[SCM] PostGIS branch master updated. 3.6.0rc2-328-g760c7eb39
Thu Feb 5 16:03:59 PST 2026
the project "PostGIS".
       via  760c7eb3951d48547c947f00cac81bc1e2ad397a (commit)
      from  bf36aef0ca85b254b8576f0936d377612a4668c0 (commit)
revisions in full, below.
commit 760c7eb3951d48547c947f00cac81bc1e2ad397a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Feb 5 16:03:49 2026 -0800
    Remove dead spherical code
diff --git a/postgis/lwgeom_spheroid.c b/postgis/lwgeom_spheroid.c
index 8c11edff5..572470fe2 100644
--- a/postgis/lwgeom_spheroid.c
+++ b/postgis/lwgeom_spheroid.c
@@ -44,12 +44,6 @@
 #define SHOW_DIGS_DOUBLE 15
 #define MAX_DIGS_DOUBLE (SHOW_DIGS_DOUBLE + 6 + 1 + 3 +1)
- * distance from -126 49  to -126 49.011096139863
- * in  'SPHEROID["GRS_1980",6378137,298.257222101]'
- * is 1234.000
 /* PG-exposed  */
 Datum ellipsoid_in(PG_FUNCTION_ARGS);
@@ -60,15 +54,6 @@ Datum LWGEOM_distance_ellipsoid(PG_FUNCTION_ARGS);
 Datum LWGEOM_distance_sphere(PG_FUNCTION_ARGS);
 Datum geometry_distance_spheroid(PG_FUNCTION_ARGS);
-/* internal */
-double distance_sphere_method(double lat1, double long1,double lat2,double long2, SPHEROID *sphere);
-double distance_ellipse_calculation(double lat1, double long1, double lat2, double long2, SPHEROID *sphere);
-double	distance_ellipse(double lat1, double long1, double lat2, double long2, SPHEROID *sphere);
-double deltaLongitude(double azimuth, double sigma, double tsm,SPHEROID *sphere);
-double mu2(double azimuth,SPHEROID *sphere);
-double bigA(double u2);
-double bigB(double u2);
  * Use the WKT definition of an ellipsoid
@@ -131,196 +116,6 @@ Datum ellipsoid_out(PG_FUNCTION_ARGS)
 	PG_RETURN_CSTRING(result);
- * support function for distance calc
- * code is taken from David Skea
- * Geographic Data BC, Province of British Columbia, Canada.
- * Thanks to GDBC and David Skea for allowing this to be
- * put in PostGIS.
-double
-deltaLongitude(double azimuth, double sigma, double tsm,SPHEROID *sphere)
-	/* compute the expansion C */
-	double das,C;
-	double ctsm,DL;
-	das = cos(azimuth)*cos(azimuth);
-	C = sphere->f/16.0 * das * (4.0 + sphere->f * (4.0 - 3.0 * das));
-	/* compute the difference in longitude */
-	ctsm = cos(tsm);
-	DL = ctsm + C * cos(sigma) * (-1.0 + 2.0 * ctsm*ctsm);
-	DL = sigma + C * sin(sigma) * DL;
-	return (1.0 - C) * sphere->f * sin(azimuth) * DL;
- *  put in PostGIS.
-double
-mu2(double azimuth,SPHEROID *sphere)
-	double    e2;
-	e2 = sqrt(sphere->a*sphere->a-sphere->b*sphere->b)/sphere->b;
-	return cos(azimuth)*cos(azimuth) * e2*e2;
- * Support function for distance calc
- *  put in PostGIS.
-double
-bigA(double u2)
-	return 1.0 + u2/256.0 * (64.0 + u2 * (-12.0 + 5.0 * u2));
- *  put in PostGIS.
-double
-bigB(double u2)
-	return u2/512.0 * (128.0 + u2 * (-64.0 + 37.0 * u2));
-double
-distance_ellipse(double lat1, double long1,
-                 double lat2, double long2, SPHEROID *sphere)
-	double result = 0;
-#if POSTGIS_DEBUG_LEVEL >= 4
-	double result2 = 0;
-#endif
-	if ( (lat1==lat2) && (long1 == long2) )
-		return 0.0; /* same point, therefore zero distance */
-	result = distance_ellipse_calculation(lat1,long1,lat2,long2,sphere);
-	result2 =  distance_sphere_method(lat1, long1,lat2,long2, sphere);
-	POSTGIS_DEBUGF(4, "delta = %lf, skae says: %.15lf,2 circle says: %.15lf",
-	         (result2-result),result,result2);
-	POSTGIS_DEBUGF(4, "2 circle says: %.15lf",result2);
-#endif
-	if (result != result)  /* NaN check
-			                        * (x==x for all x except NaN by IEEE definition)
-		result =  distance_sphere_method(lat1, long1,
-		                                 lat2,long2, sphere);
-	return result;
- * Given 2 lat/longs and ellipse, find the distance
- * note original r = 1st, s=2nd location
-double
-distance_ellipse_calculation(double lat1, double long1,
-	 * Code is taken from David Skea
-	 *  put in PostGIS.
-	double L1,L2,sinU1,sinU2,cosU1,cosU2;
-	double dl,dl1,dl2,dl3,cosdl1,sindl1;
-	double cosSigma,sigma,azimuthEQ,tsm;
-	double u2,A,B;
-	double dsigma;
-	double TEMP;
-	int iterations;
-	L1 = atan((1.0 - sphere->f ) * tan( lat1) );
-	L2 = atan((1.0 - sphere->f ) * tan( lat2) );
-	sinU1 = sin(L1);
-	sinU2 = sin(L2);
-	cosU1 = cos(L1);
-	cosU2 = cos(L2);
-	dl = long2- long1;
-	dl1 = dl;
-	cosdl1 = cos(dl);
-	sindl1 = sin(dl);
-	iterations = 0;
-	do
-		cosSigma = sinU1 * sinU2 + cosU1 * cosU2 * cosdl1;
-		sigma = acos(cosSigma);
-		azimuthEQ = asin((cosU1 * cosU2 * sindl1)/sin(sigma));
-		 * Patch from Patrica Tozer to handle minor
-		 * mathematical stability problem
-		TEMP = cosSigma - (2.0 * sinU1 * sinU2)/
-		       (cos(azimuthEQ)*cos(azimuthEQ));
-		if (TEMP > 1)
-			TEMP = 1;
-		else if (TEMP < -1)
-			TEMP = -1;
-		tsm = acos(TEMP);
-		/* (old code?)
-		tsm = acos(cosSigma - (2.0 * sinU1 * sinU2)/(cos(azimuthEQ)*cos(azimuthEQ)));
-		dl2 = deltaLongitude(azimuthEQ, sigma, tsm,sphere);
-		dl3 = dl1 - (dl + dl2);
-		dl1 = dl + dl2;
-		cosdl1 = cos(dl1);
-		sindl1 = sin(dl1);
-		iterations++;
-	while ( (iterations<999) && (fabs(dl3) > 1.0e-032));
-	/* compute expansions A and B */
-	u2 = mu2(azimuthEQ,sphere);
-	A = bigA(u2);
-	B = bigB(u2);
-	/* compute length of geodesic */
-	dsigma = B * sin(sigma) * (cos(tsm) +
-	                           (B*cosSigma*(-1.0 + 2.0 * (cos(tsm)*cos(tsm))))/4.0);
-	return sphere->b * (A * (sigma - dsigma));
@@ -385,95 +180,6 @@ Datum LWGEOM_length_ellipsoid_linestring(PG_FUNCTION_ARGS)
 	PG_RETURN_FLOAT8(length);
- *  For some lat/long points, the above method doesn't calculate the distance very well.
- *  Typically this is for two lat/long points that are very very close together (<10cm).
- *  This gets worse closer to the equator.
- *   This method works very well for very close together points, not so well if they're
- *   far away (>1km).
- *  METHOD:
- *    We create two circles (with Radius R and Radius S) and use these to calculate the distance.
- *    The first (R) is basically a (north-south) line of longitude.
- *    Its radius is approximated by looking at the ellipse. Near the equator R = 'a' (earth's major axis)
- *    near the pole R = 'b' (earth's minor axis).
- *    The second (S) is basically a (east-west) line of latitude.
- *    Its radius runs from 'a' (major axis) at the equator, and near 0 at the poles.
- *                North pole
- *              *\--S--
- *             *  R   +
- *           *     A\ +
- *          * ------ \         Equator/centre of earth
- *                South pole
- *  (side view of earth)
- *   Angle A is lat1
- *   R is the distance from the centre of the earth to the lat1/long1 point on the surface
- *   of the Earth.
- *   S is the circle-of-latitude.  Its calculated from the right triangle defined by
- *      the angle (90-A), and the hypotenuse R.
- *   Once R and S have been calculated, the actual distance between the two points can be
- *   calculated.
- *   We dissolve the vector from lat1,long1 to lat2,long2 into its X and Y components (called DeltaX,DeltaY).
- *   The actual distance that these angle-based measurements represent is taken from the two
- *   circles we just calculated; R (for deltaY) and S (for deltaX).
- *    (if deltaX is 1 degrees, then that distance represents 1/360 of a circle of radius S.)
- *  Parts taken from PROJ - geodetic_to_geocentric() (for calculating Rn)
- *  remember that lat1/long1/lat2/long2 are coming in a *RADIANS* not degrees.
- * By Patricia Tozer and Dave Blasby
- *  This is also called the "curvature method".
-	double R,S,X,Y,deltaX,deltaY;
-	double 	distance 	= 0.0;
-	double 	sin_lat 	= sin(lat1);
-	double 	sin2_lat 	= sin_lat * sin_lat;
-	double  Geocent_a 	= sphere->a;
-	double  Geocent_e2 	= sphere->e_sq;
-	R  	= Geocent_a / (sqrt(1.0e0 - Geocent_e2 * sin2_lat));
-	/* 90 - lat1, but in radians */
-	S 	= R * sin(M_PI_2 - lat1) ;
-	deltaX = long2 - long1;  /* in rads */
-	deltaY = lat2 - lat1;    /* in rads */
-	/* think: a % of 2*pi*S */
-	X = deltaX/(2.0*M_PI) * 2 * M_PI * S;
-	Y = deltaY/(2.0*M_PI) * 2 * M_PI * R;
-	distance = sqrt((X * X + Y * Y));
-	return distance;
  * distance (geometry,geometry, sphere)
Summary of changes:
 postgis/lwgeom_spheroid.c | 294 ----------------------------------------------
 1 file changed, 294 deletions(-)
hooks/post-receive
