[SCM] PostGIS branch master updated. 3.6.0rc2-127-gc57e094f7
Wed Oct 8 14:20:08 PDT 2025
the project "PostGIS".
       via  c57e094f73819eee5ffea672ee185c391e655ffe (commit)
      from  0383bab91e5f2eb7ac418fc661d473d3b87f5330 (commit)
revisions in full, below.
commit c57e094f73819eee5ffea672ee185c391e655ffe
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Oct 8 14:17:23 2025 -0700
    Avoid possible null pointer dereference. Closes #6000
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index 62e2a3586..cc3ea6800 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -276,6 +276,22 @@ lw_dist2d_is_collection(const LWGEOM *g)
+/* Check for overlapping bboxes */
+static int
+lw_dist2d_check_overlap(const LWGEOM *lwg1, const LWGEOM *lwg2)
+	assert(lwg1 && lwg2 && lwg1->bbox && lwg2->bbox);
+	/* Check if the geometries intersect. */
+	if ((lwg1->bbox->xmax < lwg2->bbox->xmin || lwg1->bbox->xmin > lwg2->bbox->xmax ||
+	     lwg1->bbox->ymax < lwg2->bbox->ymin || lwg1->bbox->ymin > lwg2->bbox->ymax))
+		return LW_FALSE;
+	return LW_TRUE;
 This is a recursive function delivering every possible combination of subgeometries
@@ -313,6 +329,8 @@ lw_dist2d_recursive(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl)
 		else
 			g1 = (LWGEOM *)lwg1;
+		if (!g1) continue;
 		if (lwgeom_is_empty(g1))
 			continue;
@@ -330,6 +348,8 @@ lw_dist2d_recursive(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl)
 			else
 				g2 = (LWGEOM *)lwg2;
+			if (!g2) continue;
 			if (lw_dist2d_is_collection(g2))
 				LWDEBUG(3, "Found collection inside second geometry collection, recursing");
@@ -529,26 +549,6 @@ lw_dist2d_distribute_bruteforce(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS
 	return LW_FALSE;
-/* Check for overlapping bboxes */
-int
-lw_dist2d_check_overlap(LWGEOM *lwg1, LWGEOM *lwg2)
-	LWDEBUG(2, "lw_dist2d_check_overlap is called");
-	if (!lwg1->bbox)
-		lwgeom_calculate_gbox(lwg1, lwg1->bbox);
-	if (!lwg2->bbox)
-		lwgeom_calculate_gbox(lwg2, lwg2->bbox);
-	/* Check if the geometries intersect. */
-	if ((lwg1->bbox->xmax < lwg2->bbox->xmin || lwg1->bbox->xmin > lwg2->bbox->xmax ||
-	     lwg1->bbox->ymax < lwg2->bbox->ymin || lwg1->bbox->ymin > lwg2->bbox->ymax))
-		LWDEBUG(3, "geometries bboxes did not overlap");
-		return LW_FALSE;
-	LWDEBUG(3, "geometries bboxes overlap");
-	return LW_TRUE;
 /** Geometries are distributed for the new faster distance-calculations */
 int
diff --git a/liblwgeom/measures.h b/liblwgeom/measures.h
index 9cf0fb958..fc3f34bfe 100644
--- a/liblwgeom/measures.h
+++ b/liblwgeom/measures.h
@@ -69,7 +69,6 @@ typedef struct
 int lw_dist2d_comp(const LWGEOM *lw1, const LWGEOM *lw2, DISTPTS *dl);
 int lw_dist2d_distribute_bruteforce(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl);
 int lw_dist2d_recursive(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl);
-int lw_dist2d_check_overlap(LWGEOM *lwg1, LWGEOM *lwg2);
 int lw_dist2d_distribute_fast(LWGEOM *lwg1, LWGEOM *lwg2, DISTPTS *dl);
Summary of changes:
 liblwgeom/measures.c | 40 ++++++++++++++++++++--------------------
 liblwgeom/measures.h |  1 -
 2 files changed, 20 insertions(+), 21 deletions(-)
hooks/post-receive
