[SCM] PostGIS branch master updated. 3.7.0beta1-232-g53e2505dff
git at osgeo.org
git at osgeo.org
Wed Aug 5 21:39:16 PDT 2026
the project "PostGIS".
via 53e2505dff444184be259c39805adced3f6d9dc4 (commit)
from 103e91dfa5a8e79f665cfddc6330baee06f42ce0 (commit)
revisions in full, below.
commit 53e2505dff444184be259c39805adced3f6d9dc4
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Thu Aug 6 02:59:09 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 91.4% (5519 of 6037 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 0ac76c739c..9d088e7478 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-08-04 15:37+0000\n"
-"PO-Revision-Date: 2026-08-06 02:39+0000\n"
+"PO-Revision-Date: 2026-08-06 04:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -22722,11 +22722,13 @@ msgid "Encode the same WGS 84 LineString using precision 5 and 6."
msgstr "同じ WGS84 LINESTRING を精度 5 と精度 6 でエンコードします。"
#. Tag: para
-#, no-c-format
+#, fuzzy, no-c-format
msgid ""
"Decode an OSRM <literal>route.geometry</literal> returned with "
"<literal>geometries=polyline6</literal>."
msgstr ""
+"<literal>geometries=polyline6</literal> で返った OSRM <literal>"
+"route.geometry</literal> をデコードする。"
#. Tag: para
#, no-c-format
@@ -24038,7 +24040,7 @@ msgstr "LINESTRING"
#. Tag: entry
#, no-c-format
msgid "LineSet (coordinates are promoted to 3D)"
-msgstr ""
+msgstr "LineSet (3次元になります)"
#. Tag: entry
#, no-c-format
@@ -24053,7 +24055,7 @@ msgstr "MULTILINESTRING"
#. Tag: entry
#, no-c-format
msgid "IndexedLineSet (coordinates are promoted to 3D)"
-msgstr ""
+msgstr "IndexedLineSet (3次元になります)"
#. Tag: entry
#, no-c-format
@@ -24096,6 +24098,8 @@ msgid ""
"IndexedFaceSet (coordinates are promoted to 3D; inner rings currently output "
"as another faceset)"
msgstr ""
+"IndexedFaceSet (3次元になります。内側リングは現在は他のフェイスセットとして出"
+"力されます)"
#. Tag: entry
#, no-c-format
@@ -24576,6 +24580,10 @@ msgid ""
"geometries. Although this function works with Z-coordinate, it does an "
"averaging of Z-Coordinate."
msgstr ""
+"3次元ジオメトリーで使う場合には、SFCGAL による <xref "
+"linkend=\"CG_3DIntersection\"/> がいいかも知れません。3次元ジオメトリーに対し"
+"て確実に3次元の共有部を出します。この関数は Z 値を持たせられますが、Z 値は平"
+"均値を取ります。"
#. Tag: para
#, no-c-format
@@ -24642,6 +24650,9 @@ msgid ""
"input is compared with <xref linkend=\"CG_3DIntersection\"/>, which performs "
"a true 3D intersection."
msgstr ""
+"本当の 3次元共有部計算ではありません。2.5次元ジオメトリー (Z 値は持つけど2次"
+"元で計算する)を使います。本当の 3次元共有部計算である <xref "
+"linkend=\"CG_3DIntersection\"/> と同じ入力で比較します。"
#. Tag: para
#, no-c-format
@@ -24744,7 +24755,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "Noding a 3D LineString which self-intersects."
-msgstr ""
+msgstr "自己インターセクトしている 3次元 LINESTRING にノードを追加します。"
#. Tag: para
#, no-c-format
@@ -24828,7 +24839,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "Split a circular polygon by a diagonal line."
-msgstr ""
+msgstr "曲線ポリゴンを対角線で分割します。"
#. Tag: para
#, no-c-format
@@ -25027,7 +25038,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "In 3D, this example does not produce the expected result."
-msgstr ""
+msgstr "3次元では、この例で期待した結果が得られません。"
#. Tag: refpurpose
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 25 ++++++++++++++++++-------
1 file changed, 18 insertions(+), 7 deletions(-)
hooks/post-receive
