[SCM] PostGIS branch master updated. 3.6.0rc2-237-geebec8c1c
git at osgeo.org
git at osgeo.org
Sat Nov 29 15:28:18 PST 2025
the project "PostGIS".
via eebec8c1cdf57805289c85ce9e155d386a860256 (commit)
from 69f409965635b20fe42da38f86947c0a6d8aa888 (commit)
revisions in full, below.
commit eebec8c1cdf57805289c85ce9e155d386a860256
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Nov 30 03:27:49 2025 +0400
LLM-friendly gotchas list to make them behave during PostGIS debug
References #5638
diff --git a/doc/SKILL.md b/doc/SKILL.md
new file mode 100644
index 000000000..5d2504c44
--- /dev/null
+++ b/doc/SKILL.md
@@ -0,0 +1,67 @@
+name: postgis-skill
+description: PostGIS-focused SQL tips, tricks and gotchas. Use when in need of dealing with geospatial data in Postgres.
+## Documentation
+ - Make sure every create statement or CTE has descriptive comment `--` in front of it.
+ - Write enough comments so you can deduce what was a requirement in the future and not walk in circles.
+ - Every feature needs to have comprehensive up-to-date documentation near it.
+## Style
+ - PostGIS functions follow their spelling from the manual (`st_segmentize` -> `ST_Segmentize`).
+ - SQL is lowercase unless instructed otherwise.
+ - Values in databases and layers should be absolute as much as possible: store "birthday" or "construction date" instead of "age".
+ - Do not mix tabs and spaces in code.
+ - Add empty lines between logical blocks.
+ - Format the code nicely and consistently.
+ - Call geometry column `geom`; geography column `geog`.
+## Indexing
+ - Create brin for all columns when creating large table that will be used for ad-hoc queries.
+ - If you have cache table that has a primary key, it makes sense to add values into `including` on same index for faster lookup.
+## Debugging
+ - Make sure that error messages towards developer are better than just "500 Internal server error".
+ - Don't stub stuff out with insane fallbacks (like lat/lon=0) - instead make the rest of the code work around data absence and inform user.
+ - SQL files should to be idempotent: drop table if exists + create table as; add some comments to make people grasp queries faster.
+ - Create both "up' and "down/rollback" migration when creating new migrations for ease of iteration.
+ - Check `select postgis_full_version();` to see if all upgrades happened successfully.
+ - Don't run one SQL file from other SQL file - this quickly becomes a mess with relative file paths.
+## Raster
+ - Do not work with GDAL on the filesystem. Import things into database and deal with data there.
+## SQL gotchas
+ - `sum(case when A then 1 else 0 end)` is just `count() filter (where A)`
+ - `row_number() ... = 1` can likely be redone as `order by + limit 1` (possibly with `distinct on` or `lateral`)
+ - `exists(select 1 from ...)` is just `exists(select from ...)`
+ - `tags ->> 'key' = 'value'` is just `tags @> '{"key": "value"}` - works faster for indexes
+ - you can't just create ordered table and then rely on it to be ordered on scan without `order by`
+## PostGIS gotchas
+ - Do not use geometry typmod unless requested (things like `geometry(multilinestring, 4326)`) - use plain `geometry` or `geography` instead. This removes clutter of `ST_Multi` and errors via `ST_SetSRID`.
+ - `ST_UnaryUnion(ST_Collect(geom))` is just `ST_Union(geom)`
+ - `ST_Buffer(geom, 0)` should be `ST_MakeValid(geom)`
+ - `select min(ST_Distance(..))` should be `select ST_Distance() ... order by a <-> b limit 1` to enable knn gist
+ - `order by ST_Distance(c.geog, t.geog)` should be `order by c.geog <-> t.geog`
+ - `ST_UnaryUnion` is a sign you're doing something wrong
+ - `ST_MakeValid` is a sign you're doing something wrong on the previous step
+ - be extra attintive when calling `ST_SetSRID`: check the actual projection of input data, check if it can be set correctly during input (`ST_GeomFromGeoJSON`, `EWKT`-style `SRID=4326;POINT(...`, `EWKB` allow that). Check if `ST_Transform` is needed instead.
+ - when looking for relation between point and polygon, prefer `ST_Intersects` to other topology predicates
+ - when generating complex geometry by walking raster or grid, may make sense to `ST_Simplify(geom, 0)`
+ - to generate neighbourhoods of predictable size, use `ST_ClusterKMeans` with k=2 and `max_radius` set to your distance.
+ - use `ST_AsEWKB` for binary representation instead of `ST_AsWKB` to keep SRID.
+ - Choosing projection:
+ SRID=4326 (2D longlat) when input or output is longitude and latitude and coordinate value is to be shown to user.
+ SRID=3857 (2D Spherical Mercator) when output will be shown on web map, ST_AsMVT, or 2D KNN requests of short distance are to be executed.
+ SRID=4978 (3D XYZ) when performing internal computations, line-of-sight, clustering and averaging across antimeridian. Beware: only use 3D-aware operations, ST_Force3DZ on 2D CRS data before calling ST_Transform to it.
+ - Instead of using `ST_Hexagon` / `ST_HexagonGrid` use `h3` extension.
+ - When you know the data is going to be dumped in binary form, gzipped and moved around, consider using `ST_QuantizeCoordinates` if precision is known.
Summary of changes:
doc/SKILL.md | 67 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
1 file changed, 67 insertions(+)
create mode 100644 doc/SKILL.md
hooks/post-receive
