[SCM] PostGIS branch stable-3.6 updated. 3.6.0-11-gbe2a0ffda
Thu Oct 2 14:08:49 PDT 2025
the project "PostGIS".
The branch, stable-3.6 has been updated
       via  be2a0ffda5b08dca0d94c1498d84b62b83fe76f9 (commit)
      from  d3f3a8bf9e23c32beb28a04c490930fd82cba95d (commit)
revisions in full, below.
commit be2a0ffda5b08dca0d94c1498d84b62b83fe76f9
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Oct 2 14:08:21 2025 -0700
    Fix arc/arc distance to handle more cases such as contained,
    circular, and other interesting arc/arc alignments that come up rarely
    in ordinary GIS data.
    Fix compoundcurve distance calculations, in particular the
    containment test, which was failing for some cases.
    Replaced containment test with a ray casting algorithm
    that makes more sense for circularstrings that the
    winding order algorithm did.
    References #5989
diff --git a/NEWS b/NEWS
index f65470d6f..98e536d63 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,7 @@ PostGIS 3.6.1
   - #5987, ST_GeometryN fails for non-collections (Paul Ramsey)
   - #5991, CircularString distance error (Paul Ramsey)
   - #5994, Null pointer in ST_AsGeoJsonRow (Alexander Kukushkin)
+  - #5998, ST_Distance error on CurvePolygon (Paul Ramsey)
 PostGIS 3.6.0
diff --git a/liblwgeom/cunit/cu_measures.c b/liblwgeom/cunit/cu_measures.c
index 610b2a593..58e7cb4ba 100644
--- a/liblwgeom/cunit/cu_measures.c
+++ b/liblwgeom/cunit/cu_measures.c
@@ -222,6 +222,11 @@ static void test_mindistance2d_tolerance(void)
 	DIST2DTEST(
 		"CURVEPOLYGON(CIRCULARSTRING(7874821 8715927,8907663 8715927,8844683 7750316,7937800 7750316,7874821 8715927))",
 		"POINT(5433865 8243495)", 2271704.2698450615, default_accepted_error);
+	/* Ticket 5989 */
+	DIST2DTEST(
+		"CURVEPOLYGON(COMPOUNDCURVE(CIRCULARSTRING(0 0, -1 5, 0 10), (0 10, -10 10, -10 0, 0 0)))",
+		"POINT(-0.5 5)", 0.5, default_accepted_error);
 static void
@@ -918,6 +923,25 @@ test_lw_dist2d_arc_arc(void)
 	B2.x = 0 ; B2.y = 1;
 	B3.x = 1 ; B3.y = 0;
+	/* Arc inside the semicircle */
+	lw_dist2d_distpts_init(&dl, DIST_MIN);
+	A1.x =  0;   A1.y = .5;
+	A2.x = -0.3; A2.y = .5;
+	A3.x =  0;   A3.y = .6;
+	rv = lw_dist2d_arc_arc(&A1, &A2, &A3, &B1, &B2, &B3, &dl);
+	printf("%g\n", dl.distance);
+	CU_ASSERT_EQUAL( rv, LW_SUCCESS );
+	CU_ASSERT_DOUBLE_EQUAL(dl.distance, 0.271798, 0.000001);
+	A1.x = -0.5; A1.y = .5;
+	A2.x = -0.4; A2.y = .2;
+	A3.x =  0;   A3.y = 0;
+	CU_ASSERT_DOUBLE_EQUAL(dl.distance, 0.292893, 0.000001);
 	/* Arc above the unit semicircle */
 	A1.x = -1; A1.y = 3;
@@ -954,6 +978,15 @@ test_lw_dist2d_arc_arc(void)
 	CU_ASSERT_DOUBLE_EQUAL(dl.distance, 0, 0.000001);
+	/* Closed circle */
+	A1.x = -2.0; A1.y = -0.1;
+	A2.x =  1.5; A2.y = -0.1;
+	A3.x =  -2.0; A3.y = -0.1;
+	CU_ASSERT_DOUBLE_EQUAL(dl.distance, 0.480742, 0.0001);
 	/* Concentric: and fully parallel */
 	A1.x = -2.0; A1.y = 0.0;
diff --git a/liblwgeom/cunit/cu_ptarray.c b/liblwgeom/cunit/cu_ptarray.c
index a28da5cce..99c689ac2 100644
--- a/liblwgeom/cunit/cu_ptarray.c
+++ b/liblwgeom/cunit/cu_ptarray.c
@@ -433,14 +433,14 @@ static void test_ptarrayarc_contains_point()
 	/* int ptarrayarc_contains_point(const POINTARRAY *pa, const POINT2D *pt) */
-	LWLINE *lwline;
+	LWCIRCSTRING *lwcirc;
 	POINTARRAY *pa;
 	POINT2D pt;
 	int rv;
 	/*** Collection of semi-circles surrounding unit square ***/
-	lwline = lwgeom_as_lwline(lwgeom_from_text("LINESTRING(-1 -1, -2 0, -1 1, 0 2, 1 1, 2 0, 1 -1, 0 -2, -1 -1)"));
-	pa = lwline->points;
+	lwcirc = lwgeom_as_lwcircstring(lwgeom_from_text("CIRCULARSTRING(-1 -1, -2 0, -1 1, 0 2, 1 1, 2 0, 1 -1, 0 -2, -1 -1)"));
+	pa = lwcirc->points;
 	/* Point in middle of square */
 	pt.x = 0;
@@ -473,9 +473,9 @@ static void test_ptarrayarc_contains_point()
 	CU_ASSERT_EQUAL(rv, LW_OUTSIDE);
 	/*** Two-edge ring made up of semi-circles (really, a circle) ***/
-	lwline_free(lwline);
-	lwline = lwgeom_as_lwline(lwgeom_from_text("LINESTRING(-1 0, 0 1, 1 0, 0 -1, -1 0)"));
+	lwcircstring_free(lwcirc);
+	lwcirc = lwgeom_as_lwcircstring(lwgeom_from_text("CIRCULARSTRING(-1 0, 0 1, 1 0, 0 -1, -1 0)"));
 	/* Point outside */
 	pt.x = -1.5;
@@ -514,9 +514,9 @@ static void test_ptarrayarc_contains_point()
 	CU_ASSERT_EQUAL(rv, LW_BOUNDARY);
 	/*** Two-edge ring, closed ***/
-	lwline = lwgeom_as_lwline(lwgeom_from_text("LINESTRING(1 6, 6 1, 9 7, 6 10, 1 6)"));
+	lwcirc = lwgeom_as_lwcircstring(lwgeom_from_text("CIRCULARSTRING(1 6, 6 1, 9 7, 6 10, 1 6)"));
 	/* Point to left of ring */
 	pt.x = 20;
@@ -525,9 +525,9 @@ static void test_ptarrayarc_contains_point()
 	/*** One-edge ring, closed circle ***/
-	lwline = lwgeom_as_lwline(lwgeom_from_text("LINESTRING(-1 0, 1 0, -1 0)"));
+	lwcirc = lwgeom_as_lwcircstring(lwgeom_from_text("CIRCULARSTRING(-1 0, 1 0, -1 0)"));
 	/* Point inside */
 	pt.x = 0;
@@ -548,23 +548,23 @@ static void test_ptarrayarc_contains_point()
 	/*** Overshort ring ***/
-	lwline = lwgeom_as_lwline(lwgeom_from_text("LINESTRING(-1 0, 1 0)"));
+	lwcirc = lwgeom_as_lwcircstring(lwgeom_from_text("CIRCULARSTRING(-1 0, 1 0)"));
 	cu_error_msg_reset();
 	rv = ptarrayarc_contains_point(pa, &pt);
 	//printf("%s\n", cu_error_msg);
-	ASSERT_STRING_EQUAL("ptarrayarc_contains_point called with even number of points", cu_error_msg);
+	ASSERT_STRING_EQUAL(cu_error_msg, "ptarrayarc_raycast_intersections called with even number of points");
 	/*** Unclosed ring ***/
-	lwline = lwgeom_as_lwline(lwgeom_from_text("LINESTRING(-1 0, 1 0, 2 0)"));
+	lwcirc = lwgeom_as_lwcircstring(lwgeom_from_text("CIRCULARSTRING(-1 0, 1 0, 2 0)"));
-	ASSERT_STRING_EQUAL("ptarrayarc_contains_point called on unclosed ring", cu_error_msg);
+	ASSERT_STRING_EQUAL(cu_error_msg, "ptarrayarc_contains_point called on unclosed ring");
 static void test_ptarray_scale()
diff --git a/liblwgeom/liblwgeom_internal.h b/liblwgeom/liblwgeom_internal.h
index e51062b00..04a3504e2 100644
--- a/liblwgeom/liblwgeom_internal.h
+++ b/liblwgeom/liblwgeom_internal.h
@@ -445,13 +445,15 @@ double lw_arc_center(const POINT2D *p1, const POINT2D *p2, const POINT2D *p3, PO
 int lw_pt_in_seg(const POINT2D *P, const POINT2D *A1, const POINT2D *A2);
 int lw_pt_in_arc(const POINT2D *P, const POINT2D *A1, const POINT2D *A2, const POINT2D *A3);
 int lw_arc_is_pt(const POINT2D *A1, const POINT2D *A2, const POINT2D *A3);
+int lw_pt_on_segment(const POINT2D* p1, const POINT2D* p2, const POINT2D* p);
 double lw_seg_length(const POINT2D *A1, const POINT2D *A2);
 double lw_arc_length(const POINT2D *A1, const POINT2D *A2, const POINT2D *A3);
 int pt_in_ring_2d(const POINT2D *p, const POINTARRAY *ring);
 int ptarray_contains_point(const POINTARRAY *pa, const POINT2D *pt);
 int ptarrayarc_contains_point(const POINTARRAY *pa, const POINT2D *pt);
 int ptarray_contains_point_partial(const POINTARRAY *pa, const POINT2D *pt, int check_closed, int *winding_number);
-int ptarrayarc_contains_point_partial(const POINTARRAY *pa, const POINT2D *pt, int check_closed, int *winding_number);
+int ptarray_raycast_intersections(const POINTARRAY *pa, const POINT2D *p, int *on_boundary);
+int ptarrayarc_raycast_intersections(const POINTARRAY *pa, const POINT2D *p, int *on_boundary);
 int lwcompound_contains_point(const LWCOMPOUND *comp, const POINT2D *pt);
 int lwgeom_contains_point(const LWGEOM *geom, const POINT2D *pt);
diff --git a/liblwgeom/lwalgorithm.c b/liblwgeom/lwalgorithm.c
index cb3727f15..a2cb2b037 100644
--- a/liblwgeom/lwalgorithm.c
+++ b/liblwgeom/lwalgorithm.c
@@ -90,7 +90,9 @@ lw_seg_length(const POINT2D *A1, const POINT2D *A2)
 int
-	return lw_segment_side(A1, A3, A2) == lw_segment_side(A1, A3, P);
+	int pt_side = lw_segment_side(A1, A3, P);
+	int arc_side = lw_segment_side(A1, A3, A2);
+	return pt_side == 0 || pt_side == arc_side;
@@ -104,6 +106,28 @@ lw_pt_in_seg(const POINT2D *P, const POINT2D *A1, const POINT2D *A2)
 	       ((A1->y <= P->y && P->y < A2->y) || (A1->y >= P->y && P->y > A2->y));
+int
+lw_pt_on_segment(const POINT2D* p1, const POINT2D* p2, const POINT2D* p)
+    // Check if the point is within the bounding box of the segment
+    if (p->x < FP_MIN(p1->x, p2->x) || p->x > FP_MAX(p1->x, p2->x) ||
+        p->y < FP_MIN(p1->y, p2->y) || p->y > FP_MAX(p1->y, p2->y))
+        return LW_FALSE;
+    // Check for collinearity using the 2D cross-product.
+    // (p.y - p1.y) * (p2.x - p1.x) - (p.x - p1.x) * (p2.y - p1.y)
+    double cross_product = (p->y - p1->y) * (p2->x - p1->x) - (p->x - p1->x) * (p2->y - p1->y);
+    if (fabs(cross_product) < DBL_EPSILON)
+        return LW_TRUE; // Point is collinear and within the bounding box
+    return LW_TRUE;
 * Returns true if arc A is actually a point (all vertices are the same) .
diff --git a/liblwgeom/lwcompound.c b/liblwgeom/lwcompound.c
index 90fee3560..1e0d5c2ee 100644
--- a/liblwgeom/lwcompound.c
+++ b/liblwgeom/lwcompound.c
@@ -184,63 +184,48 @@ int lwgeom_contains_point(const LWGEOM *geom, const POINT2D *pt)
 	return LW_FAILURE;
+ * Use a ray-casting count to determine if the point
+ * is inside or outside of the compound curve. Ray-casting
+ * is run against each component of the overall arc, and
+ * the even/odd test run against the total of all components.
+ * Returns LW_INSIDE / LW_BOUNDARY / LW_OUTSIDE
 int
-	uint32_t i;
-	LWLINE *lwline;
-	LWCIRCSTRING *lwcirc;
-	int wn = 0;
-	int winding_number = 0;
-	int result;
+	int intersections = 0;
-	for ( i = 0; i < comp->ngeoms; i++ )
+	if (lwgeom_is_empty(lwcompound_as_lwgeom(comp)))
+		return LW_OUTSIDE;
+	for (uint32_t j = 0; j < comp->ngeoms; j++)
-		LWGEOM *lwgeom = comp->geoms[i];
-		if ( lwgeom->type == LINETYPE )
+		int on_boundary = LW_FALSE;
+		const LWGEOM *sub = comp->geoms[j];
+		if (sub->type == LINETYPE)
-			lwline = lwgeom_as_lwline(lwgeom);
-			if ( comp->ngeoms == 1 )
-				return ptarray_contains_point(lwline->points, pt);
-			else
-				/* Don't check closure while doing p-i-p test */
-				result = ptarray_contains_point_partial(lwline->points, pt, LW_FALSE, &winding_number);
+			LWLINE *lwline = lwgeom_as_lwline(sub);
+			intersections += ptarray_raycast_intersections(lwline->points, pt, &on_boundary);
+		else if (sub->type == CIRCSTRINGTYPE)
+			LWCIRCSTRING *lwcirc = lwgeom_as_lwcircstring(sub);
+			intersections += ptarrayarc_raycast_intersections(lwcirc->points, pt, &on_boundary);
 		else
-			lwcirc = lwgeom_as_lwcircstring(lwgeom);
-			if ( ! lwcirc ) {
-				lwerror("Unexpected component of type %s in compound curve", lwtype_name(lwgeom->type));
-				return 0;
-				return ptarrayarc_contains_point(lwcirc->points, pt);
-			else
-				result = ptarrayarc_contains_point_partial(lwcirc->points, pt, LW_FALSE, &winding_number);
+			lwerror("%s: unsupported type %s", __func__, lwtype_name(sub->type));
-		/* Propagate boundary condition */
-		if ( result == LW_BOUNDARY )
+		if (on_boundary)
 			return LW_BOUNDARY;
-		wn += winding_number;
-	/* Outside */
-	if (wn == 0)
-		return LW_OUTSIDE;
-	/* Inside */
-	return LW_INSIDE;
+	 * Odd number of intersections means inside.
+	 * Even means outside.
+	return (intersections % 2) ? LW_INSIDE : LW_OUTSIDE;
 LWCOMPOUND *
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index bc240eb45..62e2a3586 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -1540,37 +1540,156 @@ lw_dist2d_pt_arc(const POINT2D *P, const POINT2D *A1, const POINT2D *A2, const P
 	return LW_TRUE;
-/* Auxiliary function to calculate the distance between 2 concentric arcs*/
-int lw_dist2d_arc_arc_concentric(const POINT2D *A1,
-				 const POINT2D *A2,
-				 const POINT2D *A3,
-				 double radius_A,
-				 const POINT2D *B1,
-				 const POINT2D *B2,
-				 const POINT2D *B3,
-				 double radius_B,
-				 const POINT2D *CENTER,
-				 DISTPTS *dl);
+ * @brief Calculates the intersection points of a circle and line.
+ * This function assumes the center and test point are distinct.
+ * Finds the line between the circle center and test point, and
+ * the two intersection points on the circle defined by that line.
+ * If those points fall within the provided arc (A1,A2,A3) then
+ * the points are added to the provided array (I) and the array
+ * length counter is incremented.
+ * @param A1   Point of arc
+ * @param A2   Point of arc
+ * @param A3   Point of arc
+ * @param center_A   Center of arc A circle
+ * @param radius_A   Radius of arc A circle
+ * @param P    Point to use in calculating intersection line
+ * @param I    [out] Pointer to an return value array
+ * @param ni   [out] Pointer to return array size counter
+ * @return int
+static int
+lw_dist2d_circle_intersections(
+	const POINT2D *A1, const POINT2D *A2, const POINT2D *A3,
+	const POINT2D *center_A,
+	double radius_A,
+	const POINT2D *P,
+	POINT2D *I,
+	uint32_t *ni)
+	POINT2D R;
+	// If the test point is on the center of the other
+	// arc, some other point has to be closer, by definition.
+	if (p2d_same(center_A, P))
+		return 0;
+	// Calculate vector from the center to the pt
+	double dir_x = center_A->x - P->x;
+	double dir_y = center_A->y - P->y;
+	double dist = sqrt(dir_x * dir_x + dir_y * dir_y);
+	// Normalize the direction vector to get a unit vector (length = 1)
+	double unit_x = dir_x / dist;
+	double unit_y = dir_y / dist;
+	// Calculate the two intersection points on the circle
+	// Point 1: Move from center_A along the unit vector by distance radius_A
+	R.x = center_A->x + unit_x * radius_A;
+	R.y = center_A->y + unit_y * radius_A;
+	if (lw_pt_in_arc(&R, A1, A2, A3))
+		I[(*ni)++] = R;
+	// Point 2: Move from center_A against the unit vector by distance radius_A
+	R.x = center_A->x - unit_x * radius_A;
+	R.y = center_A->y - unit_y * radius_A;
+		I[(*ni)++] = R;
+	return 0;
+ * @brief Calculates the intersection points of two overlapping circles.
+ * This function assumes the circles are known to intersect at one or two points.
+ * Specifically, the distance 'd' between their centers must satisfy:
+ * d < (rA + rB)  and  d > fabs(rA - rB)
+ * If these conditions are not met, the results are undefined.
+ * @param cA   [in] Pointer to the center point of the first circle (A).
+ * @param rA   [in] The radius of the first circle (A).
+ * @param cB   [in] Pointer to the center point of the second circle (B).
+ * @param rB   [in] The radius of the second circle (B).
+ * @param I    [out] Pointer to an array of at least 2 POINT2D structs to store the results.
+ * I[0] will contain the first intersection point.
+ * If a second exists, it will be in I[1].
+ * @return int The number of intersection points found (1 or 2). Returns 0 if
+ * the centers are coincident or another error occurs.
+static uint32_t
+lw_dist2d_circle_circle_intersections(
+	const POINT2D *cA, double rA,
+	const POINT2D *cB, double rB,
+	POINT2D *I)
+	// Vector from center A to center B
+	double dx = cB->x - cA->x;
+	double dy = cB->y - cA->y;
+	// Distance between the centers
+	double d = sqrt(dx * dx + dy * dy);
+	// 'a' is the distance from the center of circle A to the point P,
+	// which is the base of the right triangle formed by cA, P, and an intersection point.
+	double a = (rA * rA - rB * rB + d * d) / (2.0 * d);
+	// 'h' is the height of that right triangle.
+	double h_squared = rA * rA - a * a;
+	// Due to floating point errors, h_squared can be slightly negative.
+	// This happens when the circles are perfectly tangent. Clamp to 0.
+	if (h_squared < 0.0)
+		h_squared = 0.0;
+	double h = sqrt(h_squared);
+	// Find the coordinates of point P
+	double Px = cA->x + a * (dx / d);
+	double Py = cA->y + a * (dy / d);
+	// The two intersection points are found by moving from P by a distance 'h'
+	// in directions perpendicular to the line connecting the centers.
+	// The perpendicular vector to (dx, dy) is (-dy, dx).
+	// Intersection point 1
+	I[0].x = Px - h * (dy / d);
+	I[0].y = Py + h * (dx / d);
+	// If h is very close to 0, the circles are tangent and there's only one intersection point.
+	if (FP_IS_ZERO(h))
+		return 1;
+	// Intersection point 2
+	I[1].x = Px + h * (dy / d);
+	I[1].y = Py - h * (dx / d);
+	return 2;
 int
-lw_dist2d_arc_arc(const POINT2D *A1,
-		  DISTPTS *dl)
+lw_dist2d_arc_arc(
+	const POINT2D *B1, const POINT2D *B2, const POINT2D *B3,
+	DISTPTS *dl)
-	POINT2D CA, CB;               /* Center points of arcs A and B */
+	POINT2D pts_A[16];            /* Points on A that might be the nearest */
+	POINT2D pts_B[16];            /* Points on B that might be the nearest */
+	uint32_t ai = 0, bi = 0;      /* Number of points in pts_A and pts_B */
+	POINT2D center_A, center_B;   /* Center points of arcs A and B */
 	double radius_A, radius_B, d; /* Radii of arcs A and B */
-	POINT2D D;                    /* Mid-point between the centers CA and CB */
-	int pt_in_arc_A, pt_in_arc_B; /* Test whether potential intersection point is within the arc */
+	int is_disjoint, is_overlapping, is_contained, is_same_center;
+	POINT2D intersectionPts[2];
 	if (dl->mode != DIST_MIN)
 		lwerror("lw_dist2d_arc_arc only supports mindistance");
-	/* TODO: Handle case where arc is closed circle (A1 = A3) */
 	/* What if one or both of our "arcs" is actually a point? */
 	if (lw_arc_is_pt(B1, B2, B3) && lw_arc_is_pt(A1, A2, A3))
 		return lw_dist2d_pt_pt(B1, A1, dl);
@@ -1580,8 +1699,8 @@ lw_dist2d_arc_arc(const POINT2D *A1,
 		return lw_dist2d_pt_arc(A1, B1, B2, B3, dl);
 	/* Calculate centers and radii of circles. */
-	radius_A = lw_arc_center(A1, A2, A3, &CA);
-	radius_B = lw_arc_center(B1, B2, B3, &CB);
+	radius_A = lw_arc_center(A1, A2, A3, &center_A);
+	radius_B = lw_arc_center(B1, B2, B3, &center_B);
 	/* Two co-linear arcs?!? That's two segments. */
 	if (radius_A < 0 && radius_B < 0)
@@ -1595,275 +1714,112 @@ lw_dist2d_arc_arc(const POINT2D *A1,
 	if (radius_B < 0)
 		return lw_dist2d_seg_arc(B1, B3, A1, A2, A3, dl);
-	/* Center-center distance */
-	d = distance2d_pt_pt(&CA, &CB);
+	/* Circle relationships */
+	d = distance2d_pt_pt(&center_A, &center_B);
+	is_disjoint = (d > (radius_A + radius_B));
+	is_contained = (d < fabs(radius_A - radius_B));
+	is_same_center = p2d_same(&center_A, &center_B);
+	is_overlapping = ! (is_disjoint || is_contained || is_same_center);
-	/* Concentric arcs */
-	if (FP_EQUALS(d, 0.0))
-		return lw_dist2d_arc_arc_concentric(A1, A2, A3, radius_A, B1, B2, B3, radius_B, &CA, dl);
+	 * Prime the array of potential closest points with the
+	 * arc end points, which frequently participate in closest
+	 * points.
+	pts_A[ai++] = *A1;
+	pts_A[ai++] = *A3;
+	pts_B[bi++] = *B1;
+	pts_B[bi++] = *B3;
-	/* Make sure that arc "A" has the bigger radius */
-	if (radius_B > radius_A)
+	 * Overlapping circles might have a zero distance
+	 * case if the circle intersection points are inside both
+	 * arcs.
+	if (is_overlapping)
-		const POINT2D *tmp;
-		POINT2D TP; /* Temporary point P */
-		double td;
-		tmp = B1;
-		B1 = A1;
-		A1 = tmp;
-		tmp = B2;
-		B2 = A2;
-		A2 = tmp;
-		tmp = B3;
-		B3 = A3;
-		A3 = tmp;
-		TP = CB;
-		CB = CA;
-		CA = TP;
-		td = radius_B;
-		radius_B = radius_A;
-		radius_A = td;
-	/* Circles touch at a point. Is that point within the arcs? */
-	if (d == (radius_A + radius_B))
-		D.x = CA.x + (CB.x - CA.x) * radius_A / d;
-		D.y = CA.y + (CB.y - CA.y) * radius_A / d;
-		pt_in_arc_A = lw_pt_in_arc(&D, A1, A2, A3);
-		pt_in_arc_B = lw_pt_in_arc(&D, B1, B2, B3);
-		/* Arcs do touch at D, return it */
-		if (pt_in_arc_A && pt_in_arc_B)
+		 * Find the two points the circles intersect at.
+		uint32_t npoints = lw_dist2d_circle_circle_intersections(
+			&center_A, radius_A,
+			&center_B, radius_B,
+			intersectionPts);
+		for (uint32_t i = 0; i < npoints; i++)
-			lw_dist2d_distpts_set(dl, 0.0, &D, &D);
-			return LW_TRUE;
+			 * If an intersection point is contained in both
+			 * arcs, that is a location of zero distance, so
+			 * we are done calculating.
+			if (lw_pt_in_arc(&intersectionPts[i], A1, A2, A3) &&
+				lw_pt_in_arc(&intersectionPts[i], B1, B2, B3))
+				lw_dist2d_distpts_set(dl, 0.0, &intersectionPts[i], &intersectionPts[i]);
+				return LW_TRUE;
-	/* Disjoint or contained circles don't intersect. Closest point may be on */
-	/* the line joining CA to CB. */
-	else if (d > (radius_A + radius_B) /* Disjoint */ || d < (radius_A - radius_B) /* Contained */)
+	 * Join the circle centers and find the places that
+	 * line intersects the circles. Where those places
+	 * are in the arcs, they are potential sites of the
+	 * closest points.
+	if (is_disjoint || is_contained || is_overlapping)
-		POINT2D XA, XB; /* Points where the line from CA to CB cross their circle bounds */
-		/* Calculate hypothetical nearest points, the places on the */
-		/* two circles where the center-center line crosses. If both */
-		/* arcs contain their hypothetical points, that's the crossing distance */
-		XA.x = CA.x + (CB.x - CA.x) * radius_A / d;
-		XA.y = CA.y + (CB.y - CA.y) * radius_A / d;
-		XB.x = CB.x + (CA.x - CB.x) * radius_B / d;
-		XB.y = CB.y + (CA.y - CB.y) * radius_B / d;
-		pt_in_arc_A = lw_pt_in_arc(&XA, A1, A2, A3);
-		pt_in_arc_B = lw_pt_in_arc(&XB, B1, B2, B3);
-		/* If the nearest points are both within the arcs, that's our answer */
-		/* the shortest distance is at the nearest points */
+		if (!is_same_center)
-			return lw_dist2d_pt_pt(&XA, &XB, dl);
-	/* Circles cross at two points, are either of those points in both arcs? */
-	/* http://paulbourke.net/geometry/2circle/ */
-	else if (d < (radius_A + radius_B))
-		POINT2D E, F; /* Points where circle(A) and circle(B) cross */
-		/* Distance from CA to D */
-		double a = (radius_A * radius_A - radius_B * radius_B + d * d) / (2 * d);
-		/* Distance from D to E or F */
-		double h = sqrt(radius_A * radius_A - a * a);
+			/* Add points on A that intersect line from center_A to center_B */
+			lw_dist2d_circle_intersections(
+			    A1, A2, A3,
+			    &center_A, radius_A, &center_B,
+			    pts_A, &ai);
-		/* Location of D */
-		D.x = CA.x + (CB.x - CA.x) * a / d;
-		D.y = CA.y + (CB.y - CA.y) * a / d;
-		/* Start from D and project h units perpendicular to CA-D to get E */
-		E.x = D.x + (D.y - CA.y) * h / a;
-		E.y = D.y + (D.x - CA.x) * h / a;
-		/* Crossing point E contained in arcs? */
-		pt_in_arc_A = lw_pt_in_arc(&E, A1, A2, A3);
-		pt_in_arc_B = lw_pt_in_arc(&E, B1, B2, B3);
-			lw_dist2d_distpts_set(dl, 0.0, &E, &E);
-			return LW_TRUE;
+			/* Add points on B that intersect line from center_B to center_A */
+			    B1, B2, B3,
+			    &center_B, radius_B, &center_A,
+			    pts_B, &bi);
-		/* Start from D and project h units perpendicular to CA-D to get F */
-		F.x = D.x - (D.y - CA.y) * h / a;
-		F.y = D.y - (D.x - CA.x) * h / a;
+		/* Add points on A that intersect line to B1 */
+		    A1, A2, A3,
+		    &center_A, radius_A, B1,
+		    pts_A, &ai);
-		/* Crossing point F contained in arcs? */
-		pt_in_arc_A = lw_pt_in_arc(&F, A1, A2, A3);
-		pt_in_arc_B = lw_pt_in_arc(&F, B1, B2, B3);
+		/* Add points on A that intersect line to B3 */
+		    A1, A2, A3,
+		    &center_A, radius_A, B3,
+		    pts_A, &ai);
-			lw_dist2d_distpts_set(dl, 0.0, &F, &F);
-			return LW_TRUE;
-	else
-		lwerror("lw_dist2d_arc_arc: arcs neither touch, intersect nor are disjoint! INCONCEIVABLE!");
-		return LW_FALSE;
+		/* Add points on B that intersect line to A1 */
+		    B1, B2, B3,
+		    &center_B, radius_B, A1,
+		    pts_B, &bi);
+		/* Add points on B that intersect line to A3 */
+		    B1, B2, B3,
+		    &center_B, radius_B, A3,
+		    pts_B, &bi);
-	/* Closest point is in the arc A, but not in the arc B, so */
-	/* one of the B end points must be the closest. */
-	if (pt_in_arc_A && !pt_in_arc_B)
-		lw_dist2d_pt_arc(B1, A1, A2, A3, dl);
-		lw_dist2d_pt_arc(B3, A1, A2, A3, dl);
-		return LW_TRUE;
-	/* Closest point is in the arc B, but not in the arc A, so */
-	/* one of the A end points must be the closest. */
-	else if (pt_in_arc_B && !pt_in_arc_A)
-		lw_dist2d_pt_arc(A1, B1, B2, B3, dl);
-		lw_dist2d_pt_arc(A3, B1, B2, B3, dl);
-		return LW_TRUE;
-	/* Finally, one of the end-point to end-point combos is the closest. */
-	else
-		lw_dist2d_pt_pt(A1, B1, dl);
-		lw_dist2d_pt_pt(A1, B3, dl);
-		lw_dist2d_pt_pt(A3, B1, dl);
-		lw_dist2d_pt_pt(A3, B3, dl);
-		return LW_TRUE;
+	 * Now just brute force check all pairs of participating
+	 * points, to find the pair that is closest together.
+	for (uint32_t i = 0; i < ai; i++)
+		for (uint32_t j = 0; j < bi; j++)
+			lw_dist2d_pt_pt(&pts_A[i], &pts_B[j], dl);
 	return LW_TRUE;
-int
-lw_dist2d_arc_arc_concentric(const POINT2D *A1,
-			     double radius_A,
-			     double radius_B,
-			     DISTPTS *dl)
-	int seg_size;
-	double dist_sqr, shortest_sqr;
-	const POINT2D *P1;
-	const POINT2D *P2;
-	POINT2D proj;
-	if (radius_A == radius_B)
-		/* Check if B1 or B3 are in the same side as A2 in the A1-A3 arc */
-		seg_size = lw_segment_side(A1, A3, A2);
-		if (seg_size == lw_segment_side(A1, A3, B1))
-			lw_dist2d_distpts_set(dl, 0.0, B1, B1);
-			return LW_TRUE;
-		if (seg_size == lw_segment_side(A1, A3, B3))
-			lw_dist2d_distpts_set(dl, 0.0, B3, B3);
-			return LW_TRUE;
-		/* Check if A1 or A3 are in the same side as B2 in the B1-B3 arc */
-		seg_size = lw_segment_side(B1, B3, B2);
-		if (seg_size == lw_segment_side(B1, B3, A1))
-			lw_dist2d_distpts_set(dl, 0.0, A1, A1);
-			return LW_TRUE;
-		if (seg_size == lw_segment_side(B1, B3, A3))
-			lw_dist2d_distpts_set(dl, 0.0, A3, A3);
-			return LW_TRUE;
-	else
-		/* Check if any projection of B ends are in A*/
-		/* B1 */
-		proj.x = CENTER->x + (B1->x - CENTER->x) * radius_A / radius_B;
-		proj.y = CENTER->y + (B1->y - CENTER->y) * radius_A / radius_B;
-		if (seg_size == lw_segment_side(A1, A3, &proj))
-			lw_dist2d_distpts_set(dl, fabs(radius_A - radius_B), &proj, B1);
-			return LW_TRUE;
-		/* B3 */
-		proj.x = CENTER->x + (B3->x - CENTER->x) * radius_A / radius_B;
-		proj.y = CENTER->y + (B3->y - CENTER->y) * radius_A / radius_B;
-			lw_dist2d_distpts_set(dl, fabs(radius_A - radius_B), &proj, B3);
-			return LW_TRUE;
-		/* Now check projections of A in B */
-		/* A1 */
-		proj.x = CENTER->x + (A1->x - CENTER->x) * radius_B / radius_A;
-		proj.y = CENTER->y + (A1->y - CENTER->y) * radius_B / radius_A;
-		if (seg_size == lw_segment_side(B1, B3, &proj))
-			lw_dist2d_distpts_set(dl, fabs(radius_A - radius_B), &proj, A1);
-			return LW_TRUE;
-		/* A3 */
-		proj.x = CENTER->x + (A3->x - CENTER->x) * radius_B / radius_A;
-		proj.y = CENTER->y + (A3->y - CENTER->y) * radius_B / radius_A;
-			lw_dist2d_distpts_set(dl, fabs(radius_A - radius_B), &proj, A3);
-			return LW_TRUE;
-	/* Check the shortest between the distances of the 4 ends */
-	shortest_sqr = dist_sqr = distance2d_sqr_pt_pt(A1, B1);
-	P1 = A1;
-	P2 = B1;
-	dist_sqr = distance2d_sqr_pt_pt(A1, B3);
-	if (dist_sqr < shortest_sqr)
-		shortest_sqr = dist_sqr;
-		P1 = A1;
-		P2 = B3;
-	dist_sqr = distance2d_sqr_pt_pt(A3, B1);
-		P1 = A3;
-		P2 = B1;
-	dist_sqr = distance2d_sqr_pt_pt(A3, B3);
-		P1 = A3;
-		P2 = B3;
-	lw_dist2d_distpts_set(dl, sqrt(shortest_sqr), P1, P2);
-	return LW_TRUE;
 Finds the shortest distance between two segments.
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 82a3835e4..2bc6126b5 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -742,17 +742,285 @@ ptarray_is_closed_z(const POINTARRAY *in)
-* Return LW_INSIDE if the point is inside the POINTARRAY,
-* LW_OUTSIDE if it is outside, and LW_BOUNDARY if it is on
-* the boundary.
-* LW_INSIDE == 1, LW_BOUNDARY == 0, LW_OUTSIDE == -1
+ * The following is based on the "Fast Winding Number Inclusion of a Point
+ * in a Polygon" algorithm by Dan Sunday.
+ * http://softsurfer.com/Archive/algorithm_0103/algorithm_0103.htm#Winding%20Number
+ * Return:
+ *  - LW_INSIDE (1) if the point is inside the POINTARRAY
+ *  - LW_BOUNDARY (0) if it is on the boundary.
+ *  - LW_OUTSIDE (-1) if it is outside
 int
-	return ptarray_contains_point_partial(pa, pt, LW_TRUE, NULL);
+	const POINT2D *seg1, *seg2;
+	int wn = 0;
+	seg1 = getPoint2d_cp(pa, 0);
+	seg2 = getPoint2d_cp(pa, pa->npoints-1);
+	if (!p2d_same(seg1, seg2))
+		lwerror("ptarray_contains_point called on unclosed ring");
+	for (uint32_t i = 1; i < pa->npoints; i++)
+		double side, ymin, ymax;
+		seg2 = getPoint2d_cp(pa, i);
+		/* Zero length segments are ignored. */
+		if (p2d_same(seg1, seg2))
+			seg1 = seg2;
+			continue;
+		ymin = FP_MIN(seg1->y, seg2->y);
+		ymax = FP_MAX(seg1->y, seg2->y);
+		/* Only test segments in our vertical range */
+		if (pt->y > ymax || pt->y < ymin)
+			seg1 = seg2;
+			continue;
+		side = lw_segment_side(seg1, seg2, pt);
+		* A point on the boundary of a ring is not contained.
+		* WAS: if (fabs(side) < 1e-12), see #852
+		if ((side == 0) && lw_pt_in_seg(pt, seg1, seg2))
+			return LW_BOUNDARY;
+		* If the point is to the left of the line, and it's rising,
+		* then the line is to the right of the point and
+		* circling counter-clockwise, so increment.
+		if ((side < 0) && (seg1->y <= pt->y) && (pt->y < seg2->y))
+			wn++;
+		* If the point is to the right of the line, and it's falling,
+		* then the line is to the right of the point and circling
+		* clockwise, so decrement.
+		else if ( (side > 0) && (seg2->y <= pt->y) && (pt->y < seg1->y) )
+			wn--;
+		seg1 = seg2;
+	/* wn == 0 => Outside, wn != 0 => Inside */
+	return wn == 0 ? LW_OUTSIDE : LW_INSIDE;
+int
+ptarray_raycast_intersections(const POINTARRAY *pa, const POINT2D *p, int *on_boundary)
+	// A valid linestring must have at least 2 point
+	if (pa->npoints < 2)
+		lwerror("%s called on invalid linestring", __func__);
+	double px = p->x;
+	double py = p->y;
+	// Iterate through each edge of the polygon
+	for (uint32_t i = 0; i < pa->npoints-1; ++i)
+		const POINT2D* p1 = getPoint2d_cp(pa, i);
+		const POINT2D* p2 = getPoint2d_cp(pa, i+1);
+		/* Skip zero-length edges */
+		if (p2d_same(p1, p2))
+			continue;
+		/* --- Step 1: Check if the point is ON the boundary edge --- */
+		if (lw_pt_on_segment(p1, p2, p))
+			*on_boundary = LW_TRUE;
+			return 0;
+		/* --- Step 2: Perform the Ray Casting intersection test --- */
+		 * Check if the horizontal ray from p intersects the edge (p1, p2).
+		 * This is the core condition for handling vertices correctly:
+		 *   - One vertex must be strictly above the ray (py < vertex.y)
+		 *   - The other must be on or below the ray (py >= vertex.y)
+		if (((p1->y <= py) && (py < p2->y)) || ((p2->y <= py) && (py < p1->y)))
+			 * Calculate the x-coordinate where the edge intersects the ray's horizontal line.
+			 * Formula: x = x1 + (y - y1) * (x2 - x1) / (y2 - y1)
+			double x_intersection = p1->x + (py - p1->y) * (p2->x - p1->x) / (p2->y - p1->y);
+			 * If the intersection point is to the right of our test point,
+			 * it's a valid "crossing".
+			if (x_intersection > px)
+				intersections++;
+	return intersections;
+ * @brief Calculates the intersection points of a circle and a horizontal line.
+ * The equation of a circle is (x - cx)^2 + (y - cy)^2 = r^2.
+ * The equation of the horizontal line is y = y_line.
+ * Substituting y_line into the circle equation gives:
+ * (x - cx)^2 = r^2 - (y_line - cy)^2
+ * This function solves for x.
+ * @param center A pointer to the center point of the circle.
+ * @param radius The radius of the circle.
+ * @param ray The y-coordinate of the horizontal line.
+ * @param i0 A pointer to a POINT2D to store the first intersection point.
+ * @param i1 A pointer to a POINT2D to store the second intersection point.
+ * @return The number of intersection points found (0, 1, or 2).
+static int
+circle_raycast_intersections(const POINT2D *center, double radius, double ray, POINT2D *i0, POINT2D *i1)
+	// Calculate the vertical distance from the circle's center to the horizontal line.
+	double dy = ray - center->y;
+	// If the absolute vertical distance is greater than the radius, there are no intersections.
+	if (fabs(dy) > radius)
+		return 0;
+	// Use the Pythagorean theorem to find the horizontal distance (dx) from the
+	// center's x-coordinate to the intersection points.
+	// dx^2 + dy^2 = radius^2  =>  dx^2 = radius^2 - dy^2
+	double dx_squared = radius * radius - dy * dy;
+	// Case 1: One intersection (tangent)
+	// This occurs when the line just touches the top or bottom of the circle.
+	// dx_squared will be zero. We check against a small epsilon for floating-point safety.
+	if (FP_EQUALS(dx_squared, 0.0))
+		i0->x = center->x;
+		i0->y = ray;
+		return 1;
+	// Case 2: Two intersections
+	// The line cuts through the circle.
+	double dx = sqrt(dx_squared);
+	// The first intersection point has the smaller x-value.
+	i0->x = center->x - dx;
+	i0->y = ray;
+	// The second intersection point has the larger x-value.
+	i1->x = center->x + dx;
+	i1->y = ray;
+	return 2;
+int
+ptarrayarc_raycast_intersections(const POINTARRAY *pa, const POINT2D *p, int *on_boundary)
+	double px = p->x;
+	double py = p->y;
+	assert(on_boundary);
+	// A valid circular arc must have at least 3 vertices (circle).
+	if (pa->npoints < 3)
+		lwerror("%s called on invalid circularstring", __func__);
+	if (pa->npoints % 2 == 0)
+		lwerror("%s called with even number of points", __func__);
+	// Iterate through each arc of the circularstring
+	for (uint32_t i = 1; i < pa->npoints-1; i +=2)
+		const POINT2D* p0 = getPoint2d_cp(pa, i-1);
+		POINT2D center = {0,0};
+		double radius, d;
+		GBOX gbox;
+		// Skip zero-length arc
+		if (lw_arc_is_pt(p0, p1, p2))
+			continue;
+		// --- Step 1: Check if the point is ON the boundary edge ---
+		if (p2d_same(p0, p) || p2d_same(p1, p) || p2d_same(p2, p))
+			return 0;
+		// Calculate some important pieces
+		radius = lw_arc_center(p0, p1, p2, &center);
+		d = distance2d_pt_pt(p, &center);
+		if (FP_EQUALS(d, radius) && lw_pt_in_arc(p, p0, p1, p2))
+			return 0;
+		// --- Step 2: Perform the Ray Casting intersection test ---
+		// Only process arcs that our ray crosses
+		lw_arc_calculate_gbox_cartesian_2d(p0, p1, p2, &gbox);
+		if ((gbox.ymin <= py) && (py < gbox.ymax))
+			// Point of intersection on the circle that defines the arc
+			POINT2D i0, i1;
+			// How many points of intersection are there
+			int iCount = circle_raycast_intersections(&center, radius, py, &i0, &i1);
+			// Nothing to see here
+			if (iCount == 0)
+				continue;
+			// Cannot think of a case where a grazing is not a
+			// no-op
+			if (iCount == 1)
+				continue;
+			// So we must have 2 intersections
+			// Only increment the counter for intersections to the right
+			// of the test point
+			if (i0.x > px && lw_pt_in_arc(&i0, p0, p1, p2))
+				intersections++;
+			if (i1.x > px && lw_pt_in_arc(&i1, p0, p1, p2))
+				intersections++;
@@ -765,8 +1033,7 @@ ptarray_contains_point_partial(const POINTARRAY *pa, const POINT2D *pt, int chec
 	int wn = 0;
 	uint32_t i;
 	double side;
-	const POINT2D *seg1;
-	const POINT2D *seg2;
 	double ymin, ymax;
@@ -855,160 +1122,16 @@ ptarray_contains_point_partial(const POINTARRAY *pa, const POINT2D *pt, int chec
 int
-	return ptarrayarc_contains_point_partial(pa, pt, LW_TRUE /* Check closed*/, NULL);
+	int intersections;
+	if (!ptarray_is_closed_2d(pa))
+		lwerror("%s called on unclosed ring", __func__);
-int
-ptarrayarc_contains_point_partial(const POINTARRAY *pa, const POINT2D *pt, int check_closed, int *winding_number)
-	int wn = 0;
-	uint32_t i;
-	int side;
-	const POINT2D *seg3;
-	GBOX gbox;
-	/* Check for not an arc ring (always have odd # of points) */
-	if ( (pa->npoints % 2) == 0 )
-		lwerror("ptarrayarc_contains_point called with even number of points");
-	/* Check for not an arc ring (always have >= 3 points) */
-	if ( pa->npoints < 3 )
-		lwerror("ptarrayarc_contains_point called too-short pointarray");
-	/* Check for unclosed case */
-	seg1 = getPoint2d_cp(pa, 0);
-	seg3 = getPoint2d_cp(pa, pa->npoints-1);
-	if ( check_closed && ! p2d_same(seg1, seg3) )
-		lwerror("ptarrayarc_contains_point called on unclosed ring");
-	/* OK, it's closed. Is it just one circle? */
-	else if ( p2d_same(seg1, seg3) && pa->npoints == 3 )
-		double radius, d;
-		POINT2D c;
-		seg2 = getPoint2d_cp(pa, 1);
-		/* Wait, it's just a point, so it can't contain anything */
-		if ( lw_arc_is_pt(seg1, seg2, seg3) )
-		/* See if the point is within the circle radius */
-		radius = lw_arc_center(seg1, seg2, seg3, &c);
-		d = distance2d_pt_pt(pt, &c);
-		if ( FP_EQUALS(d, radius) )
-			return LW_BOUNDARY; /* Boundary of circle */
-		else if ( d < radius )
-			return LW_INSIDE; /* Inside circle */
-		else
-			return LW_OUTSIDE; /* Outside circle */
-	else if ( p2d_same(seg1, pt) || p2d_same(seg3, pt) )
-		return LW_BOUNDARY; /* Boundary case */
-	/* Start on the ring */
-	for ( i=1; i < pa->npoints; i += 2 )
-		seg2 = getPoint2d_cp(pa, i);
-		seg3 = getPoint2d_cp(pa, i+1);
-		/* Catch an easy boundary case */
-		if( p2d_same(seg3, pt) )
-		/* Skip arcs that have no size */
-			seg1 = seg3;
-			continue;
-		/* Only test segments in our vertical range */
-		lw_arc_calculate_gbox_cartesian_2d(seg1, seg2, seg3, &gbox);
-		if ( pt->y > gbox.ymax || pt->y < gbox.ymin )
-			seg1 = seg3;
-			continue;
-		/* Outside of horizontal range, and not between end points we also skip */
-		if ( (pt->x > gbox.xmax || pt->x < gbox.xmin) &&
-			 (pt->y > FP_MAX(seg1->y, seg3->y) || pt->y < FP_MIN(seg1->y, seg3->y)) )
-			seg1 = seg3;
-			continue;
-		side = lw_arc_side(seg1, seg2, seg3, pt);
-		/* On the boundary */
-		if ( (side == 0) && lw_pt_in_arc(pt, seg1, seg2, seg3) )
-		/* Going "up"! Point to left of arc. */
-		if ( side < 0 && (seg1->y <= pt->y) && (pt->y < seg3->y) )
-			wn++;
-		/* Going "down"! */
-		if ( side > 0 && (seg3->y <= pt->y) && (pt->y < seg1->y) )
-			wn--;
-		/* Inside the arc! */
-		if ( pt->x <= gbox.xmax && pt->x >= gbox.xmin )
-			POINT2D C;
-			double radius = lw_arc_center(seg1, seg2, seg3, &C);
-			double d = distance2d_pt_pt(pt, &C);
-			/* On the boundary! */
-			if ( d == radius )
-			/* Within the arc! */
-			if ( d  < radius )
-				/* Left side, increment winding number */
-				if ( side < 0 )
-					wn++;
-				/* Right side, decrement winding number */
-				if ( side > 0 )
-					wn--;
-		seg1 = seg3;
-	/* Sent out the winding number for calls that are building on this as a primitive */
-	if ( winding_number )
-		*winding_number = wn;
-	/* Outside */
-	if (wn == 0)
-	/* Inside */
-	return LW_INSIDE;
+	intersections = ptarrayarc_raycast_intersections(pa, pt, &on_boundary);
+	if (on_boundary)
+	else
Summary of changes:
 NEWS                           |   1 +
 liblwgeom/cunit/cu_measures.c  |  33 +++
 liblwgeom/cunit/cu_ptarray.c   |  42 ++--
 liblwgeom/liblwgeom_internal.h |   4 +-
 liblwgeom/lwalgorithm.c        |  26 ++-
 liblwgeom/lwcompound.c         |  73 +++---
 liblwgeom/measures.c           | 508 +++++++++++++++++++----------------------
 liblwgeom/ptarray.c            | 415 +++++++++++++++++++++------------
 8 files changed, 613 insertions(+), 489 deletions(-)
hooks/post-receive
