[SCM] postgis.net branch website updated. clarity-final-164-g2138b6c
git at osgeo.org
git at osgeo.org
Wed Nov 19 23:02:32 PST 2025
the project "postgis.net".
The branch, website has been updated
via 2138b6cf3caa40b2ad14566b7f948f5926146f03 (commit)
from b15eee7a50004f296ab618d4e7a551f37f60387b (commit)
revisions in full, below.
commit 2138b6cf3caa40b2ad14566b7f948f5926146f03
Author: Regina Obe <lr at pcorp.us>
Date: Thu Nov 20 02:02:22 2025 -0500
Announce release of PostGIS 3.6.1 windows bundle for PostgreSQL 18
diff --git a/content/documentation/getting_started/install_windows/enabling_postgis.md b/content/documentation/getting_started/install_windows/enabling_postgis.md
index c1fde57..e81d0ee 100644
--- a/content/documentation/getting_started/install_windows/enabling_postgis.md
+++ b/content/documentation/getting_started/install_windows/enabling_postgis.md
@@ -25,7 +25,7 @@ CREATE EXTENSION fuzzystrmatch;
CREATE EXTENSION postgis_tiger_geocoder;
--- need to upgrade the postgis packaged extensions do
+-- need to upgrade the postgis packaged extensions do
SELECT postgis_extensions_upgrade();
@@ -45,7 +45,7 @@ CREATE EXTENSION pgrouting;
-- for upgrading an existing install
ALTER EXTENSION pgrouting UPDATE;
--- see version details
+-- see version details
SELECT * FROM pgr_full_version();
@@ -59,7 +59,7 @@ These extension you'll find in the `extras` PostgreSQL versioned folder if you w
and non-spatial data sources
Note if you get an error accessing https sources,
you need to define the CURL_CA_BUNDLE system environment variable to something like
- C:\Program Files\PostgreSQL\15\ssl\certs\ca-bundle.crt
+ C:\Program Files\PostgreSQL\15\ssl\certs\ca-bundle.crt
This is an option in installer for PostGIS 3.4.1 bundle and above**/
CREATE EXTENSION ogr_fdw;
@@ -86,6 +86,7 @@ You will also find available in the `extras` [PostgreSQL versioned](https://winn
```postgres
-- confirm you don't have any existing pre-loaded libraries,
-- if you do make sure to readd when alter system
+-- This seems to be no longer needed for MobilityDb 1.3.0 and up (which is part of PostGIS 3.6 bundles)
SHOW shared_preload_libraries;
ALTER SYSTEM SET shared_preload_libraries = 'postgis-3';
@@ -103,7 +104,7 @@ Now you are ready to enable mobilitydb in a database.
CREATE EXTENSION mobilitydb;
-- show current version and dependencies
SELECT mobilitydb_full_version();
--- updating existing install
+-- updating existing install
ALTER EXTENSION mobilitydb UPDATE;
@@ -117,13 +118,14 @@ See the [Getting Started]({{< ref "/documentation/getting_started/" >}}) section
#### pgSphere
[pgSphere](https://pgsphere.org) is an extension used for managing spherical geometries. It is used primarily for managing astrononomical data.
-It has no reliance on PostGIS. It is not yet packaged with the PostGIS bundle, but will be in the future. You will find the binaries
+It has no reliance on PostGIS. PostGIS Windows Bundle 3.6.1 is the first version of the bundle to include this. You will find the binaries
for it in the respective *extras* folder of each [PostgreSQL buildbot folder][1] of the respective PostgreSQL versions.
To install, copy the files into your PostgreSQL install and run in your databases of choice
CREATE EXTENSION pg_sphere;
+SELECT pg_sphere_version();
[1]: https://winnie.postgis.net/download/windows/
diff --git a/content/documentation/getting_started/install_windows/released_versions.md b/content/documentation/getting_started/install_windows/released_versions.md
index bb6d0d8..5e19155 100644
--- a/content/documentation/getting_started/install_windows/released_versions.md
+++ b/content/documentation/getting_started/install_windows/released_versions.md
@@ -6,20 +6,20 @@ geekdocHidden: true
geekdocHiddenTocTree: false
-PostGIS 3.6.0 came out Sept 2nd, 2025. Windows PostGIS Bundle 3.6.0 installers for PostgreSQL 18 was last released Oct 13th 2025.
+PostGIS 3.6.1 came out Nov 13th, 2025. Windows PostGIS Bundle 3.6.1 installers for PostgreSQL 18 was last released Nov 20th 2025.
Binaries for versions of PostgreSQL 13-18 (64-bit) available in `Unreleased PostGIS Versions` and [OSGeo downloads][5]). Installers for 18(64-bit) available on [OSGeo downloads][5] and application stackbuilder.
-Installers for PostgreSQL 13-17 will be available when PostGIS 3.6.1 comes out.
+Installers for PostgreSQL 13-17 will be available soon.
-Note that this version does not include shp2pgsql-gui. We plan to include this in the 3.6.1 release after fixing some issues.
+Note: This is the first release that includes pgSphere
-PostGIS 3.6.0 bundle includes:
+PostGIS 3.6.1 bundle includes:
- * PostGIS 3.6.0 with MVT support, with raster, [GEOS](https://libgeos.org/posts/2025-08-21-geos-3-14-released/) 3.14.0, [PROJ](https://proj.org/download.html#past-releases) 8.2.1, [SFCGAL](http://sfcgal.org) support (2.2.0), address_standardizer, topology
- * PostGIS Tiger geocoder extension - Tiger 2024
- * pgRouting 4.0 [pgRouting 4.0.0-alpha](https://docs.pgrouting.org/4.0/en/index.html)
+ * PostGIS 3.6.1 with MVT support, with raster, [GEOS](https://libgeos.org/posts/2025-08-21-geos-3-14-released/) 3.14.1, [PROJ](https://proj.org/download.html#past-releases) 8.2.1, [SFCGAL](http://sfcgal.org) support (2.2.0), address_standardizer, topology
+ * PostGIS Tiger geocoder extension - Tiger 2025
+ * pgRouting 4.0 [pgRouting 4.0.0](https://docs.pgrouting.org/4.0/en/index.html)
* Commandline raster loader (raster2pgsql), shapefile import/export (shp2pgsql,pgsql2shp)
- * Commandline [osm2pgrouting main](https://github.com/pgRouting/osm2pgrouting/wiki/Documentation-for-osm2pgrouting-v2.3) for loading data from .osm files into pgRouting routable format
+ * Commandline [osm2pgrouting 3.0.0](https://github.com/pgRouting/osm2pgrouting/tree/v3.0.0) for loading data from .osm files into pgRouting routable format
* [ogrfdw 1.1.7](https://github.com/pramsey/pgsql-ogr-fdw/releases/tag/v1.1.7) - spatial foreign data wrapper for
reading both spatial (spatial columns become postgis geometry) and non-spatial data. [IMPORT FOREIGN SCHEMA](http://www.postgresonline.com/journal/archives/359-Import-Foreign-Schema-for-ogr_fdw-for-PostgreSQL-9.5.html) support
@@ -29,7 +29,8 @@ PostGIS 3.6.0 bundle includes:
* [h3-pg](https://github.com/zachasme/h3-pg) 4.1.4
for using Uber h3 api and converting h3 index representations to postgis geometry/geography/raster (raster support is new in this release).
* [MobilityDB](https://mobilitydb.com) [v1.3.0-alpha](https://github.com/MobilityDB/MobilityDB/releases/tag/v1.3.0-alpha)
- for managing trajectories. Includes many temporal spatial types and functions for them. Refer to [Enabling PostGIS Extensions: MobilityDb](../enabling_postgis/#mobilitydb) for guidance.
+ for managing trajectories. Includes many temporal spatial and non-spatial types and functions and operators for them. Refer to [Enabling PostGIS Extensions: MobilityDb](../enabling_postgis/#mobilitydb) for guidance.
+ * [pgSphere](https://github.com/postgrespro/pgsphere)[1.5.2](https://github.com/postgrespro/pgsphere/releases/tag/1.5.2) for spherical geometries. (NEW in this release)
The simplest way to get PostGIS on Windows for the EnterpriseDb Windows PostgreSQL distribution is using the StackBuilder.
Summary of changes:
.../install_windows/enabling_postgis.md | 12 +++++++-----
.../install_windows/released_versions.md | 19 ++++++++++---------
2 files changed, 17 insertions(+), 14 deletions(-)
hooks/post-receive
postgis.net
