[SCM] PostGIS branch master updated. 3.7.0beta2-55-gd7103890f
git at osgeo.org
git at osgeo.org
Sun Aug 16 18:39:21 PDT 2026
the project "PostGIS".
via d7103890f44773106d5c329919d6c49867cf2863 (commit)
from 290f43d8b0a8b038408daf5750c4400be9ab0e38 (commit)
revisions in full, below.
commit d7103890f44773106d5c329919d6c49867cf2863
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Mon Aug 17 01:16:44 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 94.1% (5683 of 6037 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 044830f89..3773cb8c2 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-08-04 15:37+0000\n"
-"PO-Revision-Date: 2026-08-07 09:39+0000\n"
+"PO-Revision-Date: 2026-08-17 01:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -32428,6 +32428,8 @@ msgid ""
"In the second result set, band 2 now points at <literal>Projected2.tif</"
"literal> and uses out-db band 1."
msgstr ""
+"結果の二つ目では、2番バンドは <literal>Projected2.tif</literal> を指し、"
+"データベース外ラスターの 1番バンドを使います。"
#. Tag: para
#, no-c-format
@@ -32476,6 +32478,8 @@ msgid ""
"In the second result set, band 2 still points at the same file but now reads "
"external band 1."
msgstr ""
+"結果の二つ目では、2番バンドは <literal>Projected2.tif</literal> を指しますが"
+"、今回はデータベース外ラスターの 1番バンドを読みます。"
#. Tag: para
#, no-c-format
@@ -32731,6 +32735,8 @@ msgid ""
"Example will consider only pixels of band 1 that are not 249 and in named "
"quantiles."
msgstr ""
+"例では 1番バンドの 249でないピクセルで、かつ名前のある分位に限って考慮に入れ"
+"ます。"
#. Tag: para
#, no-c-format
@@ -32806,12 +32812,12 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "Single raster tile."
-msgstr ""
+msgstr "単一のラスタータイル。"
#. Tag: para
#, no-c-format
msgid "Summarize pixels that intersect buildings of interest."
-msgstr ""
+msgstr "対象とする建物にインターセクトするピクセルの統計情報の概要。"
#. Tag: para
#, no-c-format
@@ -32822,11 +32828,16 @@ msgid ""
"Windows 64-bit with all of Boston Buildings and aerial Tiles (tiles each "
"150x150 pixels ~ 134,000 tiles), ~102,000 building records."
msgstr ""
+"この例では、対象建物と選択して、ラスタータイルの 2番バンドを建物境界で切取り"
+"、切り取った領域の統計情報を計算して、建物ごとの統計情報の要約を得ます。"
+"Windows 64ビットの PostGIS を使い、ボストン建物データの約 102,000件と空中写真"
+"タイル (1タイルは 150x150ピクセルで、約 134,000タイル) とで 574ミリ秒かかりま"
+"した。"
#. Tag: para
#, no-c-format
msgid "Raster coverage."
-msgstr ""
+msgstr "ラスターカバレッジ。"
#. Tag: para
#, no-c-format
@@ -32839,6 +32850,8 @@ msgid ""
"For a table, sampling less than 100% can improve speed. Here the sampling is "
"set to 25%."
msgstr ""
+"テーブルに対して 100%より小さい割合でのサンプリングで速度が改善します。ここで"
+"は 25%に設定しています。"
#. Tag: para
#, no-c-format
@@ -32933,7 +32946,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "Example will count only pixels of band 1 that are not 249."
-msgstr ""
+msgstr "この例では 1番バンドで 249でないピクセルのピクセル数を数えます。"
#. Tag: para
#, no-c-format
@@ -33156,13 +33169,13 @@ msgstr ""
msgid ""
"<varname>srid</varname> the spatial reference identifier to embed in the "
"output raster"
-msgstr ""
+msgstr "<varname>srid</varname> 出力ラスターに組み込む空間参照系識別子。"
#. Tag: para
#, no-c-format
msgid ""
"Export multiple raster tiles as a single JPEG image with 50 percent quality."
-msgstr ""
+msgstr "複数のラスタータイルを一つの 50%品質の JPEG 画像として出力する。"
#. Tag: para
#, no-c-format
@@ -33176,18 +33189,26 @@ msgid ""
"psql equivalent lo_ functions which export to the local file system instead "
"of the server file system."
msgstr ""
+"ラスターを他の書式で出力する方法の一つに、 <link xlink:href=\"https://"
+"www.postgresql.jp/document/current/html/lo-funcs.html\">PostgreSQL "
+"ラージオブジェクト サーバ側の関数</link> を使うものがあります。次ではもう一"
+"度 JPEG の例を使って結果を出力します。この例では、サーバー側の"
+"ラージオブジェクト関数を使うため、スーパーユーザーのアクセスが求められること"
+"に注意して下さい。また、サーバーネットワーク上のパスに出力します。ローカル側"
+"に出力するには、psql から呼び出す等価な lo_ 関数 (訳注: \\lo_export など) を"
+"使います。"
#. Tag: para
#, no-c-format
msgid "Export a raster as a GeoTIFF using the default creation options."
-msgstr ""
+msgstr "ラスターをデフォルトの生成オプションを使って GeoTIFF として出力する。"
#. Tag: para
#, no-c-format
msgid ""
"Export a GeoTIFF using JPEG compression at 90 percent quality and embed SRID "
"4269."
-msgstr ""
+msgstr "GeoTIFF を、品質 90%のJPEG 圧縮、SRID 4269 として出力する。"
#. Tag: para
#, no-c-format
@@ -33377,7 +33398,7 @@ msgstr ""
msgid ""
"Export the first 3 bands and map band 3 to red, band 1 to green, and band 2 "
"to blue."
-msgstr ""
+msgstr "最初の 3バンドを、3番バンドを赤、1番バンドを緑、2番バンドを青にして出力する。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 41 +++++++++++++++++++++++++++++++----------
1 file changed, 31 insertions(+), 10 deletions(-)
hooks/post-receive
