[SCM] PostGIS branch master updated. 3.6.0rc2-196-gc6f24e941
git at osgeo.org
git at osgeo.org
Wed Nov 12 11:04:27 PST 2025
the project "PostGIS".
via c6f24e9419fc0d0ee6bc73448791dfd743e9ced0 (commit)
via 26639a287dfb03c669c599105fbdac1a07bad29e (commit)
via 4748b533671032e8078870660757ab3a9b80fdf2 (commit)
from 315d6b7d248c460ef9d6cdec4520228b9a42ef20 (commit)
revisions in full, below.
commit c6f24e9419fc0d0ee6bc73448791dfd743e9ced0
Author: Regina Obe <lr at pcorp.us>
Date: Tue Nov 11 00:36:49 2025 -0500
Topogeometry corruption fix
- Fix for topogeometry corruption
- Add tests
- Add documentation for new function
References #5983 for PostGIS 3.7.0
References https://gitea.osgeo.org/postgis/postgis/pulls/274
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 640bee1fb..d50276dd4 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -553,6 +553,57 @@ Rename a topology from <varname>topo_stage</varname> to <varname>topo_prod</varn
</refsection>
</refentry>
+ <refentry xml:id="FixCorruptTopoGeometryColumn">
+ <refnamediv>
+ <refname>FixCorruptTopoGeometryColumn</refname>
+ <refpurpose>Fixes topogeometry corruption caused by upgrade to postgis_topology 3.6.0 and higher</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>text <function>FixCorruptTopoGeometryColumn</function></funcdef>
+ <paramdef><type>name </type>
+ <parameter>layerSchema</parameter></paramdef>
+ <parameter>layerTable</parameter></paramdef>
+ <parameter>layerColumn </parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>
+When upgrading from PostGIS topology <3.6.0 to version >3.6.0+, the topogeometry column definition was changed.
+This caused corruption in topogeometries created before the upgrade. This function fixes this corruption in affected tables.
+ </para>
+ <!-- use this format if new function -->
+ <para role="availability" conformance="3.6.1">Availability: 3.6.1</para>
+ </refsection>
+ <refsection>
+ <title>Examples</title>
+ <para>Fix all topology columns</para>
+ <programlisting>
+SELECT topology.FixCorruptTopoGeometryColumn(schema_name, table_name, feature_column)
+ FROM topology.layer;
+ </programlisting>
+ </refsection>
+ <!-- Optionally add a "See Also" section -->
+ <refsection>
+ <title>See Also</title>
+ <para>
+ <xref linkend="UpgradeTopology"/>
+ </para>
+ </refsection>
+ </refentry>
<refentry xml:id="Populate_Topology_Layer">
<refnamediv>
<refname>Populate_Topology_Layer</refname>
diff --git a/topology/sql/manage/FixCorruptTopoGeometryColumn.sql.in b/topology/sql/manage/FixCorruptTopoGeometryColumn.sql.in
index 869a09ce6..ccfbc83b3 100644
--- a/topology/sql/manage/FixCorruptTopoGeometryColumn.sql.in
+++ b/topology/sql/manage/FixCorruptTopoGeometryColumn.sql.in
@@ -18,30 +18,50 @@
CREATE OR REPLACE FUNCTION topology.FixCorruptTopoGeometryColumn(layerSchema name, layerTable name, layerColumn name)
RETURNS text AS
-DECLARE var_sql text; var_row_count bigint; result text;
+DECLARE var_sql text; var_row_count bigint; result text; var_create_index_sql text; var_drop_index_sql text;
BEGIN
+ result = '';
-- if topogeometry is bigint, then fix damaged integer, need to upgrade to bigint
IF EXISTS ( SELECT 1
FROM pg_catalog.pg_type AS pg_type
JOIN pg_catalog.pg_class AS pg_class ON pg_class.oid = pg_type.typrelid
JOIN pg_catalog.pg_attribute AS pga ON pga.attrelid = pg_class.oid
JOIN pg_catalog.pg_type AS pg_attr_type on pg_attr_type.oid = pga.atttypid
-WHERE pg_type.typname::regtype::text = 'topogeometry' AND pga.attname = 'id'
+WHERE pg_type.typname = 'topogeometry' AND pga.attname = 'id'
AND
pg_type.typnamespace::regnamespace::text = 'topology' AND pga.atttypid::regtype::text = 'bigint' ) THEN
+ -- generate index scripts to create and drop indexes that are based on the column
+ IF EXISTS( SELECT 1 FROM pg_indexes WHERE schemaname = layerSchema AND tablename = layerTable AND indexdef LIKE '%(' || layerColumn || ')%' ) THEN
+ SELECT string_agg(indexdef, ';'), string_agg('DROP INDEX ' || quote_ident(schemaname) || '.' || quote_ident(indexname), ';') INTO var_create_index_sql, var_drop_index_sql
+ FROM pg_indexes
+ WHERE schemaname = layerSchema
+ AND tablename = layerTable AND indexdef LIKE ('%(' || layerColumn || ')%');
+ END IF;
+ IF var_drop_index_sql > '' THEN
+ EXECUTE var_drop_index_sql;
+ END IF;
+ -- correct any corrupt topogeometries and fix
var_sql = format('UPDATE %1$I.%2$I
SET
%3$I = (
(%3$I).topology_id,
(%3$I).layer_id,
- (%3$I).id & 0xFFFFFFFF,
- (%3$I).id >> 32
+ ((%3$I).id & 0xFFFFFFFF)::bigint,
+ ((%3$I).id >> 32)::integer
)::topology.topogeometry
- WHERE ( (%3$I).id & 0xFFFFFFFF ) <> (%3$I).id OR ( (%3$I).id >> 32 ) = (%3$I).type ', layerSchema, layerTable, layerColumn);
+ WHERE ( (%3$I).id & 0xFFFFFFFF )::bigint <> (%3$I).id OR ( (%3$I).id >> 32 )::integer = (%3$I).type ', layerSchema, layerTable, layerColumn);
EXECUTE var_sql;
GET DIAGNOSTICS var_row_count = ROW_COUNT;
- result = format('%s rows updated for %s.%s.%s column to bigint id type', var_row_count, layerSchema, layerTable, layerColumn);
+ IF var_create_index_sql > '' THEN
+ EXECUTE var_create_index_sql;
+ result = result || E'\n' || 'Recreating indexes';
+ END IF;
+ result = result || E'\n' || format('%s rows updated for %s.%s.%s column to bigint id type', var_row_count, layerSchema, layerTable, layerColumn);
ELSE --we are coming from bigint and going back to integer
SET
@@ -55,7 +75,7 @@ WHERE pg_type.typname::regtype::text = 'topogeometry' AND pga.attname = 'id'
WHERE l.topology_id = (%3$I).topology_id AND l.layer_id = (%3$I).layer_id AND (%3$I).type <> l.feature_type ', topo_schema, topo_table, topo_column);
EXECUTE var_sql;
- result = format('%s rows updated for %s.%s.%s column back to integer id type', var_row_count, topo_schema, topo_table, topo_column);
+ result = result || format('%s rows updated for %s.%s.%s column back to integer id type', var_row_count, topo_schema, topo_table, topo_column);
END IF;
RETURN result;
END
diff --git a/topology/test/regress/fix_topogeometry_columns.sql b/topology/test/regress/fix_topogeometry_columns.sql
new file mode 100644
index 000000000..4849b6bf5
--- /dev/null
+++ b/topology/test/regress/fix_topogeometry_columns.sql
@@ -0,0 +1,13 @@
+set client_min_messages to WARNING;
+\i :top_builddir/topology/test/load_topology-4326.sql
+\i ../load_features.sql
+\i ../more_features.sql
+\i ../hierarchy.sql
+SELECT * FROM topology.layer;
+FROM topology.layer
+WHERE schema_name > '' AND table_name > '' AND feature_column > '';
+SELECT topology.DropTopology('city_data');
+DROP SCHEMA features CASCADE;
diff --git a/topology/test/regress/fix_topogeometry_columns_expected b/topology/test/regress/fix_topogeometry_columns_expected
index 000000000..feab46c95
--- /dev/null
+++ b/topology/test/regress/fix_topogeometry_columns_expected
@@ -0,0 +1,13 @@
+162|1|features|land_parcels|feature|3|0|
+162|2|features|traffic_signs|feature|1|0|
+162|3|features|city_streets|feature|2|0|
+162|4|features|big_parcels|feature|3|1|1
+162|5|features|big_streets|feature|2|1|3
+162|6|features|big_signs|feature|1|1|2
+0 rows updated for features.land_parcels.feature column to bigint id type
+0 rows updated for features.traffic_signs.feature column to bigint id type
+0 rows updated for features.city_streets.feature column to bigint id type
+0 rows updated for features.big_parcels.feature column to bigint id type
+0 rows updated for features.big_streets.feature column to bigint id type
+0 rows updated for features.big_signs.feature column to bigint id type
+Topology 'city_data' dropped
diff --git a/topology/test/regress/hooks/hook-after-upgrade-topology.sql b/topology/test/regress/hooks/hook-after-upgrade-topology.sql
index 936b86319..c9b25bb51 100644
--- a/topology/test/regress/hooks/hook-after-upgrade-topology.sql
+++ b/topology/test/regress/hooks/hook-after-upgrade-topology.sql
@@ -1,8 +1,24 @@
+\d upgrade_test.feature
+-- https://trac.osgeo.org/postgis/ticket/5983
-- See https://trac.osgeo.org/postgis/ticket/5102
SELECT topology.CopyTopology('upgrade_test', 'upgrade_test_copy');
+INSERT INTO upgrade_test.domain_test values (
+ '{1,2}'::topology.topoelement,
+ '{{2,3}}'::topology.topoelementarray
--- check if corruption
-select geometrytype(tg) from upgrade_test.feature limit 2;
SELECT topology.DropTopology('upgrade_test');
SELECT topology.DropTopology('upgrade_test_copy');
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 383e38ccf..0b0ab3ff9 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -97,4 +97,6 @@ TESTS += \
$(top_srcdir)/topology/test/regress/validatetopologyrelation_large.sql \
$(top_srcdir)/topology/test/regress/validatetopology.sql \
$(top_srcdir)/topology/test/regress/validatetopology_large.sql \
- $(top_srcdir)/topology/test/regress/verifylargeids.sql
+ $(top_srcdir)/topology/test/regress/verifylargeids.sql \
+ $(top_srcdir)/topology/test/regress/fix_topogeometry_columns.sql
commit 26639a287dfb03c669c599105fbdac1a07bad29e
Date: Thu Oct 30 00:08:40 2025 -0400
WIP: fix topogeometry column function addition
diff --git a/topology/Makefile.in b/topology/Makefile.in
index ce7cbb350..608f5e76a 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -141,6 +141,7 @@ topology.sql: \
sql/manage/CreateTopology.sql.in \
sql/manage/FindLayer.sql.in \
sql/manage/FindTopology.sql.in \
+ sql/manage/FixCorruptTopoGeometryColumn.sql.in \
sql/manage/ManageHelper.sql.in \
sql/manage/MakeTopologyPrecise.sql.in \
sql/manage/TotalTopologySize.sql.in \
index 000000000..869a09ce6
--- /dev/null
@@ -0,0 +1,63 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- https://postgis.net
+-- Copyright (C) 2025 Regina Obe <lr at pcorp.us>
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public License. See the COPYING file.
+-- FixCorruptTopGeometryColumn((layerSchema name, layerTable name, layerColumn name)
+-- Needed to fix corruption of topogeometries caused by upgrade from < 3.6.0 to 3.6.0 and higher
+-- Availability: 3.6.1
+CREATE OR REPLACE FUNCTION topology.FixCorruptTopoGeometryColumn(layerSchema name, layerTable name, layerColumn name)
+RETURNS text AS
+BEGIN
+ -- if topogeometry is bigint, then fix damaged integer, need to upgrade to bigint
+ IF EXISTS ( SELECT 1
+ FROM pg_catalog.pg_type AS pg_type
+ JOIN pg_catalog.pg_class AS pg_class ON pg_class.oid = pg_type.typrelid
+ JOIN pg_catalog.pg_attribute AS pga ON pga.attrelid = pg_class.oid
+ JOIN pg_catalog.pg_type AS pg_attr_type on pg_attr_type.oid = pga.atttypid
+WHERE pg_type.typname::regtype::text = 'topogeometry' AND pga.attname = 'id'
+ AND
+ pg_type.typnamespace::regnamespace::text = 'topology' AND pga.atttypid::regtype::text = 'bigint' ) THEN
+ var_sql = format('UPDATE %1$I.%2$I
+ SET
+ %3$I = (
+ (%3$I).topology_id,
+ (%3$I).layer_id,
+ (%3$I).id & 0xFFFFFFFF,
+ (%3$I).id >> 32
+ )::topology.topogeometry
+ WHERE ( (%3$I).id & 0xFFFFFFFF ) <> (%3$I).id OR ( (%3$I).id >> 32 ) = (%3$I).type ', layerSchema, layerTable, layerColumn);
+ EXECUTE var_sql;
+ GET DIAGNOSTICS var_row_count = ROW_COUNT;
+ result = format('%s rows updated for %s.%s.%s column to bigint id type', var_row_count, layerSchema, layerTable, layerColumn);
+ ELSE --we are coming from bigint and going back to integer
+ SET
+ %3$I = (
+ (%3$I).layer_id,
+ (%3$I).id,
+ l.feature_type
+ )::topogeometry
+ FROM topology.layer AS l
+ WHERE l.topology_id = (%3$I).topology_id AND l.layer_id = (%3$I).layer_id AND (%3$I).type <> l.feature_type ', topo_schema, topo_table, topo_column);
+ EXECUTE var_sql;
+ result = format('%s rows updated for %s.%s.%s column back to integer id type', var_row_count, topo_schema, topo_table, topo_column);
+ END IF;
+ RETURN result;
+END
+$$ language plpgsql;
index 248b6206f..936b86319 100644
@@ -1,6 +1,9 @@
+-- check if corruption
+select geometrytype(tg) from upgrade_test.feature limit 2;
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 96095fd5b..c364af34d 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1417,6 +1417,7 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
#include "sql/manage/CopyTopology.sql.in"
#include "sql/manage/FindTopology.sql.in"
#include "sql/manage/FindLayer.sql.in"
+#include "sql/manage/FixCorruptTopoGeometryColumn.sql.in"
#include "sql/manage/populate_topology_layer.sql.in"
#include "sql/manage/RenameTopology.sql.in"
#include "sql/manage/ValidateTopology.sql.in"
commit 4748b533671032e8078870660757ab3a9b80fdf2
Date: Wed Nov 12 12:22:24 2025 -0500
Fix xml entities issue in UK docs
diff --git a/doc/po/uk/postgis-manual.po b/doc/po/uk/postgis-manual.po
index 1881aa1a4..a28b267b1 100644
--- a/doc/po/uk/postgis-manual.po
+++ b/doc/po/uk/postgis-manual.po
@@ -40089,7 +40089,7 @@ msgstr ""
"DE-9IM визначається як 9-елементна матриця, що вказує розмір перетинів між "
"внутрішньою, межовою та зовнішньою частинами двох геометрій. Він "
"представлений 9-символьним текстовим рядком із використанням символів 'F', "
-"'0', '1', '2' (наприклад, <code>“FF1FF0102”</code>)."
+"'0', '1', '2' (наприклад, <code>\"FF1FF0102\"</code>)."
#. Tag: para
#, no-c-format
@@ -40232,8 +40232,8 @@ msgid ""
msgstr ""
"<code>3</code>: <emphasis role=\"bold\">MultivalentEndpoint</emphasis> - "
"кінцеві точки знаходяться в межі, якщо вони зустрічаються більше одного "
-"разу. Іншими словами, межа - це всі «приєднані» або «внутрішні» кінцеві "
-"точки (але не «неприєднані/зовнішні»)."
+"разу. Іншими словами, межа - це всі \"приєднані\" або \"внутрішні\" кінцеві "
+"точки (але не \"неприєднані/зовнішні\")."
#. Tag: para
#, no-c-format
@@ -40244,7 +40244,7 @@ msgid ""
msgstr ""
"<code>4</code>: <emphasis role=\"bold\">MonovalentEndpoint</emphasis> - "
"кінцеві точки знаходяться в межі, якщо вони зустрічаються тільки один раз. "
-"Іншими словами, межа - це всі «неприєднані» або «зовнішні» кінцеві точки."
+"Іншими словами, межа - це всі \"неприєднані\" або \"зовнішні\" кінцеві точки."
#. Tag: para
#, no-c-format
@@ -40351,7 +40351,7 @@ msgid ""
"be computed by <xref linkend=\"ST_Relate\"/>."
msgstr ""
"Перевіряє, чи значення <varname>intersectionMatrix</varname> моделі <link "
-"xlink:href=«http://en.wikipedia.org/wiki/DE-9IM»>Dimensionally Extended 9-"
+"xlink:href=\"http://en.wikipedia.org/wiki/DE-9IM\">Dimensionally Extended 9-"
"Intersection Model</link> (DE-9IM) відповідає "
"<varname>intersectionMatrixPattern</varname>. Значення матриці перетину "
"можна обчислити за допомогою <xref linkend=\"ST_Relate\"/>."
@@ -41379,7 +41379,7 @@ msgid ""
msgstr ""
"<emphasis role=\"bold\">Агрегатний варіант:</emphasis> повертає геометрію, "
"яка є 3D об'єднанням набору рядків геометрій. Функція ST_3DUnion() є "
-"«агрегатною» функцією в термінології PostgreSQL. Це означає, що вона оперує "
+"\"агрегатною\" функцією в термінології PostgreSQL. Це означає, що вона оперує "
"рядками даних так само, як функції SUM() і AVG(), і, як і більшість "
"агрегатів, ігнорує геометрії NULL."
@@ -41399,7 +41399,7 @@ msgid ""
msgstr ""
"яка є 3D об'єднанням набору рядків геометрій. Функція CG_3DUnion() є "
@@ -41460,7 +41460,7 @@ msgid ""
"produce more concave results. Alpha values greater than some data-dependent "
"value produce the convex hull of the input."
msgstr ""
-"«Тіснота прилягання» контролюється параметром <varname>alpha</varname>, який "
+"\"Тіснота прилягання\" контролюється параметром <varname>alpha</varname>, який "
"може мати значення від 0 до нескінченності. Менші значення альфа дають більш "
"увігнуті результати. Значення альфа, більші за певне значення, що залежить "
"від даних, дають опуклу оболонку вхідних даних."
@@ -41477,7 +41477,7 @@ msgid ""
"which defines alpha as the radius of the eroding disc."
msgstr ""
"Після впровадження CGAL значення альфа є <emphasis>квадратом</emphasis> "
-"радіуса диска, що використовується в алгоритмі Alpha-Shape для «ерозії» "
+"радіуса диска, що використовується в алгоритмі Alpha-Shape для \"ерозії\" "
"триангуляції Делоне вхідних точок. Докладнішу інформацію див. у <link "
"xlink:href=\"https://doc.cgal.org/latest/Alpha_shapes_2/index.html#"
"Chapter_2D_Alpha_Shapes\">CGAL Alpha-Shapes</link>. Це відрізняється від "
Summary of changes:
doc/extras_topology.xml | 51 +++++++++++++
doc/po/uk/postgis-manual.po | 18 ++---
topology/Makefile.in | 1 +
.../sql/manage/FixCorruptTopoGeometryColumn.sql.in | 83 ++++++++++++++++++++++
topology/test/regress/fix_topogeometry_columns.sql | 13 ++++
.../test/regress/fix_topogeometry_columns_expected | 13 ++++
.../regress/hooks/hook-after-upgrade-topology.sql | 19 +++++
topology/test/tests.mk | 4 +-
topology/topology.sql.in | 1 +
9 files changed, 193 insertions(+), 10 deletions(-)
create mode 100644 topology/sql/manage/FixCorruptTopoGeometryColumn.sql.in
create mode 100644 topology/test/regress/fix_topogeometry_columns.sql
create mode 100644 topology/test/regress/fix_topogeometry_columns_expected
hooks/post-receive
