[SCM] PostGIS branch stable-3.6 updated. 3.6.1-23-g34b1ca782
Mon Feb 9 16:11:09 PST 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
       via  34b1ca782e39d85e33d34161b6254dd206558078 (commit)
       via  d29f1693fe8cb1e050032e495d69415636a1718a (commit)
       via  8fef3f68db6337af6b95b990ddd373444fe295ff (commit)
      from  3d64dfde01432a157f37ce3694c22d24f4d65776 (commit)
revisions in full, below.
commit 34b1ca782e39d85e33d34161b6254dd206558078
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Feb 9 19:10:45 2026 -0500
    Prep for PostGIS 3.6.2 release
diff --git a/NEWS b/NEWS
index ee38ad634..72a5e5b9a 100644
--- a/NEWS
+++ b/NEWS
@@ -1,6 +1,6 @@
-PostGIS 3.6.2dev
-2026/xx/xx
+PostGIS 3.6.2
+2026/02/09
 This version requires PostgreSQL 12-18, GEOS 3.8 or higher, and Proj 6.1+.
 To take advantage of all features, GEOS 3.14+ is needed.
@@ -24,6 +24,10 @@ topogeometry corruption:
 - #6020, schema qualify call in ST_MPointFromText (Paul Ramsey)
 - #6028, crash indexing malformed empty polygon (Paul Ramsey)
 - GH-841, small memory leak in address_standardizer (Maxim Korotkov)
+- #5853, Issue with topology and tiger geocoder upgrade scripts
+           (Regina Obe, Spencer Bryson)
+- #6032, Fix postgis_tiger_geocoder upgrade for PostgreSQL < 16
+          (Regina Obe)
 PostGIS 3.6.1
diff --git a/README.postgis b/README.postgis
index bdd39454c..1a057a1af 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.6.1
-:Date: 2025-11-13
+:Version: 3.6.2
+:Date: 2026-02-09
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 351b77924..cbd77096c 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=6
-POSTGIS_MICRO_VERSION=2dev
+POSTGIS_MICRO_VERSION=2
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index bf8a795de..eff6f4c45 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,7 +2,28 @@
 <appendix xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://docbook.org/ns/docbook" version="5.0" xml:id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
+        <section>
+            <title>PostGIS 3.6.2</title>
+            <para>2026/02/09</para>
+            <para>If you are upgrading postgis_topology and have topogeometry columns, make sure to run after the upgrade to fix topogeometry corruption: <code>SELECT topology.FixCorruptTopoGeometryColumn(schema_name, table_name, feature_column) FROM topology.layer</code></para>
+            <simplesect>
+                <title>Fixes</title>
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6023">6023</link>, Fix robustness issue in ptarray_contains_point (Sandro Santilli)</para>
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6027">6027</link>, Fix RemoveUnusedPrimitives without topology in search_path
+                        (Sandro Santilli)</para>
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6019">6019</link>, make clean does not remove cunit generated files
+                        (Bas Couwenberg)</para>
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6020">6020</link>, schema qualify call in ST_MPointFromText (Paul Ramsey)</para>
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6028">6028</link>, crash indexing malformed empty polygon (Paul Ramsey)</para>
+                <para><link xlink:href="https://github.com/postgis/postgis/pull/841">GH-841</link>, small memory leak in address_standardizer (Maxim Korotkov)
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5853">5853</link>, Issue with topology and tiger geocoder upgrade scripts
+                        (Regina Obe, Spencer Bryson)</para>
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6032">6032</link>, Fix postgis_tiger_geocoder upgrade for PostgreSQL < 16
+                        (Regina Obe)</para>
+            </simplesect>
+        </section>
         <section>
             <title>PostGIS 3.6.1</title>
             <para>2025/11/13</para>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 718948b71..e778dc6db 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -71,6 +71,7 @@ UPGRADEABLE_VERSIONS = \
 	3.0.9 \
 	3.0.10 \
 	3.0.11 \
+	3.0.12 \
 	3.1.0 \
 	3.1.1 \
 	3.1.2 \
@@ -85,6 +86,7 @@ UPGRADEABLE_VERSIONS = \
 	3.1.10 \
 	3.1.11 \
 	3.1.12 \
+	3.1.13 \
 	3.2.0 \
 	3.2.1 \
 	3.2.2 \
@@ -94,6 +96,7 @@ UPGRADEABLE_VERSIONS = \
 	3.2.6 \
 	3.2.7 \
 	3.2.8 \
+	3.2.9 \
 	3.3.0 \
 	3.3.1 \
 	3.3.2 \
@@ -103,15 +106,18 @@ UPGRADEABLE_VERSIONS = \
 	3.3.6 \
 	3.3.7 \
 	3.3.8 \
+	3.3.9 \
 	3.4.0 \
 	3.4.1 \
 	3.4.2 \
 	3.4.3 \
 	3.4.4 \
+	3.4.5 \
 	3.5.0 \
 	3.5.1 \
 	3.5.2 \
 	3.5.3 \
 	3.5.4 \
+	3.5.5 \
 	3.6.0 \
 	3.6.1
commit d29f1693fe8cb1e050032e495d69415636a1718a
Date:   Mon Feb 9 19:09:04 2026 -0500
    FIXES TO CIRRUS CI
    - Get rid of $NCPU and put in a 2 instead and lower the ram.  References #6047 for PostGIS 3.6.2
    - Change FreeBSD to 14.3, 14.2 is no longer available
diff --git a/.cirrus.yml b/.cirrus.yml
index 25feb7449..b58691c4a 100644
--- a/.cirrus.yml
+++ b/.cirrus.yml
@@ -53,12 +53,12 @@ task:
       gmake ${MAKEJOBS} check RUNTESTFLAGS="-v --extension --dumprestore" || { service postgresql onestop; exit 1; }
   freebsd_instance:
-    cpu: ${NCPU}
-    memory: 24G
+    cpu: 2
+    memory: 8G
   matrix:
-    - name: 14.2-RELEASE
+    - name: 14.3-RELEASE
       freebsd_instance:
-        image_family: freebsd-14-2
+        image_family: freebsd-14-3
 task:
commit 8fef3f68db6337af6b95b990ddd373444fe295ff
Date:   Mon Feb 9 18:26:56 2026 -0500
    Remove postgis_extension_remove_objects
    Closes #5853 for PostGIS 3.6.2
    Closes #6032 for PostGIS 3.6.2
diff --git a/extensions/postgis_extension_helper.sql.in b/extensions/postgis_extension_helper.sql.in
index d5f473d16..3341f9ef1 100644
--- a/extensions/postgis_extension_helper.sql.in
+++ b/extensions/postgis_extension_helper.sql.in
@@ -14,73 +14,6 @@
 -- This is a suite of SQL helper functions for use during a PostGIS extension install/upgrade
 -- The functions get uninstalled after the extension install/upgrade process
--- postgis_extension_remove_objects: This function removes objects of a particular class from an extension
--- this is needed because there is no ALTER EXTENSION DROP FUNCTION/AGGREGATE command
--- and we can't CREATE OR REPLACE functions whose signatures have changed and we can drop them if they are part of an extension
--- So we use this to remove it from extension first before we drop
-CREATE FUNCTION postgis_extension_remove_objects(param_extension text, param_type text)
-  RETURNS boolean AS
-DECLARE
-	var_sql text := '';
-	var_r record;
-	var_result boolean := false;
-	var_class text := '';
-	var_is_aggregate boolean := false;
-	var_sql_list text := '';
-	var_pgsql_version integer := pg_catalog.current_setting('server_version_num');
-BEGIN
-		var_class := CASE WHEN pg_catalog.lower(param_type) OPERATOR(pg_catalog.=)'function' OR pg_catalog.lower(param_type) OPERATOR(pg_catalog.=) 'aggregate' THEN 'pg_catalog.pg_proc' ELSE '' END;
-		var_is_aggregate := CASE WHEN pg_catalog.lower(param_type) OPERATOR(pg_catalog.=) 'aggregate' THEN true ELSE false END;
-		IF var_pgsql_version OPERATOR(pg_catalog.<) 110000 THEN
-			var_sql_list := $sql$SELECT 'ALTER EXTENSION ' OPERATOR(pg_catalog.||)  e.extname OPERATOR(pg_catalog.||) ' DROP ' OPERATOR(pg_catalog.||) $3 OPERATOR(pg_catalog.||) ' ' OPERATOR(pg_catalog.||) COALESCE(proc.proname OPERATOR(pg_catalog.||) '(' OPERATOR(pg_catalog.||) oidvectortypes(proc.proargtypes) OPERATOR(pg_catalog.||) ')' ,typ.typname, cd.relname, op.oprname,
-					cs.typname OPERATOR(pg_catalog.||) ' AS ' OPERATOR(pg_catalog.||) ct.typname OPERATOR(pg_catalog.||) ') ', opcname, opfname) OPERATOR(pg_catalog.||) ';' AS remove_command
-			FROM pg_catalog.pg_depend As d INNER JOIN pg_catalog.pg_extension As e
-				ON d.refobjid OPERATOR(pg_catalog.=) e.oid INNER JOIN pg_catalog.pg_class As c ON
-					c.oid OPERATOR(pg_catalog.=) d.classid
-					LEFT JOIN pg_catalog.pg_proc AS proc ON proc.oid OPERATOR(pg_catalog.=) d.objid
-					LEFT JOIN pg_catalog.pg_type AS typ ON typ.oid OPERATOR(pg_catalog.=) d.objid
-					LEFT JOIN pg_catalog.pg_class As cd ON cd.oid OPERATOR(pg_catalog.=) d.objid
-					LEFT JOIN pg_operator As op ON op.oid OPERATOR(pg_catalog.=) d.objid
-					LEFT JOIN pg_catalog.pg_cast AS ca ON ca.oid OPERATOR(pg_catalog.=) d.objid
-					LEFT JOIN pg_catalog.pg_type AS cs ON ca.castsource OPERATOR(pg_catalog.=) cs.oid
-					LEFT JOIN pg_catalog.pg_type AS ct ON ca.casttarget OPERATOR(pg_catalog.=) ct.oid
-					LEFT JOIN pg_opclass As oc ON oc.oid OPERATOR(pg_catalog.=) d.objid
-					LEFT JOIN pg_opfamily As ofa ON ofa.oid OPERATOR(pg_catalog.=) d.objid
-			WHERE d.deptype OPERATOR(pg_catalog.=) 'e' and e.extname OPERATOR(pg_catalog.=) $1 and c.relname OPERATOR(pg_catalog.=) $2 AND COALESCE(proc.proisagg, false) OPERATOR(pg_catalog.=) $4;$sql$;
-		ELSE -- for PostgreSQL 11 and above, they removed proc.proisagg among others and replaced with some func type thing
-			WHERE d.deptype OPERATOR(pg_catalog.=) 'e' and e.extname OPERATOR(pg_catalog.=) $1 and c.relname OPERATOR(pg_catalog.=) $2 AND (proc.prokind OPERATOR(pg_catalog.=) 'a')  OPERATOR(pg_catalog.=) $4;$sql$;
-		END IF;
-		FOR var_r IN EXECUTE var_sql_list  USING param_extension, var_class, param_type, var_is_aggregate
-		LOOP
-			var_sql := var_sql OPERATOR(pg_catalog.||) var_r.remove_command OPERATOR(pg_catalog.||) ';';
-		END LOOP;
-		IF var_sql > '' THEN
-			EXECUTE var_sql;
-			var_result := true;
-		END IF;
-		RETURN var_result;
-END;
-LANGUAGE plpgsql VOLATILE;
 CREATE FUNCTION postgis_extension_drop_if_exists(param_extension text, param_statement text)
   RETURNS boolean AS
diff --git a/extensions/postgis_extension_helper_uninstall.sql b/extensions/postgis_extension_helper_uninstall.sql
index 2fb1d1756..756dc80f8 100644
--- a/extensions/postgis_extension_helper_uninstall.sql
+++ b/extensions/postgis_extension_helper_uninstall.sql
@@ -13,7 +13,6 @@
 -- This drops extension helper functions
 -- and should be called at the end of the extension upgrade file
-DROP FUNCTION postgis_extension_remove_objects(text, text);
 DROP FUNCTION postgis_extension_drop_if_exists(text, text);
 DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(varchar);
 DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(text);
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index ce3db167b..e0faf1caf 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -31,6 +31,12 @@ DATA_built = \
 REGRESS = test-normalize_address test-upgrade
 REGRESS_OPTS = --load-extension=fuzzystrmatch --load-extension=postgis --load-extension=$(EXTENSION)
+EXTSCHEMA_SUPPORTED = yes
+## PostgreSQL < 16 doesn't understand new @extschema:extname@ syntax, so strip it
+ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" "<" 160),1)
+EXTSCHEMA_SUPPORTED = no
+endif
 SQL_BITS     = $(wildcard sql_bits/*.sql)
 EXTRA_CLEAN = sql expected ${SQL_BITS}
@@ -51,14 +57,14 @@ expected:
 sql:
 	mkdir -p $@
-## PostgreSQL < 16 doesn't understand new @extschema:extname@ syntax, so strip it
-ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" "<" 160),1)
+ifeq ($(EXTSCHEMA_SUPPORTED),yes)
 sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
-	$(PERL) -lpe "s/\@extschema:[a-z]+\@\./ /g" < $< > $@
-else
- sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
 	cp $< $@
+else
+# PG < 16 doesn't support new @extschema:<extension_name>@
+# so we need to strip those out
+sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
+	$(PERL) -lpe "s/\@extschema:[^@]+\@\./ /g" < $< > $@
 endif
 expected/test-normalize_address.out: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/normalize_address_regress | expected
@@ -74,14 +80,14 @@ sql/test-normalize_address.sql: sql_bits/test_tuples_only_unaligned.sql.in ../..
 sql/test-upgrade.sql: | sql
 	echo 'ALTER EXTENSION ${EXTENSION} UPDATE TO "ANY"; ALTER EXTENSION ${EXTENSION} UPDATE TO "$(EXTVERSION)"' > $@
-## no_relocate clause is only availabe in PostgreSQL 16 and above, so strip it for lower
-%.control: %.control.in Makefile
-	$(PERL) -lpe 's/^no_relocate.*//g; s/\@EXTVERSION\@/$(EXTVERSION)/g'  < "$<" > "$@"
-else
+## no_relocate clause is only available in PostgreSQL 16 and above, so strip it for lower
 	$(PERL) -lpe "s'@EXTVERSION@'$(EXTVERSION)'g" \
+else
+%.control: %.control.in Makefile
+	$(PERL) -lpe 's/^no_relocate.*//g; s/\@EXTVERSION\@/$(EXTVERSION)/g'  < "$<" > "$@"
 endif
 expected/test-upgrade.out: sql/test-upgrade.sql | expected
@@ -98,7 +104,7 @@ sql/$(EXTENSION).sql: sql/$(EXTENSION)_pre.sql ../../utils/create_or_replace_to_
 		| $(PERL) @top_srcdir@/utils/create_or_replace_to_create.pl sql/$(EXTENSION)_pre.sql \
-sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in | sql
+sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: ../postgis_extension_helper.sql sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in | sql
 	cat $^ > $@
 	echo "SELECT postgis_extension_drop_if_exists('${EXTENSION}', 'DROP SCHEMA tiger_data');" >> $@
 	cat @srcdir@/../postgis_extension_helper_uninstall.sql  >> $@
@@ -205,9 +211,14 @@ sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql_bits/tiger_geocoder--unpack
 #aggregates are special
 #they can be dropped but we need to remove
 #them from the extension first
 sql/tiger_geocoder_upgrade_minor.sql:  sql/tiger_geocoder_minor.sql.in | sql
-	sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' \
+	$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
+else
+sql/tiger_geocoder_upgrade_minor.sql:  sql/tiger_geocoder_minor.sql.in | sql
+	$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g ; s/\@extschema:[^@]+\@\.//g' $< > $@
+endif
 #only extension files
 EXTRA_CLEAN += $(wildcard expected/*--*.out)
diff --git a/extensions/postgis_tiger_geocoder/sql_bits/remove_from_extension.sql.in b/extensions/postgis_tiger_geocoder/sql_bits/remove_from_extension.sql.in
deleted file mode 100644
index c0fc12a3e..000000000
--- a/extensions/postgis_tiger_geocoder/sql_bits/remove_from_extension.sql.in
+++ /dev/null
@@ -1,19 +0,0 @@
--- PostGIS - Spatial Types for PostgreSQL
--- http://postgis.net
--- Copyright (C) 2011 Regina Obe <lr at pcorp.us>
--- This is free software; you can redistribute and/or modify it under
--- the terms of the GNU General Public Licence. See the COPYING file.
--- Author: Regina Obe <lr at pcorp.us>
--- This drops extension helper functions
--- and should be called at the end of the extension upgrade file
--- removes all postgis_topology functions from postgis_topology extension since they will be read
--- during upgrade
-SELECT postgis_extension_remove_objects('postgis_tiger_geocoder', 'FUNCTION');
-SELECT postgis_extension_remove_objects('postgis_tiger_geocoder', 'AGGREGATE');
diff --git a/extensions/postgis_topology/Makefile.in b/extensions/postgis_topology/Makefile.in
index ef3f6034c..0bc04fc56 100644
--- a/extensions/postgis_topology/Makefile.in
+++ b/extensions/postgis_topology/Makefile.in
@@ -42,7 +42,6 @@ DATA_built = \
 EXTENSION_UPGRADE_SCRIPTS = \
 	extlock.sql \
 	../postgis_extension_helper.sql \
-	sql_bits/remove_from_extension.sql.in \
 	sql/topology_upgrade.sql \
 	sql_bits/mark_editable_objects.sql.in \
diff --git a/extensions/postgis_topology/sql_bits/remove_from_extension.sql.in b/extensions/postgis_topology/sql_bits/remove_from_extension.sql.in
index cc4cca819..000000000
--- a/extensions/postgis_topology/sql_bits/remove_from_extension.sql.in
+++ /dev/null
@@ -1,19 +0,0 @@
--- during upgrade
-SELECT postgis_extension_remove_objects('postgis_topology', 'FUNCTION');
-SELECT postgis_extension_remove_objects('postgis_topology', 'AGGREGATE');
Summary of changes:
 .cirrus.yml                                        |  8 +--
 NEWS                                               |  8 ++-
 README.postgis                                     |  4 +-
 Version.config                                     |  2 +-
 doc/release_notes.xml                              | 21 +++++++
 extensions/postgis_extension_helper.sql.in         | 67 ----------------------
 extensions/postgis_extension_helper_uninstall.sql  |  1 -
 extensions/postgis_tiger_geocoder/Makefile.in      | 39 ++++++++-----
 .../sql_bits/remove_from_extension.sql.in          | 19 ------
 extensions/postgis_topology/Makefile.in            |  1 -
 extensions/upgradeable_versions.mk                 |  6 ++
 12 files changed, 65 insertions(+), 130 deletions(-)
 delete mode 100644 extensions/postgis_tiger_geocoder/sql_bits/remove_from_extension.sql.in
 delete mode 100644 extensions/postgis_topology/sql_bits/remove_from_extension.sql.in
hooks/post-receive
