[SCM] PostGIS branch stable-3.0 updated. 3.0.11-23-g89467dc26
git at osgeo.org
git at osgeo.org
Wed Feb 4 21:15:53 PST 2026
the project "PostGIS".
The branch, stable-3.0 has been updated
via 89467dc26d9e4d9bfc7d6d47372970997696e194 (commit)
via 2f87c5be808d3a969a3fa101290715ab6bb53496 (commit)
from 8736b619abe7f5c75848521b03e2e626e58d3e01 (commit)
revisions in full, below.
commit 89467dc26d9e4d9bfc7d6d47372970997696e194
Author: Regina Obe <lr at pcorp.us>
Date: Thu Feb 5 00:14:53 2026 -0500
Get rid of dronie config
diff --git a/.drone-1.0.yml b/.drone-1.0.yml
deleted file mode 100644
index 52e04cf11..000000000
--- a/.drone-1.0.yml
+++ /dev/null
@@ -1,29 +0,0 @@
-# This is for the drone 1.0 agent
-# https://docs.drone.io/user-guide/pipeline/steps/
-# https://dronie.osgeo.org #1.0 server
-# See https://git.osgeo.org/gitea/postgis/postgis-docker
-# todo: add docker images from https://hub.docker.com/r/postgis/postgis-build-env/tags/
-test-image: &test-image docker.osgeo.org/postgis/build-test:trisquel2
-clone: &clone
- image: plugins/git
- depth: 20
- recursive: false
-kind: pipeline
-name: build
-clone: *clone
-steps:
- - name: build-10
- image: *test-image
- pull: always
- commands:
- - PGVER=10 sh ci/dronie/postgis_regress.sh
- - name: build-13
- pull: always
- commands:
- - PGVER=13 sh ci/dronie/postgis_regress.sh
commit 2f87c5be808d3a969a3fa101290715ab6bb53496
Date: Thu Feb 5 00:11:45 2026 -0500
TIGER EXTENSION SECURITY fix
Ensure tables are created by tiger extension and bale if not. Patch provided by Andrey Borodin (Yandex)
References #5998 for PostGIS 3.0.12
diff --git a/NEWS b/NEWS
index 1a7c37d08..d2daeb585 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
-PostGIS 3.0.12dev
-xxxx/xx/xx
+PostGIS 3.0.12 (EOL)
+2026/02/xx
PostgreSQL 9.5-13 required. GEOS 3.6+ required but GEOS 3.9+ to take advantage of all features.
Proj 4.9+ required.
@@ -13,6 +13,8 @@ Proj 4.9+ required.
- Handle null returns from wkb parser, Paul Ramsey
- #5818, GT-244 Fix CG_IsSolid function (Loïc Bartoletti)
- #6028, Crash indexing malformed empty polygon (Paul Ramsey)
+ - #5998, [tiger_geocoder] [security] CVE-2022-2625, make sure tables requires
+ by extension are owned by extension
PostGIS 3.0.11
diff --git a/extras/tiger_geocoder/pagc_normalize/pagc_tables.sql b/extras/tiger_geocoder/pagc_normalize/pagc_tables.sql
index ff78fc8f8..da6fc91a9 100644
--- a/extras/tiger_geocoder/pagc_normalize/pagc_tables.sql
+++ b/extras/tiger_geocoder/pagc_normalize/pagc_tables.sql
@@ -11,14 +11,23 @@ BEGIN
IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND table_name = 'pagc_gaz') THEN
CREATE TABLE pagc_gaz (id serial NOT NULL primary key ,seq integer ,word text, stdword text, token integer,is_custom boolean NOT NULL default true);
GRANT SELECT ON pagc_gaz TO public;
+ ELSE
+ -- Insist on invoking Postgres logic of owning table by extension. This prevent attacks like CVE-2022-2625.
+ CREATE TABLE IF NOT EXISTS pagc_gaz (id serial NOT NULL primary key ,seq integer ,word text, stdword text, token integer,is_custom boolean NOT NULL default true);
END IF;
IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND table_name = 'pagc_lex') THEN
CREATE TABLE pagc_lex (id serial NOT NULL primary key,seq integer,word text,stdword text,token integer,is_custom boolean NOT NULL default true);
GRANT SELECT ON pagc_lex TO public;
+ ELSE
+ -- Same as above.
+ CREATE TABLE IF NOT EXISTS pagc_lex (id serial NOT NULL primary key,seq integer,word text,stdword text,token integer,is_custom boolean NOT NULL default true);
END IF;
IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND table_name = 'pagc_rules') THEN
CREATE TABLE pagc_rules (id serial NOT NULL primary key,rule text, is_custom boolean DEFAULT true);
GRANT SELECT ON pagc_rules TO public;
+ ELSE
+ -- Same as above.
+ CREATE TABLE IF NOT EXISTS pagc_rules (id serial NOT NULL primary key,rule text, is_custom boolean DEFAULT true);
END IF;
IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND table_name = 'pagc_gaz' AND data_type='text') THEN
-- its probably old table structure change type of lex and gaz columns
diff --git a/extras/tiger_geocoder/tiger_loader_2012.sql b/extras/tiger_geocoder/tiger_loader_2012.sql
index c4d6da1b7..00593ecf5 100644
--- a/extras/tiger_geocoder/tiger_loader_2012.sql
+++ b/extras/tiger_geocoder/tiger_loader_2012.sql
@@ -57,18 +57,14 @@ $$
DO
BEGIN
- IF NOT EXISTS (SELECT * FROM information_schema.tables WHERE table_name = 'loader_platform' AND table_schema = 'tiger') THEN
- CREATE TABLE loader_platform(os varchar(50) PRIMARY KEY, declare_sect text, pgbin text, wget text, unzip_command text, psql text, path_sep text, loader text, environ_set_command text, county_process_command text);
- END IF;
+ CREATE TABLE IF NOT EXISTS loader_platform(os varchar(50) PRIMARY KEY, declare_sect text, pgbin text, wget text, unzip_command text, psql text, path_sep text, loader text, environ_set_command text, county_process_command text);
END
$$ LANGUAGE 'plpgsql';
DO
BEGIN
- IF NOT EXISTS (SELECT * FROM information_schema.schemata WHERE schema_name = 'tiger_data') THEN
- CREATE SCHEMA tiger_data;
- END IF;
+ CREATE SCHEMA IF NOT EXISTS tiger_data;
END
@@ -125,9 +121,7 @@ done');
-- variables table
DO $$
BEGIN
- IF NOT EXISTS (SELECT * FROM information_schema.tables WHERE table_name = 'loader_variables' AND table_schema = 'tiger') THEN
- CREATE TABLE loader_variables(tiger_year varchar(4) PRIMARY KEY, website_root text, staging_fold text, data_schema text, staging_schema text);
- END IF;
+ CREATE TABLE IF NOT EXISTS loader_variables(tiger_year varchar(4) PRIMARY KEY, website_root text, staging_fold text, data_schema text, staging_schema text);
END
@@ -138,8 +132,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
DO $$
BEGIN
- IF NOT EXISTS (SELECT * FROM information_schema.tables WHERE table_name = 'loader_lookuptables' AND table_schema = 'tiger') THEN
- CREATE TABLE loader_lookuptables(process_order integer NOT NULL DEFAULT 1000,
+ CREATE TABLE IF NOT EXISTS loader_lookuptables(process_order integer NOT NULL DEFAULT 1000,
lookup_name text primary key,
table_name text, single_mode boolean NOT NULL DEFAULT true,
load boolean NOT NULL DEFAULT true,
@@ -149,7 +142,6 @@ BEGIN
post_load_process text, single_geom_mode boolean DEFAULT false,
insert_mode char(1) NOT NULL DEFAULT 'c',
pre_load_process text,columns_exclude text[], website_root_override text);
- END IF;
END
diff --git a/extras/tiger_geocoder/tiger_loader_2013.sql b/extras/tiger_geocoder/tiger_loader_2013.sql
index d42f60ea2..8b6e0d166 100644
--- a/extras/tiger_geocoder/tiger_loader_2013.sql
+++ b/extras/tiger_geocoder/tiger_loader_2013.sql
@@ -56,18 +56,14 @@ $$
DO
BEGIN
- END IF;
END
DO
BEGIN
- END IF;
END
@@ -124,9 +120,7 @@ done');
-- variables table
DO $$
BEGIN
- END IF;
END
@@ -137,8 +131,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
DO $$
BEGIN
@@ -148,7 +141,6 @@ BEGIN
- END IF;
END
diff --git a/extras/tiger_geocoder/tiger_loader_2014.sql b/extras/tiger_geocoder/tiger_loader_2014.sql
index bedb84051..8726e5afe 100644
--- a/extras/tiger_geocoder/tiger_loader_2014.sql
+++ b/extras/tiger_geocoder/tiger_loader_2014.sql
@@ -89,6 +89,72 @@ IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_sche
CONSTRAINT enforce_srid_geom CHECK (st_srid(the_geom) = 4269)
COMMENT ON TABLE tiger.bg IS 'block groups';
+ELSE
+ CREATE TABLE IF NOT EXISTS tract
+ gid serial NOT NULL,
+ statefp varchar(2),
+ countyfp varchar(3),
+ tractce varchar(6),
+ tract_id varchar(11) PRIMARY KEY,
+ name varchar(7),
+ namelsad varchar(20),
+ mtfcc varchar(5),
+ funcstat varchar(1),
+ aland double precision,
+ awater double precision,
+ intptlat varchar(11),
+ intptlon varchar(12),
+ the_geom geometry,
+ CONSTRAINT enforce_dims_geom CHECK (st_ndims(the_geom) = 2),
+ CONSTRAINT enforce_geotype_geom CHECK (geometrytype(the_geom) = 'MULTIPOLYGON'::text OR the_geom IS NULL),
+ CONSTRAINT enforce_srid_geom CHECK (st_srid(the_geom) = 4269)
+ CREATE TABLE IF NOT EXISTS tabblock
+ blockce varchar(4),
+ tabblock_id varchar(16) PRIMARY KEY,
+ name varchar(20),
+ mtfcc varchar(5),
+ ur varchar(1),
+ uace varchar(5),
+ CREATE TABLE IF NOT EXISTS bg
+ blkgrpce varchar(1),
+ bg_id varchar(12) PRIMARY KEY,
+ namelsad varchar(13),
+ mtfcc varchar(5),
END IF;
IF EXISTS(SELECT * FROM information_schema.columns WHERE table_schema = 'tiger' AND column_name = 'tabblock_id' AND table_name = 'tabblock' AND character_maximum_length < 16) THEN -- size of name and tabblock_id fields need to be increased
@@ -144,18 +210,14 @@ $$
DO
BEGIN
- END IF;
END
DO
BEGIN
- END IF;
END
@@ -212,9 +274,7 @@ done');
-- variables table
DO $$
BEGIN
- END IF;
END
@@ -225,8 +285,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
DO $$
BEGIN
@@ -236,7 +295,6 @@ BEGIN
- END IF;
END
diff --git a/extras/tiger_geocoder/tiger_loader_2015.sql b/extras/tiger_geocoder/tiger_loader_2015.sql
index fe0bdf62f..3311be2e7 100644
--- a/extras/tiger_geocoder/tiger_loader_2015.sql
+++ b/extras/tiger_geocoder/tiger_loader_2015.sql
+ELSE
+ name varchar(7),
+ mtfcc varchar(5),
+ name varchar(20),
+ mtfcc varchar(5),
+ ur varchar(1),
+ uace varchar(5),
+ mtfcc varchar(5),
END IF;
DO
BEGIN
- END IF;
END
DO
BEGIN
- END IF;
END
-- variables table
DO $$
BEGIN
- END IF;
END
DO $$
BEGIN
- END IF;
END
diff --git a/extras/tiger_geocoder/tiger_loader_2016.sql b/extras/tiger_geocoder/tiger_loader_2016.sql
index 0cb93e442..39dd37f0a 100644
--- a/extras/tiger_geocoder/tiger_loader_2016.sql
+++ b/extras/tiger_geocoder/tiger_loader_2016.sql
+ELSE
+ name varchar(7),
+ mtfcc varchar(5),
+ name varchar(20),
+ mtfcc varchar(5),
+ ur varchar(1),
+ uace varchar(5),
+ mtfcc varchar(5),
END IF;
DO
BEGIN
- END IF;
END
DO
BEGIN
- END IF;
END
@@ -211,9 +273,7 @@ done');
-- variables table
DO $$
BEGIN
- END IF;
END
@@ -224,8 +284,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
DO $$
BEGIN
@@ -235,7 +294,6 @@ BEGIN
- END IF;
END
diff --git a/extras/tiger_geocoder/tiger_loader_2017.sql b/extras/tiger_geocoder/tiger_loader_2017.sql
index 9a7c6a726..5644a4d53 100644
--- a/extras/tiger_geocoder/tiger_loader_2017.sql
+++ b/extras/tiger_geocoder/tiger_loader_2017.sql
+ELSE
+ name varchar(7),
+ mtfcc varchar(5),
+ name varchar(20),
+ mtfcc varchar(5),
+ ur varchar(1),
+ uace varchar(5),
+ mtfcc varchar(5),
END IF;
DO
BEGIN
- END IF;
END
DO
BEGIN
- END IF;
END
-- variables table
DO $$
BEGIN
- END IF;
END
DO $$
BEGIN
- END IF;
END
diff --git a/extras/tiger_geocoder/tiger_loader_2018.sql b/extras/tiger_geocoder/tiger_loader_2018.sql
index 61e68797a..33697e785 100644
--- a/extras/tiger_geocoder/tiger_loader_2018.sql
+++ b/extras/tiger_geocoder/tiger_loader_2018.sql
+ELSE
+ name varchar(7),
+ mtfcc varchar(5),
+ name varchar(20),
+ mtfcc varchar(5),
+ ur varchar(1),
+ uace varchar(5),
+ mtfcc varchar(5),
END IF;
DO
BEGIN
- END IF;
END
DO
BEGIN
- END IF;
END
-- variables table
DO $$
BEGIN
- END IF;
END
DO $$
BEGIN
- END IF;
END
diff --git a/extras/tiger_geocoder/tiger_loader_2019.sql b/extras/tiger_geocoder/tiger_loader_2019.sql
index 3fce651ff..9485011cf 100644
--- a/extras/tiger_geocoder/tiger_loader_2019.sql
+++ b/extras/tiger_geocoder/tiger_loader_2019.sql
+ELSE
+ name varchar(7),
+ mtfcc varchar(5),
+ name varchar(20),
+ mtfcc varchar(5),
+ ur varchar(1),
+ uace varchar(5),
+ mtfcc varchar(5),
END IF;
@@ -123,12 +189,11 @@ CREATE OR REPLACE FUNCTION drop_state_tables_generate_script(param_state text, p
SELECT array_to_string(array_agg('DROP TABLE ' || quote_ident(table_schema) || '.' || quote_ident(table_name) || ';'),E'\n')
FROM (SELECT * FROM information_schema.tables
- WHERE table_schema = $2 AND table_name like lower($1) || '~_%' ESCAPE '~' ORDER BY table_name) AS foo;
+ WHERE table_schema = $2 AND table_name like lower($1) || '_%' ORDER BY table_name) AS foo;
LANGUAGE sql VOLATILE;
-- Helper function that generates script to drop all nation tables (county, state) in a particular schema
-- This is useful for loading 2011 because state and county tables aren't broken out into separate state files
DROP FUNCTION IF EXISTS drop_national_tables_generate_script(text);
@@ -145,18 +210,14 @@ $$
DO
BEGIN
- END IF;
END
DO
BEGIN
- END IF;
END
@@ -212,9 +273,7 @@ done');
-- variables table
DO $$
BEGIN
- END IF;
END
@@ -225,8 +284,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
DO $$
BEGIN
@@ -236,7 +294,6 @@ BEGIN
- END IF;
END
Summary of changes:
.drone-1.0.yml | 29 --------
NEWS | 6 +-
.../tiger_geocoder/pagc_normalize/pagc_tables.sql | 9 +++
extras/tiger_geocoder/tiger_loader_2012.sql | 16 +---
extras/tiger_geocoder/tiger_loader_2013.sql | 16 +---
extras/tiger_geocoder/tiger_loader_2014.sql | 82 ++++++++++++++++++---
extras/tiger_geocoder/tiger_loader_2015.sql | 82 ++++++++++++++++++---
extras/tiger_geocoder/tiger_loader_2016.sql | 82 ++++++++++++++++++---
extras/tiger_geocoder/tiger_loader_2017.sql | 82 ++++++++++++++++++---
extras/tiger_geocoder/tiger_loader_2018.sql | 82 ++++++++++++++++++---
extras/tiger_geocoder/tiger_loader_2019.sql | 85 ++++++++++++++++++----
11 files changed, 442 insertions(+), 129 deletions(-)
delete mode 100644 .drone-1.0.yml
hooks/post-receive
