[PostGIS] #5983: Data corruption in topology.topoelement and topology.topogeometry after upgrade to 3.6.0
trac at osgeo.org
Wed Oct 15 10:45:29 PDT 2025
upgrade to 3.6.0
Reporter: packi | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.6.1
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Comment (by strk):
> I'm suspecting very few people are using the bigint feature, so we might
be able to fix simply by updating the catalog back to what it was. Going
to test that theory out.
Yes please, tests are always good to have. I would start for a test
showing EXACTLY this problem, see if you can have CI turn red by just
touching `topology/test/regress/hooks/hook-before-upgrade-topology.sql`
and `topology/test/regress/hooks/hook-after-upgrade-topology.sql` ... we
NEED to be able to see this failure shown by `utils/check_all_upgrades.sh`
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5983#comment:14>
