[SCM] PostGIS branch master updated. 3.6.0rc2-153-gc33f545a1
Wed Oct 22 13:38:33 PDT 2025
the project "PostGIS".
       via  c33f545a1feffd88ab6f8fdc34536e1b8ede9ed1 (commit)
      from  19e25a659e825484fcd8a013b5364a2621ae46b5 (commit)
revisions in full, below.
commit c33f545a1feffd88ab6f8fdc34536e1b8ede9ed1
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Oct 22 13:38:18 2025 -0700
    Add ST_MMin and ST_MMax functions to match up to the other
    XYZ variants. Closes #2858.
diff --git a/doc/reference_accessor.xml b/doc/reference_accessor.xml
index ac5864537..b75f26317 100644
--- a/doc/reference_accessor.xml
+++ b/doc/reference_accessor.xml
@@ -906,10 +906,10 @@ FROM (
         The exterior ring (shell) has index 0.  The interior rings (holes) have indices of 1 and higher.
         </para>
-		<note>This only works for POLYGON geometries, not MULTIPOLYGONs.
+		<note><para>This only works for POLYGON geometries, not MULTIPOLYGONs.
 		Use <xref linkend="ST_Dump"/> to extract polygon elements from polygonal geometries:
 		<code>ST_DumpRings( (ST_Dump(geom)).geom )</code>
-		</note>
+		</para></note>
 		<para role="availability" conformance="1.1.3.">Availability: PostGIS 1.1.3. Requires PostgreSQL 7.3 or higher.</para>
 		<para>&Z_support;</para>
@@ -921,7 +921,7 @@ FROM (
         <para>Extracting all rings as polygons.</para>
 		<programlisting>SELECT polyTable.field1, polyTable.field1,
 	  (ST_DumpRings(polyTable.geom)).geom As geom
-FROM polyTable;
+FROM polyTable
 </programlisting>
         <para>Extracting shell and holes from a polygon.</para>
 <programlisting>SELECT path, ST_AsText(geom) As geom
diff --git a/doc/reference_bbox.xml b/doc/reference_bbox.xml
index 46bfcc698..797c36f3d 100644
--- a/doc/reference_bbox.xml
+++ b/doc/reference_bbox.xml
@@ -1,45 +1,45 @@
 <!-- Converted by db4-upgrade version 1.1 -->
 <section xmlns="http://docbook.org/ns/docbook" version="5.0" xml:id="BBox_Functions">
-	  <title>Bounding Box Functions</title><info>
-	    <abstract>
-			<para>These functions produce or operate on bounding boxes.
-			They can also provide and accept geometry values, by using automatic or explicit casts.
-			</para>
-			<para>See also <xref linkend="PostGIS_BoxFunctions"/>.</para>
-    	</abstract>
+      <title>Bounding Box Functions</title><info>
+        <abstract>
+            <para>These functions produce or operate on bounding boxes.
+            They can also provide and accept geometry values, by using automatic or explicit casts.
+            </para>
+            <para>See also <xref linkend="PostGIS_BoxFunctions"/>.</para>
+        </abstract>
     </info>
-	<refentry xml:id="Box2D">
-	  <refnamediv>
-		<refname>Box2D</refname>
+    <refentry xml:id="Box2D">
+      <refnamediv>
+        <refname>Box2D</refname>
-		<refpurpose>Returns a BOX2D representing the 2D extent of a geometry.</refpurpose>
-	  </refnamediv>
+        <refpurpose>Returns a BOX2D representing the 2D extent of a geometry.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>box2d <function>Box2D</function></funcdef>
-			<paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>box2d <function>Box2D</function></funcdef>
+            <paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
-		<title>Description</title>
+      <refsection>
+        <title>Description</title>
-		<para>Returns a <xref linkend="box2d_type"/> representing the 2D extent of the geometry.</para>
+        <para>Returns a <xref linkend="box2d_type"/> representing the 2D extent of the geometry.</para>
-		<para role="enhanced" conformance="2.0.0">Enhanced: 2.0.0 support for Polyhedral surfaces, Triangles and TIN was introduced.</para>
-		<para>&curve_support;</para>
-		<para>&P_support;</para>
-		<para>&T_support;</para>
-	  </refsection>
+        <para role="enhanced" conformance="2.0.0">Enhanced: 2.0.0 support for Polyhedral surfaces, Triangles and TIN was introduced.</para>
+        <para>&curve_support;</para>
+        <para>&P_support;</para>
+        <para>&T_support;</para>
+      </refsection>
-	  <refsection>
-		<title>Examples</title>
+      <refsection>
+        <title>Examples</title>
 <programlisting>SELECT Box2D(ST_GeomFromText('LINESTRING(1 2, 3 4, 5 6)'));
@@ -54,46 +54,46 @@ box2d
 BOX(220186.984375 150406,220288.25 150506.140625)
 </programlisting>
-	  </refsection>
+      </refsection>
-	  <!-- Optionally add a "See Also" section -->
-	  <refsection>
-		<title>See Also</title>
+      <!-- Optionally add a "See Also" section -->
+      <refsection>
+        <title>See Also</title>
-		<para><xref linkend="Box3D"/>, <xref linkend="ST_GeomFromText"/></para>
-	  </refsection>
-	</refentry>
+        <para><xref linkend="Box3D"/>, <xref linkend="ST_GeomFromText"/></para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="Box3D">
-	  <refnamediv>
-		<refname>Box3D</refname>
+    <refentry xml:id="Box3D">
+      <refnamediv>
+        <refname>Box3D</refname>
-		<refpurpose>Returns a BOX3D representing the 3D extent of a geometry.</refpurpose>
-	  </refnamediv>
+        <refpurpose>Returns a BOX3D representing the 3D extent of a geometry.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>box3d <function>Box3D</function></funcdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>box3d <function>Box3D</function></funcdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>Returns a <xref linkend="box3d_type"/> representing the 3D extent of the geometry.</para>
-		<para>&Z_support;</para>
-	  </refsection>
+        <para>Returns a <xref linkend="box3d_type"/> representing the 3D extent of the geometry.</para>
+        <para>&Z_support;</para>
+      </refsection>
-	  <refsection>
+      <refsection>
 <programlisting>SELECT Box3D(ST_GeomFromEWKT('LINESTRING(1 2 3, 3 4 5, 5 6 5)'));
@@ -108,75 +108,75 @@ Box3d
 BOX3D(220227 150406 1,220268 150415 1)
 </programlisting>
-	  </refsection>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<para><xref linkend="Box2D"/>, <xref linkend="ST_GeomFromEWKT"/></para>
-	  </refsection>
-	</refentry>
+        <para><xref linkend="Box2D"/>, <xref linkend="ST_GeomFromEWKT"/></para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="ST_EstimatedExtent">
-	  <refnamediv>
-		<refname>ST_EstimatedExtent</refname>
+    <refentry xml:id="ST_EstimatedExtent">
+      <refnamediv>
+        <refname>ST_EstimatedExtent</refname>
-		<refpurpose>Returns the estimated extent of a spatial table.</refpurpose>
-	  </refnamediv>
+        <refpurpose>Returns the estimated extent of a spatial table.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>box2d <function>ST_EstimatedExtent</function></funcdef>
-			<paramdef><type>text </type> <parameter>schema_name</parameter></paramdef>
-			<paramdef><type>text </type> <parameter>table_name</parameter></paramdef>
-			<paramdef><type>text </type> <parameter>geocolumn_name</parameter></paramdef>
-			<paramdef><type>boolean </type> <parameter>parent_only</parameter></paramdef>
-		  </funcprototype>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>box2d <function>ST_EstimatedExtent</function></funcdef>
+            <paramdef><type>text </type> <parameter>schema_name</parameter></paramdef>
+            <paramdef><type>text </type> <parameter>table_name</parameter></paramdef>
+            <paramdef><type>text </type> <parameter>geocolumn_name</parameter></paramdef>
+            <paramdef><type>boolean </type> <parameter>parent_only</parameter></paramdef>
+          </funcprototype>
-		  <funcprototype>
-		  </funcprototype>
+          <funcprototype>
+          </funcprototype>
-		  <funcprototype>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+          <funcprototype>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>Returns the estimated extent of a spatial table as a <xref linkend="box2d_type"/>.
-            The	current schema is used if not specified.
-			The estimated extent is taken from the geometry column's statistics.
+        <para>Returns the estimated extent of a spatial table as a <xref linkend="box2d_type"/>.
+            The current schema is used if not specified.
+            The estimated extent is taken from the geometry column's statistics.
             This is usually much faster than computing the exact extent of the table
             using <xref linkend="ST_Extent"/> or <xref linkend="ST_3DExtent"/>.
             </para>
         <para>
             The default behavior is to also use statistics collected from child tables (tables
-			with INHERITS) if available. If <varname>parent_only</varname> is set to TRUE, only
-			statistics for the given table are used and child tables are ignored.
-		</para>
+            with INHERITS) if available. If <varname>parent_only</varname> is set to TRUE, only
+            statistics for the given table are used and child tables are ignored.
+        </para>
-		<para>For PostgreSQL >= 8.0.0 statistics are gathered by VACUUM
-		ANALYZE and the result extent will be about 95% of the actual one.
+        <para>For PostgreSQL >= 8.0.0 statistics are gathered by VACUUM
+        ANALYZE and the result extent will be about 95% of the actual one.
         For PostgreSQL < 8.0.0 statistics are gathered by running
-		<code>update_geometry_stats()</code> and the result extent is exact.
+        <code>update_geometry_stats()</code> and the result extent is exact.
         </para>
         <note>
             <para>
             In the absence of statistics (empty table or no ANALYZE called) this function
             returns NULL.  Prior to version 1.5.4 an exception was thrown instead.
-		    </para>
+            </para>
         </note>
         <note>
@@ -188,201 +188,201 @@ BOX3D(220227 150406 1,220268 150415 1)
     <para role="availability" conformance="1.0.0">Availability: 1.0.0</para>
     <para role="changed" conformance="2.1.0.">Changed: 2.1.0. Up to 2.0.x this was called ST_Estimated_Extent.</para>
-	  </refsection>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<programlisting>SELECT ST_EstimatedExtent('ny', 'edges', 'geom');
+        <programlisting>SELECT ST_EstimatedExtent('ny', 'edges', 'geom');
 --result--
 BOX(-8877653 4912316,-8010225.5 5589284)
 SELECT ST_EstimatedExtent('feature_poly', 'geom');
 --result--
 BOX(-124.659652709961 24.6830825805664,-67.7798080444336 49.0012092590332)
-		</programlisting>
-	  </refsection>
+        </programlisting>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<para><xref linkend="ST_Extent"/>, <xref linkend="ST_3DExtent"/></para>
-	  </refsection>
-	</refentry>
+        <para><xref linkend="ST_Extent"/>, <xref linkend="ST_3DExtent"/></para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="ST_Expand">
-	  <refnamediv>
-		<refname>ST_Expand</refname>
-		<refpurpose>Returns a bounding box expanded from another bounding box or a geometry.</refpurpose>
-	  </refnamediv>
+    <refentry xml:id="ST_Expand">
+      <refnamediv>
+        <refname>ST_Expand</refname>
+        <refpurpose>Returns a bounding box expanded from another bounding box or a geometry.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>geometry <function>ST_Expand</function></funcdef>
-			<paramdef><type>float</type> <parameter>units_to_expand</parameter></paramdef>
-		  </funcprototype>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry <function>ST_Expand</function></funcdef>
+            <paramdef><type>float</type> <parameter>units_to_expand</parameter></paramdef>
+          </funcprototype>
-		  <funcprototype>
-			<paramdef><type>float</type> <parameter>dx</parameter></paramdef>
-			<paramdef><type>float</type> <parameter>dy</parameter></paramdef>
-			<paramdef choice="opt"><type>float</type> <parameter>dz=0</parameter></paramdef>
-			<paramdef choice="opt"><type>float</type> <parameter>dm=0</parameter></paramdef>
-		  </funcprototype>
+          <funcprototype>
+            <paramdef><type>float</type> <parameter>dx</parameter></paramdef>
+            <paramdef><type>float</type> <parameter>dy</parameter></paramdef>
+            <paramdef choice="opt"><type>float</type> <parameter>dz=0</parameter></paramdef>
+            <paramdef choice="opt"><type>float</type> <parameter>dm=0</parameter></paramdef>
+          </funcprototype>
-		  <funcprototype>
-			<funcdef>box2d <function>ST_Expand</function></funcdef>
-			<paramdef><type>box2d </type> <parameter>box</parameter></paramdef>
-		  </funcprototype>
+          <funcprototype>
+            <funcdef>box2d <function>ST_Expand</function></funcdef>
+            <paramdef><type>box2d </type> <parameter>box</parameter></paramdef>
+          </funcprototype>
-		  <funcprototype>
-		  </funcprototype>
+          <funcprototype>
+          </funcprototype>
-		  <funcprototype>
-			<funcdef>box3d <function>ST_Expand</function></funcdef>
-			<paramdef><type>box3d </type> <parameter>box</parameter></paramdef>
-		  </funcprototype>
+          <funcprototype>
+            <funcdef>box3d <function>ST_Expand</function></funcdef>
+            <paramdef><type>box3d </type> <parameter>box</parameter></paramdef>
+          </funcprototype>
-		  <funcprototype>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+          <funcprototype>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>Returns a bounding box expanded from the bounding box of the input,
-			either by specifying a single distance with which the box should be expanded on both
-			axes, or by specifying an expansion distance for each axis.
+        <para>Returns a bounding box expanded from the bounding box of the input,
+            either by specifying a single distance with which the box should be expanded on both
+            axes, or by specifying an expansion distance for each axis.
-			Uses double-precision. Can be used for distance queries, or to add a bounding box
-			filter to a query to take advantage of a spatial index.</para>
+            Uses double-precision. Can be used for distance queries, or to add a bounding box
+            filter to a query to take advantage of a spatial index.</para>
-		<para>In addition to the version of ST_Expand accepting and returning a geometry, variants
-			are provided that accept and return
+        <para>In addition to the version of ST_Expand accepting and returning a geometry, variants
+            are provided that accept and return
             <xref linkend="box2d_type"/> and <xref linkend="box3d_type"/> data types.
-		</para>
+        </para>
-		<para>Distances are in the units of the spatial reference system of the input.</para>
+        <para>Distances are in the units of the spatial reference system of the input.</para>
-		<para>ST_Expand is similar to <xref linkend="ST_Buffer"/>,
-			except while buffering expands a geometry in all directions,
-			ST_Expand expands the bounding box along each axis.</para>
+        <para>ST_Expand is similar to <xref linkend="ST_Buffer"/>,
+            except while buffering expands a geometry in all directions,
+            ST_Expand expands the bounding box along each axis.</para>
-		<note>
-		  <para>Pre version 1.3, ST_Expand was used in conjunction with <xref linkend="ST_Distance"/> to do indexable distance queries.  For example,
-			<code>geom && ST_Expand('POINT(10 20)', 10) AND ST_Distance(geom, 'POINT(10 20)') < 10</code>.
-			This has been replaced by the simpler and more efficient <xref linkend="ST_DWithin"/> function.</para>
-		</note>
+        <note>
+          <para>Pre version 1.3, ST_Expand was used in conjunction with <xref linkend="ST_Distance"/> to do indexable distance queries.  For example,
+            <code>geom && ST_Expand('POINT(10 20)', 10) AND ST_Distance(geom, 'POINT(10 20)') < 10</code>.
+            This has been replaced by the simpler and more efficient <xref linkend="ST_DWithin"/> function.</para>
+        </note>
         <para role="availability" conformance="1.5.0">Availability: 1.5.0 behavior changed to output double precision instead of float4 coordinates.</para>
         <para role="enhanced" conformance="2.3.0">Enhanced: 2.3.0 support was added to expand a box by different amounts in different dimensions.</para>
-	  </refsection>
+      </refsection>
-	  <refsection>
-		<note><para>Examples below use US National Atlas Equal Area (SRID=2163) which is a meter projection</para></note>
-		<programlisting>
-		<!-- TODO: fix results of documentation to reflect new behavior -->
+      <refsection>
+        <note><para>Examples below use US National Atlas Equal Area (SRID=2163) which is a meter projection</para></note>
+        <programlisting>
+        <!-- TODO: fix results of documentation to reflect new behavior -->
 --10 meter expanded box around bbox of a linestring
 SELECT CAST(ST_Expand(ST_GeomFromText('LINESTRING(2312980 110676,2312923 110701,2312892 110714)', 2163),10) As box2d);
-					 st_expand
+                     st_expand
  BOX(2312882 110666,2312990 110724)
 --10 meter expanded 3D box of a 3D box
 SELECT ST_Expand(CAST('BOX3D(778783 2951741 1,794875 2970042.61545891 10)' As box3d),10)
-							  st_expand
+                              st_expand
  BOX3D(778773 2951731 -9,794885 2970052.61545891 20)
  --10 meter geometry astext rep of a expand box around a point geometry
  SELECT ST_AsEWKT(ST_Expand(ST_GeomFromEWKT('SRID=2163;POINT(2312980 110676)'),10));
-											st_asewkt
+                                            st_asewkt
  SRID=2163;POLYGON((2312970 110666,2312970 110686,2312990 110686,2312990 110666,2312970 110666))
-		</programlisting>
-	  </refsection>
+        </programlisting>
+      </refsection>
-	  <refsection>
-		<para><xref linkend="ST_Buffer"/>, <xref linkend="ST_DWithin"/>, <xref linkend="ST_SRID"/></para>
-	  </refsection>
-	</refentry>
+      <refsection>
+        <para><xref linkend="ST_Buffer"/>, <xref linkend="ST_DWithin"/>, <xref linkend="ST_SRID"/></para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="ST_Extent">
-	  <refnamediv>
-		<refname>ST_Extent</refname>
-		<refpurpose>Aggregate function that returns the bounding box of geometries.</refpurpose>
-	  </refnamediv>
+    <refentry xml:id="ST_Extent">
+      <refnamediv>
+        <refname>ST_Extent</refname>
+        <refpurpose>Aggregate function that returns the bounding box of geometries.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>box2d <function>ST_Extent</function></funcdef>
-			<paramdef><type>geometry set</type> <parameter>geomfield</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>box2d <function>ST_Extent</function></funcdef>
+            <paramdef><type>geometry set</type> <parameter>geomfield</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>An aggregate function that returns a <xref linkend="box2d_type"/> bounding box
+        <para>An aggregate function that returns a <xref linkend="box2d_type"/> bounding box
         that bounds a set of geometries.
         </para>
-		<para>The bounding box coordinates are in the spatial reference system of the input geometries.</para>
+        <para>The bounding box coordinates are in the spatial reference system of the input geometries.</para>
-		<para>ST_Extent is similar in concept to Oracle Spatial/Locator's SDO_AGGR_MBR.</para>
+        <para>ST_Extent is similar in concept to Oracle Spatial/Locator's SDO_AGGR_MBR.</para>
-		<note>
-		  <para>ST_Extent returns boxes with only X and Y ordinates even with 3D geometries.
+        <note>
+          <para>ST_Extent returns boxes with only X and Y ordinates even with 3D geometries.
           To return XYZ ordinates use <xref linkend="ST_3DExtent"/>.</para>
-		</note>
+        </note>
-		<note>
-		  <para>The returned <code>box3d</code> value does not include a SRID.
+        <note>
+          <para>The returned <code>box3d</code> value does not include a SRID.
             Use <xref linkend="ST_SetSRID"/> to convert it into a geometry with SRID metadata.
             The SRID is the same as the input geometries.</para>
-		</note>
+        </note>
-	  </refsection>
+      </refsection>
-	  <refsection>
-		<note><para>Examples below use Massachusetts State Plane ft (SRID=2249)</para></note>
-		<programlisting>
+      <refsection>
+        <note><para>Examples below use Massachusetts State Plane ft (SRID=2249)</para></note>
+        <programlisting>
 SELECT ST_Extent(geom) as bextent FROM sometable;
-					 st_bextent
+                     st_bextent
 BOX(739651.875 2908247.25,794875.8125 2970042.75)
@@ -392,7 +392,7 @@ SELECT ST_Extent(geom) as bextent
 FROM sometable
 GROUP BY category ORDER BY category;
-					  bextent                       |         name
+                      bextent                       |         name
  BOX(778783.5625 2951741.25,794875.8125 2970042.75) | A
  BOX(751315.8125 2919164.75,765202.6875 2935417.25) | B
@@ -402,226 +402,226 @@ GROUP BY category ORDER BY category;
  -- and render the extended text representation of that geometry
 SELECT ST_SetSRID(ST_Extent(geom),2249) as bextent FROM sometable;
-				bextent
+                bextent
  SRID=2249;POLYGON((739651.875 2908247.25,739651.875 2970042.75,794875.8125 2970042.75,
  794875.8125 2908247.25,739651.875 2908247.25))
-		</programlisting>
-	  </refsection>
+        </programlisting>
+      </refsection>
-	  <refsection>
-		<para>
+      <refsection>
+        <para>
             <xref linkend="ST_EstimatedExtent"/>,
             <xref linkend="ST_3DExtent"/>,
-		</para>
-	  </refsection>
-	</refentry>
+        </para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="ST_3DExtent">
-	  <refnamediv>
-		<refname>ST_3DExtent</refname>
-		<refpurpose>Aggregate function that returns the 3D bounding box of geometries.</refpurpose>
-	  </refnamediv>
+    <refentry xml:id="ST_3DExtent">
+      <refnamediv>
+        <refname>ST_3DExtent</refname>
+        <refpurpose>Aggregate function that returns the 3D bounding box of geometries.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>box3d <function>ST_3DExtent</function></funcdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>box3d <function>ST_3DExtent</function></funcdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>An aggregate function that returns a <xref linkend="box3d_type"/> (includes Z ordinate) bounding box
+        <para>An aggregate function that returns a <xref linkend="box3d_type"/> (includes Z ordinate) bounding box
         </para>
-		<note>
+        <note>
-		</note>
+        </note>
-		<para role="changed" conformance="2.0.0">Changed: 2.0.0 In prior versions this used to be called ST_Extent3D</para>
-	  </refsection>
+        <para role="changed" conformance="2.0.0">Changed: 2.0.0 In prior versions this used to be called ST_Extent3D</para>
+      </refsection>
-	  <refsection>
-		<programlisting>
+      <refsection>
+        <programlisting>
 SELECT ST_3DExtent(foo.geom) As b3extent
 FROM (SELECT ST_MakePoint(x,y,z) As geom
-	FROM generate_series(1,3) As x
-		CROSS JOIN generate_series(1,2) As y
-		CROSS JOIN generate_series(0,2) As Z) As foo;
-	  b3extent
+    FROM generate_series(1,3) As x
+        CROSS JOIN generate_series(1,2) As y
+        CROSS JOIN generate_series(0,2) As Z) As foo;
+      b3extent
  BOX3D(1 1 0,3 2 2)
 --Get the extent of various elevated circular strings
 FROM (SELECT ST_Translate(ST_Force_3DZ(ST_LineToCurve(ST_Buffer(ST_Point(x,y),1))),0,0,z) As geom
-	b3extent
+    b3extent
  BOX3D(1 0 0,4 2 2)
-		</programlisting>
-	  </refsection>
+        </programlisting>
+      </refsection>
-	  <refsection>
-		<para><xref linkend="ST_Extent"/>, <xref linkend="ST_Force_3DZ"/>, <xref linkend="ST_SetSRID"/></para>
-	  </refsection>
-	</refentry>
+      <refsection>
+        <para><xref linkend="ST_Extent"/>, <xref linkend="ST_Force_3DZ"/>, <xref linkend="ST_SetSRID"/></para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="ST_MakeBox2D">
-	  <refnamediv>
-		<refname>ST_MakeBox2D</refname>
+    <refentry xml:id="ST_MakeBox2D">
+      <refnamediv>
+        <refname>ST_MakeBox2D</refname>
-		<refpurpose>Creates a BOX2D defined by two 2D point geometries.</refpurpose>
-	  </refnamediv>
+        <refpurpose>Creates a BOX2D defined by two 2D point geometries.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>box2d <function>ST_MakeBox2D</function></funcdef>
-			<paramdef><type>geometry </type> <parameter>pointLowLeft</parameter></paramdef>
-			<paramdef><type>geometry </type> <parameter>pointUpRight</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>box2d <function>ST_MakeBox2D</function></funcdef>
+            <paramdef><type>geometry </type> <parameter>pointLowLeft</parameter></paramdef>
+            <paramdef><type>geometry </type> <parameter>pointUpRight</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>Creates a <xref linkend="box2d_type"/> defined by two Point
-			geometries.  This is useful for doing range queries.</para>
-	  </refsection>
+        <para>Creates a <xref linkend="box2d_type"/> defined by two Point
+            geometries.  This is useful for doing range queries.</para>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<programlisting><![CDATA[
+        <programlisting><![CDATA[
 --Return all features that fall reside or partly reside in a US national atlas coordinate bounding box
 --It is assumed here that the geometries are stored with SRID = 2163 (US National atlas equal area)
 SELECT feature_id, feature_name, geom
 FROM features
 WHERE geom && ST_SetSRID(ST_MakeBox2D(ST_Point(-989502.1875, 528439.5625),
-	ST_Point(-987121.375 ,529933.1875)),2163)
+    ST_Point(-987121.375 ,529933.1875)),2163)
 ]]></programlisting>
-	  </refsection>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<para><xref linkend="ST_Point"/>, <xref linkend="ST_SetSRID"/>, <xref linkend="ST_SRID"/></para>
-	  </refsection>
-	</refentry>
+        <para><xref linkend="ST_Point"/>, <xref linkend="ST_SetSRID"/>, <xref linkend="ST_SRID"/></para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="ST_3DMakeBox">
-	  <refnamediv>
-		<refname>ST_3DMakeBox</refname>
+    <refentry xml:id="ST_3DMakeBox">
+      <refnamediv>
+        <refname>ST_3DMakeBox</refname>
-		<refpurpose>Creates a BOX3D defined by two 3D point	geometries.</refpurpose>
-	  </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>box3d <function>ST_3DMakeBox</function></funcdef>
-			<paramdef><type>geometry </type> <parameter>point3DLowLeftBottom</parameter></paramdef>
-			<paramdef><type>geometry </type> <parameter>point3DUpRightTop</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+        <refpurpose>Creates a BOX3D defined by two 3D point geometries.</refpurpose>
+      </refnamediv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>box3d <function>ST_3DMakeBox</function></funcdef>
+            <paramdef><type>geometry </type> <parameter>point3DLowLeftBottom</parameter></paramdef>
+            <paramdef><type>geometry </type> <parameter>point3DUpRightTop</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>Creates a <xref linkend="box3d_type"/> defined by two 3D Point
-			geometries. </para>
+        <para>Creates a <xref linkend="box3d_type"/> defined by two 3D Point
+            geometries. </para>
-		<!-- Optionally mention 3D support -->
-		<para><inlinemediaobject>
-			<imageobject>
-			  <imagedata fileref="images/check.png"/>
-			</imageobject>
-		  </inlinemediaobject> This function supports 3D and will not drop the z-index.</para>
-		 <para role="changed" conformance="2.0.0">Changed: 2.0.0 In prior versions this used to be called ST_MakeBox3D</para>
-	  </refsection>
+        <!-- Optionally mention 3D support -->
+        <para><inlinemediaobject>
+            <imageobject>
+              <imagedata fileref="images/check.png"/>
+            </imageobject>
+          </inlinemediaobject> This function supports 3D and will not drop the z-index.</para>
+         <para role="changed" conformance="2.0.0">Changed: 2.0.0 In prior versions this used to be called ST_MakeBox3D</para>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<programlisting>
+        <programlisting>
 SELECT ST_3DMakeBox(ST_MakePoint(-989502.1875, 528439.5625, 10),
-	ST_MakePoint(-987121.375 ,529933.1875, 10)) As abb3d
+    ST_MakePoint(-987121.375 ,529933.1875, 10)) As abb3d
 --bb3d--
 BOX3D(-989502.1875 528439.5625 10,-987121.375 529933.1875 10)
-	</programlisting>
-	  </refsection>
+    </programlisting>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<para><xref linkend="ST_MakePoint"/>, <xref linkend="ST_SetSRID"/>, <xref linkend="ST_SRID"/></para>
-	  </refsection>
-	</refentry>
+        <para><xref linkend="ST_MakePoint"/>, <xref linkend="ST_SetSRID"/>, <xref linkend="ST_SRID"/></para>
+      </refsection>
+    </refentry>
-		<refentry xml:id="ST_XMax">
-	  <refnamediv>
-		<refname>ST_XMax</refname>
+        <refentry xml:id="ST_XMax">
+      <refnamediv>
+        <refname>ST_XMax</refname>
-		<refpurpose>Returns the X maxima of a 2D or 3D bounding box or a geometry.</refpurpose>
-	  </refnamediv>
+        <refpurpose>Returns the X maxima of a 2D or 3D bounding box or a geometry.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>float <function>ST_XMax</function></funcdef>
-			<paramdef><type>box3d </type> <parameter>aGeomorBox2DorBox3D</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>float <function>ST_XMax</function></funcdef>
+            <paramdef><type>box3d </type> <parameter>aGeomorBox2DorBox3D</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>Returns the X maxima of a 2D or 3D bounding box or a geometry.</para>
+        <para>Returns the X maxima of a 2D or 3D bounding box or a geometry.</para>
-		<note>
-		  <para>Although this function is only defined for box3d, it also works for box2d and geometry values due to automatic casting.
-			However, it will not accept a geometry or box2d text representation, since those do not auto-cast.</para>
-		</note>
+        <note>
+          <para>Although this function is only defined for box3d, it also works for box2d and geometry values due to automatic casting.
+            However, it will not accept a geometry or box2d text representation, since those do not auto-cast.</para>
+        </note>
-	  </refsection>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<programlisting>SELECT ST_XMax('BOX3D(1 2 3, 4 5 6)');
+        <programlisting>SELECT ST_XMax('BOX3D(1 2 3, 4 5 6)');
 st_xmax
 4
@@ -644,52 +644,52 @@ SELECT ST_XMax(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 150505 2,2
 st_xmax
 220288.248780547
-		</programlisting>
-	  </refsection>
+        </programlisting>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<para><xref linkend="ST_XMin"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_ZMin"/></para>
-	  </refsection>
-	</refentry>
+        <para><xref linkend="ST_XMin"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_ZMin"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_MMin"/>, <xref linkend="ST_MMax"/></para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="ST_XMin">
-	  <refnamediv>
-		<refname>ST_XMin</refname>
+    <refentry xml:id="ST_XMin">
+      <refnamediv>
+        <refname>ST_XMin</refname>
-		<refpurpose>Returns the X minima of a 2D or 3D bounding box or a geometry.</refpurpose>
-	  </refnamediv>
+        <refpurpose>Returns the X minima of a 2D or 3D bounding box or a geometry.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>float <function>ST_XMin</function></funcdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>float <function>ST_XMin</function></funcdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>Returns the X minima of a 2D or 3D bounding box or a geometry.</para>
+        <para>Returns the X minima of a 2D or 3D bounding box or a geometry.</para>
-		<note>
-			However it will not accept a geometry or box2d text representation, since those do not auto-cast.</para>
-		</note>
+        <note>
+            However it will not accept a geometry or box2d text representation, since those do not auto-cast.</para>
+        </note>
-	  </refsection>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<programlisting>SELECT ST_XMin('BOX3D(1 2 3, 4 5 6)');
+        <programlisting>SELECT ST_XMin('BOX3D(1 2 3, 4 5 6)');
 st_xmin
 1
@@ -712,52 +712,52 @@ SELECT ST_XMin(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 150505 2,2
 st_xmin
 220186.995121892
-		</programlisting>
-	  </refsection>
+        </programlisting>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<para><xref linkend="ST_XMax"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_ZMin"/></para>
-	  </refsection>
-	</refentry>
+        <para><xref linkend="ST_XMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_ZMin"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_MMin"/>, <xref linkend="ST_MMax"/></para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="ST_YMax">
-	  <refnamediv>
-		<refname>ST_YMax</refname>
+    <refentry xml:id="ST_YMax">
+      <refnamediv>
+        <refname>ST_YMax</refname>
-		<refpurpose>Returns the Y maxima of a 2D or 3D bounding box or a geometry.</refpurpose>
-	  </refnamediv>
+        <refpurpose>Returns the Y maxima of a 2D or 3D bounding box or a geometry.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>float <function>ST_YMax</function></funcdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>float <function>ST_YMax</function></funcdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>Returns the Y maxima of a 2D or 3D bounding box or a geometry.</para>
+        <para>Returns the Y maxima of a 2D or 3D bounding box or a geometry.</para>
-		<note>
-		</note>
+        <note>
+        </note>
-	  </refsection>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<programlisting>SELECT ST_YMax('BOX3D(1 2 3, 4 5 6)');
+        <programlisting>SELECT ST_YMax('BOX3D(1 2 3, 4 5 6)');
 st_ymax
 5
@@ -780,52 +780,52 @@ SELECT ST_YMax(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 150505 2,2
 st_ymax
 150506.126829327
-		</programlisting>
-	  </refsection>
+        </programlisting>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<para><xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_ZMin"/></para>
-	  </refsection>
-	</refentry>
+        <para><xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_ZMin"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_MMin"/>, <xref linkend="ST_MMax"/></para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="ST_YMin">
-	  <refnamediv>
-		<refname>ST_YMin</refname>
+    <refentry xml:id="ST_YMin">
+      <refnamediv>
+        <refname>ST_YMin</refname>
-		<refpurpose>Returns the Y minima of a 2D or 3D bounding box or a geometry.</refpurpose>
-	  </refnamediv>
+        <refpurpose>Returns the Y minima of a 2D or 3D bounding box or a geometry.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>float <function>ST_YMin</function></funcdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>float <function>ST_YMin</function></funcdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>Returns the Y minima of a 2D or 3D bounding box or a geometry.</para>
+        <para>Returns the Y minima of a 2D or 3D bounding box or a geometry.</para>
-		<note>
-		</note>
+        <note>
+        </note>
-	  </refsection>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<programlisting>SELECT ST_YMin('BOX3D(1 2 3, 4 5 6)');
+        <programlisting>SELECT ST_YMin('BOX3D(1 2 3, 4 5 6)');
 st_ymin
 2
@@ -848,52 +848,52 @@ SELECT ST_YMin(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 150505 2,2
 st_ymin
 150406
-		</programlisting>
-	  </refsection>
+        </programlisting>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<para><xref linkend="ST_GeomFromEWKT"/>, <xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_ZMin"/></para>
-	  </refsection>
-	</refentry>
+        <para><xref linkend="ST_GeomFromEWKT"/>, <xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_ZMin"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_MMin"/>, <xref linkend="ST_MMax"/></para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="ST_ZMax">
-	  <refnamediv>
-		<refname>ST_ZMax</refname>
+    <refentry xml:id="ST_ZMax">
+      <refnamediv>
+        <refname>ST_ZMax</refname>
-		<refpurpose>Returns the Z maxima of a 2D or 3D bounding box or a geometry.</refpurpose>
-	  </refnamediv>
+        <refpurpose>Returns the Z maxima of a 2D or 3D bounding box or a geometry.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>float <function>ST_ZMax</function></funcdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>float <function>ST_ZMax</function></funcdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>Returns the Z maxima of a 2D or 3D bounding box or a geometry.</para>
+        <para>Returns the Z maxima of a 2D or 3D bounding box or a geometry.</para>
-		<note>
-		</note>
+        <note>
+        </note>
-	  </refsection>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<programlisting>SELECT ST_ZMax('BOX3D(1 2 3, 4 5 6)');
+        <programlisting>SELECT ST_ZMax('BOX3D(1 2 3, 4 5 6)');
 st_zmax
 6
@@ -916,52 +916,52 @@ SELECT ST_ZMax(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 150505 2,2
 st_zmax
 3
-		</programlisting>
-	  </refsection>
+        </programlisting>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<para><xref linkend="ST_GeomFromEWKT"/>, <xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_ZMax"/></para>
-	  </refsection>
-	</refentry>
+        <para><xref linkend="ST_GeomFromEWKT"/>, <xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_ZMin"/>, <xref linkend="ST_MMin"/>, <xref linkend="ST_MMax"/></para>
+      </refsection>
+    </refentry>
-	<refentry xml:id="ST_ZMin">
-	  <refnamediv>
-		<refname>ST_ZMin</refname>
+    <refentry xml:id="ST_ZMin">
+      <refnamediv>
+        <refname>ST_ZMin</refname>
-		<refpurpose>Returns the Z minima of a 2D or 3D bounding box or a geometry.</refpurpose>
-	  </refnamediv>
+        <refpurpose>Returns the Z minima of a 2D or 3D bounding box or a geometry.</refpurpose>
+      </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>float <function>ST_ZMin</function></funcdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>float <function>ST_ZMin</function></funcdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
-	  <refsection>
+      <refsection>
-		<para>Returns the Z minima of a 2D or 3D bounding box or a geometry.</para>
+        <para>Returns the Z minima of a 2D or 3D bounding box or a geometry.</para>
-		<note>
-		</note>
+        <note>
+        </note>
-	  </refsection>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<programlisting>SELECT ST_ZMin('BOX3D(1 2 3, 4 5 6)');
+        <programlisting>SELECT ST_ZMin('BOX3D(1 2 3, 4 5 6)');
 st_zmin
 3
@@ -984,15 +984,94 @@ SELECT ST_ZMin(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 150505 2,2
 st_zmin
 1
-		</programlisting>
-	  </refsection>
+        </programlisting>
+      </refsection>
-	  <refsection>
+      <refsection>
-		<para><xref linkend="ST_GeomFromEWKT"/>, <xref linkend="ST_GeomFromText"/>, <xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_ZMax"/></para>
-	  </refsection>
-	</refentry>
+        <para><xref linkend="ST_GeomFromEWKT"/>, <xref linkend="ST_GeomFromText"/>, <xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_MMin"/>, <xref linkend="ST_MMax"/></para>
+      </refsection>
+    </refentry>
+    <refentry xml:id="ST_MMin">
+      <refnamediv>
+        <refname>ST_MMin</refname>
+        <refpurpose>Returns the M minima of a geometry.</refpurpose>
+      </refnamediv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>float <function>ST_MMin</function></funcdef><paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
+      <refsection>
+        <para>Returns the M minima of a geometry, or null of the geometry lacks M values.</para>
+      </refsection>
+      <refsection>
+        <programlisting>SELECT ST_MMin('POINT M (1 2 3)');
+st_mmin
+3
+        </programlisting>
+      </refsection>
+      <refsection>
+        <para><xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_ZMin"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_MMax"/></para>
+      </refsection>
+    </refentry>
+    <refentry xml:id="ST_MMax">
+      <refnamediv>
+        <refname>ST_MMax</refname>
+      </refnamediv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>float <function>ST_MMax</function></funcdef><paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
+      <refsection>
+      </refsection>
+      <refsection>
+        <programlisting>SELECT ST_MMax('POINT M (1 2 3)');
+st_mmax
+3       </programlisting>
+      </refsection>
+      <refsection>
+        <para><xref linkend="ST_XMin"/>, <xref linkend="ST_XMax"/>, <xref linkend="ST_YMin"/>, <xref linkend="ST_YMax"/>, <xref linkend="ST_ZMin"/>, <xref linkend="ST_ZMax"/>, <xref linkend="ST_MMin"/></para>
+      </refsection>
+    </refentry>
  </section>
diff --git a/doc/reference_coverage.xml b/doc/reference_coverage.xml
index d00788df2..ccd8b868a 100644
--- a/doc/reference_coverage.xml
+++ b/doc/reference_coverage.xml
@@ -177,14 +177,14 @@ SELECT true = ALL (
       and can be input to coverage processing functions.
       </para>
-      <note>To aid in determining a maximum gap width,
+      <note><para>To aid in determining a maximum gap width,
       gaps can be computed by cleaning with <code>gapMaximumWidth => 0</code>
       and using <xref linkend="ST_CoverageUnion"/> to union the result coverage.
       Holes in the union correspond to gaps in the original dataset.
       Gap widths can be measured by extracting the holes as polygons
       and running <xref linkend="ST_MaximumInscribedCircle"/>
       on them; the gap width is twice the computed radius.
-      </note>
+      </para></note>
       <para role="availability" conformance="3.6.0">Availability: 3.6.0 - requires GEOS >= 3.14.0</para>
     </refsection>
diff --git a/postgis/lwgeom_box3d.c b/postgis/lwgeom_box3d.c
index 96288e624..11ba71483 100644
--- a/postgis/lwgeom_box3d.c
+++ b/postgis/lwgeom_box3d.c
@@ -455,6 +455,41 @@ Datum BOX3D_zmax(PG_FUNCTION_ARGS)
 	PG_RETURN_FLOAT8(Max(box->zmin, box->zmax));
+Datum ST_MMin(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(ST_MMin);
+	GBOX gbox;
+	GSERIALIZED *gser = PG_GETARG_GSERIALIZED_P(0);
+	if (gserialized_get_gbox_p(gser, &gbox) != LW_TRUE)
+		PG_RETURN_NULL();
+	if (!FLAGS_GET_M(gbox.flags))
+		PG_RETURN_NULL();
+	PG_RETURN_FLOAT8(Min(gbox.mmin, gbox.mmax));
+Datum ST_MMax(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(ST_MMax);
+	GBOX gbox;
+		PG_RETURN_NULL();
+		PG_RETURN_NULL();
+	PG_RETURN_FLOAT8(Max(gbox.mmin, gbox.mmax));
  * Used in the ST_Extent and ST_Extent3D aggregates, does not read the
  * serialized cached bounding box (since that is floating point)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index f508024c5..c1a57bc0d 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1098,6 +1098,20 @@ CREATE OR REPLACE FUNCTION ST_ZMax(box3d)
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_DEFAULT;
+-- Availability: 3.7.0
+CREATE OR REPLACE FUNCTION ST_MMin(geometry)
+	RETURNS FLOAT8
+	AS 'MODULE_PATHNAME','ST_MMin'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	_COST_DEFAULT;
+CREATE OR REPLACE FUNCTION ST_MMax(geometry)
+	RETURNS FLOAT8
+	AS 'MODULE_PATHNAME','ST_MMax'
+	_COST_DEFAULT;
 --  BOX2D FUNCTIONS
Summary of changes:
 doc/reference_accessor.xml |    6 +-
 doc/reference_bbox.xml     | 1291 +++++++++++++++++++++++---------------------
 doc/reference_coverage.xml |    4 +-
 postgis/lwgeom_box3d.c     |   35 ++
 postgis/postgis.sql.in     |   14 +
 5 files changed, 739 insertions(+), 611 deletions(-)
hooks/post-receive
