[PostGIS] #5688: Allow 0-tolerance topology loading
PostGIS trac at osgeo.org
Tue Oct 7 02:47:17 PDT 2025
  Reporter:  strk         |      Owner:  strk
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 3.7.0
 Component:  topology     |    Version:  master
Resolution:               |   Keywords:
Description changed by strk:
Old description:
> Currently not available as a value of 0 passed to the topology population
> functions mean "use the precision found in the topology.topology record"
> and a 0 in the topology.topology record means "use a computed precision
> based on input geometry".
> A WIP to add proper 0-tolerance support (to avoid snapping) is here:
> https://git.osgeo.org/gitea/postgis/postgis/pulls/6
New description:
 https://gitea.osgeo.org/postgis/postgis/pulls/271
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5688#comment:3>
