[PostGIS] #6008: Add a Variant of ST_Polygon(raster) with Guaranteed Valid Geometry Output
PostGIS trac at osgeo.org
Tue Oct 21 08:57:08 PDT 2025
  Reporter:              |      Owner:  robe
  GISuser5432            |
      Type:  task        |     Status:  new
  Priority:  high        |  Milestone:  PostGIS 3.6.1
 Component:  raster      |    Version:  3.6.x
Resolution:              |   Keywords:  PostGIS_Raster; ST_Polygon(rast);
                         |  Valid Geometry;
Comment (by pramsey):
 Passing the output through `ST_MakeValid(geom, 'method=structure')` or
 `ST_MakeValid(geom, 'method=linework')` is something you can do now. If
 the actual `ST_Polygon` function is failing, that's a different problem
 entirely, and looking at
 [https://github.com/postgis/postgis/pull/674/files GH674] not a problem
 that was introduced when the validity checks were removed. I'd rather you
 just wrap your function in ST_MakeValid than add a flag that just does the
 exact same thing.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6008#comment:1>
