[PostGIS] #5868: Add Function to Detect Valid Polygons with Point Touching Rings
PostGIS trac at osgeo.org
Fri Mar 21 08:11:25 PDT 2025
  Reporter:  gravitystorm  |      Owner:  pramsey
      Type:  defect        |     Status:  new
  Priority:  medium        |  Milestone:  PostGIS 3.5.3
 Component:  postgis       |    Version:  3.4.x
Resolution:                |   Keywords:
Description changed by gravitystorm:
Old description:
> Certain functions are not implemented for valid polygons with point
> touching rings (see https://trac.osgeo.org/postgis/ticket/5867).
> For some use-cases, it would be handy if there was a function that could
> be used to detect such polygons ahead of time, in order to handle them
> separately. I haven't been able to find any existing postgis function
> that does this, but if I've missed one please let me know.
> With such a function, you could choose to ignore these polygons, e.g.
> select CG_StraightSkeleton(geom)
>   from table
>  where !ST_PolygonHasPointTouchingRing(geom)
> Alternatively, you could buffer only the geometries that have point
> touching rings, without buffering the vast majority that don't, e.g.
>        case when ST_PolygonHasPointTouchingRing(geom)
>        then st_buffer(geom, 0.0001)
>        else geom
>        end)
>   from table
New description:
 separately. I haven't been able to find any existing postgis function that
   from table
  where !ST_ValidPolygonHasPointTouchingInnerRing(geom)
        case when ST_ValidPolygonHasPointTouchingInnerRing(geom)
        else geom
        end)
   from table
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5868#comment:5>
