[SCM] PostGIS branch master updated. 3.6.0rc2-152-g19e25a659
Mon Oct 20 09:12:55 PDT 2025
the project "PostGIS".
       via  19e25a659e825484fcd8a013b5364a2621ae46b5 (commit)
      from  01c39190148c91ec62889fadbabc25afb7f707fd (commit)
revisions in full, below.
commit 19e25a659e825484fcd8a013b5364a2621ae46b5
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon Oct 20 09:12:46 2025 -0700
    Improve doc example for ST_DumpRings
diff --git a/doc/reference_accessor.xml b/doc/reference_accessor.xml
index 016122e20..ac5864537 100644
--- a/doc/reference_accessor.xml
+++ b/doc/reference_accessor.xml
@@ -918,28 +918,21 @@ FROM (
 	  <refsection>
 		<title>Examples</title>
-        <para>General form of query.</para>
+        <para>Extracting all rings as polygons.</para>
 		<programlisting>SELECT polyTable.field1, polyTable.field1,
 	  (ST_DumpRings(polyTable.geom)).geom As geom
 FROM polyTable;
 </programlisting>
-        <para>A polygon with a single hole.</para>
-<programlisting>SELECT path, ST_AsEWKT(geom) As geom
+        <para>Extracting shell and holes from a polygon.</para>
+<programlisting>SELECT path, ST_AsText(geom) As geom
 	FROM ST_DumpRings(
-		ST_GeomFromEWKT('POLYGON((-8149064 5133092 1,-8149064 5132986 1,-8148996 5132839 1,-8148972 5132767 1,-8148958 5132508 1,-8148941 5132466 1,-8148924 5132394 1,
-		-8148903 5132210 1,-8148930 5131967 1,-8148992 5131978 1,-8149237 5132093 1,-8149404 5132211 1,-8149647 5132310 1,-8149757 5132394 1,
-		-8150305 5132788 1,-8149064 5133092 1),
-		(-8149362 5132394 1,-8149446 5132501 1,-8149548 5132597 1,-8149695 5132675 1,-8149362 5132394 1))')
-		)  as foo;
- path |                                            geom
-  {0} | POLYGON((-8149064 5133092 1,-8149064 5132986 1,-8148996 5132839 1,-8148972 5132767 1,-8148958 5132508 1,
-	  |          -8148941 5132466 1,-8148924 5132394 1,
-	  |          -8148903 5132210 1,-8148930 5131967 1,
-	  |          -8148992 5131978 1,-8149237 5132093 1,
-	  |          -8149404 5132211 1,-8149647 5132310 1,-8149757 5132394 1,-8150305 5132788 1,-8149064 5133092 1))
-  {1} | POLYGON((-8149362 5132394 1,-8149446 5132501 1,
-	  |          -8149548 5132597 1,-8149695 5132675 1,-8149362 5132394 1))</programlisting>
+		    'POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9), (2 2, 2 3, 3 3, 3 2, 2 2), (4 2, 4 4, 6 4, 6 2, 4 2))');
+ path |              geom
+ {0}  | POLYGON((1 9,9 9,9 1,1 1,1 9))
+ {1}  | POLYGON((2 2,2 3,3 3,3 2,2 2))
+ {2}  | POLYGON((4 2,4 4,6 4,6 2,4 2))</programlisting>
 	  </refsection>
 	  <!-- Optionally add a "See Also" section -->
Summary of changes:
 doc/reference_accessor.xml | 27 ++++++++++-----------------
 1 file changed, 10 insertions(+), 17 deletions(-)
hooks/post-receive
