[PostGIS] #5983: Data corruption in topology.topoelement and topology.topogeometry after upgrade to 3.6.0
trac at osgeo.org
Wed Oct 15 16:55:25 PDT 2025
upgrade to 3.6.0
Reporter: packi | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.6.1
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Comment (by robe):
this seems to rollback the change for topogeometry:
UPDATE pg_catalog.pg_attribute AS n SET atttypid = 'int'::regtype, attlen
= 4
FROM pg_catalog.pg_type
join pg_catalog.pg_class on pg_class.oid =
pg_type.typrelid
join pg_catalog.pg_attribute AS pga on
pga.attrelid = pg_class.oid
join pg_type as pg_attr_type on pg_attr_type.oid =
pga.atttypid
WHERE pg_type.typname::regtype::text = 'topogeometry' AND pga.attname =
'id'
AND
pg_type.typnamespace::regnamespace::text = 'topology' AND
n.attrelid = pga.attrelid
AND n.attnum = pga.attnum AND pga.atttypid::regtype::text = 'bigint';
After that my query:
SELECT geometrytype(topo) FROM topo_states;
changes from:
UNEXPECTED
to:
MULTIPOLYGON
But I haven't checked yet what happens if I had updated records after the
move.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5983#comment:15>
