[PostGIS] #5869: woodie failing on regress index
    trac at osgeo.org
    Sat Mar 22 14:21:33 PDT 2025
 Reporter:  robe          |      Owner:  robe
     Type:  defect        |     Status:  new
 Priority:  blocker       |  Milestone:  PostGIS 3.6.0
Component:  QA/buildbots  |    Version:  master
 Keywords:                |
 Woodie has been failing on this for both pg12 and pg17 runs.
 Haven't figured out what changed.  I tried rerunning to see if it was a
 fluke but still an issue.
 Woodie seems to be the only ci failing
  regress/core/regress_index .. failed (diff expected obtained:
 /tmp/pgis_reg/test_54_diff)
 /woodpecker/src/git.osgeo.org/gitea/postgis/postgis/regress/core/regress_index_expected
 2025-03-20 21:36:47.291191428 +0000
 +++ /tmp/pgis_reg/test_54_out   2025-03-20 21:57:33.691533418 +0000
 @@ -10,6 +10,10 @@
  27373|POINT(125.017705 130.219927)
  33863|POINT(131.608071 127.468328)
  45851|POINT(130.986464 132.890625)
 +WARNING:  nonstandard use of escape in a string literal at character 389
 +WARNING:  nonstandard use of escape in a string literal at character 293
 +WARNING:  nonstandard use of escape in a string literal at character 28
  &&|1|5+-5:true
  &&|2|912+-60:true
  &&|3|12505+-500:true
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5869>
