[PostGIS] #6007: Diffferrent results with two version of postgis master.
trac at osgeo.org
Tue Oct 21 05:20:13 PDT 2025
Reporter: Lars Aksel Opsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.1
Component: postgis | Version: master
Keywords: |
Postgis below gives one result
https://gitlab.com/nibioopensource/resolve-overlap-and-
gap/-/pipelines/2111443784
POSTGIS="3.7.0dev 3.6.0rc2-55-gfda22140e" [EXTENSION] PGSQL="160"
GEOS="3.15.0dev-CAPI-1.21.0" PROJ="9.8.0 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ 9.8.0)
LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
(Internal)" TOPOLOGY
while this gives another result
-num surfaces total|219
+num surfaces total|217
gap/-/jobs/11789714169
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6007>
