[PostGIS] #5983: Potential data corruption in topology.topoelement after upgrade to 3.6.0
trac at osgeo.org
Wed Oct 8 21:34:08 PDT 2025
Reporter: packi | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.6.1
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Comment (by robe):
Replying to [comment:8 francoisb]:
> The `topology.topogeometry` composite type appears to be affected too,
probably with the same root cause. I can file a separate ticket if
applicable.
It's fine to have it all here. We should take care of it as a single fix.
Just need to relabel the bug.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5983#comment:9>
