[PostGIS] #6009: Error of ST_Polygon(raster) function in PostGIS 3.4.3 and 3.5.4
PostGIS trac at osgeo.org
Tue Oct 21 10:45:06 PDT 2025
  Reporter:              |      Owner:  robe
  GISuser5432            |
      Type:  defect      |     Status:  new
  Priority:  high        |  Milestone:  PostGIS 3.5.5
 Component:  raster      |    Version:  3.5.x
Resolution:              |   Keywords:  PostGIS_Raster; Raster;
                         |  ST_Polygon(Raster)
Description changed by GISuser5432:
Old description:
> I tried to run ST_Polygon(Raster) on a raster table and for 3 rows, it
> produced an error.
> This is the simple query:
> {{{#!div style="font-size: 80%"
> Code highlighting:
>   {{{#!sql
>   SELECT ST_Polygon(raster)
>   FROM error_sounding_2m
> This is the error message:
> ERROR:  rt_raster_surface: Could not union the pixel polygons using
> GEOSUnaryUnion()
> SQL state: XX000
> This is the version of the PostGIS:
> POSTGIS="3.4.3 e365945" [EXTENSION] PGSQL="170" GEOS="3.9.0-CAPI-1.16.2"
> PROJ="7.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
> DATABASE_PATH=/usr/share/proj/proj.db" GDAL="GDAL 3.2.2, released
> 2021/03/05" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3"
> WAGYU="0.5.0 (Internal)" RASTER
> I also checked it for 3.5 and I had the same error. Only in 3.6 the error
> was fixed!
> The DB dump is attached for 3 raw of raster in a DB called enav.
New description:
 produced an error.
 Code highlighting:
   {{{#!sql
 GEOSUnaryUnion()
 SQL state: XX000
 was fixed!
 I must also say that all tests were done in Docker containers of PostGIS.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6009#comment:1>
