[PostGIS] #6008: Add a Variant of ST_Polygon(raster) with Guaranteed Valid Geometry Output
trac at osgeo.org
Tue Oct 21 08:48:30 PDT 2025
Reporter: GISuser5432 | Owner: robe
Type: task | Status: new
Priority: high | Milestone: PostGIS
| 3.6.1
Component: raster | Version: 3.6.x
Keywords: PostGIS_Raster; ST_Polygon(rast); |
Valid Geometry; |
I am upgrading an old project that uses ST_Polygon(raster)
[https://postgis.net/docs/RT_ST_Polygon.html] in a production environment.
While preparing to upgrade PostGIS to the latest version, I noticed that
starting from version **3.3.0**, the function no longer **checks the
validity** of the output geometry to improve performance.
Although this optimization makes sense for speed, there are use cases
where **100% valid output is critical**. Handling invalid geometries case
by case in production can be error-prone.
**Proposal:**
Add an optional argument to ST_Polygon(raster) that allows users to choose
between:
* Fast mode (current behavior, no validity check)
* Robust mode (guarantees valid geometry output)
I am not certain whether passing the result through ST_MakeValid(geom) is
always sufficient, or if invalid geometries can still occur.
A variant or option that guarantees validity would be extremely valuable
for production environments.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6008>
