[PostGIS] #5868: Add Function to Detect Valid Polygons with Point Touching Rings
PostGIS trac at osgeo.org
Fri Mar 21 11:03:20 PDT 2025
  Reporter:  gravitystorm  |      Owner:  pramsey
      Type:  defect        |     Status:  new
  Priority:  medium        |  Milestone:  PostGIS 3.5.3
 Component:  postgis       |    Version:  3.4.x
Resolution:                |   Keywords:
Comment (by mdavis):
 Thanks for the clarification.
 One option is to make a SQL function to check whether the shell ring of a
 valid polygon and the inner hole rings intersect.
 In fact, there is code in GEOS to transform polygons with touching holes
 into equivalent self-touching rings (AKA inverted/exverted rings).  This
 currently isn't exposed, but it could be - either as a PostGIS function,
 or simply as a preprocessing step inside the affected CG functions.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5868#comment:6>
