[SCM] PostGIS branch master updated. 3.5.0-233-g1d0c40a01
    git at osgeo.org
    git at osgeo.org
    Sun Mar 30 14:38:33 PDT 2025
the project "PostGIS".
       via  1d0c40a017cca46d0bb61eaf735feda70a554605 (commit)
      from  9637dc369361ac118e1ad37da7a519dae9dfab5e (commit)
revisions in full, below.
commit 1d0c40a017cca46d0bb61eaf735feda70a554605
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Mar 30 17:38:26 2025 -0400
    Fix error in example, and change image output to be single color.  Add extra link
diff --git a/doc/html/images/wkt/cg_straightskeletonpartition01.wkt b/doc/html/images/wkt/cg_straightskeletonpartition01.wkt
index 7f305a64d..bdf0ba9aa 100644
--- a/doc/html/images/wkt/cg_straightskeletonpartition01.wkt
+++ b/doc/html/images/wkt/cg_straightskeletonpartition01.wkt
@@ -1,9 +1,9 @@
 ArgA;POLYGON((190 190,164.03987973986756 164.03987973986756,190 140))
-ArgB;POLYGON((10 190,40.697077206292434 159.30292279370755,164.03987973986756 164.03987973986756,190 190))
+ArgA;POLYGON((10 190,40.697077206292434 159.30292279370755,164.03987973986756 164.03987973986756,190 190))
 ArgA;POLYGON((10 10,35 35,35 153.15077848154866,40.697077206292434 159.30292279370755,10 190))
-ArgB;POLYGON((190 10,184.18861169915812 15.811388300841896,158.3772233983162 20,50 20,35 35,10 10))
+ArgA;POLYGON((190 10,184.18861169915812 15.811388300841896,158.3772233983162 20,50 20,35 35,10 10))
 ArgA;POLYGON((190 20,184.18861169915812 15.811388300841896,190 10))
-ArgB;POLYGON((160 30,158.3772233983162 20,184.18861169915812 15.811388300841896,190 20))
+ArgA;POLYGON((160 30,158.3772233983162 20,184.18861169915812 15.811388300841896,190 20))
 ArgA;POLYGON((60 30,50 20,158.3772233983162 20,160 30))
-ArgB;POLYGON((60 130,35 153.15077848154866,35 35,50 20,60 30))
+ArgA;POLYGON((60 130,35 153.15077848154866,35 35,50 20,60 30))
 ArgA;POLYGON((190 140,164.03987973986756 164.03987973986756,40.697077206292434 159.30292279370755,35 153.15077848154866,60 130))
\ No newline at end of file
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index 45e88a42d..225963886 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -2592,7 +2592,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         <refsection>
             <title>See Also</title>
-            <para><xref linkend="CG_ExtrudeStraightSkeleton" /></para>
+            <para><xref linkend="CG_StraightSkeletonPartition" />, <xref linkend="CG_ExtrudeStraightSkeleton" /></para>
         </refsection>
     </refentry>
@@ -3033,7 +3033,9 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         <programlisting>SELECT ST_AsText(CG_StraightSkeletonPartition('POLYGON((0 0, 4 0, 2 2, 0 0))', true));
 -- Result: MULTIPOLYGON(((0 0,2 0.83,2 2)),((4 0,2 0.83,0 0)),((2 2,2 0.83,4 0)))</programlisting>
-        <programlisting>SELECT CG_StraightSkeletonPartition(ST_GeomFromText('POLYGON (( 190 190, 10 190, 10 10, 190 10, 190 20, 160 30, 60 30, 60 130, 190 140, 190 190 ))', true);</programlisting>
+        <programlisting>SELECT CG_StraightSkeletonPartition(ST_GeomFromText('POLYGON (( 190 190, 10 190, 10 10, 190 10, 190 20
+            , 160 30, 60 30, 60 130, 190 140, 190 190 ))')
+            , true );</programlisting>
         <informaltable>
             <tgroup cols="2">
                 <tbody>
Summary of changes:
 doc/html/images/wkt/cg_straightskeletonpartition01.wkt | 8 ++++----
 doc/reference_sfcgal.xml                               | 6 ++++--
 2 files changed, 8 insertions(+), 6 deletions(-)
hooks/post-receive
