[SCM] PostGIS branch master updated. 3.6.0rc2-126-g0383bab91
Wed Oct 8 13:28:26 PDT 2025
the project "PostGIS".
       via  0383bab91e5f2eb7ac418fc661d473d3b87f5330 (commit)
      from  747d7732b009ee6821501f290a3f729e56a9634d (commit)
revisions in full, below.
commit 0383bab91e5f2eb7ac418fc661d473d3b87f5330
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Oct 8 13:27:52 2025 -0700
    Support MultiLineString as input to ST_MakeLine.
    Handle each sub-geometry in order it appears
    in the collection.
    Closes #6001
diff --git a/NEWS b/NEWS
index f07ea83e1..69d76e147 100644
--- a/NEWS
+++ b/NEWS
@@ -5,7 +5,7 @@ xxxx/xx/xx
  - #5993, [topology] Add max_edges parameter to TopoGeo_AddLinestring
           (Sandro Santilli)
+ - #6001, support MultiLineString in ST_MakeLine (Paul Ramsey)
 PostGIS 3.6.0
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 819527f6b..e849926c5 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -1,70 +1,70 @@
 <!-- Converted by db4-upgrade version 1.1 -->
 <section xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://docbook.org/ns/docbook" version="5.0" xml:id="Geometry_Constructors">
-	  <title>Geometry Constructors</title>
+      <title>Geometry Constructors</title>
-	<refentry xml:id="ST_Collect">
-	  <refnamediv>
-		<refname>ST_Collect</refname>
-		<refpurpose>Creates a GeometryCollection or Multi* geometry from a set of geometries.</refpurpose>
-	  </refnamediv>
+    <refentry xml:id="ST_Collect">
+      <refnamediv>
+        <refname>ST_Collect</refname>
+        <refpurpose>Creates a GeometryCollection or Multi* geometry from a set of geometries.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-			<funcprototype>
-				<funcdef>geometry <function>ST_Collect</function></funcdef>
-					<paramdef><type>geometry</type> <parameter>g1</parameter></paramdef>
-					<paramdef><type>geometry</type> <parameter>g2</parameter></paramdef>
-			</funcprototype>
-			<funcprototype>
-					<paramdef><type>geometry[]</type> <parameter>g1_array</parameter></paramdef>
-			</funcprototype>
-			<funcprototype>
-					<paramdef><type>geometry set</type> <parameter>g1field</parameter></paramdef>
-			</funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+            <funcprototype>
+                <funcdef>geometry <function>ST_Collect</function></funcdef>
+                    <paramdef><type>geometry</type> <parameter>g1</parameter></paramdef>
+                    <paramdef><type>geometry</type> <parameter>g2</parameter></paramdef>
+            </funcprototype>
+            <funcprototype>
+                    <paramdef><type>geometry[]</type> <parameter>g1_array</parameter></paramdef>
+            </funcprototype>
+            <funcprototype>
+                    <paramdef><type>geometry set</type> <parameter>g1field</parameter></paramdef>
+            </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
-		<title>Description</title>
-		<para> Collects geometries into a geometry collection.
-			The result is either a Multi* or a
-			GeometryCollection, depending on whether the input geometries have the same or different types
-			(homogeneous or heterogeneous).
-			The input geometries are left unchanged within the collection.
-			</para>
+      <refsection>
+        <title>Description</title>
+        <para> Collects geometries into a geometry collection.
+            The result is either a Multi* or a
+            GeometryCollection, depending on whether the input geometries have the same or different types
+            (homogeneous or heterogeneous).
+            The input geometries are left unchanged within the collection.
+            </para>
-		<para><emphasis role="bold">Variant 1:</emphasis> accepts two input geometries</para>
-		<para><emphasis role="bold">Variant 2:</emphasis> accepts an array of geometries</para>
-		<para><emphasis role="bold">Variant 3:</emphasis> aggregate function accepting a rowset of geometries.</para>
+        <para><emphasis role="bold">Variant 1:</emphasis> accepts two input geometries</para>
+        <para><emphasis role="bold">Variant 2:</emphasis> accepts an array of geometries</para>
+        <para><emphasis role="bold">Variant 3:</emphasis> aggregate function accepting a rowset of geometries.</para>
-		<note><para>
-		If any of the input geometries are collections (Multi* or GeometryCollection)
-		ST_Collect returns a GeometryCollection (since that is the only type
-		which can contain nested collections).
-		To prevent this, use <xref linkend="ST_Dump"/> in a subquery to expand the
-		input collections to their atomic elements (see example below).
-		</para></note>
+        <note><para>
+        If any of the input geometries are collections (Multi* or GeometryCollection)
+        ST_Collect returns a GeometryCollection (since that is the only type
+        which can contain nested collections).
+        To prevent this, use <xref linkend="ST_Dump"/> in a subquery to expand the
+        input collections to their atomic elements (see example below).
+        </para></note>
-		<note><para>ST_Collect and <xref linkend="ST_Union"/> appear similar, but in fact operate quite differently.
-		ST_Collect aggregates geometries into a collection without changing them in any way.
-		ST_Union geometrically merges geometries where they overlap,
-		and splits linestrings at intersections.
-		It may return single geometries when it dissolves boundaries.
-		</para></note>
+        <note><para>ST_Collect and <xref linkend="ST_Union"/> appear similar, but in fact operate quite differently.
+        ST_Collect aggregates geometries into a collection without changing them in any way.
+        ST_Union geometrically merges geometries where they overlap,
+        and splits linestrings at intersections.
+        It may return single geometries when it dissolves boundaries.
+        </para></note>
-		<para role="availability" conformance="1.4.0">Availability: 1.4.0 -  ST_Collect(geomarray) was introduced. ST_Collect was enhanced to handle more geometries faster.</para>
-		<para>&Z_support;</para>
-		<para>&curve_support;</para>
-	  </refsection>
+        <para role="availability" conformance="1.4.0">Availability: 1.4.0 -  ST_Collect(geomarray) was introduced. ST_Collect was enhanced to handle more geometries faster.</para>
+        <para>&Z_support;</para>
+        <para>&curve_support;</para>
+      </refsection>
-	  <refsection>
-		<title>Examples - Two-input variant</title>
-		<para>Collect 2D points.</para>
+      <refsection>
+        <title>Examples - Two-input variant</title>
+        <para>Collect 2D points.</para>
 <programlisting>
 SELECT ST_AsText( ST_Collect( ST_GeomFromText('POINT(1 2)'),
-	ST_GeomFromText('POINT(-2 3)') ));
+    ST_GeomFromText('POINT(-2 3)') ));
 st_astext
@@ -74,9 +74,9 @@ MULTIPOINT((1 2),(-2 3))
 <para>Collect 3D points.</para>
 <programlisting>
 SELECT ST_AsEWKT( ST_Collect( ST_GeomFromEWKT('POINT(1 2 3)'),
-		ST_GeomFromEWKT('POINT(1 2 4)') ) );
+        ST_GeomFromEWKT('POINT(1 2 4)') ) );
-		st_asewkt
+        st_asewkt
  MULTIPOINT(1 2 3,1 2 4)
  </programlisting>
@@ -84,15 +84,15 @@ SELECT ST_AsEWKT( ST_Collect( ST_GeomFromEWKT('POINT(1 2 3)'),
 <para>Collect curves.</para>
  <programlisting>
 SELECT ST_AsText( ST_Collect( 'CIRCULARSTRING(220268 150415,220227 150505,220227 150406)',
-		'CIRCULARSTRING(220227 150406,2220227 150407,220227 150406)'));
+        'CIRCULARSTRING(220227 150406,2220227 150407,220227 150406)'));
-		st_astext
+        st_astext
 MULTICURVE(CIRCULARSTRING(220268 150415,220227 150505,220227 150406),
  CIRCULARSTRING(220227 150406,2220227 150407,220227 150406))
 </programlisting>
-		</refsection>
-		<refsection>
+        </refsection>
+        <refsection>
 <title>Examples - Array variant</title>
 <para>Using an array constructor for a subquery.</para>
 <programlisting>
@@ -101,186 +101,188 @@ SELECT ST_Collect( ARRAY( SELECT geom FROM sometable ) );
 <para>Using an array constructor for values.</para>
 <programlisting>
-		ARRAY[ ST_GeomFromText('LINESTRING(1 2, 3 4)'),
-			ST_GeomFromText('LINESTRING(3 4, 4 5)') ] )) As wktcollect;
+        ARRAY[ ST_GeomFromText('LINESTRING(1 2, 3 4)'),
+            ST_GeomFromText('LINESTRING(3 4, 4 5)') ] )) As wktcollect;
 --wkt collect --
 MULTILINESTRING((1 2,3 4),(3 4,4 5))
 </programlisting>
-		</refsection>
-		<refsection>
-		<title>Examples - Aggregate variant</title>
-		<para>Creating multiple collections by grouping geometries in a table.</para>
+        </refsection>
+        <refsection>
+        <title>Examples - Aggregate variant</title>
+        <para>Creating multiple collections by grouping geometries in a table.</para>
 <programlisting>
 SELECT stusps, ST_Collect(f.geom) as geom
-	 FROM (SELECT stusps, (ST_Dump(geom)).geom As geom
-				FROM
-				somestatetable ) As f
-	GROUP BY stusps
+     FROM (SELECT stusps, (ST_Dump(geom)).geom As geom
+                FROM
+                somestatetable ) As f
+    GROUP BY stusps
 </programlisting>
-	  </refsection>
-	  <refsection>
-		<title>See Also</title>
-		<para><xref linkend="ST_Dump"/>, <xref linkend="ST_Union"/></para>
-	  </refsection>
-	</refentry>
+      </refsection>
+      <refsection>
+        <title>See Also</title>
+        <para><xref linkend="ST_Dump"/>, <xref linkend="ST_Union"/></para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="ST_LineFromMultiPoint">
-	  <refnamediv>
-		<refname>ST_LineFromMultiPoint</refname>
+    <refentry xml:id="ST_LineFromMultiPoint">
+      <refnamediv>
+        <refname>ST_LineFromMultiPoint</refname>
-		<refpurpose>Creates a LineString from a MultiPoint geometry.</refpurpose>
-	  </refnamediv>
+        <refpurpose>Creates a LineString from a MultiPoint geometry.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>geometry <function>ST_LineFromMultiPoint</function></funcdef>
-			<paramdef><type>geometry </type> <parameter>aMultiPoint</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry <function>ST_LineFromMultiPoint</function></funcdef>
+            <paramdef><type>geometry </type> <parameter>aMultiPoint</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>Creates a LineString from a MultiPoint geometry.</para>
+        <para>Creates a LineString from a MultiPoint geometry.</para>
-		<para>Use <xref linkend="ST_MakeLine"/> to create lines from Point or LineString inputs.</para>
+        <para>Use <xref linkend="ST_MakeLine"/> to create lines from Point or LineString inputs.</para>
-	  </refsection>
+      </refsection>
-	  <refsection>
-		<title>Examples</title>
-		<para>Create a 3D line string from a 3D MultiPoint</para>
-		<programlisting>
+      <refsection>
+        <title>Examples</title>
+        <para>Create a 3D line string from a 3D MultiPoint</para>
+        <programlisting>
 SELECT ST_AsEWKT(  ST_LineFromMultiPoint('MULTIPOINT(1 2 3, 4 5 6, 7 8 9)')  );
 --result--
 LINESTRING(1 2 3,4 5 6,7 8 9)
 </programlisting>
-	  </refsection>
+      </refsection>
-	  <!-- Optionally add a "See Also" section -->
-	  <refsection>
+      <!-- Optionally add a "See Also" section -->
+      <refsection>
-		<para><xref linkend="ST_AsEWKT"/>, <xref linkend="ST_MakeLine"/></para>
-	  </refsection>
-	</refentry>
+        <para><xref linkend="ST_AsEWKT"/>, <xref linkend="ST_MakeLine"/></para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="ST_MakeEnvelope">
-		<refnamediv>
-		<refname>ST_MakeEnvelope</refname>
+    <refentry xml:id="ST_MakeEnvelope">
+        <refnamediv>
+        <refname>ST_MakeEnvelope</refname>
-		<refpurpose>Creates a rectangular Polygon from minimum and maximum coordinates.</refpurpose>
-		</refnamediv>
+        <refpurpose>Creates a rectangular Polygon from minimum and maximum coordinates.</refpurpose>
+        </refnamediv>
-		<refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>geometry <function>ST_MakeEnvelope</function></funcdef>
-			<paramdef><type>float</type> <parameter>xmin</parameter></paramdef>
-			<paramdef><type>float</type> <parameter>ymin</parameter></paramdef>
-			<paramdef><type>float</type> <parameter>xmax</parameter></paramdef>
-			<paramdef><type>float</type> <parameter>ymax</parameter></paramdef>
-			<paramdef choice="opt"><type>integer</type> <parameter>srid=unknown</parameter></paramdef>
-		  </funcprototype>
-		 </funcsynopsis>
-		</refsynopsisdiv>
+        <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry <function>ST_MakeEnvelope</function></funcdef>
+            <paramdef><type>float</type> <parameter>xmin</parameter></paramdef>
+            <paramdef><type>float</type> <parameter>ymin</parameter></paramdef>
+            <paramdef><type>float</type> <parameter>xmax</parameter></paramdef>
+            <paramdef><type>float</type> <parameter>ymax</parameter></paramdef>
+            <paramdef choice="opt"><type>integer</type> <parameter>srid=unknown</parameter></paramdef>
+          </funcprototype>
+         </funcsynopsis>
+        </refsynopsisdiv>
-		<refsection>
+        <refsection>
-			<para>Creates a rectangular Polygon from the minimum and maximum values for X and Y.
-			Input values must be in the spatial reference system specified by the SRID.
-			If no SRID is specified the unknown spatial reference system (SRID 0) is used.</para>
+            <para>Creates a rectangular Polygon from the minimum and maximum values for X and Y.
+            Input values must be in the spatial reference system specified by the SRID.
+            If no SRID is specified the unknown spatial reference system (SRID 0) is used.</para>
-			<para role="availability" conformance="1.5">Availability: 1.5</para>
-			<para role="enhanced" conformance="2.0">Enhanced: 2.0: Ability to specify an envelope without specifying an SRID was introduced.</para>
+            <para role="availability" conformance="1.5">Availability: 1.5</para>
+            <para role="enhanced" conformance="2.0">Enhanced: 2.0: Ability to specify an envelope without specifying an SRID was introduced.</para>
-		</refsection>
+        </refsection>
-		<refsection>
-		<title>Example: Building a bounding box polygon</title>
-		 <programlisting>
+        <refsection>
+        <title>Example: Building a bounding box polygon</title>
+         <programlisting>
 SELECT ST_AsText( ST_MakeEnvelope(10, 10, 11, 11, 4326) );
 st_asewkt
 POLYGON((10 10, 10 11, 11 11, 11 10, 10 10))
 </programlisting>
-		</refsection>
-		<refsection>
-			<para><xref linkend="ST_MakePoint"/>, <xref linkend="ST_MakeLine"/>, <xref linkend="ST_MakePolygon"/>, <xref linkend="ST_TileEnvelope"/></para>
-		</refsection>
-	</refentry>
+        </refsection>
+        <refsection>
+            <para><xref linkend="ST_MakePoint"/>, <xref linkend="ST_MakeLine"/>, <xref linkend="ST_MakePolygon"/>, <xref linkend="ST_TileEnvelope"/></para>
+        </refsection>
+    </refentry>
-	<refentry xml:id="ST_MakeLine">
-		<refnamediv>
-		<refname>ST_MakeLine</refname>
+    <refentry xml:id="ST_MakeLine">
+        <refnamediv>
+        <refname>ST_MakeLine</refname>
-		<refpurpose>Creates a LineString from Point, MultiPoint, or LineString geometries.</refpurpose>
-		</refnamediv>
+        <refpurpose>Creates a LineString from Point, MultiPoint, or LineString geometries.</refpurpose>
+        </refnamediv>
-		<refsynopsisdiv>
-		<funcsynopsis>
-			<funcprototype>
-				<funcdef>geometry <function>ST_MakeLine</function></funcdef>
-				<paramdef><type>geometry</type> <parameter>geom1</parameter></paramdef>
-				<paramdef><type>geometry</type> <parameter>geom2</parameter></paramdef>
-			</funcprototype>
+        <refsynopsisdiv>
+        <funcsynopsis>
+            <funcprototype>
+                <funcdef>geometry <function>ST_MakeLine</function></funcdef>
+                <paramdef><type>geometry</type> <parameter>geom1</parameter></paramdef>
+                <paramdef><type>geometry</type> <parameter>geom2</parameter></paramdef>
+            </funcprototype>
-			<funcprototype>
-				<paramdef><type>geometry[]</type> <parameter>geoms_array</parameter></paramdef>
-			</funcprototype>
+            <funcprototype>
+                <paramdef><type>geometry[]</type> <parameter>geoms_array</parameter></paramdef>
+            </funcprototype>
-			<funcprototype>
-				<paramdef><type>geometry set</type> <parameter>geoms</parameter></paramdef>
-			</funcprototype>
-		</funcsynopsis>
-		</refsynopsisdiv>
+            <funcprototype>
+                <paramdef><type>geometry set</type> <parameter>geoms</parameter></paramdef>
+            </funcprototype>
+        </funcsynopsis>
+        </refsynopsisdiv>
-		<refsection>
+        <refsection>
-		<para>Creates a LineString containing the points of Point, MultiPoint, or LineString geometries.
-		Other geometry types cause an error.
-		</para>
-		To ensure the order of the input geometries use <varname>ORDER BY</varname> in the function call,
-		or a subquery with an <varname>ORDER BY</varname> clause.</para>
+        <para>Creates a LineString containing the points of Point, MultiPoint, or LineString geometries.
+        Other geometry types cause an error.
+        </para>
+        To ensure the order of the input geometries use <varname>ORDER BY</varname> in the function call,
+        or a subquery with an <varname>ORDER BY</varname> clause.</para>
-		<para>
-		Repeated nodes at the beginning of input LineStrings are collapsed to a single point.
-		Repeated points in Point and MultiPoint inputs are not collapsed.
-		<xref linkend="ST_RemoveRepeatedPoints"/> can be used to collapse repeated points from the output LineString.
-		</para>
+        <para>
+        Repeated nodes at the beginning of input LineStrings are collapsed to a single point.
+        Repeated points in Point and MultiPoint inputs are not collapsed.
+        Components of MultiLineString are handled in the order they appear in the collection.
+        <xref linkend="ST_RemoveRepeatedPoints"/> can be used to collapse repeated points from the output LineString.
+        </para>
-		<para role="availability" conformance="2.3.0">Availability: 2.3.0 -  Support for MultiPoint input elements was introduced</para>
-		<para role="availability" conformance="2.0.0">Availability: 2.0.0 -  Support for LineString input elements was introduced</para>
-		<para role="availability" conformance="1.4.0">Availability: 1.4.0 -  ST_MakeLine(geomarray) was introduced. ST_MakeLine aggregate functions was enhanced to handle more points faster.</para>
+        <para role="availability" conformance="3.7.0">Availability: 3.7.0 -  Support for MultiLineString input elements was introduced</para>
+        <para role="availability" conformance="2.3.0">Availability: 2.3.0 -  Support for MultiPoint input elements was introduced</para>
+        <para role="availability" conformance="2.0.0">Availability: 2.0.0 -  Support for LineString input elements was introduced</para>
+        <para role="availability" conformance="1.4.0">Availability: 1.4.0 -  ST_MakeLine(geomarray) was introduced. ST_MakeLine aggregate functions was enhanced to handle more points faster.</para>
-		</refsection>
+        </refsection>
-		<refsection>
-			<title>Examples: Two-input variant</title>
+        <refsection>
+            <title>Examples: Two-input variant</title>
 <para>Create a line composed of two points.</para>
 <programlisting>
 SELECT ST_AsText( ST_MakeLine(ST_Point(1,2), ST_Point(3,4)) );
-	  st_astext
+      st_astext
  LINESTRING(1 2,3 4)
 </programlisting>
@@ -289,7 +291,7 @@ SELECT ST_AsText( ST_MakeLine(ST_Point(1,2), ST_Point(3,4)) );
 <programlisting>
 SELECT ST_AsEWKT( ST_MakeLine(ST_MakePoint(1,2,3), ST_MakePoint(3,4,5) ));
-		st_asewkt
+        st_asewkt
  LINESTRING(1 2 3,3 4 5)
 </programlisting>
@@ -302,123 +304,123 @@ SELECT ST_AsEWKT( ST_MakeLine(ST_MakePoint(1,2,3), ST_MakePoint(3,4,5) ));
  LINESTRING(0 0,1 1,2 2,3 3)
 </programlisting>
-		</refsection>
+        </refsection>
-		<refsection>
-			<title>Examples: Array variant</title>
+        <refsection>
+            <title>Examples: Array variant</title>
-		<para>Create a line from an array formed by a subquery with ordering.</para>
+        <para>Create a line from an array formed by a subquery with ordering.</para>
 <programlisting>
 SELECT ST_MakeLine( ARRAY( SELECT ST_Centroid(geom) FROM visit_locations ORDER BY visit_time) );
 </programlisting>
-		<para>Create a 3D line from an array of 3D points</para>
+        <para>Create a 3D line from an array of 3D points</para>
 <programlisting>
           ARRAY[ ST_MakePoint(1,2,3), ST_MakePoint(3,4,5), ST_MakePoint(6,6,6) ]  ));
-		st_asewkt
+        st_asewkt
 LINESTRING(1 2 3,3 4 5,6 6 6)
 </programlisting>
-		</refsection>
+        </refsection>
-		<refsection>
-		<title>Examples: Aggregate variant</title>
-		<para>This example queries time-based sequences of GPS points from a set of tracks
-		and creates one record for each track.
-		The result geometries are LineStrings composed of the GPS track points in the order of travel.</para>
+        <refsection>
+        <title>Examples: Aggregate variant</title>
+        <para>This example queries time-based sequences of GPS points from a set of tracks
+        and creates one record for each track.
+        The result geometries are LineStrings composed of the GPS track points in the order of travel.</para>
 <para>Using aggregate <varname>ORDER BY</varname> provides a correctly-ordered LineString.</para>
-		<programlisting>
+        <programlisting>
 SELECT gps.track_id, ST_MakeLine(gps.geom ORDER BY gps_time) As geom
-	FROM gps_points As gps
-	GROUP BY track_id;</programlisting>
+    FROM gps_points As gps
+    GROUP BY track_id;</programlisting>
 <para>Prior to PostgreSQL 9, ordering in a subquery can be used.
 However, sometimes the query plan may not respect the order of the subquery.</para>
-		<programlisting>
+        <programlisting>
 SELECT gps.track_id, ST_MakeLine(gps.geom) As geom
-	FROM ( SELECT track_id, gps_time, geom
-			FROM gps_points ORDER BY track_id, gps_time ) As gps
-		</refsection>
+    FROM ( SELECT track_id, gps_time, geom
+            FROM gps_points ORDER BY track_id, gps_time ) As gps
+        </refsection>
-		<refsection>
-			<para><xref linkend="ST_RemoveRepeatedPoints"/>,
+        <refsection>
+            <para><xref linkend="ST_RemoveRepeatedPoints"/>,
             <xref linkend="ST_AsText"/>,
             <xref linkend="ST_GeomFromText"/>,
             <xref linkend="ST_Point"/>
             </para>
-		</refsection>
-	</refentry>
+        </refsection>
+    </refentry>
-	<refentry xml:id="ST_MakePoint">
-		<refnamediv>
-		<refname>ST_MakePoint</refname>
+    <refentry xml:id="ST_MakePoint">
+        <refnamediv>
+        <refname>ST_MakePoint</refname>
-		<refpurpose>Creates a 2D, 3DZ or 4D Point.</refpurpose>
-		</refnamediv>
+        <refpurpose>Creates a 2D, 3DZ or 4D Point.</refpurpose>
+        </refnamediv>
-		<refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>geometry <function>ST_MakePoint</function></funcdef>
-			<paramdef><type>float</type> <parameter>x</parameter></paramdef>
-			<paramdef><type>float</type> <parameter>y</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-		<funcsynopsis>
-		  <funcprototype>
-			<paramdef><type>float</type> <parameter>z</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-		<funcsynopsis>
-		  <funcprototype>
-			<paramdef><type>float</type> <parameter>m</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-		</refsynopsisdiv>
+        <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry <function>ST_MakePoint</function></funcdef>
+            <paramdef><type>float</type> <parameter>x</parameter></paramdef>
+            <paramdef><type>float</type> <parameter>y</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+        <funcsynopsis>
+          <funcprototype>
+            <paramdef><type>float</type> <parameter>z</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+        <funcsynopsis>
+          <funcprototype>
+            <paramdef><type>float</type> <parameter>m</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+        </refsynopsisdiv>
-		<refsection>
+        <refsection>
-			<para>Creates a 2D XY, 3D XYZ or 4D XYZM Point geometry.
-			Use <xref linkend="ST_MakePointM"/> to make points with XYM coordinates.</para>
+            <para>Creates a 2D XY, 3D XYZ or 4D XYZM Point geometry.
+            Use <xref linkend="ST_MakePointM"/> to make points with XYM coordinates.</para>
-			<para>Use <xref linkend="ST_SetSRID"/> to specify a SRID for the created point.</para>
+            <para>Use <xref linkend="ST_SetSRID"/> to specify a SRID for the created point.</para>
-			<para>
-			While not OGC-compliant, <varname>ST_MakePoint</varname> is
-			faster than <xref linkend="ST_GeomFromText"/>
-			and <xref linkend="ST_PointFromText"/>.
-			It is also easier to use for numeric coordinate values.</para>
+            <para>
+            While not OGC-compliant, <varname>ST_MakePoint</varname> is
+            faster than <xref linkend="ST_GeomFromText"/>
+            and <xref linkend="ST_PointFromText"/>.
+            It is also easier to use for numeric coordinate values.</para>
-			<note><para>For geodetic coordinates, <varname>X</varname> is longitude and <varname>Y</varname> is latitude</para></note>
+            <note><para>For geodetic coordinates, <varname>X</varname> is longitude and <varname>Y</varname> is latitude</para></note>
-			<note><para>
-			The functions
-			<xref linkend="ST_Point"/>, <xref linkend="ST_PointZ"/>, <xref linkend="ST_PointM"/>, and <xref linkend="ST_PointZM"/>
-			can be used to create points with a given SRID.
-			</para></note>
+            <note><para>
+            The functions
+            <xref linkend="ST_Point"/>, <xref linkend="ST_PointZ"/>, <xref linkend="ST_PointM"/>, and <xref linkend="ST_PointZM"/>
+            can be used to create points with a given SRID.
+            </para></note>
-		</refsection>
+        </refsection>
-		<refsection>
-		 <programlisting>-- Create a point with unknown SRID
+        <refsection>
+         <programlisting>-- Create a point with unknown SRID
 SELECT ST_MakePoint(-71.1043443253471, 42.3150676015829);
 -- Create a point in the WGS 84 geodetic CRS
@@ -432,62 +434,62 @@ SELECT ST_Z(ST_MakePoint(1, 2,1.5));
 result
 1.5</programlisting>
-		</refsection>
-		<refsection>
-			<para>
-			<xref linkend="ST_GeomFromText"/>, <xref linkend="ST_PointFromText"/>, <xref linkend="ST_SetSRID"/>, <xref linkend="ST_MakePointM"/>,
-			<xref linkend="ST_Point"/>, <xref linkend="ST_PointZ"/>, <xref linkend="ST_PointM"/>, <xref linkend="ST_PointZM"/>
- 			</para>
-		</refsection>
-	</refentry>
+        </refsection>
+        <refsection>
+            <para>
+            <xref linkend="ST_GeomFromText"/>, <xref linkend="ST_PointFromText"/>, <xref linkend="ST_SetSRID"/>, <xref linkend="ST_MakePointM"/>,
+            <xref linkend="ST_Point"/>, <xref linkend="ST_PointZ"/>, <xref linkend="ST_PointM"/>, <xref linkend="ST_PointZM"/>
+            </para>
+        </refsection>
+    </refentry>
-	<refentry xml:id="ST_MakePointM">
-		<refnamediv>
-		<refname>ST_MakePointM</refname>
+    <refentry xml:id="ST_MakePointM">
+        <refnamediv>
+        <refname>ST_MakePointM</refname>
-		<refpurpose>Creates a Point from X, Y and M values.</refpurpose>
-		</refnamediv>
+        <refpurpose>Creates a Point from X, Y and M values.</refpurpose>
+        </refnamediv>
-		<refsynopsisdiv>
-			<funcsynopsis>
-			  <funcprototype>
-				<funcdef>geometry <function>ST_MakePointM</function></funcdef>
-			  </funcprototype>
-			</funcsynopsis>
-		</refsynopsisdiv>
+        <refsynopsisdiv>
+            <funcsynopsis>
+              <funcprototype>
+                <funcdef>geometry <function>ST_MakePointM</function></funcdef>
+              </funcprototype>
+            </funcsynopsis>
+        </refsynopsisdiv>
-		<refsection>
+        <refsection>
-			<para>Creates a point with X, Y and M (measure) ordinates.
-			Use <xref linkend="ST_MakePoint"/> to make points with XY, XYZ, or XYZM coordinates.</para>
+            <para>Creates a point with X, Y and M (measure) ordinates.
+            Use <xref linkend="ST_MakePoint"/> to make points with XY, XYZ, or XYZM coordinates.</para>
-			<note><para>
-			The functions
-			<xref linkend="ST_PointM"/>, and <xref linkend="ST_PointZM"/>
-			can be used to create points with an M value and a given SRID.
-			</para></note>
+            <note><para>
+            The functions
+            <xref linkend="ST_PointM"/>, and <xref linkend="ST_PointZM"/>
+            can be used to create points with an M value and a given SRID.
+            </para></note>
-		</refsection>
+        </refsection>
-		<refsection>
-			<note><para><xref linkend="ST_AsEWKT"/> is used for text output
-			because <xref linkend="ST_AsText"/> does not support M values.</para></note>
+        <refsection>
+            <note><para><xref linkend="ST_AsEWKT"/> is used for text output
+            because <xref linkend="ST_AsText"/> does not support M values.</para></note>
-			<para>Create point with unknown SRID.</para>
-		 <programlisting>
+            <para>Create point with unknown SRID.</para>
+         <programlisting>
 SELECT ST_AsEWKT(  ST_MakePointM(-71.1043443253471, 42.3150676015829, 10)  );
-				   st_asewkt
+                   st_asewkt
  POINTM(-71.1043443253471 42.3150676015829 10)
 </programlisting>
@@ -496,7 +498,7 @@ SELECT ST_AsEWKT(  ST_MakePointM(-71.1043443253471, 42.3150676015829, 10)  );
 <programlisting>
 SELECT ST_AsEWKT( ST_SetSRID(  ST_MakePointM(-71.104, 42.315, 10),  4326));
-						st_asewkt
+                        st_asewkt
 SRID=4326;POINTM(-71.104 42.315 10)
 </programlisting>
@@ -509,59 +511,59 @@ result
 10
 </programlisting>
-		</refsection>
-		<refsection>
-			<para><xref linkend="ST_MakePoint"/>, <xref linkend="ST_SetSRID"/>,
-			<xref linkend="ST_PointM"/>, <xref linkend="ST_PointZM"/></para>
-		</refsection>
-	</refentry>
+        </refsection>
+        <refsection>
+            <para><xref linkend="ST_MakePoint"/>, <xref linkend="ST_SetSRID"/>,
+            <xref linkend="ST_PointM"/>, <xref linkend="ST_PointZM"/></para>
+        </refsection>
+    </refentry>
-	<refentry xml:id="ST_MakePolygon">
-		<refnamediv>
-		<refname>ST_MakePolygon</refname>
+    <refentry xml:id="ST_MakePolygon">
+        <refnamediv>
+        <refname>ST_MakePolygon</refname>
-		<refpurpose>Creates a Polygon from a shell and optional list of holes.</refpurpose>
-		</refnamediv>
+        <refpurpose>Creates a Polygon from a shell and optional list of holes.</refpurpose>
+        </refnamediv>
-		<refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>geometry <function>ST_MakePolygon</function></funcdef>
-			<paramdef><type>geometry</type> <parameter>linestring</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-		<funcsynopsis>
-		  <funcprototype>
-			<paramdef><type>geometry</type> <parameter>outerlinestring</parameter></paramdef>
-			<paramdef><type>geometry[]</type> <parameter>interiorlinestrings</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-		</refsynopsisdiv>
+        <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry <function>ST_MakePolygon</function></funcdef>
+            <paramdef><type>geometry</type> <parameter>linestring</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+        <funcsynopsis>
+          <funcprototype>
+            <paramdef><type>geometry</type> <parameter>outerlinestring</parameter></paramdef>
+            <paramdef><type>geometry[]</type> <parameter>interiorlinestrings</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+        </refsynopsisdiv>
-		<refsection>
+        <refsection>
-			<para>Creates a Polygon formed by the given shell and optional array of holes.
-			Input	geometries must be closed LineStrings (rings).</para>
+            <para>Creates a Polygon formed by the given shell and optional array of holes.
+            Input   geometries must be closed LineStrings (rings).</para>
-			<para><emphasis role="bold">Variant 1:</emphasis>  Accepts one shell LineString.</para>
-			<para><emphasis role="bold">Variant 2:</emphasis>  Accepts a shell LineString and an array of
-			inner (hole) LineStrings. A geometry array can be constructed using the PostgreSQL array_agg(), ARRAY[] or
-			ARRAY() constructs.</para>
+            <para><emphasis role="bold">Variant 1:</emphasis>  Accepts one shell LineString.</para>
+            <para><emphasis role="bold">Variant 2:</emphasis>  Accepts a shell LineString and an array of
+            inner (hole) LineStrings. A geometry array can be constructed using the PostgreSQL array_agg(), ARRAY[] or
+            ARRAY() constructs.</para>
-			<note><para>This function does not accept MultiLineStrings.
-			Use <xref linkend="ST_LineMerge"/> to generate a LineString, or <xref linkend="ST_Dump"/> to extract LineStrings.</para>
-			</note>
+            <note><para>This function does not accept MultiLineStrings.
+            Use <xref linkend="ST_LineMerge"/> to generate a LineString, or <xref linkend="ST_Dump"/> to extract LineStrings.</para>
+            </note>
-		</refsection>
+        </refsection>
-		<refsection>
-		<title>Examples: Single input variant</title>
-		<para>Create a Polygon from a 2D LineString.</para>
-		 <programlisting>
+        <refsection>
+        <title>Examples: Single input variant</title>
+        <para>Create a Polygon from a 2D LineString.</para>
+         <programlisting>
 SELECT ST_MakePolygon( ST_GeomFromText('LINESTRING(75 29,77 29,77 29, 75 29)'));
 </programlisting>
@@ -589,18 +591,18 @@ st_asewkt
 POLYGONM((75.15 29.53 1,77 29 1,77.6 29.5 2,75.15 29.53 2))
 </programlisting>
-		</refsection>
-		<refsection>
-			<title>Examples: Outer shell with inner holes variant</title>
+        </refsection>
+        <refsection>
+            <title>Examples: Outer shell with inner holes variant</title>
-			<para>Create a donut Polygon with an extra hole</para>
-		   <programlisting>
+            <para>Create a donut Polygon with an extra hole</para>
+           <programlisting>
 SELECT ST_MakePolygon( ST_ExteriorRing( ST_Buffer(ring.line,10)),
-	ARRAY[  ST_Translate(ring.line, 1, 1),
-		ST_ExteriorRing(ST_Buffer(ST_Point(20,20),1)) ]
+    ARRAY[  ST_Translate(ring.line, 1, 1),
+        ST_ExteriorRing(ST_Buffer(ST_Point(20,20),1)) ]
 FROM (SELECT ST_ExteriorRing(
-	ST_Buffer(ST_Point(10,10),10,10)) AS line ) AS ring;
+    ST_Buffer(ST_Point(10,10),10,10)) AS line ) AS ring;
 </programlisting>
     <para>Create a set of province boundaries with holes
     representing lakes.  The input is a table of
@@ -618,20 +620,20 @@ FROM (SELECT ST_ExteriorRing(
     <note><para>The CASE construct is used because passing a null array into
     ST_MakePolygon results in a NULL return value.</para></note>
-		<programlisting>
+        <programlisting>
 SELECT p.gid, p.province_name,
-	CASE WHEN array_agg(w.geom) IS NULL
-	THEN p.geom
-	ELSE  ST_MakePolygon( ST_LineMerge(ST_Boundary(p.geom)),
+    CASE WHEN array_agg(w.geom) IS NULL
+    THEN p.geom
+    ELSE  ST_MakePolygon( ST_LineMerge(ST_Boundary(p.geom)),
                         array_agg(w.geom)) END
 FROM
-	provinces p LEFT JOIN waterlines w
-		ON (ST_Within(w.geom, p.geom) AND ST_IsClosed(w.geom))
+    provinces p LEFT JOIN waterlines w
+        ON (ST_Within(w.geom, p.geom) AND ST_IsClosed(w.geom))
 GROUP BY p.gid, p.province_name, p.geom;
 </programlisting>
-	<para>Another technique is to utilize a correlated subquery
-	and the ARRAY() constructor that converts a row set to an array.</para>
+    <para>Another technique is to utilize a correlated subquery
+    and the ARRAY() constructor that converts a row set to an array.</para>
 <programlisting>
     CASE WHEN EXISTS( SELECT w.geom
@@ -648,31 +650,31 @@ SELECT p.gid,  p.province_name,
     END AS geom
 FROM provinces p;
 </programlisting>
-		</refsection>
-		<refsection>
-			<para>
-				<xref linkend="ST_BuildArea"/>
-				<xref linkend="ST_Polygon"/>
-			</para>
-		</refsection>
-	</refentry>
+        </refsection>
+        <refsection>
+            <para>
+                <xref linkend="ST_BuildArea"/>
+                <xref linkend="ST_Polygon"/>
+            </para>
+        </refsection>
+    </refentry>
-	<refentry xml:id="ST_Point">
-	  <refnamediv>
-		<refname>ST_Point</refname>
+    <refentry xml:id="ST_Point">
+      <refnamediv>
+        <refname>ST_Point</refname>
-		<refpurpose>Creates a Point with X, Y and SRID values.</refpurpose>
-	  </refnamediv>
+        <refpurpose>Creates a Point with X, Y and SRID values.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>geometry <function>ST_Point</function></funcdef>
-		  </funcprototype>
-		</funcsynopsis>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry <function>ST_Point</function></funcdef>
+          </funcprototype>
+        </funcsynopsis>
         <funcsynopsis>
           <funcprototype>
@@ -681,38 +683,38 @@ FROM provinces p;
             <paramdef><type>integer</type> <parameter>srid=unknown</parameter></paramdef>
           </funcprototype>
         </funcsynopsis>
-	  </refsynopsisdiv>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>Returns a Point with the given X and Y coordinate values. This is the SQL-MM equivalent for <xref linkend="ST_MakePoint"/> that takes just X and Y.</para>
+        <para>Returns a Point with the given X and Y coordinate values. This is the SQL-MM equivalent for <xref linkend="ST_MakePoint"/> that takes just X and Y.</para>
-	    <para role="enhanced" conformance="3.2.0">Enhanced: 3.2.0 srid as an extra optional argument was added. Older installs require combining with ST_SetSRID to mark the srid on the geometry.</para>
-		<para>&sqlmm_compliant; SQL-MM 3: 6.1.2</para>
+        <para role="enhanced" conformance="3.2.0">Enhanced: 3.2.0 srid as an extra optional argument was added. Older installs require combining with ST_SetSRID to mark the srid on the geometry.</para>
+        <para>&sqlmm_compliant; SQL-MM 3: 6.1.2</para>
-	  </refsection>
+      </refsection>
-	  <refsection>
-		<title>Examples: Geometry</title>
+      <refsection>
+        <title>Examples: Geometry</title>
         <programlisting>SELECT ST_Point( -71.104, 42.315);</programlisting>
         <para>Creating a point with SRID specified:</para>
-		<programlisting>SELECT ST_Point( -71.104, 42.315, 4326);</programlisting>
+        <programlisting>SELECT ST_Point( -71.104, 42.315, 4326);</programlisting>
         <para>Alternative way of specifying SRID:</para>
         <programlisting>SELECT ST_SetSRID( ST_Point( -71.104, 42.315), 4326);</programlisting>
-	  </refsection>
+      </refsection>
-	  <refsection>
-		<title>Examples: Geography</title>
+      <refsection>
+        <title>Examples: Geography</title>
-		<para>Create <link linkend="PostGIS_Geography">geography</link> points using the <varname>::</varname> cast syntax:</para>
-		<programlisting>SELECT ST_Point( -71.104, 42.315, 4326)::geography;</programlisting>
+        <para>Create <link linkend="PostGIS_Geography">geography</link> points using the <varname>::</varname> cast syntax:</para>
+        <programlisting>SELECT ST_Point( -71.104, 42.315, 4326)::geography;</programlisting>
         <para>Pre-PostGIS 3.2 code, using <varname>CAST</varname>:</para>
         <programlisting>SELECT CAST( ST_SetSRID(ST_Point( -71.104, 42.315), 4326) AS geography);</programlisting>
@@ -723,17 +725,17 @@ In this example a point in Pennsylvania State Plane feet (SRID 2273)
 is projected to WGS84 (SRID 4326).</para>
 <programlisting>
 SELECT ST_Transform( ST_Point( 3637510, 3014852, 2273), 4326)::geography;</programlisting>
-	  </refsection>
+      </refsection>
-	  <refsection>
+      <refsection>
-			<xref linkend="ST_PointZ"/>, <xref linkend="ST_PointM"/>, <xref linkend="ST_PointZM"/>,
-			<xref linkend="ST_SetSRID"/>, <xref linkend="ST_Transform"/></para>
-	  </refsection>
-	</refentry>
+            <xref linkend="ST_PointZ"/>, <xref linkend="ST_PointM"/>, <xref linkend="ST_PointZM"/>,
+            <xref linkend="ST_SetSRID"/>, <xref linkend="ST_Transform"/></para>
+      </refsection>
+    </refentry>
     <refentry xml:id="ST_PointZ">
@@ -849,49 +851,49 @@ SELECT ST_Transform( ST_Point( 3637510, 3014852, 2273), 4326)::geography;</progr
       </refsection>
     </refentry>
-	<refentry xml:id="ST_Polygon">
-	  <refnamediv>
-		<refname>ST_Polygon</refname>
-		<refpurpose>Creates a Polygon from a LineString with a specified SRID.</refpurpose>
-	  </refnamediv>
+    <refentry xml:id="ST_Polygon">
+      <refnamediv>
+        <refname>ST_Polygon</refname>
+        <refpurpose>Creates a Polygon from a LineString with a specified SRID.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>geometry <function>ST_Polygon</function></funcdef>
-			<paramdef><type>geometry </type> <parameter>lineString</parameter></paramdef>
-			<paramdef><type>integer </type> <parameter>srid</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry <function>ST_Polygon</function></funcdef>
+            <paramdef><type>geometry </type> <parameter>lineString</parameter></paramdef>
+            <paramdef><type>integer </type> <parameter>srid</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>Returns a polygon built from the given LineString
-		and sets the spatial reference system from the <varname>srid</varname>.</para>
+        <para>Returns a polygon built from the given LineString
+        and sets the spatial reference system from the <varname>srid</varname>.</para>
-		<para>ST_Polygon is similar to <xref linkend="ST_MakePolygon"/> Variant 1
-		with the addition of setting the SRID.</para>
-		<para>To create polygons with holes
-		use <xref linkend="ST_MakePolygon"/> Variant 2 and then <xref linkend="ST_SetSRID"/>.
-		</para>
+        <para>ST_Polygon is similar to <xref linkend="ST_MakePolygon"/> Variant 1
+        with the addition of setting the SRID.</para>
+        <para>To create polygons with holes
+        use <xref linkend="ST_MakePolygon"/> Variant 2 and then <xref linkend="ST_SetSRID"/>.
+        </para>
-		</note>
+        </note>
-		<para>&sfs_compliant;</para>
-		<para>&sqlmm_compliant; SQL-MM 3: 8.3.2</para>
+        <para>&sfs_compliant;</para>
+        <para>&sqlmm_compliant; SQL-MM 3: 8.3.2</para>
-	  </refsection>
+      </refsection>
-	  <refsection>
+      <refsection>
 <para>Create a 2D polygon.</para>
-		<programlisting>
+        <programlisting>
 SELECT ST_AsText( ST_Polygon('LINESTRING(75 29, 77 29, 77 29, 75 29)'::geometry, 4326) );
 -- result --
@@ -904,40 +906,40 @@ SELECT ST_AsEWKT( ST_Polygon( ST_GeomFromEWKT('LINESTRING(75 29 1, 77 29 2, 77 2
 -- result --
 SRID=4326;POLYGON((75 29 1, 77 29 2, 77 29 3, 75 29 1))
 </programlisting>
-	  </refsection>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<para> <xref linkend="ST_AsEWKT"/>, <xref linkend="ST_AsText"/>, <xref linkend="ST_GeomFromEWKT"/>, <xref linkend="ST_GeomFromText"/>, <xref linkend="ST_LineMerge"/>, <xref linkend="ST_MakePolygon"/></para>
-	  </refsection>
-	</refentry>
+        <para> <xref linkend="ST_AsEWKT"/>, <xref linkend="ST_AsText"/>, <xref linkend="ST_GeomFromEWKT"/>, <xref linkend="ST_GeomFromText"/>, <xref linkend="ST_LineMerge"/>, <xref linkend="ST_MakePolygon"/></para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="ST_TileEnvelope">
-		<refnamediv>
-		<refname>ST_TileEnvelope</refname>
-		<refpurpose>Creates a rectangular Polygon in <link xlink:href="https://en.wikipedia.org/wiki/Web_Mercator_projection">Web Mercator</link> (SRID:3857) using the <link xlink:href="https://en.wikipedia.org/wiki/Tiled_web_map">XYZ tile system</link>.</refpurpose>
-		</refnamediv>
+    <refentry xml:id="ST_TileEnvelope">
+        <refnamediv>
+        <refname>ST_TileEnvelope</refname>
+        <refpurpose>Creates a rectangular Polygon in <link xlink:href="https://en.wikipedia.org/wiki/Web_Mercator_projection">Web Mercator</link> (SRID:3857) using the <link xlink:href="https://en.wikipedia.org/wiki/Tiled_web_map">XYZ tile system</link>.</refpurpose>
+        </refnamediv>
-		<refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>geometry <function>ST_TileEnvelope</function></funcdef>
-			<paramdef><type>integer</type> <parameter>tileZoom</parameter></paramdef>
-			<paramdef><type>integer</type> <parameter>tileX</parameter></paramdef>
-			<paramdef><type>integer</type> <parameter>tileY</parameter></paramdef>
-			<paramdef choice="opt"><type>geometry</type> <parameter>bounds=SRID=3857;LINESTRING(-20037508.342789 -20037508.342789,20037508.342789 20037508.342789)</parameter></paramdef>
-			<paramdef choice="opt"><type>float</type> <parameter>margin=0.0</parameter></paramdef>
-		  </funcprototype>
-		 </funcsynopsis>
-		</refsynopsisdiv>
+        <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry <function>ST_TileEnvelope</function></funcdef>
+            <paramdef><type>integer</type> <parameter>tileZoom</parameter></paramdef>
+            <paramdef><type>integer</type> <parameter>tileX</parameter></paramdef>
+            <paramdef><type>integer</type> <parameter>tileY</parameter></paramdef>
+            <paramdef choice="opt"><type>geometry</type> <parameter>bounds=SRID=3857;LINESTRING(-20037508.342789 -20037508.342789,20037508.342789 20037508.342789)</parameter></paramdef>
+            <paramdef choice="opt"><type>float</type> <parameter>margin=0.0</parameter></paramdef>
+          </funcprototype>
+         </funcsynopsis>
+        </refsynopsisdiv>
-		<refsection>
+        <refsection>
             giving the extent of a tile in the <link xlink:href="https://en.wikipedia.org/wiki/Tiled_web_map">XYZ tile system</link>.
             The tile is specified by the zoom level Z and the XY index of the tile in the grid at that level.
             Can be used to define the tile bounds required by <xref linkend="ST_AsMVTGeom"/> to convert geometry
@@ -949,7 +951,7 @@ SRID=4326;POLYGON((75 29 1, 77 29 2, 77 29 3, 75 29 1))
             The optional <varname>bounds</varname> parameter can be used to generate tiles in any coordinate system.
             It is a geometry that has the SRID and extent of the "Zoom Level zero" square within which the XYZ tile system is inscribed.</para>
-			<para>The optional <varname>margin</varname> parameter can be used to expand a tile by the given percentage.
+            <para>The optional <varname>margin</varname> parameter can be used to expand a tile by the given percentage.
             E.g. <varname>margin=0.125</varname> expands the tile by 12.5%, which is equivalent to buffer=512 when the tile extent size is 4096, as used in <xref linkend="ST_AsMVTGeom"/>.
             This is useful to create a tile buffer to include data lying outside of the tile's visible area, but whose existence affects the tile rendering.
             For example, a city name (a point) could be near an edge of a tile, so its label should be rendered on two tiles, even though the point is located in the visible area of just one tile.
@@ -958,13 +960,13 @@ SRID=4326;POLYGON((75 29 1, 77 29 2, 77 29 3, 75 29 1))
             Do not specify a margin when using with <varname>ST_AsMVTGeom</varname>.
             See the example for <xref linkend="ST_AsMVT"/>.</para>
-			<para role="enhanced" conformance="3.1.0">Enhanced: 3.1.0 Added margin parameter.</para>
-			<para role="availability" conformance="3.0.0">Availability: 3.0.0</para>
-		</refsection>
+            <para role="enhanced" conformance="3.1.0">Enhanced: 3.1.0 Added margin parameter.</para>
+            <para role="availability" conformance="3.0.0">Availability: 3.0.0</para>
+        </refsection>
-		<refsection>
-		<title>Example: Building a tile envelope</title>
-		 <programlisting>SELECT ST_AsText( ST_TileEnvelope(2, 1, 1) );
+        <refsection>
+        <title>Example: Building a tile envelope</title>
+         <programlisting>SELECT ST_AsText( ST_TileEnvelope(2, 1, 1) );
  st_astext
@@ -976,64 +978,64 @@ SELECT ST_AsText( ST_TileEnvelope(3, 1, 1, ST_MakeEnvelope(-180, -90, 180, 90, 4
  POLYGON((-135 45,-135 67.5,-90 67.5,-90 45,-135 45))
 </programlisting>
-		</refsection>
-		<refsection>
-			<para><xref linkend="ST_MakeEnvelope"/></para>
-		</refsection>
-	</refentry>
+        </refsection>
+        <refsection>
+            <para><xref linkend="ST_MakeEnvelope"/></para>
+        </refsection>
+    </refentry>
-	<refentry xml:id="ST_HexagonGrid">
-		<refnamediv>
-		<refname>ST_HexagonGrid</refname>
-		<refpurpose>Returns a set of hexagons and cell indices that completely cover the bounds of the geometry argument.</refpurpose>
-		</refnamediv>
+    <refentry xml:id="ST_HexagonGrid">
+        <refnamediv>
+        <refname>ST_HexagonGrid</refname>
+        <refpurpose>Returns a set of hexagons and cell indices that completely cover the bounds of the geometry argument.</refpurpose>
+        </refnamediv>
-		<refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>setof record <function>ST_HexagonGrid</function></funcdef>
-			<paramdef><type>float8</type> <parameter>size</parameter></paramdef>
-			<paramdef><type>geometry</type> <parameter>bounds</parameter></paramdef>
-		  </funcprototype>
-		 </funcsynopsis>
-		</refsynopsisdiv>
+        <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>setof record <function>ST_HexagonGrid</function></funcdef>
+            <paramdef><type>float8</type> <parameter>size</parameter></paramdef>
+            <paramdef><type>geometry</type> <parameter>bounds</parameter></paramdef>
+          </funcprototype>
+         </funcsynopsis>
+        </refsynopsisdiv>
-		<refsection>
+        <refsection>
-			<para>Starts with the concept of a hexagon tiling of the plane.
-			(Not a hexagon tiling of the globe, this is not the
-			<link xlink:href="https://github.com/uber/h3">H3</link> tiling scheme.)
-			For a given planar SRS, and a given edge size, starting at the origin of the SRS,
-			there is one unique hexagonal tiling of the plane, Tiling(SRS, Size).
-			This function answers the question: what hexagons in a given Tiling(SRS, Size)
-			overlap with a given bounds.</para>
+            <para>Starts with the concept of a hexagon tiling of the plane.
+            (Not a hexagon tiling of the globe, this is not the
+            <link xlink:href="https://github.com/uber/h3">H3</link> tiling scheme.)
+            For a given planar SRS, and a given edge size, starting at the origin of the SRS,
+            there is one unique hexagonal tiling of the plane, Tiling(SRS, Size).
+            This function answers the question: what hexagons in a given Tiling(SRS, Size)
+            overlap with a given bounds.</para>
-			<para><inlinemediaobject><imageobject>
-				<imagedata fileref="images/st_hexagongrid01.png"/>
-			</imageobject></inlinemediaobject></para>
+            <para><inlinemediaobject><imageobject>
+                <imagedata fileref="images/st_hexagongrid01.png"/>
+            </imageobject></inlinemediaobject></para>
-			<para>The SRS for the output hexagons is the SRS provided by the bounds geometry.</para>
-			<para>Doubling or tripling the edge size of the hexagon generates a new parent tiling that
-			fits with the origin tiling. Unfortunately, it is not possible to generate parent
-			hexagon tilings that the child tiles perfectly fit inside.</para>
+            <para>The SRS for the output hexagons is the SRS provided by the bounds geometry.</para>
+            <para>Doubling or tripling the edge size of the hexagon generates a new parent tiling that
+            fits with the origin tiling. Unfortunately, it is not possible to generate parent
+            hexagon tilings that the child tiles perfectly fit inside.</para>
-				<imagedata fileref="images/st_hexagongrid02.png"/>
+                <imagedata fileref="images/st_hexagongrid02.png"/>
-			<para role="availability" conformance="3.1.0">Availability: 3.1.0</para>
+            <para role="availability" conformance="3.1.0">Availability: 3.1.0</para>
-		</refsection>
+        </refsection>
-		<refsection>
-		<title>Example: Counting points in hexagons</title>
-		<para>To do a point summary against a hexagonal tiling, generate a hexagon grid using the
-		extent of the points as the bounds, then spatially join to that grid.</para>
-		 <programlisting>SELECT COUNT(*), hexes.geom
+        <refsection>
+        <title>Example: Counting points in hexagons</title>
+        <para>To do a point summary against a hexagonal tiling, generate a hexagon grid using the
+        extent of the points as the bounds, then spatially join to that grid.</para>
+         <programlisting>SELECT COUNT(*), hexes.geom
 FROM
     ST_HexagonGrid(
         10000,
@@ -1045,16 +1047,16 @@ FROM
 GROUP BY hexes.geom;</programlisting>
     </refsection>
     <refsection>
-		<title>Example: Generating hex coverage of polygons</title>
-		<para>If we generate a set of hexagons for each polygon boundary and filter
-			out those that do not intersect their hexagons, we end up with a tiling for
-			each polygon.</para>
-			<imagedata fileref="images/st_hexagongrid03.png"/>
-		<para>Tiling states results in a hexagon coverage of each state, and multiple
-			hexagons overlapping at the borders between states.</para>
-		<note><para>The LATERAL keyword is implied for set-returning functions when referring to a prior table in the FROM list. So CROSS JOIN LATERAL, CROSS JOIN, or just plain , are equivalent constructs for this example.</para></note>
+        <title>Example: Generating hex coverage of polygons</title>
+        <para>If we generate a set of hexagons for each polygon boundary and filter
+            out those that do not intersect their hexagons, we end up with a tiling for
+            each polygon.</para>
+            <imagedata fileref="images/st_hexagongrid03.png"/>
+        <para>Tiling states results in a hexagon coverage of each state, and multiple
+            hexagons overlapping at the borders between states.</para>
+        <note><para>The LATERAL keyword is implied for set-returning functions when referring to a prior table in the FROM list. So CROSS JOIN LATERAL, CROSS JOIN, or just plain , are equivalent constructs for this example.</para></note>
         <programlisting>SELECT admin1.gid, hex.geom
 FROM
     admin1
@@ -1069,41 +1071,41 @@ WHERE
             <para><xref linkend="ST_EstimatedExtent"/>, <xref linkend="ST_SetSRID"/>, <xref linkend="ST_SquareGrid"/>, <xref linkend="ST_TileEnvelope"/></para>
         </refsection>
-	</refentry>
+    </refentry>
-	<refentry xml:id="ST_Hexagon">
-		<refnamediv>
-		<refname>ST_Hexagon</refname>
-		<refpurpose>Returns a single hexagon, using the provided edge size and
-			cell coordinate within the hexagon grid space.</refpurpose>
-		</refnamediv>
+    <refentry xml:id="ST_Hexagon">
+        <refnamediv>
+        <refname>ST_Hexagon</refname>
+        <refpurpose>Returns a single hexagon, using the provided edge size and
+            cell coordinate within the hexagon grid space.</refpurpose>
+        </refnamediv>
-		<refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>geometry <function>ST_Hexagon</function></funcdef>
-			<paramdef><type>integer</type> <parameter>cell_i</parameter></paramdef>
-			<paramdef><type>integer</type> <parameter>cell_j</parameter></paramdef>
-			<paramdef choice="opt"><type>geometry</type> <parameter>origin</parameter></paramdef>
-		  </funcprototype>
-		 </funcsynopsis>
-		</refsynopsisdiv>
+        <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry <function>ST_Hexagon</function></funcdef>
+            <paramdef><type>integer</type> <parameter>cell_i</parameter></paramdef>
+            <paramdef><type>integer</type> <parameter>cell_j</parameter></paramdef>
+            <paramdef choice="opt"><type>geometry</type> <parameter>origin</parameter></paramdef>
+          </funcprototype>
+         </funcsynopsis>
+        </refsynopsisdiv>
-		<refsection>
+        <refsection>
-			<para>Uses the same hexagon tiling concept as <xref linkend="ST_HexagonGrid"/>, but generates just one hexagon at the desired cell coordinate. Optionally,
-			can adjust origin coordinate of the tiling, the default origin is at 0,0.
-			</para>
-			<para>Hexagons are generated with no SRID set, so use <xref linkend="ST_SetSRID"/> to set the SRID to the one you expect.</para>
+            <para>Uses the same hexagon tiling concept as <xref linkend="ST_HexagonGrid"/>, but generates just one hexagon at the desired cell coordinate. Optionally,
+            can adjust origin coordinate of the tiling, the default origin is at 0,0.
+            </para>
+            <para>Hexagons are generated with no SRID set, so use <xref linkend="ST_SetSRID"/> to set the SRID to the one you expect.</para>
-		</refsection>
+        </refsection>
-		<refsection>
-		<title>Example: Creating a hexagon at the origin</title>
-		 <programlisting>SELECT ST_AsText(ST_SetSRID(ST_Hexagon(1.0, 0, 0), 3857));
+        <refsection>
+        <title>Example: Creating a hexagon at the origin</title>
+         <programlisting>SELECT ST_AsText(ST_SetSRID(ST_Hexagon(1.0, 0, 0), 3857));
 POLYGON((-1 0,-0.5
          -0.866025403784439,0.5
@@ -1111,12 +1113,12 @@ POLYGON((-1 0,-0.5
          0,0.5
          0.866025403784439,-0.5
          0.866025403784439,-1 0)) </programlisting>
-		</refsection>
-		<refsection>
-			<para><xref linkend="ST_TileEnvelope"/>, <xref linkend="ST_HexagonGrid"/>, <xref linkend="ST_Square"/></para>
-		</refsection>
-	</refentry>
+        </refsection>
+        <refsection>
+            <para><xref linkend="ST_TileEnvelope"/>, <xref linkend="ST_HexagonGrid"/>, <xref linkend="ST_Square"/></para>
+        </refsection>
+    </refentry>
     <refentry xml:id="ST_SquareGrid">
         <refnamediv>
@@ -1203,51 +1205,51 @@ FROM admin0 WHERE name = 'Canada'
         </refsection>
     </refentry>
-	<refentry xml:id="ST_Square">
-		<refnamediv>
-		<refname>ST_Square</refname>
-		<refpurpose>Returns a single square, using the provided edge size and
-			cell coordinate within the square grid space.</refpurpose>
-		</refnamediv>
+    <refentry xml:id="ST_Square">
+        <refnamediv>
+        <refname>ST_Square</refname>
+        <refpurpose>Returns a single square, using the provided edge size and
+            cell coordinate within the square grid space.</refpurpose>
+        </refnamediv>
-		<refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>geometry <function>ST_Square</function></funcdef>
-			<paramdef choice="opt"><type>geometry</type> <parameter>origin='POINT(0 0)'</parameter></paramdef>
-		  </funcprototype>
-		 </funcsynopsis>
-		</refsynopsisdiv>
+        <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry <function>ST_Square</function></funcdef>
+            <paramdef choice="opt"><type>geometry</type> <parameter>origin='POINT(0 0)'</parameter></paramdef>
+          </funcprototype>
+         </funcsynopsis>
+        </refsynopsisdiv>
-		<refsection>
+        <refsection>
-			<para>Uses the same square tiling concept as <xref linkend="ST_SquareGrid"/>, but generates just one square at the desired cell coordinate. Optionally,
-			</para>
+            <para>Uses the same square tiling concept as <xref linkend="ST_SquareGrid"/>, but generates just one square at the desired cell coordinate. Optionally,
+            </para>
-			<para>
+            <para>
 Squares are generated with the SRID of the given origin.
 Use <xref linkend="ST_SetSRID"/> to set the SRID if the given origin
 has an unknown SRID (as is the case by default).</para>
-		</refsection>
+        </refsection>
-		<refsection>
-		<title>Example: Creating a square at the origin</title>
-		 <programlisting>SELECT ST_AsText(ST_SetSRID(ST_Square(1.0, 0, 0), 3857));
+        <refsection>
+        <title>Example: Creating a square at the origin</title>
+         <programlisting>SELECT ST_AsText(ST_SetSRID(ST_Square(1.0, 0, 0), 3857));
  POLYGON((0 0,0 1,1 1,1 0,0 0))</programlisting>
- 		</refsection>
-		<refsection>
-			<para><xref linkend="ST_TileEnvelope"/>, <xref linkend="ST_SquareGrid"/>, <xref linkend="ST_Hexagon"/></para>
-		</refsection>
-	</refentry>
+        </refsection>
+        <refsection>
+            <para><xref linkend="ST_TileEnvelope"/>, <xref linkend="ST_SquareGrid"/>, <xref linkend="ST_Hexagon"/></para>
+        </refsection>
+    </refentry>
diff --git a/liblwgeom/lwline.c b/liblwgeom/lwline.c
index 999927fea..50185f510 100644
--- a/liblwgeom/lwline.c
+++ b/liblwgeom/lwline.c
@@ -192,6 +192,16 @@ lwline_from_lwgeom_array(int32_t srid, uint32_t ngeoms, LWGEOM **geoms)
 			ptarray_append_ptarray(pa, ((LWLINE*)g)->points, -1);
+		else if ( g->type == MULTILINETYPE )
+			LWMLINE *mline = lwgeom_as_lwmline(g);
+			for ( uint32_t j = 0; j < mline->ngeoms; j++ )
+				LWLINE *line = mline->geoms[j];
+				if (lwline_is_empty(line)) continue;
+				ptarray_append_ptarray(pa, line->points, -1);
 		else if ( g->type == MULTIPOINTTYPE )
 			it = lwpointiterator_create(g);
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 507e2283d..4bf5816e9 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -184,7 +184,7 @@ ptarray_append_ptarray(POINTARRAY *pa1, POINTARRAY *pa2, double gap_tolerance)
 	/* Check for pathology */
 	if( ! pa1 || ! pa2 )
-		lwerror("ptarray_append_ptarray: null input");
+		lwerror("%s: null input", __func__);
 		return LW_FAILURE;
@@ -194,13 +194,13 @@ ptarray_append_ptarray(POINTARRAY *pa1, POINTARRAY *pa2, double gap_tolerance)
 	if( FLAGS_GET_READONLY(pa1->flags) )
-		lwerror("ptarray_append_ptarray: target pointarray is read-only");
+		lwerror("%s: target pointarray is read-only", __func__);
 		return LW_FAILURE;
 	if( FLAGS_GET_ZM(pa1->flags) != FLAGS_GET_ZM(pa2->flags) )
-		lwerror("ptarray_append_ptarray: appending mixed dimensionality is not allowed");
+		lwerror("%s: appending mixed dimensionality is not allowed", __func__);
 		return LW_FAILURE;
@@ -209,17 +209,17 @@ ptarray_append_ptarray(POINTARRAY *pa1, POINTARRAY *pa2, double gap_tolerance)
 	/* Check for duplicate end point */
 	if ( pa1->npoints )
-		POINT2D tmp1, tmp2;
-		getPoint2d_p(pa1, pa1->npoints-1, &tmp1);
-		getPoint2d_p(pa2, 0, &tmp2);
+		const POINT2D *tmp1, *tmp2;
+		tmp1 = getPoint2d_cp(pa1, pa1->npoints-1);
+		tmp2 = getPoint2d_cp(pa2, 0);
 		/* If the end point and start point are the same, then don't copy start point */
-		if (p2d_same(&tmp1, &tmp2)) {
+		if (p2d_same(tmp1, tmp2)) {
 			poff = 1;
 			--npoints;
-		else if ( gap_tolerance == 0 || ( gap_tolerance > 0 &&
-		           distance2d_pt_pt(&tmp1, &tmp2) > gap_tolerance ) )
+		else if ((gap_tolerance == 0) ||
+		         (gap_tolerance > 0 && distance2d_pt_pt(tmp1, tmp2) > gap_tolerance) )
 			lwerror("Second line start point too far from first line end point");
 			return LW_FAILURE;
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 1e126ce82..06ea00934 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -1467,8 +1467,10 @@ Datum LWGEOM_makeline_garray(PG_FUNCTION_ARGS)
 		geom = (GSERIALIZED *)DatumGetPointer(value);
-		if (gserialized_get_type(geom) != POINTTYPE && gserialized_get_type(geom) != LINETYPE &&
-		    gserialized_get_type(geom) != MULTIPOINTTYPE)
+		if (gserialized_get_type(geom) != POINTTYPE &&
+		    gserialized_get_type(geom) != MULTIPOINTTYPE &&
+		    gserialized_get_type(geom) != LINETYPE &&
+		    gserialized_get_type(geom) != MULTILINETYPE)
 			continue;
diff --git a/regress/core/ctors.sql b/regress/core/ctors.sql
index 2af13ae92..d4038d44e 100644
--- a/regress/core/ctors.sql
+++ b/regress/core/ctors.sql
@@ -36,3 +36,11 @@ select ST_makebox2d('POINT(0 0)', 'SRID=3;POINT(1 1)');
 select ST_3DMakeBox('SRID=3;POINT(0 0)', 'SRID=3;POINT(1 1)');
 select ST_3DMakeBox('POINT(0 0)', 'SRID=3;POINT(1 1)');
+SELECT 'ST_MakeLine2', ST_AsText(ST_MakeLine(geom))
+FROM (
+  VALUES
+  ('LINESTRING(0 0, 1 1)'),
+  ('MULTILINESTRING((1 1, 2 2), (2 2, 3 3))'),
+  ('MULTILINESTRING(EMPTY, (4 4, 5 5))')
+  ) AS geoms(geom);
diff --git a/regress/core/ctors_expected b/regress/core/ctors_expected
index a459f433a..d18c7100c 100644
--- a/regress/core/ctors_expected
+++ b/regress/core/ctors_expected
@@ -9,3 +9,4 @@ BOX(0 0,1 1)
 ERROR:  BOX2D_construct: Operation on mixed SRID geometries (Point, 0) != (Point, 3)
 BOX3D(0 0 0,1 1 0)
 ERROR:  BOX3D_construct: Operation on mixed SRID geometries (Point, 0) != (Point, 3)
+ST_MakeLine2|LINESTRING(0 0,1 1,2 2,3 3,4 4,5 5)
Summary of changes:
 NEWS                             |    2 +-
 doc/reference_constructor.xml    | 1408 +++++++++++++++++++-------------------
 liblwgeom/lwline.c               |   10 +
 liblwgeom/ptarray.c              |   18 +-
 postgis/lwgeom_functions_basic.c |    6 +-
 regress/core/ctors.sql           |    8 +
 regress/core/ctors_expected      |    1 +
 7 files changed, 738 insertions(+), 715 deletions(-)
hooks/post-receive
