[SCM] PostGIS branch stable-3.2 updated. 3.2.7-65-g9c9a4ab60
Sat Feb 7 05:13:45 PST 2026
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  9c9a4ab6052b2da23dd7b8e239d14b9d7bddc1b4 (commit)
      from  773847871a9edcb021432a3bcb1f7f8b5b975c89 (commit)
revisions in full, below.
commit 9c9a4ab6052b2da23dd7b8e239d14b9d7bddc1b4
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Feb 7 06:32:08 2026 -0500
    Try to fix xml issue
    Add missing upgrade path
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 5cbc4aa88..2969d34cb 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,7 +2,6 @@
 <appendix id="release_notes">
   <title>Appendix</title>
    <subtitle>Release Notes</subtitle>
     <sect1>
         <title>PostGIS 3.2.9</title>
         <para>2026/02/07</para>
@@ -12,12 +11,12 @@
             <para><ulink url="https://trac.osgeo.org/postgis/ticket/6023">6023</ulink>, Fix robustness issue in ptarray_contains_point (Sandro Santilli)</para>
             <para><ulink url="https://trac.osgeo.org/postgis/ticket/5951">5951</ulink>, [topology] Fix crash in ST_GetFaceEdges with corrupted topology (Sandro Santilli)</para>
             <para><ulink url="https://trac.osgeo.org/postgis/ticket/5947">5947</ulink>, [topology] Fix crash in ST_ModEdgeHeal (Sandro Santilli)</para>
-            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5925">5925</ulink>, #5946, [topology] Have GetFaceContainingPoint survive EMPTY edges (Sandro Santilli)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5925">5925</ulink>, <ulink url="https://trac.osgeo.org/postgis/ticket/5946">5946</ulink>, [topology] Have GetFaceContainingPoint survive EMPTY edges (Sandro Santilli)</para>
             <para><ulink url="https://trac.osgeo.org/postgis/ticket/5922">5922</ulink>, [topology] Fix crash in TopoGeo_AddLinestring with EMPTY input (Sandro Santilli)</para>
             <para><ulink url="https://trac.osgeo.org/postgis/ticket/5908">5908</ulink>, [topology] Fix crash in GetFaceContainingPoint (Sandro Santilli)</para>
             <para><ulink url="https://trac.osgeo.org/postgis/ticket/5907">5907</ulink>, [topology] Fix crash in TopoGeo_AddPolygon with EMPTY input (Sandro Santilli)</para>
             <para><ulink url="https://trac.osgeo.org/postgis/ticket/5876">5876</ulink>, Fix ST_AddPoint with empty point argument (Paul Ramsey)</para>
-            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5818">5818</ulink>, GT-244 Fix CG_IsSolid function (Loïc Bartoletti)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5818">5818</ulink>, <ulink url="https://gitea.osgeo.org/postgis/postgis/pulls/244">GT-244</ulink> Fix CG_IsSolid function (Loïc Bartoletti)</para>
             <para><ulink url="https://trac.osgeo.org/postgis/ticket/5885">5885</ulink>, Fix documentation about grid-based overlay operations (Sandro Santilli)</para>
             <para><ulink url="https://trac.osgeo.org/postgis/ticket/5921">5921</ulink>, Crash freeing uninitialized pointer (Arsenii Mukhin)</para>
             <para><ulink url="https://trac.osgeo.org/postgis/ticket/5912">5912</ulink>, Crash on GML with xlink and no prefix (Paul Ramsey)</para>
@@ -27,14 +26,14 @@
             <para><ulink url="https://trac.osgeo.org/postgis/ticket/5991">5991</ulink>, CircularString distance error (Paul Ramsey)</para>
             <para><ulink url="https://trac.osgeo.org/postgis/ticket/5962">5962</ulink>, Consistent clipping of MULTI/POINT (Paul Ramsey)</para>
             <para><ulink url="https://trac.osgeo.org/postgis/ticket/5989">5989</ulink>, CurvePolygon distance error (Paul Ramsey)</para>
-            <para><ulink url="https://trac.osgeo.org/postgis/ticket/6028">6028</ulink>, Crash indexing malformed empty polygon (Paul Ramsey</para>)
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/6028">6028</ulink>, Crash indexing malformed empty polygon (Paul Ramsey)</para>
             <para><ulink url="https://github.com/postgis/postgis/pull/841">GH-841</ulink>, small memory leak in address_standardizer (Maxim Korotkov)</para>
-            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5998">5998</ulink>, [tiger_geocoder] [security] CVE-2022-2625, make sure tables required
-            by extension are owned by extension
-            authored: Andrey Borodin (Yandex), reported by Sergey Bobrov (Kaspersky)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5998">5998</ulink>, [tiger_geocoder] [security] CVE-2022-2625, make sure tables required by extension are owned by extension authored: Andrey Borodin (Yandex), reported by Sergey Bobrov (Kaspersky)</para>
             <para><ulink url="https://trac.osgeo.org/postgis/ticket/5985">5985</ulink>, Fix configure issue with Debian 12 and 13 (Regina Obe, Sandro Santilli)</para>
         </simplesect>
     </sect1>
     <sect1>
         <title>PostGIS 3.2.8</title>
         <para>2024/12/22</para>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index c4c9b021e..21ac7e760 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -74,7 +74,7 @@ UPGRADEABLE_VERSIONS = \
 	3.0.12 \
 	3.1.0 \
 	3.1.1 \
-	3.1.2	\
+	3.1.2 \
 	3.1.3 \
 	3.1.4 \
 	3.1.5 \
@@ -85,6 +85,7 @@ UPGRADEABLE_VERSIONS = \
 	3.1.10 \
 	3.1.11 \
 	3.1.12 \
+	3.1.13 \
 	3.2.0 \
 	3.2.1 \
 	3.2.2 \
Summary of changes:
 doc/release_notes.xml              | 13 ++++++-------
 extensions/upgradeable_versions.mk |  3 ++-
 2 files changed, 8 insertions(+), 8 deletions(-)
hooks/post-receive
