[PostGIS] #5862: Postgis topology, silently craating topo edge crosses edge , mixed face labeling in ring
trac at osgeo.org
Wed Mar 12 09:42:08 PDT 2025
labeling in ring
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: high | Milestone:
Component: topology | Version: master
Resolution: | Keywords: robustness
Changes (by strk):
* keywords: => robustness
Comment:
I've attached a simplified testcase.
The problem is once again with edge segments being almost concidental but
not having an intersection, as shown in figure (note the lack of nodes
near the end point of the incoming offending red line):
[[Image(case.png)]]
The incoming line results in a new node and the edge merge code seems to
be choking on that, but fails to notice it before it is too late!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5862#comment:2>
