[SCM] PostGIS branch master updated. 3.6.0rc2-144-g863681495
Fri Oct 17 15:15:26 PDT 2025
the project "PostGIS".
       via  8636814957602317b35130153770a06bfcb1784b (commit)
      from  fd358eeafb64d35535d6650aeb308cf8852665c9 (commit)
revisions in full, below.
commit 8636814957602317b35130153770a06bfcb1784b
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Oct 18 02:14:27 2025 +0400
    Add notes on how to run single test
    References #5638
diff --git a/AGENTS.md b/AGENTS.md
index 683dd6a0b..61b9fe6f8 100644
--- a/AGENTS.md
+++ b/AGENTS.md
@@ -186,6 +186,33 @@ Additional targets of interest:
   the same PostgreSQL instance before invoking this.
 * `make installcheck` – runs tests against an installed copy (after `make install`).
+### Running a single C unit test
+After building the tree (Section 5), you can exercise one CUnit suite in
+isolation. From the repository root run:
+```bash
+cd liblwgeom/cunit
+make cu_tester
+./cu_tester geodetic    # replace "geodetic" with another suite or test name as needed
+The `cu_tester` binary also accepts individual test names if you need to drill
+down further.
+### Running a single SQL regression test
+With PostgreSQL running as configured above and the extension installed via
+`sudo make install`, target one SQL file by passing it to the regression driver:
+```bash
+export PGPASSWORD=postgres   # or reuse another password if you kept SCRAM auth
+make -C regress check RUNTESTFLAGS="--extension" TESTS="$(pwd)/regress/core/affine"
+Swap `regress/core/affine` for the test you need.
 ## 7. Inspecting coverage results
 Coverage builds rely on the `lcov` utilities. After executing the coverage `make check` run:
@@ -238,7 +265,10 @@ reflow a specific range, or pass `--extensions c,cpp,h` when touching files with
 non-standard suffixes. Validate that the resulting diff stays focused on the
 code you touched.
-Review STYLE file in root of the repository for other stylistic preferences.
+Review `STYLE` file in root of the repository for other stylistic preferences.
+For release policies, upgrade implications, and naming
+conventions for new features, skim `doc/developer.md` (PostGIS Developer
+How-To) for a concise overview of those workflows.
 The Codecov upload commands in `ci/github/run_coverage.sh` and
 `ci/github/run_garden.sh` require outbound network access; they are harmless to
Summary of changes:
 AGENTS.md | 32 +++++++++++++++++++++++++++++++-
 1 file changed, 31 insertions(+), 1 deletion(-)
hooks/post-receive
