[SCM] PostGIS branch master updated. 3.5.0-236-g38f849b80
    git at osgeo.org
    git at osgeo.org
    Mon Mar 31 08:47:46 PDT 2025
the project "PostGIS".
       via  38f849b803ca79fb94701f466bca00fe311e9b0a (commit)
       via  af1ffd63891fadc95a4a102cdfa014defc7f6e93 (commit)
      from  9ba7f79196adbc11f9f742d95c3fd567b58a5338 (commit)
revisions in full, below.
commit 38f849b803ca79fb94701f466bca00fe311e9b0a
Author: luca <lucadeluge at gmail.com>
Date:   Mon Mar 31 14:32:07 2025 +0000
    Translated PostGIS Manual using Weblate (Italian)
    Currently translated at 25.5% (1471 of 5756 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/it/
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index 2c83f0a79..637d6430e 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -4,13 +4,14 @@
 # Regina Obe <regina at arrival3d.com>, 2023.
 # Sandro Santilli <strk at kbt.io>, 2024.
 # DeepL <noreply-mt-deepl at weblate.org>, 2025.
+# luca <lucadeluge at gmail.com>, 2025.
 msgid ""
 msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-11-19 11:58+0000\n"
 "PO-Revision-Date: 2025-03-31 15:47+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"Last-Translator: luca <lucadeluge at gmail.com>\n"
 "Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/it/>\n"
 "Language: it_IT\n"
@@ -2025,9 +2026,9 @@ msgid ""
 "The set of rules matching the input and the corresponding score for each. "
 "The first rule (highest scoring) is what is used for standardization"
 msgstr ""
-"L'insieme delle regole che corrispondono all'input e il punteggio "
-"corrispondente per ciascuna di esse. La prima regola (con il punteggio più "
-"alto) è quella utilizzata per la standardizzazione."
+"L'insieme delle regole che corrispondono all'input e il punteggio relativo "
+"per ciascuna di esse. La prima regola (con il punteggio più alto) è quella "
+"utilizzata per la standardizzazione."
 #. Tag: para
 #, no-c-format
commit af1ffd63891fadc95a4a102cdfa014defc7f6e93
Author: DeepL <noreply-mt-deepl at weblate.org>
Date:   Mon Mar 31 14:32:54 2025 +0000
index a9eee6d9e..2c83f0a79 100644
@@ -9,7 +9,7 @@ msgstr ""
-"PO-Revision-Date: 2025-03-31 14:32+0000\n"
+"PO-Revision-Date: 2025-03-31 15:47+0000\n"
@@ -2035,11 +2035,14 @@ msgid ""
 "The standardized address elements <xref linkend=\"stdaddr\"/> that would be "
 "returned when running <xref linkend=\"standardize_address\"/>"
 msgstr ""
+"Gli elementi di indirizzo standardizzati <xref linkend=\"stdaddr\"/> che "
+"verrebbero restituiti durante l'esecuzione di <xref linkend="
+"\"standardize_address\"/>"
 #. Tag: para
 #, no-c-format
 msgid "Availability: 3.4.0"
-msgstr ""
+msgstr "Disponibilità: 3.4.0"
 #. Tag: title
 #, no-c-format
@@ -2049,12 +2052,13 @@ msgstr "Esempi"
 #. Tag: para
 #, no-c-format
 msgid "Using address_standardizer_data_us extension"
-msgstr ""
+msgstr "Utilizzo dell'estensione address_standardizer_data_us"
 #. Tag: para
 #, no-c-format
 msgid "Variant 1: Single line address and returning the input tokens"
 msgstr ""
+"Variante 1: indirizzo a riga singola e restituzione dei token di ingresso"
 #. Tag: para
 #, no-c-format
@@ -2062,6 +2066,8 @@ msgid ""
 "Variant 2: Multi line address and returning first rule input mappings and "
 "score"
 msgstr ""
+"Variante 2: indirizzo multilinea e restituzione delle mappature di ingresso "
+"della prima regola e del punteggio"
 #. Tag: title
 #, no-c-format
@@ -2074,11 +2080,13 @@ msgid ""
 ", <xref linkend=\"rulestab\"/>, <xref linkend=\"lextab\"/>, <xref "
 "linkend=\"gaztab\"/>, <xref linkend=\"Pagc_Normalize_Address\"/>"
 msgstr ""
+", <xref linkend=\"rulestab\"/>, <xref linkend=\"lextab\"/>, <xref linkend="
+"\"gaztab\"/>, <xref linkend=\"Pagc_Normalize_Address\"/>"
 #. Tag: refpurpose
 #, no-c-format
 msgid "Takes a 1 line address and breaks into parts"
-msgstr ""
+msgstr "Prende un indirizzo di 1 riga e lo suddivide in parti"
 #. Tag: para
 #, no-c-format
@@ -2098,12 +2106,12 @@ msgstr "Disponibilità: 2.2.0"
 #. Tag: para
 #, no-c-format
 msgid "Single Address"
-msgstr ""
+msgstr "Indirizzo singolo"
 #. Tag: para
 #, no-c-format
 msgid "Table of addresses"
-msgstr ""
+msgstr "Tabella degli indirizzi"
 #. Tag: refpurpose
 #, no-c-format
@@ -2123,7 +2131,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Variant 1: Takes an address as a single line."
-msgstr ""
+msgstr "Variante 1: prende un indirizzo come una singola riga."
 #. Tag: para
 #, no-c-format
@@ -2139,6 +2147,8 @@ msgstr ""
 msgid ""
 "Variant 1: Single line address. This doesn't work well with non-US addresses"
 msgstr ""
+"Variante 1: indirizzo a riga singola. Non funziona bene con gli indirizzi "
+"non statunitensi."
 #. Tag: para
 #, no-c-format
@@ -2157,7 +2167,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Variant 2: As a two part Address"
-msgstr ""
+msgstr "Variante 2: come indirizzo in due parti"
 #. Tag: title
 #, no-c-format
Summary of changes:
 doc/po/it_IT/postgis-manual.po | 35 +++++++++++++++++++++++------------
 1 file changed, 23 insertions(+), 12 deletions(-)
hooks/post-receive
