[PostGIS] #5688: Allow 0-tolerance topology loading
trac at osgeo.org
Thu Oct 9 22:27:10 PDT 2025
Reporter: strk | Owner: strk
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 3.7.0
Component: topology | Version: master
Resolution: fixed | Keywords:
Changes (by Sandro Santilli <strk@…>):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"58374818b0c985b5a825fdd18dbee1238c0cc83a/git" 5837481/git]:
{{{#!CommitTicketReference repository="git"
revision="58374818b0c985b5a825fdd18dbee1238c0cc83a"
Add 0-tolerance (no snapping) support in topology population functions
Retains the default of automatic computation, which is now obtained
by passing -1 as the tolerance
Document default tolerance value
Update tests to adapt to the breaking change.
Closes #5688
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5688#comment:4>
