[SCM] PostGIS branch stable-3.1 updated. 3.1.11-47-g0051d330b
Wed Feb 4 21:05:32 PST 2026
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  0051d330b2697d1218db44ad4d5c26c9c9aff3a2 (commit)
      from  d4ba80220e80650b112fafa201b0deea95b5c875 (commit)
revisions in full, below.
commit 0051d330b2697d1218db44ad4d5c26c9c9aff3a2
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Feb 5 00:04:09 2026 -0500
        Ensure tables are created by tiger extension and bale if not. Patch provided by Andrey Borodin (Yandex)
        References #5998 for PostGIS 3.1.13
diff --git a/NEWS b/NEWS
index 6df4cf20a..da155622d 100644
--- a/NEWS
+++ b/NEWS
@@ -19,6 +19,8 @@ YYYY/MM/DD
  - #5991, CircularString distance error (Paul Ramsey)
  - #5962, Consistent clipping of MULTI/POINT (Paul Ramsey)
  - #6028, Crash indexing malformed empty polygon (Paul Ramsey)
+ - #5998, [tiger_geocoder] [security] CVE-2022-2625, make sure tables requires
+           by extension are owned by extension
 PostGIS 3.1.12
diff --git a/extras/tiger_geocoder/pagc_normalize/pagc_tables.sql b/extras/tiger_geocoder/pagc_normalize/pagc_tables.sql
index ff78fc8f8..da6fc91a9 100644
--- a/extras/tiger_geocoder/pagc_normalize/pagc_tables.sql
+++ b/extras/tiger_geocoder/pagc_normalize/pagc_tables.sql
@@ -11,14 +11,23 @@ BEGIN
 	IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND table_name = 'pagc_gaz')  THEN
 		CREATE TABLE pagc_gaz (id serial NOT NULL primary key ,seq integer ,word text, stdword text, token integer,is_custom boolean NOT NULL default true);
 		GRANT SELECT ON pagc_gaz TO public;
+	ELSE
+		-- Insist on invoking Postgres logic of owning table by extension. This prevent attacks like CVE-2022-2625.
+		CREATE TABLE IF NOT EXISTS pagc_gaz (id serial NOT NULL primary key ,seq integer ,word text, stdword text, token integer,is_custom boolean NOT NULL default true);
 	END IF;
 	IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND table_name = 'pagc_lex')  THEN
 		CREATE TABLE pagc_lex (id serial NOT NULL primary key,seq integer,word text,stdword text,token integer,is_custom boolean NOT NULL default true);
 		GRANT SELECT ON pagc_lex TO public;
+	ELSE
+		-- Same as above.
+		CREATE TABLE IF NOT EXISTS pagc_lex (id serial NOT NULL primary key,seq integer,word text,stdword text,token integer,is_custom boolean NOT NULL default true);
 	END IF;
 	IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND table_name = 'pagc_rules')  THEN
 		CREATE TABLE pagc_rules (id serial NOT NULL primary key,rule text, is_custom boolean DEFAULT true);
 		GRANT SELECT ON pagc_rules TO public;
+	ELSE
+		-- Same as above.
+		CREATE TABLE IF NOT EXISTS pagc_rules (id serial NOT NULL primary key,rule text, is_custom boolean DEFAULT true);
 	END IF;
 	IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND table_name = 'pagc_gaz' AND data_type='text')  THEN
 	-- its probably old table structure change type of lex and gaz columns
diff --git a/extras/tiger_geocoder/tiger_loader_2012.sql b/extras/tiger_geocoder/tiger_loader_2012.sql
index c4d6da1b7..00593ecf5 100644
--- a/extras/tiger_geocoder/tiger_loader_2012.sql
+++ b/extras/tiger_geocoder/tiger_loader_2012.sql
@@ -57,18 +57,14 @@ $$
 DO
 BEGIN
-  IF NOT EXISTS (SELECT * FROM information_schema.tables WHERE table_name = 'loader_platform' AND table_schema = 'tiger') THEN
-      CREATE TABLE loader_platform(os varchar(50) PRIMARY KEY, declare_sect text, pgbin text, wget text, unzip_command text, psql text, path_sep text, loader text, environ_set_command text, county_process_command text);
-  END IF;
+   CREATE TABLE IF NOT EXISTS loader_platform(os varchar(50) PRIMARY KEY, declare_sect text, pgbin text, wget text, unzip_command text, psql text, path_sep text, loader text, environ_set_command text, county_process_command text);
 END
 $$ LANGUAGE 'plpgsql';
 DO
 BEGIN
-  IF NOT EXISTS (SELECT * FROM information_schema.schemata WHERE schema_name = 'tiger_data') THEN
-       CREATE SCHEMA tiger_data;
-  END IF;
+    CREATE SCHEMA IF NOT EXISTS tiger_data;
 END
@@ -125,9 +121,7 @@ done');
 -- variables table
 DO $$
 BEGIN
-  IF NOT EXISTS (SELECT * FROM information_schema.tables WHERE table_name = 'loader_variables' AND table_schema = 'tiger') THEN
-      CREATE TABLE loader_variables(tiger_year varchar(4) PRIMARY KEY, website_root text, staging_fold text, data_schema text, staging_schema text);
-  END IF;
+    CREATE TABLE IF NOT EXISTS loader_variables(tiger_year varchar(4) PRIMARY KEY, website_root text, staging_fold text, data_schema text, staging_schema text);
 END
@@ -138,8 +132,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
 DO $$
 BEGIN
-  IF NOT EXISTS (SELECT * FROM information_schema.tables WHERE table_name = 'loader_lookuptables' AND table_schema = 'tiger') THEN
-   CREATE TABLE loader_lookuptables(process_order integer NOT NULL DEFAULT 1000,
+   CREATE TABLE IF NOT EXISTS loader_lookuptables(process_order integer NOT NULL DEFAULT 1000,
 		lookup_name text primary key,
 		table_name text, single_mode boolean NOT NULL DEFAULT true,
 		load boolean NOT NULL DEFAULT true,
@@ -149,7 +142,6 @@ BEGIN
 		post_load_process text, single_geom_mode boolean DEFAULT false,
 		insert_mode char(1) NOT NULL DEFAULT 'c',
 		pre_load_process text,columns_exclude text[], website_root_override text);
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2013.sql b/extras/tiger_geocoder/tiger_loader_2013.sql
index d42f60ea2..8b6e0d166 100644
--- a/extras/tiger_geocoder/tiger_loader_2013.sql
+++ b/extras/tiger_geocoder/tiger_loader_2013.sql
@@ -56,18 +56,14 @@ $$
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
@@ -124,9 +120,7 @@ done');
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
@@ -137,8 +131,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
 DO $$
 BEGIN
@@ -148,7 +141,6 @@ BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2014.sql b/extras/tiger_geocoder/tiger_loader_2014.sql
index bedb84051..8726e5afe 100644
--- a/extras/tiger_geocoder/tiger_loader_2014.sql
+++ b/extras/tiger_geocoder/tiger_loader_2014.sql
@@ -89,6 +89,72 @@ IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_sche
 	  CONSTRAINT enforce_srid_geom CHECK (st_srid(the_geom) = 4269)
 	COMMENT ON TABLE tiger.bg IS 'block groups';
+ELSE
+	CREATE TABLE IF NOT EXISTS tract
+	  gid serial NOT NULL,
+	  statefp varchar(2),
+	  countyfp varchar(3),
+	  tractce varchar(6),
+	  tract_id varchar(11) PRIMARY KEY,
+	  name varchar(7),
+	  namelsad varchar(20),
+	  mtfcc varchar(5),
+	  funcstat varchar(1),
+	  aland double precision,
+	  awater double precision,
+	  intptlat varchar(11),
+	  intptlon varchar(12),
+	  the_geom geometry,
+	  CONSTRAINT enforce_dims_geom CHECK (st_ndims(the_geom) = 2),
+	  CONSTRAINT enforce_geotype_geom CHECK (geometrytype(the_geom) = 'MULTIPOLYGON'::text OR the_geom IS NULL),
+	  CONSTRAINT enforce_srid_geom CHECK (st_srid(the_geom) = 4269)
+	CREATE TABLE IF NOT EXISTS tabblock
+	  blockce varchar(4),
+	  tabblock_id varchar(16) PRIMARY KEY,
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	CREATE TABLE IF NOT EXISTS bg
+	  blkgrpce varchar(1),
+	  bg_id varchar(12) PRIMARY KEY,
+	  namelsad varchar(13),
+	  mtfcc varchar(5),
 END IF;
 IF EXISTS(SELECT * FROM information_schema.columns WHERE table_schema = 'tiger' AND column_name = 'tabblock_id' AND table_name = 'tabblock' AND character_maximum_length < 16)  THEN -- size of name and tabblock_id fields need to be increased
@@ -144,18 +210,14 @@ $$
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
@@ -212,9 +274,7 @@ done');
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
@@ -225,8 +285,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
 DO $$
 BEGIN
@@ -236,7 +295,6 @@ BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2015.sql b/extras/tiger_geocoder/tiger_loader_2015.sql
index fe0bdf62f..3311be2e7 100644
--- a/extras/tiger_geocoder/tiger_loader_2015.sql
+++ b/extras/tiger_geocoder/tiger_loader_2015.sql
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
 DO $$
 BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2016.sql b/extras/tiger_geocoder/tiger_loader_2016.sql
index 0cb93e442..39dd37f0a 100644
--- a/extras/tiger_geocoder/tiger_loader_2016.sql
+++ b/extras/tiger_geocoder/tiger_loader_2016.sql
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
@@ -211,9 +273,7 @@ done');
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
@@ -224,8 +284,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
 DO $$
 BEGIN
@@ -235,7 +294,6 @@ BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2017.sql b/extras/tiger_geocoder/tiger_loader_2017.sql
index 9a7c6a726..5644a4d53 100644
--- a/extras/tiger_geocoder/tiger_loader_2017.sql
+++ b/extras/tiger_geocoder/tiger_loader_2017.sql
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
 DO $$
 BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2018.sql b/extras/tiger_geocoder/tiger_loader_2018.sql
index 61e68797a..33697e785 100644
--- a/extras/tiger_geocoder/tiger_loader_2018.sql
+++ b/extras/tiger_geocoder/tiger_loader_2018.sql
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
 DO $$
 BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2019.sql b/extras/tiger_geocoder/tiger_loader_2019.sql
index 12a395b60..9485011cf 100644
--- a/extras/tiger_geocoder/tiger_loader_2019.sql
+++ b/extras/tiger_geocoder/tiger_loader_2019.sql
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
 DO $$
 BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2020.sql b/extras/tiger_geocoder/tiger_loader_2020.sql
index 2343fe15c..01c81f26a 100644
--- a/extras/tiger_geocoder/tiger_loader_2020.sql
+++ b/extras/tiger_geocoder/tiger_loader_2020.sql
@@ -2,7 +2,7 @@
 -- PostGIS - Spatial Types for PostgreSQL
 -- http://postgis.net
--- Copyright (C) 2012-2021 Regina Obe and Leo Hsu
+-- Copyright (C) 2012-2018 Regina Obe and Leo Hsu
 -- Paragon Corporation
 -- This is free software; you can redistribute and/or modify it under
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
@@ -165,18 +231,14 @@ $$
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
@@ -232,9 +294,7 @@ done');
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
@@ -245,8 +305,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
 DO $$
 BEGIN
@@ -256,7 +315,6 @@ BEGIN
-  END IF;
 END
@@ -275,8 +333,9 @@ COMMENT ON COLUMN loader_lookuptables.website_root_override IS 'Path to use for
 INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, single_geom_mode, insert_mode, pre_load_process, post_load_process, columns_exclude )
 VALUES(10, 'tract', 'tract', true, false, true,false, 'c',
 '${psql} -c "CREATE TABLE ${data_schema}.${state_abbrev}_${lookup_name}(CONSTRAINT pk_${state_abbrev}_${lookup_name} PRIMARY KEY (tract_id) ) INHERITS(tiger.${lookup_name}); " ',
-	'${psql} -c "ALTER TABLE ${staging_schema}.${state_abbrev}_${table_name} RENAME geoid TO tract_id;"
-	${psql} -c "SELECT loader_load_staged_data(lower(''${state_abbrev}_${table_name}''), lower(''${state_abbrev}_${lookup_name}'')); "
+	'${psql} -c "ALTER TABLE ${staging_schema}.${state_abbrev}_${table_name} RENAME geoid IF EXISTS TO tract_id;
+	ALTER TABLE ${staging_schema}.${state_abbrev}_${table_name} RENAME geoid10 IF EXISTS TO tract_id;
+	SELECT loader_load_staged_data(lower(''${state_abbrev}_${table_name}''), lower(''${state_abbrev}_${lookup_name}'')); "
 	${psql} -c "CREATE INDEX ${data_schema}_${state_abbrev}_${lookup_name}_the_geom_gist ON ${data_schema}.${state_abbrev}_${lookup_name} USING gist(the_geom);"
 	${psql} -c "VACUUM ANALYZE ${data_schema}.${state_abbrev}_${lookup_name};"
 	${psql} -c "ALTER TABLE ${data_schema}.${state_abbrev}_${lookup_name} ADD CONSTRAINT chk_statefp CHECK (statefp = ''${state_fips}'');"', ARRAY['gid']);
@@ -291,7 +350,7 @@ ${psql} -c "CREATE INDEX ${data_schema}_${state_abbrev}_${lookup_name}_the_geom_
 ${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', '{gid, uatyp10, uatype, suffix1ce}'::text[]);
-VALUES(11, 'tabblock20', 'tabblock20', false, false, true,false, 'c',
+VALUES(11, 'tabblock20', 'tabblock20', true, false, true,false, 'c',
 '${psql} -c "CREATE TABLE ${data_schema}.${state_abbrev}_${lookup_name}(CONSTRAINT pk_${state_abbrev}_${lookup_name} PRIMARY KEY (geoid)) INHERITS(tiger.${lookup_name});" ',
 '${psql} -c "SELECT loader_load_staged_data(lower(''${state_abbrev}_${table_name}''), lower(''${state_abbrev}_${lookup_name}'')); "
Summary of changes:
 NEWS                                               |  2 +
 .../tiger_geocoder/pagc_normalize/pagc_tables.sql  |  9 +++
 extras/tiger_geocoder/tiger_loader_2012.sql        | 16 +---
 extras/tiger_geocoder/tiger_loader_2013.sql        | 16 +---
 extras/tiger_geocoder/tiger_loader_2014.sql        | 82 ++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2015.sql        | 82 ++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2016.sql        | 82 ++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2017.sql        | 82 ++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2018.sql        | 82 ++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2019.sql        | 82 ++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2020.sql        | 91 ++++++++++++++++++----
 11 files changed, 514 insertions(+), 112 deletions(-)
hooks/post-receive
