[SCM] PostGIS branch master updated. 3.5.0-232-g9637dc369
    git at osgeo.org
    git at osgeo.org
    Mon Mar 24 20:39:16 PDT 2025
the project "PostGIS".
       via  9637dc369361ac118e1ad37da7a519dae9dfab5e (commit)
      from  d0e22f8867b685eee6e67cdeb1affe2666f61983 (commit)
revisions in full, below.
commit 9637dc369361ac118e1ad37da7a519dae9dfab5e
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Mar 24 11:48:32 2025 -0400
    - Fix straight skeleton doco links
    - Add image example for CG_StraightSkeletonPartition
diff --git a/doc/html/images/Makefile.in b/doc/html/images/Makefile.in
index 04c7e141e..1d638b7b0 100644
--- a/doc/html/images/Makefile.in
+++ b/doc/html/images/Makefile.in
@@ -46,6 +46,7 @@ GENERATED_IMAGES= \
 	cg_visibility03.png \
 	cg_ymonotonepartition01.png \
 	cg_ymonotonepartition02.png \
+	cg_straightskeletonpartition01.png \
 	de9im01.png \
 	de9im02.png \
 	st_alphashape01.png \
diff --git a/doc/html/images/wkt/cg_straightskeletonpartition01.wkt b/doc/html/images/wkt/cg_straightskeletonpartition01.wkt
new file mode 100644
index 000000000..7f305a64d
--- /dev/null
+++ b/doc/html/images/wkt/cg_straightskeletonpartition01.wkt
@@ -0,0 +1,9 @@
+ArgA;POLYGON((190 190,164.03987973986756 164.03987973986756,190 140))
+ArgB;POLYGON((10 190,40.697077206292434 159.30292279370755,164.03987973986756 164.03987973986756,190 190))
+ArgA;POLYGON((10 10,35 35,35 153.15077848154866,40.697077206292434 159.30292279370755,10 190))
+ArgB;POLYGON((190 10,184.18861169915812 15.811388300841896,158.3772233983162 20,50 20,35 35,10 10))
+ArgA;POLYGON((190 20,184.18861169915812 15.811388300841896,190 10))
+ArgB;POLYGON((160 30,158.3772233983162 20,184.18861169915812 15.811388300841896,190 20))
+ArgA;POLYGON((60 30,50 20,158.3772233983162 20,160 30))
+ArgB;POLYGON((60 130,35 153.15077848154866,35 35,50 20,60 30))
+ArgA;POLYGON((190 140,164.03987973986756 164.03987973986756,40.697077206292434 159.30292279370755,35 153.15077848154866,60 130))
\ No newline at end of file
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index 673d88528..45e88a42d 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -1809,7 +1809,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         <refsection>
             <title>See Also</title>
-            <para><xref linkend="CG_StraightSkeleton"/></para>
+            <para><xref linkend="CG_StraightSkeleton"/>, <xref linkend="CG_StraightSkeletonPartition"/></para>
         </refsection>
     </refentry>
@@ -2116,7 +2116,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         </refsection>
         <refsection>
-            <para><xref linkend="ST_Extrude" />, <xref linkend="CG_StraightSkeleton" /></para>
+            <para><xref linkend="ST_Extrude" />, <xref linkend="CG_ExtrudeStraightSkeleton" />, <xref linkend="CG_StraightSkeleton" />,  <xref linkend="CG_StraightSkeletonPartition" /> </para>
         </refsection>
     </refentry>
@@ -3032,10 +3032,39 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         <title>Examples</title>
         <programlisting>SELECT ST_AsText(CG_StraightSkeletonPartition('POLYGON((0 0, 4 0, 2 2, 0 0))', true));
 -- Result: MULTIPOLYGON(((0 0,2 0.83,2 2)),((4 0,2 0.83,0 0)),((2 2,2 0.83,4 0)))</programlisting>
+        <programlisting>SELECT CG_StraightSkeletonPartition(ST_GeomFromText('POLYGON (( 190 190, 10 190, 10 10, 190 10, 190 20, 160 30, 60 30, 60 130, 190 140, 190 190 ))', true);</programlisting>
+        <informaltable>
+            <tgroup cols="2">
+                <tbody>
+                    <row>
+                        <entry><para><informalfigure>
+                                    <mediaobject>
+                                        <imageobject>
+                                            <imagedata fileref="images/st_straightskeleton01.png"/>
+                                        </imageobject>
+                                        <caption><para>Original polygon</para></caption>
+                                    </mediaobject>
+                            </informalfigure></para>
+                        </entry>
+                                    <mediaobject>
+                                        <imageobject>
+                                            <imagedata fileref="images/cg_straightskeletonpartition01.png"/>
+                                        </imageobject>
+                                        <caption><para>Straight Skeleton Partition of polygon</para></caption>
+                                    </mediaobject>
+                        </entry>
+                    </row>
+                </tbody>
+            </tgroup>
+        </informaltable>
     </refsection>
     <refsection>
-        <para><xref linkend="ST_StraightSkeleton"/>, <xref linkend="ST_Polygonize"/></para>
+        <para><xref linkend="CG_StraightSkeleton"/>, <xref linkend="ST_Polygonize"/></para>
     </refsection>
 </refentry>
Summary of changes:
 doc/html/images/Makefile.in                        |  1 +
 .../images/wkt/cg_straightskeletonpartition01.wkt  |  9 ++++++
 doc/reference_sfcgal.xml                           | 35 ++++++++++++++++++++--
 3 files changed, 42 insertions(+), 3 deletions(-)
 create mode 100644 doc/html/images/wkt/cg_straightskeletonpartition01.wkt
hooks/post-receive
