotateY\"/>, <xref linkend=\"CG_RotateZ\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"CG_RotateY\"/>, <xref linkend=\"CG_RotateZ\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -43091,7 +43101,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"CG_RotateZ\"/>, <xref linkend=\"CG_3DRotate\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"CG_RotateZ\"/>, <xref linkend=\"CG_3DRotate\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -43104,6 +43114,8 @@ msgid ""
 "Rotates the input geometry <parameter>geom</parameter> by <parameter>angle</"
 "parameter> radians around the Y-axis passing."
 msgstr ""
+"Fait pivoter la géométrie d'entrée <parameter>geom</parameter> de "
+"<parameter>angle</parameter> radians autour de l'axe Y."
 #. Tag: refpurpose
 #, no-c-format
@@ -43122,7 +43134,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"CG_RotateY\"/>, <xref linkend=\"CG_3DRotate\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"CG_RotateY\"/>, <xref linkend=\"CG_3DRotate\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -43148,6 +43160,7 @@ msgstr ""
 msgid ""
 ", <xref linkend=\"CG_3DScaleAroundCenter\"/>, <xref linkend=\"ST_Scale\"/>"
 msgstr ""
+", <xref linkend=\"CG_3DScaleAroundCenter\"/>, <xref linkend=\"ST_Scale\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -43171,7 +43184,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"CG_3DScaleAroundCenter\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"CG_3DScaleAroundCenter\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -43196,12 +43209,12 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"CG_3DScale\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"CG_3DScale\"/>"
 #. Tag: refpurpose
 #, no-c-format
 msgid "Translates (moves) a geometry by given offsets in 2D space."
-msgstr ""
+msgstr "Déplace une géométrie en fonction de décalages donnés dans l'espace 2D."
 #. Tag: para
 #, no-c-format
@@ -43210,6 +43223,10 @@ msgid ""
 "<parameter>deltaX</parameter> to the X coordinates and <parameter>deltaY</"
 "parameter> to the Y coordinates. Z coordinates are dropped."
 msgstr ""
+"Déplace la géométrie d'entrée <parameter>geom</parameter> en ajoutant "
+"<parameter>deltaX</parameter> aux coordonnées X et <parameter>deltaY</"
+"parameter> aux coordonnées Y. Les coordonnées Z sont supprimées. Les "
+"coordonnées Z ne sont pas prises en compte."
 #. Tag: para
 #, no-c-format
@@ -43219,7 +43236,7 @@ msgstr ", <xref linkend=\"ST_Translate\"/>"
 #. Tag: refpurpose
 #, no-c-format
 msgid "Translates (moves) a geometry by given offsets in 3D space."
-msgstr ""
+msgstr "Déplace une géométrie en fonction de décalages donnés dans l'espace 3D."
 #. Tag: para
 #, no-c-format
@@ -43229,6 +43246,10 @@ msgid ""
 "parameter> to the Y coordinates, and <parameter>deltaZ</parameter> to the Z "
 "coordinates."
 msgstr ""
+"<parameter>deltaX</parameter> aux coordonnées X, <parameter>deltaY</"
+"parameter> aux coordonnées Y et <parameter>deltaZ</parameter> aux "
+"coordonnées Z."
 #. Tag: title
 #, no-c-format
@@ -45365,6 +45386,9 @@ msgid ""
 "<xref linkend=\"PostGIS_LibXML_Version\"/>, <xref "
 "linkend=\"PostGIS_Version\"/>"
 msgstr ""
+", <xref linkend=\"PostGIS_Full_Version\"/>, <xref linkend="
+"\"PostGIS_GEOS_Version\"/>, <xref linkend=\"PostGIS_Lib_Version\"/>, <xref "
+"linkend=\"PostGIS_LibXML_Version\"/>, <xref linkend=\"PostGIS_Version\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -45381,6 +45405,8 @@ msgid ""
 "Returns the version number of the PROJ library, or against which PostGIS was "
 "built."
 msgstr ""
+"Renvoie le numéro de version de la bibliothèque PROJ, ou par rapport à "
+"laquelle PostGIS a été buildé."
 #. Tag: refpurpose
 #, no-c-format
@@ -45557,7 +45583,7 @@ msgid "PostGIS 3.6.0"
 msgstr "PostGIS 3.6.0"
 #. Tag: para
+#, no-c-format
 msgid "2025/xx/xx"
 msgstr "2025/xx/xx"
commit eb0a1042dcadcd7ceb14838be291c0ee753255fb
Author: DeepL <noreply-mt-deepl at weblate.org>
Date:   Tue Mar 4 13:18:38 2025 +0000
index 321a5801d..bc3d6ad16 100644
@@ -11,7 +11,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2025-03-04 11:47+0000\n"
+"PO-Revision-Date: 2025-03-04 14:47+0000\n"
@@ -42918,7 +42918,7 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Computes the straight skeleton partition of a polygon."
-msgstr ""
+msgstr "Calcule la partition du squelette droit d'un polygone."
 #. Tag: para
 #, no-c-format
@@ -42930,16 +42930,22 @@ msgid ""
 "automatically adjust the orientation of the input polygon to ensure correct "
 "results."
 msgstr ""
+"Calcule la partition du squelette droit du polygone d'entrée geometry "
+"<parameter>geom</parameter>. Le squelette droit est une partition du "
+"polygone en faces formées en traçant l'effondrement de ses arêtes. Si "
+"<parameter>auto_orientation</parameter> vaut true, la fonction ajustera "
+"automatiquement l'orientation du polygone d'entrée pour garantir des "
+"résultats corrects."
 #. Tag: para
 #, no-c-format
 msgid "Availability: 3.6.0 - requires SFCGAL >= 2.0.0."
-msgstr ""
+msgstr "Disponibilité : 3.6.0 - nécessite SFCGAL >= 2.0.0."
 #. Tag: refpurpose
 #, no-c-format
 msgid "Computes a 3D buffer around a geometry."
-msgstr ""
+msgstr "Calcule un tampon 3D autour d'une géométrie."
 #. Tag: para
 #, no-c-format
@@ -42956,7 +42962,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Availability: 3.6.0 - requires SFCGAL >= 2.0.0"
-msgstr ""
+msgstr "Disponibilité : 3.6.0 - nécessite SFCGAL >= 2.0.0"
 #. Tag: para
 #, no-c-format
@@ -42965,26 +42971,29 @@ msgid ""
 "into <link xlink:href=\"https://postgis.net/docs/support/viewers/x3d_viewer."
 "htm\">X3D Viewer</link>."
 msgstr ""
+"Les images suivantes ont été obtenues en collant le résultat de la requête "
+"ST_AsX3D dans <link xlink:href=\"https://postgis.net/docs/support/viewers/"
+"x3d_viewer.htm\">X3D Viewer</link>."
 #. Tag: para
 #, no-c-format
 msgid "segments=32 (rounded buffer)"
-msgstr ""
+msgstr "segments=32 (tampon arrondi)"
 #. Tag: para
 #, no-c-format
 msgid "5 segments rounded"
-msgstr ""
+msgstr "5 segments arrondis"
 #. Tag: para
 #, no-c-format
 msgid "32 segments, round"
-msgstr ""
+msgstr "32 segments, ronds"
 #. Tag: para
 #, no-c-format
 msgid "32 segments, square"
-msgstr ""
+msgstr "32 segments, carrés"
 #. Tag: para
 #, no-c-format
@@ -42994,7 +43003,7 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Rotates a geometry by a given angle around the origin (0,0)."
-msgstr ""
+msgstr "Fait pivoter une géométrie d'un angle donné autour de l'origine (0,0)."
 #. Tag: para
 #, no-c-format
@@ -43004,6 +43013,11 @@ msgid ""
 "in 2D space; Z coordinates are not modified. Positive angles rotate the "
 "geometry counter-clockwise."
 msgstr ""
+"<parameter>angle</parameter> radians autour du point d'origine (0,0). La "
+"rotation est effectuée dans l'espace 2D ; les coordonnées Z ne sont pas "
+"modifiées. Les angles positifs font tourner la géométrie dans le sens "
+"inverse des aiguilles d'une montre."
 #. Tag: para
 #, no-c-format
@@ -43014,6 +43028,7 @@ msgstr ""
 #, no-c-format
 msgid "Rotates a geometry by a given angle around a specified point in 2D."
 msgstr ""
+"Fait pivoter une géométrie d'un angle donné autour d'un point spécifié en 2D."
 #. Tag: para
 #, no-c-format
@@ -43024,6 +43039,12 @@ msgid ""
 "coordinates are dropped. Positive angles rotate the geometry counter-"
 "clockwise."
 msgstr ""
+"<parameter>angle</parameter> radians autour du point (<parameter>cx</"
+"parameter>, <parameter>cy</parameter>). La rotation est effectuée dans "
+"l'espace 2D ; les coordonnées Z ne sont pas prises en compte. Les angles "
+"positifs font tourner la géométrie dans le sens inverse des aiguilles d'une "
+"montre."
 #. Tag: para
 #, no-c-format
@@ -43033,7 +43054,7 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Rotates a geometry in 3D space around an axis vector."
-msgstr ""
+msgstr "Fait pivoter une géométrie dans l'espace 3D autour d'un vecteur d'axe."
 #. Tag: para
 #, no-c-format
@@ -43043,6 +43064,10 @@ msgid ""
 "parameter>, <parameter>ay</parameter>, <parameter>az</parameter>) passing "
 "through the origin (0,0,0)."
 msgstr ""
+"<parameter>angle</parameter> radians autour d'un axe défini par le vecteur "
+"(<parameter>ax</parameter>, <parameter>ay</parameter>, "
+"<parameter>az</parameter>) passant par l'origine (0,0,0)."
 #. Tag: para
 #, no-c-format
@@ -43052,7 +43077,7 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Rotates a geometry around the X-axis by a given angle."
-msgstr ""
+msgstr "Fait pivoter une géométrie autour de l'axe X d'un angle donné."
 #. Tag: para
 #, no-c-format
@@ -43060,6 +43085,8 @@ msgid ""
 "parameter> radians around the X-axis."
 msgstr ""
+"<parameter>angle</parameter> radians autour de l'axe X."
 #. Tag: para
 #, no-c-format
@@ -43069,7 +43096,7 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Rotates a geometry around the Y-axis by a given angle."
-msgstr ""
+msgstr "Fait pivoter une géométrie autour de l'axe Y d'un angle donné."
 #. Tag: para
 #, no-c-format
@@ -43081,7 +43108,7 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Rotates a geometry around the Z-axis by a given angle."
-msgstr ""
+msgstr "Fait pivoter une géométrie autour de l'axe Z d'un angle donné."
 #. Tag: para
 #, no-c-format
@@ -43089,6 +43116,8 @@ msgid ""
 "parameter> radians around the Z-axis."
 msgstr ""
+"<parameter>angle</parameter> radians autour de l'axe Z."
 #. Tag: para
 #, no-c-format
@@ -43099,6 +43128,8 @@ msgstr ""
 #, no-c-format
 msgid "Scales a geometry uniformly in all dimensions by a given factor."
 msgstr ""
+"Met à l'échelle une géométrie uniformément dans toutes les dimensions selon "
+"un facteur donné."
 #. Tag: para
 #, no-c-format
@@ -43107,6 +43138,10 @@ msgid ""
 "<parameter>factor</parameter> in all dimensions (X, Y, and Z). The scaling "
 "is performed relative to the origin point (0,0,0)."
 msgstr ""
+"Met à l'échelle la géométrie d'entrée <parameter>geom</parameter> par un "
+"facteur d'échelle uniforme <parameter></parameter> dans toutes les "
+"dimensions (X, Y et Z). La mise à l'échelle est effectuée par rapport au "
+"point d'origine (0,0,0)."
 #. Tag: para
 #, no-c-format
@@ -43118,6 +43153,8 @@ msgstr ""
 #, no-c-format
 msgid "Scales a geometry by separate factors along X, Y, and Z axes."
 msgstr ""
+"Met à l'échelle une géométrie en fonction de facteurs distincts le long des "
+"axes X, Y et Z."
 #. Tag: para
 #, no-c-format
@@ -43126,6 +43163,10 @@ msgid ""
 "along the X, Y, and Z axes. The scaling is performed relative to the origin "
 "point (0,0,0)."
 msgstr ""
+"Met à l'échelle la géométrie d'entrée <parameter>geom</parameter> en "
+"fonction de différents facteurs le long des axes X, Y et Z. La mise à "
+"l'échelle est effectuée par rapport au point d'origine (0,0,0). La mise à "
+"l'échelle est effectuée par rapport au point d'origine (0,0,0)."
 #. Tag: para
 #, no-c-format
@@ -43136,6 +43177,8 @@ msgstr ""
 #, no-c-format
 msgid "Scales a geometry in 3D space around a specified center point."
 msgstr ""
+"Met à l'échelle une géométrie dans l'espace 3D autour d'un point central "
+"spécifié."
 #. Tag: para
 #, no-c-format
@@ -43145,6 +43188,10 @@ msgid ""
 "(<parameter>centerX</parameter>, <parameter>centerY</parameter>, "
 "<parameter>centerZ</parameter>)."
 msgstr ""
+"Met à l'échelle la géométrie d'entrée <parameter>geom</parameter> par "
+"différents facteurs le long des axes X, Y et Z, par rapport à un point "
+"central spécifié (<parameter>centerX</parameter>, <parameter>centerY</"
+"parameter>, <parameter>centerZ</parameter>)."
 #. Tag: para
 #, no-c-format
@@ -45244,7 +45291,7 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Returns the version number of the libjson-c library."
-msgstr ""
+msgstr "Renvoie le numéro de version de la bibliothèque libjson-c."
 #. Tag: para
 #, no-c-format
@@ -45325,6 +45372,8 @@ msgid ""
 "Returns the version number of the PROJ library against which PostGIS was "
 "built."
 msgstr ""
+"Renvoie le numéro de version de la bibliothèque PROJ avec laquelle PostGIS a "
+"été construit."
 #. Tag: para
 #, no-c-format
@@ -45505,7 +45554,7 @@ msgstr "Notes de version"
 #. Tag: title
 #, no-c-format
-msgstr ""
+msgstr "PostGIS 3.6.0"
 #. Tag: para
Summary of changes:
 doc/po/fr/postgis-manual.po | 145 +++++++++++++++++++++++++++++++++-----------
 1 file changed, 110 insertions(+), 35 deletions(-)
hooks/post-receive
