[SCM] PostGIS branch master updated. 3.5.0-230-gb159ebbe9
Thu Mar 20 14:36:23 PDT 2025
the project "PostGIS".
       via  b159ebbe934c190fc874581fb5dbda6f9bd7453b (commit)
      from  50a5f3c40bad4eb65fb6b0d59c9d21b48fb94530 (commit)
revisions in full, below.
commit b159ebbe934c190fc874581fb5dbda6f9bd7453b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Mar 20 14:35:55 2025 -0700
    Allow estimated_extent to work with table/namespace names closer to max length.
    References #5819
diff --git a/postgis/gserialized_estimate.c b/postgis/gserialized_estimate.c
index e888dcb83..0f7d4f81a 100644
--- a/postgis/gserialized_estimate.c
+++ b/postgis/gserialized_estimate.c
@@ -2600,7 +2600,7 @@ Datum gserialized_estimated_extent(PG_FUNCTION_ARGS)
 	char *col = NULL;
 	int16 attnum, idx_attnum;
 	Oid atttypid = InvalidOid;
-	char nsp_tbl[NAMEDATALEN];
+	char nsp_tbl[2*NAMEDATALEN+6];
 	char *tbl;
 	Oid tbl_oid, idx_oid = 0;
 	ND_STATS *nd_stats;
@@ -2625,13 +2625,13 @@ Datum gserialized_estimated_extent(PG_FUNCTION_ARGS)
 		char *nsp = text_to_cstring(PG_GETARG_TEXT_P(0));
 		tbl = text_to_cstring(PG_GETARG_TEXT_P(1));
 		coltxt = PG_GETARG_TEXT_P(2);
-		snprintf(nsp_tbl, NAMEDATALEN, "\"%s\".\"%s\"", nsp, tbl);
+		snprintf(nsp_tbl, sizeof(nsp_tbl), "\"%s\".\"%s\"", nsp, tbl);
 	if ( PG_NARGS() == 2 )
 		tbl = text_to_cstring(PG_GETARG_TEXT_P(0));
 		coltxt = PG_GETARG_TEXT_P(1);
-		snprintf(nsp_tbl, NAMEDATALEN, "\"%s\"", tbl);
+		snprintf(nsp_tbl, sizeof(nsp_tbl), "\"%s\"", tbl);
 	/* Parse the namespace/table strings and lookup in system catalogs */
Summary of changes:
 postgis/gserialized_estimate.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
