[PostGIS] #5869: woodie failing on regress index
PostGIS trac at osgeo.org
Sat Mar 22 14:23:53 PDT 2025
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.6.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Changes (by robe):
 * component:  QA/buildbots => postgis
 * owner:  robe => pramsey
Comment:
 oh wait this might be my fault.  Just remembered I had changed this test
 to fix PG18 failing cause they introduced decimals in row count and I
 think woodie might be the only bot testing escape string postgres config
 settings.  So I'll fix this test.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5869#comment:1>
